We are trying to run example application given in deepstream SDK 5.1. I have cloned the example python application from: NVIDIA-AI-IOT/deepstream_python_apps
Here is my environment setup:
- Ubuntu: 18.04
- Python: python3
- Gstreamer: 1.14.5
- L4T: 32.6.1
- Deepstrem SDK: 5.1
- TensorRT: 8.0
- CUDA: 10.2.300
- CUDNN: 8.2.1
Tried to run deepstream application test 1 by following command and getting the error as below:
$ python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
(gst-plugin-scanner:12189): GStreamer-WARNING **: 09:43:52.971: Failed to load plugin '/usr/lib/aarch64-linux-
gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libnvinfer.so.7: cannot open shared object file: No such file or
directory
(gst-plugin-scanner:12189): GStreamer-WARNING **: 09:43:53.548: Failed to load plugin '/usr/lib/aarch64-linux-
gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libnvinfer.so.7: cannot open shared object file: No such file
or directory
(gst-plugin-scanner:12189): GStreamer-WARNING **: 09:43:53.665: Failed to load plugin '/usr/lib/aarch64-linux-
gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libnvparsers.so.7: cannot open shared object file: No such file or
directory
(gst-plugin-scanner:12189): GStreamer-WARNING **: 09:43:53.785: Failed to load plugin '/usr/lib/aarch64-linux-
gnu/gstreamer-1.0/deepstream/libnvdsgst_inferaudio.so': libnvparsers.so.7: cannot open shared object file: No such file
or directory
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Unable to create pgie
Unable to create nvosd
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
File "deepstream_test_1.py", line 266, in <module>
sys.exit(main(sys.argv))
File "deepstream_test_1.py", line 203, in main
pgie.set_property('config-file-path', "dstest1_pgie_config.txt")
AttributeError: 'NoneType' object has no attribute 'set_property'
As I can see from the log it is not able to create GPU inference engine and OSD.
Please help to resolve this issue.
Thanks and Regards
Vikas Dwivedi
