DS3.0 deepstream_test4_app.cpp
I almost couldn’t wait to experience DS3.0,
so I download the DS3.0 at the first time,
and install it as the reference of started guide,
it seems deepstream-test4-app is a new good job,
so I have tried it,
./deepstream-test4-app ../../../../samples/streams/sample_720p.h264
but an error occurs
Now playing: …/…/…/…/samples/streams/sample_720p.h264
Running…
ERROR from element nvmsg-broker: Could not configure supporting library.
Error details: gstnvmsgbroker.c(325): gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
unable to connect to broker library
Returned, stopping playback
Deleting pipeline
it seemms have something to do with “librdkafka”,
the install guide says:
cd librdkafka
git reset --hard 7101c2310341ab3f4675fc565f64f0967e135a6a
./configure
make
sudo make install
sudo mkdir -p /usr/local/deepstream
sudo cp /usr/local/lib/librdkafka* /usr/local/deepstream
I have do it , the problem still occurs.
Any message is appreciated!:)
HI,
Have you resolve this issue, if no, can you do
rm rm ~/.cache/gstreamer-1.0/ -rf
and then try again the app?
@amycao,
yeah I have tried the command,
rm -rf ~/.cache/gstreamer-1.0
the error still appears,
and command
gst-inspect-1.0 nvmsgbroker
could print the information of nvmsgbroker.
Use of test4-app is to demonstrate message sending to cloud, So user has to first setup the server to receive the messages and then use the endpoint of that server to send the messages, please see README within the app, you need to modify the macro #define CONNECTION_STRING “foo.bar.com;80;dsapp1”,
Can you follow the Documentation https://developer.nvidia.com/compute/machine-learning/deepstream-documentation
SWE-SWDOCDPSTR-001-APNT.pdf 2.2 DEPLOYING THE ANALYTICS SERVER?
Server repo: deepstream_360_d_smart_parking_application/analytics_server_docker at master · NVIDIA-AI-IOT/deepstream_360_d_smart_parking_application · GitHub
We will add this to the readme of test4-app.
I have the exact same problem. I ran this test application on deepstream4.0 with jetson platform. I changed the c variable as following:
#define PROTOCOL_ADAPTOR_LIB "/usr/lib/aarch64-linux-gnu/tegra/libnvds_kafka_proto.so"
#define CONNECTION_STRING "<my ip address>;9092;metromind-start"
#define CONFIG_FILE_PATH ""
I am trying to send message through kafak broker. Is there anything that I have missed?
Do you have analytic server running, you also need have it running for reiceiving message from deepstream-test4,
Yes, I did. I set up the kafka module in analytic server. The kafka docker container works fine.
the docker you used is for x86 desktop.
Yes, I have a pc which is x86 desktop as analytics server, and a jetson board as a perception server. I set up the kafka module on analytic server, and run deepstream-test4 on jetson. I think it must be a setting issue on the test 4 application before the video file was sent. Because if I specify a file that doesn’t exist, I would still get the same error
ERROR from element nvmsg-broker: GStreamer encountered a general resource error.
Error details: gstnvmsgbroker.c(290): gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
Invalid connection string format
Deleting pipeline
Did you make it work in the end? Would you mind sharing what was the problem?
I ever setup both analytic and perception on x86 desktop, never tried analytic server on x86 desktop, perception server on Jetson xavier, will try to see if it works for this case.
Thank you for your help! Please let me know if there is any special setting needed besides the one in README file.
please add GST_DEBUG=4 “app command” > log 2>&1, and paste the full log.
