Error running deepsteram Test5 on deepstream 6.0
**• Hardware Platform (Jetson / GPU): Jetson Nano
**• DeepStream Version: 6.0
**• JetPack Version (valid for Jetson only): 4.6
I am trying to run the deepstream occupnacy analytics on DS 6.0 and I get this error:
(gst-plugin-scanner:14436): GStreamer-WARNING **: 12:55:59.645: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14436): GStreamer-WARNING **: 12:55:59.651: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14436): GStreamer-WARNING **: 12:55:59.843: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-plugin-scanner:14436): GStreamer-WARNING **: 12:55:59.938: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so’: /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(deepstream-test5-analytics:14435): GLib-CRITICAL **: 12:56:00.731: g_strchug: assertion ‘string != NULL’ failed
(deepstream-test5-analytics:14435): GLib-CRITICAL **: 12:56:00.731: g_strchomp: assertion ‘string != NULL’ failed
Warning: ‘input-dims’ parameter has been deprecated. Use ‘infer-dims’ instead.
** ERROR: main:1088: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink1: Could not configure supporting library.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.cpp(402): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstBin:sink_sub_bin1/GstNvMsgBroker:sink_sub_bin_sink1:
unable to connect to broker library
ERROR from sink_sub_bin_sink1: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:sink_sub_bin1/GstNvMsgBroker:sink_sub_bin_sink1:
Failed to start
App run failed
Below is the test5 running file:
test5_config_file_src_infer_tlt.txt (6.6 KB)
Please use “gst-inspect-1.0” command to check the DeepStream SDK status.
This is the result I get:
(gst-plugin-scanner:6534): GStreamer-WARNING **: 18:21:10.480: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_msgconv.so’: /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_msgconv.so: undefined symbol: nvds_msg2p_generate_multiple_new
(gst-plugin-scanner:6534): GStreamer-WARNING **: 18:21:12.073: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so’: /opt/nvidia/deepstream/deepstream-6.0/lib/gst-plugins/libnvdsgst_msgconv.so: undefined symbol: nvds_msg2p_generate_multiple_new
(gst-plugin-scanner:6534): GStreamer-WARNING **: 18:21:12.273: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:6534): GStreamer-WARNING **: 18:21:12.308: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:6534): GStreamer-WARNING **: 18:21:12.981: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-plugin-scanner:6534): GStreamer-WARNING **: 18:21:13.443: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so’: /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
amrwbdec: amrwbdec: AMR-WB audio decoder
pbtypes: GstVideoMultiviewFlagsSet (GstDynamicTypeFactory)
multifile: splitmuxsrc: Split File Demuxing Bin
multifile: splitmuxsink: Split Muxing Bin
multifile: splitfilesrc: Split-File Source
multifile: multifilesink: Multi-File Sink
multifile: multifilesrc: Multi-File Source
encoding: encodebin: Encoder Bin
flv: flvmux: FLV muxer
flv: flvdemux: FLV Demuxer
equalizer: equalizer-10bands: 10 Band Equalizer
equalizer: equalizer-3bands: 3 Band Equalizer
equalizer: equalizer-nbands: N Band Equalizer
adpcmenc: adpcmenc: ADPCM encoder
mpeg2dec: mpeg2dec: mpeg1 and mpeg2 video decoder
compositor: compositor: Compositor
videoframe_audiolevel: videoframe-audiolevel: Video-frame audio level
subenc: webvttenc: WebVTT encoder
subenc: srtenc: Srt encoder
nvdrmvideosink: nvdrmvideosink: Nvidia Drm Video Sink
dvbsuboverlay: dvbsuboverlay: DVB Subtitles Overlay
de265: libde265dec: HEVC/H.265 decoder
videotestsrc: videotestsrc: Video test source
cluttergst3: clutterautovideosink: Generic bin
fieldanalysis: fieldanalysis: Video field analysis
taglib: apev2mux: TagLib-based APEv2 Muxer
taglib: id3v2mux: TagLib-based ID3v2 Muxer
mpg123: mpg123audiodec: mpg123 mp3 decoder
rtsp: rtpdec: RTP Decoder
rtsp: rtspsrc: RTSP packet receiver
auparse: auparse: AU audio demuxer
omx: nvoverlaysink: OpenMax Video Sink
omx: omxvp9enc: OpenMAX VP9 Video Encoder
