Unable to run deepstream_test_1_usb.py
**• Hardware Platform (igx aarch64)
**• DeepStream Version 6.4
**• Issue Type question
Trying to run the python scripts in
I followed deepstream_python_apps/bindings/README.md at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
then
cd deepstream_python_apps/apps/deepstream-test1-usbcam
python3 deepstream_test_1_usb.py /dev/video1
got:
Creating Pipeline
Creating Source
Creating Video Converter
 Unable to create NvStreamMux
 Unable to create pgie
 Unable to create nvosd
Creating nv3dsink
 Unable to create nv3dsink
Playing cam /dev/video0
  File "/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1-usbcam/deepstream_test_1_usb.py", line 280, in <module>
    sys.exit(main(sys.argv))
  File "/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1-usbcam/deepstream_test_1_usb.py", line 213, in main
    streammux.set_property('width', 1920)
AttributeError: 'NoneType' object has no attribute 'set_property'
Have you installed DeepStream SDK? python binding is only wrap the native sdk, you need to install Deepstream SDK first
Is this a GPU or a jetson? It is recommended that you use docker
Using docker, installed DeepStream 6.4 , its a dGPU
Does the following command have any results?
gst-inspect-1.0 nvstreammux
Which docker do you use and what is your command to start docker?
try the following script .
/opt/nvidia/deepstream/deepstream/install.sh
Docker image I am using 6.4-samples-multiarch
inspect returns : No such element or plugin 'nvstreammux'
also tried install.sh nothing changed
Please use the docker image below. The 6.4-samples-multiarch can only be used for display and does not include related header files.
deepstream:6.4-triton-multiarch
same problem while running this, also running command is:
docker run -it --rm --net=host --runtime nvidia --device=/dev/video0  -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.4 -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream:6.4-triton-multiarch
still No such element or plugin 'nvstreammux'
also tried C app samples in
/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/
which almost same thing is missing. This line is triggered :
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
streammux issue again
If your device is a dGPU, the correct command should be the following.
There are some subtle differences between dGPU and Jetson,This will affect the operation of deepstream
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.4 deepstream:6.4-triton-multiarch