[code]
0:00:00.000108607 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_INIT gst.c:586:init_pre:e[00m Initializing GStreamer Core Library version 1.14.4
0:00:00.000219743 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_INIT gst.c:587:init_pre:e[00m Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000252767 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_INIT gst.c:607:init_pre:e[00m Linux Nvidia 4.9.140-tegra #1 SMP PREEMPT Thu May 16 09:40:33 PDT 2019 aarch64
0:00:00.000636767 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_INIT gstmessage.c:127:_priv_gst_message_initialize:e[00m init messages
0:00:00.001469277 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_INIT gstcontext.c:84:_priv_gst_context_initialize:e[00m init contexts
0:00:00.001755453 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize:e[00m registering 0 static plugins
0:00:00.001920317 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static:e[00m registered static plugin “staticelements”
0:00:00.001947645 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static:e[00m added static plugin “staticelements”, result: 1
0:00:00.001986237 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m GST_REGISTRY gstregistry.c:1727:ensure_current_registry:e[00m reading registry cache: /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.034889741 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache:e[00m loaded /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin in 0.032843 seconds
0:00:00.035025997 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m GST_REGISTRY gstregistry.c:1583:scan_and_update_registry:e[00m Validating plugins from registry cache: /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.039410215 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m GST_REGISTRY gstregistry.c:1685:scan_and_update_registry:e[00m Registry cache has not changed
0:00:00.039458631 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m GST_REGISTRY gstregistry.c:1762:ensure_current_registry:e[00m registry reading and updating done, result = 1
0:00:00.039480295 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_INIT gst.c:807:init_post:e[00m GLib runtime version: 2.56.4
0:00:00.039501383 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_INIT gst.c:809:init_post:e[00m GLib headers version: 2.56.4
0:00:00.039516519 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_INIT gst.c:810:init_post:e[00m initialized GStreamer successfully
0:00:00.039611942 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “pipeline” named “dstest4-pipeline”
0:00:00.041043108 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.041088004 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “filesrc” named “file-source”
0:00:00.041280932 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0x556b13c220e[00m adding pad ‘src’
0:00:00.043878048 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so” loaded
0:00:00.043934496 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “h264parse” named “h264-parser”
0:00:00.044120096 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0x556b143460e[00m adding pad ‘sink’
0:00:00.044162880 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0x556b143460e[00m adding pad ‘src’
0:00:00.044224448 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m baseparse gstbaseparse.c:3961:gst_base_parse_set_pts_interpolation:GstH264Parse@0x556b143460e[00m PTS interpolation: no
0:00:00.079698861 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so” loaded
0:00:00.079770029 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nvv4l2decoder” named “nvv4l2-decoder”
0:00:00.080039084 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0x556b198d90e[00m adding pad ‘sink’
0:00:00.080087628 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0x556b198d90e[00m adding pad ‘src’
0:00:00.090453725 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvdsgst_multistream.so” loaded
0:00:00.090518301 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nvstreammux” named “nvstreammux”
0:00:00.090800733 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstNvStreamMux@0x556b1f6020e[00m adding pad ‘src’
0:00:00.131965601 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvdsgst_infer.so” loaded
0:00:00.132052321 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nvinfer” named “primary-nvinference-engine”
0:00:00.132321729 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b4cc7c0e[00m adding pad ‘sink’
0:00:00.132381121 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b4cc7c0e[00m adding pad ‘src’
0:00:00.133612031 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideoconvert.so” loaded
0:00:00.133663359 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nvvideoconvert” named “nvvideo-converter”
(deepstream-test4-app:7702): GLib-GObject-WARNING **: 09:07:53.837: cannot register existing type ‘GstNvBufMemoryType’
(deepstream-test4-app:7702): GLib-CRITICAL **: 09:07:53.837: g_once_init_leave: assertion ‘result != 0’ failed
(deepstream-test4-app:7702): GLib-GObject-CRITICAL **: 09:07:53.837: g_param_spec_enum: assertion ‘G_TYPE_IS_ENUM (enum_type)’ failed
(deepstream-test4-app:7702): GLib-GObject-CRITICAL **: 09:07:53.837: validate_pspec_to_install: assertion ‘G_IS_PARAM_SPEC (pspec)’ failed
0:00:00.134156318 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b4d50d0e[00m adding pad ‘sink’
0:00:00.134221790 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b4d50d0e[00m adding pad ‘src’
0:00:00.141572212 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvdsgst_osd.so” loaded
0:00:00.141636692 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nvdsosd” named “nv-onscreendisplay”
0:00:00.141858643 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b4ed650e[00m adding pad ‘sink’
0:00:00.141914387 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b4ed650e[00m adding pad ‘src’