omx: omxvp8enc: OpenMAX VP8 Video Encoder
omx: omxh265enc: OpenMAX H.265 Video Encoder
omx: omxh264enc: OpenMAX H.264 Video Encoder
omx: omxwmvdec: OpenMAX WMV Video Decoder
omx: omxmpeg2videodec: OpenMAX MPEG2 Video Decoder
omx: omxvp9dec: OpenMAX VP9 Video Decoder
omx: omxvp8dec: OpenMAX VP8 Video Decoder
omx: omxh265dec: OpenMAX H.265 Video Decoder
omx: omxh264dec: OpenMAX H.264 Video Decoder
omx: omxmpeg4videodec: OpenMAX MPEG4 Video Decoder
nvcompositor: nvcompositor: NvCompositor
x265: x265enc: x265enc
audiofxbad: audiochannelmix: Simple stereo audio mixer
twolame: twolamemp2enc: TwoLAME mp2 encoder
shapewipe: shapewipe: Shape Wipe transition filter
mpegpsdemux: mpegpsdemux: MPEG Program Stream Demuxer
nvegltransform: nvegltransform: NvEGLTransform
accurip: accurip: AccurateRip™ CRC element
shm: shmsink: Shared Memory Sink
shm: shmsrc: Shared Memory Source
festival: festival: Festival Text-to-Speech synthesizer
resindvd: rsndvdbin: rsndvdbin
gdp: gdppay: GDP Payloader
gdp: gdpdepay: GDP Depayloader
level: level: Level
asf: rtpasfdepay: RTP ASF packet depayloader
asf: rtspwms: WMS RTSP Extension
asf: asfdemux: ASF Demuxer
multipart: multipartmux: Multipart muxer
multipart: multipartdemux: Multipart demuxer
tcp: multisocketsink: Multi socket sink
tcp: multifdsink: Multi filedescriptor sink
tcp: tcpserversrc: TCP server source
tcp: tcpserversink: TCP server sink
tcp: tcpclientsrc: TCP client source
tcp: tcpclientsink: TCP client sink
tcp: socketsrc: socket source
amrnb: amrnbenc: AMR-NB audio encoder
amrnb: amrnbdec: AMR-NB audio decoder
bluez: avdtpsrc: Bluetooth AVDTP Source
bluez: avdtpsink: Bluetooth AVDTP sink
bluez: a2dpsink: Bluetooth A2DP sink
nvtee: nvtee: NvTee
audiorate: audiorate: Audio rate adjuster
soundtouch: bpmdetect: BPM Detector
soundtouch: pitch: Pitch controller
gdkpixbuf: gdkpixbufsink: GdkPixbuf sink
gdkpixbuf: gdkpixbufoverlay: GdkPixbuf Overlay
gdkpixbuf: gdkpixbufdec: GdkPixbuf image decoder
goom: goom: GOOM: what a GOOM!
smooth: smooth: Smooth effect
webp: webpenc: WEBP image encoder
webp: webpdec: WebP image decoder
dvdread: dvdreadsrc: DVD Source
webrtcdsp: webrtcechoprobe: Accoustic Echo Canceller probe
webrtcdsp: webrtcdsp: Voice Processor (AGC, AEC, filters, etc.)
opusparse: opusparse: Opus audio parser
wavparse: wavparse: WAV audio demuxer
typefindfunctions: audio/audible: aa, aax
typefindfunctions: audio/x-xi: xi
typefindfunctions: video/x-pva: pva
typefindfunctions: application/x-ssa: ssa, ass
typefindfunctions: application/octet-stream: no extensions
typefindfunctions: image/x-degas: no extensions
typefindfunctions: image/x-icon: no extensions
typefindfunctions: application/x-yuv4mpeg: no extensions
typefindfunctions: image/vnd.wap.wbmp: no extensions
typefindfunctions: image/vnd.adobe.photoshop: psd
typefindfunctions: application/msword: doc
typefindfunctions: application/pdf: pdf
typefindfunctions: audio/x-kss: kss
typefindfunctions: video/x-ivf: ivf
typefindfunctions: audio/x-sap: sap
typefindfunctions: audio/x-vgm: vgm
typefindfunctions: audio/x-gbs: gbs
typefindfunctions: audio/x-ay: ay
typefindfunctions: audio/x-gym: gym
typefindfunctions: audio/x-nsf: nsf
typefindfunctions: video/vivo: viv
typefindfunctions: application/x-mmsh: no extensions
typefindfunctions: multipart/x-mixed-replace: no extensions
typefindfunctions: video/x-dirac: no extensions
typefindfunctions: application/x-ms-dos-executable: dll, exe, ocx, sys, scr, msstyles, cpl
typefindfunctions: application/x-ar: a
typefindfunctions: application/x-tar: tar
typefindfunctions: application/x-rar: rar
typefindfunctions: image/svg+xml: svg
typefindfunctions: application/postscript: ps
typefindfunctions: audio/x-caf: caf
typefindfunctions: audio/x-wavpack-correction: wvc
typefindfunctions: audio/x-wavpack: wv, wvp
typefindfunctions: audio/x-spc: spc
typefindfunctions: audio/aac: aac, adts, adif, loas
typefindfunctions: application/x-executable: no extensions
typefindfunctions: text/x-cmml: no extensions
typefindfunctions: application/x-ogg-skeleton: no extensions
typefindfunctions: audio/x-celt: no extensions
