No such element or plugin 'nvstreammux' on deepstream:5.1-21.02-devel docker
• Hardware Platform GPU
• DeepStream Version 5.1-21.02-devel
• TensorRT Version 7.2.2-1+cuda11.1
• NVIDIA GPU Driver Version 450.102.04
• Issue Type( questions, bugs)
• How to reproduce the issue ?
docker pull nvcr.io/nvidia/deepstream:5.1-21.02-devel
• Requirement details
Hello, I pull docker nvcr.io/nvidia/deepstream:5.1-21.02-devel and create container base on that image. Then check nvstreammux and nvstreamdemux not exist in gst-inspect
The first time:
gst-inspect-1.0 nvstreammux
nvbufsurftransform:cuInit failed : 804
(gst-plugin-scanner:34): GStreamer-WARNING **: 14:56:15.979: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:35): GStreamer-WARNING **: 14:56:15.999: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
The rest time:
Seems GPU driver version is not correct. Quickstart Guide — DeepStream 6.1.1 Release documentation