0:00:00.145719630 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvdsgst_msgconv.so” loaded
0:00:00.145783214 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nvmsgconv” named “nvmsg-converter”
0:00:00.145954925 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b548150e[00m adding pad ‘sink’
0:00:00.146003629 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b548150e[00m adding pad ‘src’
0:00:00.146454637 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvdsgst_msgbroker.so” loaded
0:00:00.146496365 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nvmsgbroker” named “nvmsg-broker”
0:00:00.146653612 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x556b547c70e[00m adding pad ‘sink’
0:00:00.146694604 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “tee” named “nvsink-tee”
0:00:00.146807820 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x556b54d000e[00m adding pad ‘sink’
0:00:00.146851852 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “queue” named “nvtee-que1”
0:00:00.147040268 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x556b5521c0e[00m adding pad ‘sink’
0:00:00.147089996 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x556b5521c0e[00m adding pad ‘src’
0:00:00.147127084 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “queue” named “nvtee-que2”
0:00:00.147170732 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x556b5524c0e[00m adding pad ‘sink’
0:00:00.147211851 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x556b5524c0e[00m adding pad ‘src’
0:00:00.148647817 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so” loaded
0:00:00.148708233 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nveglglessink” named “nvvideo-renderer”
0:00:00.148947241 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x556b55bd50e[00m adding pad ‘sink’
0:00:00.149620680 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;36m GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry:e[00m plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so” loaded
0:00:00.149661544 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create:e[00m creating element “nvegltransform” named “nvegl-transform”
0:00:00.149813096 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b55e0f0e[00m adding pad ‘sink’
0:00:00.149855048 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x556b55e0f0e[00m adding pad ‘src’
0:00:00.149946952 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m filesrc gstfilesrc.c:261:gst_file_src_set_location:e[00m filename : …/…/…/…/samples/streams/sample_720p.h264
0:00:00.149969352 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m filesrc gstfilesrc.c:262:gst_file_src_set_location:e[00m uri : file:///home/nvidia/deepstream_sdk_on_jetson/samples/streams/sample_720p.h264
Unknown key ‘parse-func’ for group [property]
0:00:00.151200422 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad:e[00m no such pad ‘sink_0’ in element “nvstreammux”
0:00:00.151295878 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:e[00m adding pad ‘sink_0’
0:00:00.151325158 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad:e[00m found pad nvv4l2-decoder:src
0:00:00.151361542 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvv4l2-decoder:src and nvstreammux:sink_0
0:00:00.151404453 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvstreammux:srce[00m pad has no peer
0:00:00.151541765 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvv4l2-decoder:src and nvstreammux:sink_0, successful
0:00:00.151577349 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.151598149 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvv4l2-decoder:srce[00m Received event on flushing pad. Discarding
0:00:00.151647045 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element file-source:(any) to element h264-parser:(any)
0:00:00.151678181 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link file-source:src and h264-parser:sink
0:00:00.151712581 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:h264-parser:srce[00m pad has no peer
0:00:00.151768133 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m file-source and h264-parser in same bin, no need for ghost pads
0:00:00.151799621 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link file-source:src and h264-parser:sink
0:00:00.151827525 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:h264-parser:srce[00m pad has no peer
0:00:00.151857157 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked file-source:src and h264-parser:sink, successful
0:00:00.151875365 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.151893605 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:file-source:srce[00m Received event on flushing pad. Discarding
0:00:00.151925221 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element h264-parser:(any) to element nvv4l2-decoder:(any)
0:00:00.151950821 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link h264-parser:src and nvv4l2-decoder:sink
0:00:00.151984293 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvstreammux:srce[00m pad has no peer
0:00:00.152148324 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m h264-parser and nvv4l2-decoder in same bin, no need for ghost pads
0:00:00.152182948 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link h264-parser:src and nvv4l2-decoder:sink
0:00:00.152214948 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvstreammux:srce[00m pad has no peer
0:00:00.152349892 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked h264-parser:src and nvv4l2-decoder:sink, successful
0:00:00.152371108 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.152390884 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:h264-parser:srce[00m Received event on flushing pad. Discarding
0:00:00.152421956 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element nvstreammux:(any) to element primary-nvinference-engine:(any)