typefindfunctions: audio/x-speex: no extensions
typefindfunctions: application/x-ogm-text: no extensions
typefindfunctions: application/x-ogm-audio: no extensions
typefindfunctions: application/x-ogm-video: no extensions
typefindfunctions: video/x-theora: no extensions
typefindfunctions: audio/x-vorbis: no extensions
typefindfunctions: audio/x-flac: flac
typefindfunctions: application/x-subtitle-vtt: vtt
typefindfunctions: subtitle/x-kate: no extensions
typefindfunctions: application/x-compress: Z
typefindfunctions: application/zip: zip
typefindfunctions: application/x-gzip: gz
typefindfunctions: application/x-bzip: bz2
typefindfunctions: image/x-sun-raster: ras
typefindfunctions: image/x-xpixmap: xpm
typefindfunctions: image/x-jng: jng
typefindfunctions: video/x-mng: mng
typefindfunctions: image/x-xcf: xcf
typefindfunctions: audio/x-sid: sid
typefindfunctions: audio/x-sbc: sbc
typefindfunctions: audio/iLBC-sh: ilbc
typefindfunctions: audio/x-amr-wb-sh: amr
typefindfunctions: audio/x-amr-nb-sh: amr
typefindfunctions: video/x-dv: dv, dif
typefindfunctions: video/x-mve: mve
typefindfunctions: application/mxf: mxf
typefindfunctions: video/x-matroska: mkv, mka, mk3d, webm
typefindfunctions: image/x-portable-pixmap: pnm, ppm, pgm, pbm
typefindfunctions: image/x-exr: exr
typefindfunctions: image/webp: webp
typefindfunctions: image/tiff: tif, tiff
typefindfunctions: image/bmp: bmp
typefindfunctions: image/png: png
typefindfunctions: image/gif: gif
typefindfunctions: image/jpeg: jpg, jpe, jpeg
typefindfunctions: application/x-ape: ape
typefindfunctions: audio/x-shorten: shn
typefindfunctions: audio/x-rf64: rf64
typefindfunctions: audio/x-w64: w64
typefindfunctions: audio/x-ircam: sf
typefindfunctions: audio/x-sds: sds
typefindfunctions: audio/x-voc: voc
typefindfunctions: audio/x-nist: nist
typefindfunctions: audio/x-paris: paf
typefindfunctions: audio/x-svx: iff, svx
typefindfunctions: audio/x-aiff: aiff, aif, aifc
typefindfunctions: audio/x-wav: wav
typefindfunctions: application/xml: xml
typefindfunctions: application/ttml+xml: ttml+xml
typefindfunctions: application/smil: smil
typefindfunctions: application/sdp: sdp
typefindfunctions: application/x-hls: m3u8
typefindfunctions: application/itc: itc
typefindfunctions: text/uri-list: ram
typefindfunctions: text/utf-32: txt
typefindfunctions: text/utf-16: txt
typefindfunctions: text/plain: txt
typefindfunctions: video/x-flv: flv
typefindfunctions: application/vnd.ms-sstr+xml: no extensions
typefindfunctions: application/dash+xml: mpd, MPD
typefindfunctions: application/x-shockwave-flash: swf, swfl
typefindfunctions: application/x-pn-realaudio: ra, ram, rm, rmvb
typefindfunctions: application/vnd.rn-realmedia: ra, ram, rm, rmvb
typefindfunctions: text/html: htm, html
typefindfunctions: video/mj2: mj2
typefindfunctions: image/x-jpc: jpc, j2k
typefindfunctions: image/jp2: jp2
typefindfunctions: image/x-quicktime: qif, qtif, qti
typefindfunctions: video/quicktime: mov, mp4
typefindfunctions: application/x-3gp: 3gp
typefindfunctions: audio/x-m4a: m4a
typefindfunctions: video/x-nuv: nuv
typefindfunctions: video/x-h265: h265, x265, 265
typefindfunctions: video/x-h264: h264, x264, 264
typefindfunctions: video/x-h263: h263, 263
typefindfunctions: video/mpeg4: m4v
typefindfunctions: video/mpeg-elementary: mpv, mpeg, mpg
typefindfunctions: application/ogg: ogg, oga, ogv, ogm, ogx, spx, anx, axa, axv
typefindfunctions: video/mpegts: ts, mts
typefindfunctions: video/mpeg-sys: mpe, mpeg, mpg
typefindfunctions: audio/x-gsm: gsm
typefindfunctions: audio/x-dts: dts
typefindfunctions: audio/x-ac3: ac3, eac3
typefindfunctions: audio/mpeg: mp3, mp2, mp1, mpga
typefindfunctions: audio/x-mod: 669, amf, ams, dbm, digi, dmf, dsm, gdm, far, imf, it, j2b, mdl, med, mod, mt2, mtm, okt, psm, ptm, sam, s3m, stm, stx, ult, umx, xm
typefindfunctions: audio/x-ttafile: tta
typefindfunctions: application/x-apetag: mp3, ape, mpc, wv
typefindfunctions: application/x-id3v1: mp3, mp2, mp1, mpga, ogg, flac, tta
typefindfunctions: application/x-id3v2: mp3, mp2, mp1, mpga, ogg, flac, tta
typefindfunctions: video/x-fli: flc, fli
typefindfunctions: audio/mobile-xmf: mxmf
typefindfunctions: audio/riff-midi: mid, midi
typefindfunctions: audio/midi: mid, midi
typefindfunctions: audio/x-imelody: imy, ime, imelody
typefindfunctions: video/x-vcd: dat
typefindfunctions: video/x-cdxa: dat
typefindfunctions: audio/qcelp: qcp
typefindfunctions: video/x-msvideo: avi
typefindfunctions: audio/x-au: au, snd
typefindfunctions: audio/x-musepack: mpc, mpp, mp+
typefindfunctions: video/x-ms-asf: asf, wm, wma, wmv
videocrop: aspectratiocrop: aspectratiocrop
videocrop: videocrop: Crop
audioparsers: wavpackparse: Wavpack audio stream parser
audioparsers: sbcparse: SBC audio parser
audioparsers: mpegaudioparse: MPEG1 Audio Parser
audioparsers: flacparse: FLAC audio parser
audioparsers: dcaparse: DTS Coherent Acoustics audio stream parser
audioparsers: ac3parse: AC3 audio stream parser
audioparsers: amrparse: AMR audio stream parser
audioparsers: aacparse: AAC audio stream parser
freeverb: freeverb: Reverberation/room effect
rtmp: rtmpsink: RTMP output sink
rtmp: rtmpsrc: RTMP Source
audiotestsrc: audiotestsrc: Audio test source
videomixer: videomixer: Video mixer 2
fbdevsink: fbdevsink: fbdev video sink
gio: giostreamsrc: GIO stream source
gio: giostreamsink: GIO stream sink
gio: giosrc: GIO source
gio: giosink: GIO sink
decklink: decklinkvideosrc: Decklink Video Source
decklink: decklinkaudiosrc: Decklink Audio Source
decklink: decklinkvideosink: Decklink Video Sink
decklink: decklinkaudiosink: Decklink Audio Sink
gaudieffects: gaussianblur: GstGaussianBlur
gaudieffects: solarize: Solarize
gaudieffects: exclusion: Exclusion
gaudieffects: dodge: Dodge
gaudieffects: dilate: Dilate
gaudieffects: chromium: Chromium
gaudieffects: burn: Burn
hls: hlssink2: HTTP Live Streaming sink
hls: hlssink: HTTP Live Streaming sink
hls: hlsdemux: HLS Demuxer
mulaw: mulawdec: Mu Law audio decoder
mulaw: mulawenc: Mu Law audio encoder
ivfparse: ivfparse: IVF parser
openglmixers: glstereomix: OpenGL stereo video combiner
openglmixers: glvideomixerelement: OpenGL video_mixer
openglmixers: glvideomixer: OpenGL video_mixer bin
openglmixers: glmixerbin: OpenGL video_mixer empty bin
lame: lamemp3enc: L.A.M.E. mp3 encoder
geometrictransform: perspective: perspective
geometrictransform: fisheye: fisheye
geometrictransform: mirror: mirror
geometrictransform: square: square
geometrictransform: tunnel: tunnel
geometrictransform: bulge: bulge
geometrictransform: stretch: stretch
geometrictransform: waterripple: waterripple
geometrictransform: twirl: twirl
geometrictransform: sphere: sphere
geometrictransform: rotate: rotate
geometrictransform: pinch: pinch
geometrictransform: marble: marble
geometrictransform: kaleidoscope: kaleidoscope
geometrictransform: diffuse: diffuse
geometrictransform: circle: circle
navigationtest: navigationtest: Video navigation test
mpegtsmux: mpegtsmux: MPEG Transport Stream Muxer
sbc: sbcenc: Bluetooth SBC audio encoder
sbc: sbcdec: Bluetooth SBC audio decoder
siren: sirenenc: Siren Encoder element
siren: sirendec: Siren Decoder element
netsim: netsim: Network Simulator
id3demux: id3demux: ID3 tag demuxer
mms: mmssrc: MMS streaming source
vcdsrc: vcdsrc: VCD Source
aasink: aasink: ASCII art video sink
cacasink: cacasink: A colored ASCII art video sink
inter: intervideosink: Internal video sink
inter: intervideosrc: Internal video source
inter: intersubsink: Internal subtitle sink
inter: intersubsrc: Internal subtitle source
inter: interaudiosink: Internal audio sink
inter: interaudiosrc: Internal audio source
pango: textrender: Text renderer
pango: clockoverlay: Clock overlay
pango: timeoverlay: Time overlay
pango: textoverlay: Text overlay
colormanagement: lcms: LCMS2 ICC correction
ttmlsubs: ttmlrender: TTML subtitle renderer
ttmlsubs: ttmlparse: TTML subtitle parser
nvv4l2camerasrc: nvv4l2camerasrc: NvV4l2CameraSrc
audiovisualizers: wavescope: Waveform oscilloscope
audiovisualizers: synaescope: Synaescope
audiovisualizers: spectrascope: Frequency spectrum scope
audiovisualizers: spacescope: Stereo visualizer