0:00:00.152448388 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link nvstreammux:src and primary-nvinference-engine:sink
0:00:00.152478308 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:primary-nvinference-engine:srce[00m pad has no peer
0:00:00.152529508 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m nvstreammux and primary-nvinference-engine in same bin, no need for ghost pads
0:00:00.152559780 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvstreammux:src and primary-nvinference-engine:sink
0:00:00.152600836 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:primary-nvinference-engine:srce[00m pad has no peer
0:00:00.152644932 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvstreammux:src and primary-nvinference-engine:sink, successful
0:00:00.152663748 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.152681444 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvstreammux:srce[00m Received event on flushing pad. Discarding
0:00:00.152711940 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element primary-nvinference-engine:(any) to element nvvideo-converter:(any)
0:00:00.152740068 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link primary-nvinference-engine:src and nvvideo-converter:sink
0:00:00.152804675 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvvideo-converter:srce[00m pad has no peer
0:00:00.152912035 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m primary-nvinference-engine and nvvideo-converter in same bin, no need for ghost pads
0:00:00.152947491 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link primary-nvinference-engine:src and nvvideo-converter:sink
0:00:00.153002435 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvvideo-converter:srce[00m pad has no peer
0:00:00.153083619 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked primary-nvinference-engine:src and nvvideo-converter:sink, successful
0:00:00.153102083 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.153119555 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:primary-nvinference-engine:srce[00m Received event on flushing pad. Discarding
0:00:00.153148099 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element nvvideo-converter:(any) to element nv-onscreendisplay:(any)
0:00:00.153173283 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link nvvideo-converter:src and nv-onscreendisplay:sink
0:00:00.153269635 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nv-onscreendisplay:srce[00m pad has no peer
0:00:00.153313635 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m nvvideo-converter and nv-onscreendisplay in same bin, no need for ghost pads
0:00:00.153341539 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvvideo-converter:src and nv-onscreendisplay:sink
0:00:00.153434339 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nv-onscreendisplay:srce[00m pad has no peer
0:00:00.153476162 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvvideo-converter:src and nv-onscreendisplay:sink, successful
0:00:00.153508514 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.153527042 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvvideo-converter:srce[00m Received event on flushing pad. Discarding
0:00:00.153554370 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element nv-onscreendisplay:(any) to element nvsink-tee:(any)
0:00:00.153578722 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link nv-onscreendisplay:src and nvsink-tee:sink
0:00:00.153707522 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m nv-onscreendisplay and nvsink-tee in same bin, no need for ghost pads
0:00:00.153736546 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nv-onscreendisplay:src and nvsink-tee:sink
0:00:00.153861954 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nv-onscreendisplay:src and nvsink-tee:sink, successful
0:00:00.153880610 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.153898594 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nv-onscreendisplay:srce[00m Received event on flushing pad. Discarding
0:00:00.153927170 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element nvtee-que1:(any) to element nvmsg-converter:(any)
0:00:00.153951618 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link nvtee-que1:src and nvmsg-converter:sink
0:00:00.153979746 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvtee-que1:sinke[00m pad has no peer
0:00:00.154010594 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvmsg-converter:srce[00m pad has no peer
0:00:00.154037314 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m nvtee-que1 and nvmsg-converter in same bin, no need for ghost pads
0:00:00.154066978 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvtee-que1:src and nvmsg-converter:sink
0:00:00.154094562 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvtee-que1:sinke[00m pad has no peer
0:00:00.154122050 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvmsg-converter:srce[00m pad has no peer
0:00:00.154149505 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvtee-que1:src and nvmsg-converter:sink, successful
0:00:00.154167201 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.154186081 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvtee-que1:srce[00m Received event on flushing pad. Discarding
0:00:00.154231649 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element nvmsg-converter:(any) to element nvmsg-broker:(any)
0:00:00.154258337 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link nvmsg-converter:src and nvmsg-broker:sink
0:00:00.154286817 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvtee-que1:sinke[00m pad has no peer
0:00:00.154320865 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m nvmsg-converter and nvmsg-broker in same bin, no need for ghost pads