nveglstreamsrc: nveglstreamsrc: nVidia EGL Stream
ivtc: combdetect: Comb Detect
ivtc: ivtc: Inverse Telecine
waylandsink: waylandsink: wayland video sink
audiomixmatrix: audiomixmatrix: Matrix audio mix
rtp: rtpstorage: RTP storage
rtp: rtpulpfecenc: RTP FEC Encoder
rtp: rtpulpfecdec: RTP FEC Decoder
rtp: rtpreddec: Redundant Audio Data (RED) Decoder
rtp: rtpredenc: Redundant Audio Data (RED) Encoder
rtp: rtpstreamdepay: RTP Stream Depayloading
rtp: rtpstreampay: RTP Stream Payloading
rtp: rtpvrawpay: RTP Raw Video payloader
rtp: rtpvrawdepay: RTP Raw Video depayloader
rtp: rtpvp9pay: RTP VP9 payloader
rtp: rtpvp9depay: RTP VP9 depayloader
rtp: rtpvp8pay: RTP VP8 payloader
rtp: rtpvp8depay: RTP VP8 depayloader
rtp: rtpvorbispay: RTP Vorbis payloader
rtp: rtpvorbisdepay: RTP Vorbis depayloader
rtp: rtptheorapay: RTP Theora payloader
rtp: rtptheoradepay: RTP Theora depayloader
rtp: rtpsv3vdepay: RTP SVQ3 depayloader
rtp: rtpspeexdepay: RTP Speex depayloader
rtp: rtpspeexpay: RTP Speex payloader
rtp: rtpsirendepay: RTP Siren packet depayloader
rtp: rtpsirenpay: RTP Payloader for Siren Audio
rtp: rtpsbcpay: RTP packet payloader
rtp: rtpsbcdepay: RTP SBC audio depayloader
rtp: rtpqdm2depay: RTP QDM2 depayloader
rtp: rtpqcelpdepay: RTP QCELP depayloader
rtp: rtpmp4gpay: RTP MPEG4 ES payloader
rtp: rtpmp4gdepay: RTP MPEG4 ES depayloader
rtp: rtpmp4adepay: RTP MPEG4 audio depayloader
rtp: rtpmp4apay: RTP MPEG4 audio payloader
rtp: rtpmp4vdepay: RTP MPEG4 video depayloader
rtp: rtpmp4vpay: RTP MPEG4 Video payloader
rtp: rtpmp2tpay: RTP MPEG2 Transport Stream payloader
rtp: rtpmp2tdepay: RTP MPEG Transport Stream depayloader
rtp: rtpmp1sdepay: RTP MPEG1 System Stream depayloader
rtp: asteriskh263: RTP Asterisk H263 depayloader
rtp: rtpL24depay: RTP audio depayloader
rtp: rtpL24pay: RTP audio payloader
rtp: rtpL16depay: RTP audio depayloader
rtp: rtpL16pay: RTP audio payloader
rtp: rtpL8depay: RTP audio depayloader
rtp: rtpL8pay: RTP audio payloader
rtp: rtpklvpay: RTP KLV Payloader
rtp: rtpklvdepay: RTP KLV Depayloader
rtp: rtpjpegpay: RTP JPEG payloader
rtp: rtpjpegdepay: RTP JPEG depayloader
rtp: rtpj2kpay: RTP JPEG 2000 payloader
rtp: rtpj2kdepay: RTP JPEG 2000 depayloader
rtp: rtph265pay: RTP H265 payloader
rtp: rtph265depay: RTP H265 depayloader
rtp: rtph264pay: RTP H264 payloader
rtp: rtph264depay: RTP H264 depayloader
rtp: rtph263pay: RTP H263 packet payloader
rtp: rtph263depay: RTP H263 depayloader
rtp: rtph263pdepay: RTP H263 depayloader
rtp: rtph263ppay: RTP H263 payloader
rtp: rtph261depay: RTP H261 depayloader
rtp: rtph261pay: RTP H261 packet payloader
rtp: rtpopuspay: RTP Opus payloader
rtp: rtpopusdepay: RTP Opus packet depayloader
rtp: rtpmpvpay: RTP MPEG2 ES video payloader
rtp: rtpmpvdepay: RTP MPEG video depayloader
rtp: rtpmparobustdepay: RTP MPEG audio depayloader
rtp: rtpmpapay: RTP MPEG audio payloader
rtp: rtpmpadepay: RTP MPEG audio depayloader
rtp: rtppcmapay: RTP PCMA payloader
rtp: rtppcmupay: RTP PCMU payloader
rtp: rtppcmudepay: RTP PCMU depayloader
rtp: rtppcmadepay: RTP PCMA depayloader
rtp: rtpamrpay: RTP AMR payloader
rtp: rtpamrdepay: RTP AMR depayloader
rtp: rtpgsmpay: RTP GSM payloader
rtp: rtpgsmdepay: RTP GSM depayloader
rtp: rtpg729pay: RTP G.729 payloader
rtp: rtpg729depay: RTP G.729 depayloader
rtp: rtpg726pay: RTP G.726 payloader
rtp: rtpg726depay: RTP G.726 depayloader
rtp: rtpg723pay: RTP G.723 payloader
rtp: rtpg723depay: RTP G.723 depayloader
rtp: rtpg722pay: RTP audio payloader
rtp: rtpg722depay: RTP audio depayloader
rtp: rtpilbcdepay: RTP iLBC depayloader
rtp: rtpilbcpay: RTP iLBC Payloader
rtp: rtpgstpay: RTP GStreamer payloader
rtp: rtpgstdepay: GStreamer depayloader
rtp: rtpdvpay: RTP DV Payloader
rtp: rtpdvdepay: RTP DV Depayloader
rtp: rtpceltpay: RTP CELT payloader
rtp: rtpceltdepay: RTP CELT depayloader
rtp: rtpbvpay: RTP BV Payloader
rtp: rtpbvdepay: RTP BroadcomVoice depayloader
rtp: rtpac3pay: RTP AC3 audio payloader
rtp: rtpac3depay: RTP AC3 depayloader
adpcmdec: adpcmdec: ADPCM decoder
faceoverlay: faceoverlay: faceoverlay
mxf: mxfmux: MXF muxer