0:00:00.154351969 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvmsg-converter:src and nvmsg-broker:sink
0:00:00.154380865 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvtee-que1:sinke[00m pad has no peer
0:00:00.154414721 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvmsg-converter:src and nvmsg-broker:sink, successful
0:00:00.154433409 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.154451777 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvmsg-converter:srce[00m Received event on flushing pad. Discarding
0:00:00.154483457 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element nvtee-que2:(any) to element nvegl-transform:(any)
0:00:00.154510689 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link nvtee-que2:src and nvegl-transform:sink
0:00:00.154536673 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvtee-que2:sinke[00m pad has no peer
0:00:00.154565857 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvegl-transform:srce[00m pad has no peer
0:00:00.154637217 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m nvtee-que2 and nvegl-transform in same bin, no need for ghost pads
0:00:00.154677185 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvtee-que2:src and nvegl-transform:sink
0:00:00.154707137 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvtee-que2:sinke[00m pad has no peer
0:00:00.154735649 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvegl-transform:srce[00m pad has no peer
0:00:00.154932928 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvtee-que2:src and nvegl-transform:sink, successful
0:00:00.154965184 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.154984608 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvtee-que2:srce[00m Received event on flushing pad. Discarding
0:00:00.155084320 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full:e[00m trying to link element nvegl-transform:(any) to element nvvideo-renderer:(any)
0:00:00.155199712 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1035:gst_pad_check_link:e[00m trying to link nvegl-transform:src and nvvideo-renderer:sink
0:00:00.155234912 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvtee-que2:sinke[00m pad has no peer
0:00:00.155336288 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting:e[00m nvegl-transform and nvvideo-renderer in same bin, no need for ghost pads
0:00:00.155375360 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvegl-transform:src and nvvideo-renderer:sink
0:00:00.155405440 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:4232:gst_pad_peer_query:nvtee-que2:sinke[00m pad has no peer
0:00:00.155490432 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvegl-transform:src and nvvideo-renderer:sink, successful
0:00:00.155512640 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.155562943 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvegl-transform:srce[00m Received event on flushing pad. Discarding
0:00:00.155600255 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad:e[00m found pad nvtee-que1:sink
0:00:00.155706207 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:e[00m adding pad ‘src_0’
0:00:00.155759999 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:e[00m adding pad ‘src_1’
0:00:00.155800159 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvsink-tee:src_0 and nvtee-que1:sink
0:00:00.155998815 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvsink-tee:src_0 and nvtee-que1:sink, successful
0:00:00.156030623 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.156052479 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvsink-tee:src_0e[00m Received event on flushing pad. Discarding
0:00:00.156084895 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad:e[00m found pad nvtee-que2:sink
0:00:00.156114079 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2378:gst_pad_link_prepare:e[00m trying to link nvsink-tee:src_1 and nvtee-que2:sink
0:00:00.156333598 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;41m GST_PADS gstpad.c:2586:gst_pad_link_full:e[00m linked nvsink-tee:src_1 and nvtee-que2:sink, successful
0:00:00.156359646 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstevent.c:1517:gst_event_new_reconfigure:e[00m creating reconfigure event
0:00:00.156379902 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;34m GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvsink-tee:src_1e[00m Received event on flushing pad. Discarding
0:00:00.156412606 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad:e[00m found pad nv-onscreendisplay:sink
file is here tada!Now playing: …/…/…/…/samples/streams/sample_720p.h264
0:00:00.156613598 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next READY
Using winsys: x11
0:00:00.156798334 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00m egladaption gstegladaptation_egl.c:186:gst_egl_adaptation_init_display:e[00m System reports supported EGL version v1.5
0:00:00.157073213 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to READY
0:00:00.157105693 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:e[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.157142205 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvvideo-renderer’ changed state to 2(READY) successfully
0:00:00.157174429 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.157566397 e[335m 7702e[00m 0x556aef1800 e[33;01mWARN e[00m e[00m nvmsgbroker gstnvmsgbroker.c:297:gst_nvmsgbroker_start:e[00m error: unable to open shared library
0:00:00.157621692 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;47m GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details:e[00m posting message: Could not initialize supporting library.
0:00:00.157671292 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;47m GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details:e[00m posted error message: Could not initialize supporting library.
0:00:00.157695836 e[335m 7702e[00m 0x556aef1800 e[33;01mWARN e[00m e[00m basesink gstbasesink.c:5265:gst_base_sink_change_state:e[00m error: Failed to start
0:00:00.157722172 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;47m GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details:e[00m posting message: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
0:00:00.157748956 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;47m GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details:e[00m posted error message: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
0:00:00.157767452 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2961:gst_element_change_state:e[00m have FAILURE change_state return
0:00:00.157786172 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2549:gst_element_abort_state:e[00m aborting state from NULL to READY
0:00:00.157807740 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2970:gst_bin_change_state_func:e[00m child ‘nvmsg-broker’ failed to go to state 2(READY)
0:00:00.157916796 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.157941404 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:e[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.157971004 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158013628 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158039100 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158063708 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158087772 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158112252 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158135932 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158161980 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158186364 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158698555 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158744059 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158772347 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158796443 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
0:00:00.158826075 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2961:gst_element_change_state:e[00m have FAILURE change_state return
Running…
ERROR from element nvmsg-broker: Could not initialize supporting library.
Error details: gstnvmsgbroker.c(297): gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
0:00:00.158978907 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘src_0’
0:00:00.159003546 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink:e[00m unlinking nvsink-tee:src_0(0x556b572040) and nvtee-que1:sink(0x556b54a760)
0:00:00.159034618 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink:e[00m unlinked nvsink-tee:src_0 and nvtee-que1:sink
0:00:00.159068858 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘src_1’
0:00:00.159092122 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink:e[00m unlinking nvsink-tee:src_1(0x556b5722a0) and nvtee-que2:sink(0x556b54ac00)
0:00:00.159117114 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink:e[00m unlinked nvsink-tee:src_1 and nvtee-que2:sink
0:00:00.159189338 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159232634 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159253402 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvvideo-renderer’ changed state to 1(NULL) successfully
0:00:00.159276986 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159295674 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159314682 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvmsg-broker’ changed state to 1(NULL) successfully
0:00:00.159336794 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159355194 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159373914 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvegl-transform’ changed state to 1(NULL) successfully
0:00:00.159395994 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159414330 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159432890 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvmsg-converter’ changed state to 1(NULL) successfully
0:00:00.159454010 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159472282 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159492346 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvtee-que2’ changed state to 1(NULL) successfully
0:00:00.159514842 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159597786 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159619834 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvtee-que1’ changed state to 1(NULL) successfully
0:00:00.159647386 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159666170 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159703545 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvsink-tee’ changed state to 1(NULL) successfully
0:00:00.159727417 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159746809 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159765785 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nv-onscreendisplay’ changed state to 1(NULL) successfully
0:00:00.159788409 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159806745 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159825337 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvvideo-converter’ changed state to 1(NULL) successfully
0:00:00.159847609 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159865753 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159884601 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘primary-nvinference-engine’ changed state to 1(NULL) successfully
0:00:00.159907033 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159925177 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.159943929 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvstreammux’ changed state to 1(NULL) successfully
0:00:00.159966041 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.159984217 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.160002969 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘nvv4l2-decoder’ changed state to 1(NULL) successfully
0:00:00.160025209 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.160043449 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.160062265 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘h264-parser’ changed state to 1(NULL) successfully
0:00:00.160161753 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2506:gst_bin_element_set_state:e[00m current NULL pending VOID_PENDING, desired next NULL