mxf: mxfdemux: MXF Demuxer
bz2: bz2dec: BZ2 decoder
bz2: bz2enc: BZ2 encoder
deinterlace: deinterlace: Deinterlacer
dtsdec: dtsdec: DTS audio decoder
soup: souphttpclientsink: HTTP client sink
soup: souphttpsrc: HTTP client source
jp2kdecimator: jp2kdecimator: JPEG2000 decimator
imagefreeze: imagefreeze: Still frame stream generator
subparse: ssaparse: SSA Subtitle Parser
subparse: subparse: Subtitle parser
subparse: subparse_typefind: srt, sub, mpsub, mdvd, smi, txt, dks, vtt
faad: faad: AAC audio decoder
srtp: srtpdec: SRTP decoder
srtp: srtpenc: SRTP encoder
video4linux2: v4l2deviceprovider (GstDeviceProviderFactory)
video4linux2: v4l2radio: Radio (video4linux2) Tuner
video4linux2: v4l2sink: Video (video4linux2) Sink
video4linux2: v4l2src: Video (video4linux2) Source
wavenc: wavenc: WAV audio muxer
proxy: proxysink: Proxy Sink
proxy: proxysrc: Proxy source
segmentclip: videosegmentclip: Video buffer segment clipper
segmentclip: audiosegmentclip: Audio buffer segment clipper
a52dec: a52dec: ATSC A/52 audio decoder
coretracers: leaks (GstTracerFactory)
coretracers: stats (GstTracerFactory)
coretracers: rusage (GstTracerFactory)
coretracers: log (GstTracerFactory)
coretracers: latency (GstTracerFactory)
vpx: vp9enc: On2 VP9 Encoder
vpx: vp9dec: On2 VP9 Decoder
vpx: vp8enc: On2 VP8 Encoder
vpx: vp8dec: On2 VP8 Decoder
x264: x264enc: x264enc
realmedia: pnmsrc: PNM packet receiver
realmedia: rtspreal: RealMedia RTSP Extension
realmedia: rdtmanager: RTP Decoder
realmedia: rdtdepay: RDT packet parser
realmedia: rademux: RealAudio Demuxer
realmedia: rmdemux: RealMedia Demuxer
dtmf: rtpdtmfdepay: RTP DTMF packet depayloader
dtmf: rtpdtmfsrc: RTP DTMF packet generator
dtmf: dtmfsrc: DTMF tone generator
mpeg2enc: mpeg2enc: mpeg2enc video encoder
mpegpsmux: mpegpsmux: MPEG Program Stream Muxer
voamrwbenc: voamrwbenc: AMR-WB audio encoder
nvvideocuda: videocuda: CUDA Post processor
replaygain: rgvolume: ReplayGain volume
replaygain: rglimiter: ReplayGain limiter
replaygain: rganalysis: ReplayGain analysis
sdpelem: sdpsrc: SDP Source
sdpelem: sdpdemux: SDP session setup
curl: curlhttpsrc: HTTP Client Source using libcURL
curl: curlsmtpsink: Curl smtp sink
curl: curlftpsink: Curl ftp sink
curl: curlfilesink: Curl file sink
curl: curlhttpsink: Curl http sink
nvvideo4linux2: nvv4l2vp9enc: V4L2 VP9 Encoder
nvvideo4linux2: nvv4l2vp8enc: V4L2 VP8 Encoder
nvvideo4linux2: nvv4l2h265enc: V4L2 H.265 Encoder
nvvideo4linux2: nvv4l2h264enc: V4L2 H.264 Encoder
nvvideo4linux2: nvv4l2decoder: NVIDIA v4l2 video decoder
spectrum: spectrum: Spectrum analyzer
nveglglessink: nveglglessink: EGL/GLES vout Sink
dashdemux: dashdemux: DASH Demuxer
rtpmanager: rtpdtmfmux: RTP muxer
rtpmanager: rtpmux: RTP muxer
rtpmanager: rtpssrcdemux: RTP SSRC Demux
rtpmanager: rtprtxsend: RTP Retransmission Sender
rtpmanager: rtprtxreceive: RTP Retransmission receiver
rtpmanager: rtprtxqueue: RTP Retransmission Queue
rtpmanager: rtpsession: RTP Session
rtpmanager: rtpptdemux: RTP Demux
rtpmanager: rtpjitterbuffer: RTP packet jitter-buffer
rtpmanager: rtpbin: RTP Bin
wavpack: wavpackenc: Wavpack audio encoder
wavpack: wavpackdec: Wavpack audio decoder
timecode: avwait: Timecode Wait
timecode: timecodestamper: Timecode stamper
cdio: cdiocddasrc: CD audio source (CDDA)
y4menc: y4menc: YUV4MPEG video encoder
dc1394: dc1394src: 1394 IIDC Video Source
gtk: gtkglsink: Gtk GL Video Sink
gtk: gtksink: Gtk Video Sink
jack: jackaudiosink: Audio Sink (Jack)
jack: jackaudiosrc: Audio Source (Jack)
assrender: assrender: ASS/SSA Render
speed: speed: Speed
speex: speexdec: Speex audio decoder
speex: speexenc: Speex audio encoder
removesilence: removesilence: RemoveSilence
xvimagesink: xvimagesink: Video sink
mplex: mplex: mplex video multiplexer
videoconvert: videoconvert: Colorspace converter
nvdsgst_multistreamtiler: nvmultistreamtiler: Stream Tiler DS
nvdsgst_dewarper: nvdewarper: nvdewarper
nvdsgst_videotemplate: nvdsvideotemplate: NvDsVideoTemplate plugin for Transform/In-Place use-cases
nvdsgst_logger: nvdslogger: Nvdslogger
nvdsgst_segvisual: nvsegvisual: nvsegvisual