0:00:00.160201721 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2623:gst_bin_element_set_state:e[00m skipping transition from NULL to NULL
0:00:00.160221433 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstbin.c:2954:gst_bin_change_state_func:e[00m child ‘file-source’ changed state to 1(NULL) successfully
0:00:00.160245337 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31m GST_STATES gstelement.c:2676:gst_element_continue_state:e[00m completed state change to NULL
Deleting pipeline
0:00:00.160302745 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink:e[00m unlinking nvtee-que2:src(0x556b54ae50) and nvegl-transform:sink(0x556b54b2f0)
0:00:00.160333273 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink:e[00m unlinked nvtee-que2:src and nvegl-transform:sink
0:00:00.160364537 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink:e[00m unlinking nvegl-transform:src(0x556b54b540) and nvvideo-renderer:sink(0x556b54b0a0)
0:00:00.160390392 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink:e[00m unlinked nvegl-transform:src and nvvideo-renderer:sink
0:00:00.160414296 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:e[00m removed child “nvegl-transform”
0:00:00.160449752 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:e[00m 0x556b55e0f0 dispose
0:00:00.160470520 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘sink’
0:00:00.160495480 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘src’
0:00:00.160519640 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:e[00m 0x556b55e0f0 parent class dispose
0:00:00.160540120 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:e[00m 0x556b55e0f0 finalize
0:00:00.160558648 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:e[00m 0x556b55e0f0 finalize parent
0:00:00.160583000 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:e[00m removed child “nvvideo-renderer”
0:00:00.160615288 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink:e[00m unlinking nvmsg-converter:src(0x556b54a070) and nvmsg-broker:sink(0x556b54a2c0)
0:00:00.160642648 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink:e[00m unlinked nvmsg-converter:src and nvmsg-broker:sink
0:00:00.160668984 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:e[00m removed child “nvmsg-broker”
0:00:00.160699928 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink:e[00m unlinking nvtee-que1:src(0x556b54a9b0) and nvmsg-converter:sink(0x556b13fd40)
0:00:00.160739096 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink:e[00m unlinked nvtee-que1:src and nvmsg-converter:sink
0:00:00.160766136 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:e[00m removed child “nvmsg-converter”
0:00:00.160791896 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:e[00m 0x556b548150 dispose
0:00:00.160810808 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘sink’
0:00:00.160834584 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘src’
0:00:00.160858392 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:e[00m 0x556b548150 parent class dispose
0:00:00.160879768 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:e[00m 0x556b548150 finalize
0:00:00.160898904 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:e[00m 0x556b548150 finalize parent
0:00:00.160922328 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:e[00m removed child “nvtee-que2”
0:00:00.160947864 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:e[00m 0x556b5524c0 dispose
0:00:00.160966424 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘sink’
0:00:00.160990744 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘src’
0:00:00.161015128 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:e[00m 0x556b5524c0 parent class dispose
0:00:00.161037240 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:e[00m 0x556b5524c0 finalize
0:00:00.161055992 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:e[00m 0x556b5524c0 finalize parent
0:00:00.161079192 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:e[00m removed child “nvtee-que1”
0:00:00.161104663 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:e[00m 0x556b5521c0 dispose
0:00:00.161123223 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘sink’
0:00:00.161146775 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘src’
0:00:00.161171191 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:e[00m 0x556b5521c0 parent class dispose
0:00:00.161191703 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:e[00m 0x556b5521c0 finalize
0:00:00.161209815 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:e[00m 0x556b5521c0 finalize parent
0:00:00.161245911 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink:e[00m unlinking nv-onscreendisplay:src(0x556b13faf0) and nvsink-tee:sink(0x556b54a510)
0:00:00.161272215 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink:e[00m unlinked nv-onscreendisplay:src and nvsink-tee:sink
0:00:00.161298135 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:e[00m removed child “nvsink-tee”
0:00:00.161323991 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:e[00m 0x556b54d000 dispose
0:00:00.161342935 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:e[00m removing pad ‘sink’
0:00:00.161367447 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:e[00m 0x556b54d000 parent class dispose
0:00:00.161388311 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:e[00m 0x556b54d000 finalize
0:00:00.161406263 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:e[00m 0x556b54d000 finalize parent
0:00:00.161431575 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink:e[00m unlinking nvvideo-converter:src(0x556b13f650) and nv-onscreendisplay:sink(0x556b13f8a0)
0:00:00.161457559 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink:e[00m unlinked nvvideo-converter:src and nv-onscreendisplay:sink
0:00:00.161484407 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;37;41m GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:e[00m removed child “nv-onscreendisplay”
0:00:00.161509975 e[335m 7702e[00m 0x556aef1800 e[36mINFO e[00m e[00;01;31;44m GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:e[00m 0x556b4ed650 dispose
sorry for confuse,just use this command,it will ouput the log to file log,please paste the log here
Do you install kafka on Jetson device?
Yes, I did. with command:
apt-get install librdkafka1=0.11.3-1build1
And folder /usr/lib/aarch64-gnu/tegra/ can find the library “so” files.
ll /usr/lib/aarch64-linux-gnu/tegra/libnvds_kafka_proto.so
how about the return result,
please check macro PROTOCOL_ADAPTOR_LIB within the code, the path it pointed if exist.