nvdsgst_of: nvof: nvof
nvdsgst_audiotemplate: nvdsaudiotemplate: DS AUDIO template Plugin for Transform IP use-cases
nvdsgst_tracker: nvtracker: NvTracker plugin
nvdsgst_dsexample: dsexample: DsExample plugin
nvdsgst_ofvisual: nvofvisual: nvofvisual
nvdsgst_multistream: nvstreamdemux: Stream demultiplexer
nvdsgst_multistream: nvstreammux: Stream multiplexer
nvdsgst_infer: nvinfer: NvInfer plugin
nvdsgst_preprocess: nvdspreprocess: gst-nvdspreprocess plugin
nvdsgst_msgbroker: nvmsgbroker: Message Broker
nvdsgst_dsanalytics: nvdsanalytics: DsAnalytics plugin
nvvideoconvert: nvvideoconvert: NvVidConv Plugin
nvdsgst_inferaudio: nvinferaudio: NvInfer Audio plugin
nvdsgst_osd: nvdsosd: NvDsOsd plugin
nvvidconv: nvvidconv: NvVidConv Plugin
dtls: dtlssrtpdemux: DTLS SRTP Demultiplexer
dtls: dtlssrtpenc: DTLS-SRTP Encoder
dtls: dtlssrtpdec: DTLS-SRTP Decoder
dtls: dtlsdec: DTLS Decoder
dtls: dtlsenc: DTLS Encoder
ximagesrc: ximagesrc: Ximage video source
gsm: gsmdec: GSM audio decoder
gsm: gsmenc: GSM audio encoder
id3tag: id3mux: ID3 v1 and v2 Muxer
opengl: gloverlay: Gstreamer OpenGL Overlay
opengl: gldeinterlace: OpenGL deinterlacing filter
opengl: gltestsrc: Video test source
opengl: glstereosplit: GLStereoSplit
opengl: glviewconvert: OpenGL Multiview/3D conversion filter
opengl: glfilterapp: OpenGL application filter
opengl: glshader: OpenGL fragment shader filter
opengl: glcolorscale: OpenGL color scale
opengl: gleffects_laplacian: Laplacian Convolution Demo Effect
opengl: gleffects_blur: Blur with 9x9 separable convolution Effect
opengl: gleffects_sobel: Sobel edge detection Effect
opengl: gleffects_glow: Glow Lighting Effect
opengl: gleffects_sin: All Grey but Red Effect
opengl: gleffects_xray: Glowing negative effect
opengl: gleffects_lumaxpro: Luma Cross Processing Effect
opengl: gleffects_xpro: Cross Processing Effect
opengl: gleffects_sepia: Sepia Toning Effect
opengl: gleffects_heat: Heat Signature Effect
opengl: gleffects_square: Square Effect
opengl: gleffects_bulge: Bulge Effect
opengl: gleffects_twirl: Twirl Effect
opengl: gleffects_fisheye: FishEye Effect
opengl: gleffects_tunnel: Light Tunnel Effect
opengl: gleffects_stretch: Stretch Effect
opengl: gleffects_squeeze: Squeeze Effect
opengl: gleffects_mirror: Mirror Effect
opengl: gleffects_identity: Do nothing Effect
opengl: gleffects: Gstreamer OpenGL Effects
opengl: glvideoflip: OpenGL video flip filter
opengl: gltransformation: OpenGL transformation filter
opengl: glfiltercube: OpenGL cube filter
opengl: glsrcbin: GL Src Bin
opengl: glsinkbin: GL Sink Bin
opengl: glfilterbin: GL Filter Bin
opengl: glcolorbalance: Video balance
opengl: glcolorconvert: OpenGL color converter
opengl: gldownload: OpenGL downloader
opengl: glupload: OpenGL uploader
opengl: glimagesinkelement: OpenGL video sink
opengl: glimagesink: GL Sink Bin
mpegtsdemux: tsdemux: MPEG transport stream demuxer
mpegtsdemux: tsparse: MPEG transport stream parser
bs2b: bs2b: Crossfeed effect
vulkan: vulkanupload: Vulkan Uploader
vulkan: vulkansink: Vulkan video sink
nvvideosinks: nv3dsink: Nvidia 3D sink
spandsp: tonegeneratesrc: Telephony Tone Generator source
spandsp: dtmfdetect: DTMF detector element
spandsp: spanplc: SpanDSP PLC
png: pngenc: PNG image encoder
png: pngdec: PNG image decoder
openmpt: openmptdec: OpenMPT-based module music decoder
nvjpeg: nvjpegdec: JPEG image decoder
nvjpeg: nvjpegenc: JPEG image encoder
alphacolor: alphacolor: Alpha color filter
voaacenc: voaacenc: AAC audio encoder
dvdspu: dvdspu: Sub-picture Overlay
1394: hdv1394src: Firewire (1394) HDV video source
1394: dv1394src: Firewire (1394) DV video source
alpha: alpha: Alpha filter
goom2k1: goom2k1: GOOM: what a GOOM! 2k1 edition
alsa: alsamidisrc: AlsaMidi Source
alsa: alsasink: Audio sink (ALSA)
alsa: alsasrc: Audio source (ALSA)
y4mdec: y4mdec: YUV4MPEG demuxer/decoder
videoscale: videoscale: Video scaler
dv: dvdec: DV video decoder
dv: dvdemux: DV system stream demuxer
udp: udpsrc: UDP packet receiver
udp: dynudpsink: UDP packet sender
udp: multiudpsink: UDP packet sender
udp: udpsink: UDP packet sender
audioconvert: audioconvert: Audio converter
videosignal: simplevideomark: Video marker
videosignal: simplevideomarkdetect: Video detecter
videosignal: videoanalyse: Video analyser
adder: adder: Adder
nvarguscamerasrc: nvarguscamerasrc: NvArgusCameraSrc
jpegformat: jifmux: JPEG stream muxer
jpegformat: jpegparse: JPEG stream parser
debugutilsbad: fakevideosink: Fake Video Sink
debugutilsbad: errorignore: Convert some GstFlowReturn types into others
debugutilsbad: watchdog: Watchdog
debugutilsbad: debugspy: DebugSpy
debugutilsbad: compare: Compare buffers
debugutilsbad: chopmydata: FIXME
debugutilsbad: fpsdisplaysink: Measure and show framerate on videosink
debugutilsbad: checksumsink: Checksum sink
dvdlpcmdec: dvdlpcmdec: DVD LPCM Audio decoder
asfmux: asfparse: ASF parser
asfmux: rtpasfpay: RTP ASF payloader
asfmux: asfmux: ASF muxer
videofilter: videomedian: Median effect
videofilter: videoflip: Video flipper
videofilter: videobalance: Video balance
videofilter: gamma: Video gamma correction
shout2: shout2send: Icecast network sink
videorate: videorate: Video rate adjuster
flac: flactag: FLAC tagger
flac: flacdec: FLAC audio decoder
flac: flacenc: FLAC audio encoder
apetag: apedemux: APE tag demuxer
rawparse: rawvideoparse: rawvideoparse
rawparse: rawaudioparse: rawaudioparse
rawparse: unalignedvideoparse: unalignedvideoparse
rawparse: unalignedaudioparse: unalignedaudioparse
avi: avisubtitle: Avi subtitle parser
avi: avimux: Avi muxer
avi: avidemux: Avi demuxer
openal: openalsrc: OpenAL Audio Source
openal: openalsink: OpenAL Audio Sink
zbar: zbar: Barcode detector
sid: siddec: Sid decoder
cdparanoia: cdparanoiasrc: CD Audio (cdda) Source, Paranoia IV
monoscope: monoscope: Monoscope
openexr: openexrdec: OpenEXR decoder
pulseaudio: pulsedeviceprovider (GstDeviceProviderFactory)
pulseaudio: pulsesrc: PulseAudio Audio Source
pulseaudio: pulsesink: PulseAudio Audio Sink
audiofx: scaletempo: Scaletempo
audiofx: audioecho: Audio echo
audiofx: audiofirfilter: Audio FIR filter
audiofx: audiowsincband: Band pass & band reject filter
audiofx: audiowsinclimit: Low pass & high pass filter
audiofx: audioiirfilter: Audio IIR filter
audiofx: audiochebband: Band pass & band reject filter
audiofx: audiocheblimit: Low pass & high pass filter
audiofx: audiodynamic: Dynamic range controller
audiofx: audioamplify: Audio amplifier
audiofx: audiokaraoke: AudioKaraoke
audiofx: audioinvert: Audio inversion
audiofx: audiopanorama: Stereo positioning
audiolatency: audiolatency: AudioLatency
dvdsub: dvdsubparse: DVD subtitle parser
dvdsub: dvdsubdec: DVD subtitle decoder
theora: theoraparse: Theora video parser
theora: theoraenc: Theora video encoder
theora: theoradec: Theora video decoder
interlace: interlace: Interlace filter
smpte: smptealpha: SMPTE transitions
smpte: smpte: SMPTE transitions
xingmux: xingmux: MP3 Xing muxer
pnm: pnmenc: PNM image encoder
pnm: pnmdec: PNM image decoder
wildmidi: wildmididec: WildMidi-based MIDI music decoder
ximagesink: ximagesink: Video sink
ofa: ofa: OFA
legacyrawparse: audioparse: Audio Parse
legacyrawparse: videoparse: Video Parse
kms: kmssink: KMS video sink
smoothstreaming: mssdemux: Smooth Streaming demuxer
yadif: yadif: YADIF deinterlacer
flite: flitetestsrc: Flite speech test source
matroska: webmmux: WebM muxer
matroska: matroskamux: Matroska muxer
matroska: matroskaparse: Matroska parser
matroska: matroskademux: Matroska demuxer
effectv: rippletv: RippleTV effect
effectv: streaktv: StreakTV effect
effectv: radioactv: RadioacTV effect
effectv: optv: OpTV effect
effectv: quarktv: QuarkTV effect
effectv: revtv: RevTV effect
effectv: vertigotv: VertigoTV effect
effectv: shagadelictv: ShagadelicTV
effectv: warptv: WarpTV effect
effectv: dicetv: DiceTV effect
effectv: agingtv: AgingTV effect
effectv: edgetv: EdgeTV effect
audioresample: audioresample: Audio resampler
midi: midiparse: MidiParse
interleave: deinterleave: Audio deinterleaver
interleave: interleave: Audio interleaver
rtponvif: rtponvifparse: ONVIF NTP timestamps RTP extension
rtponvif: rtponviftimestamp: ONVIF NTP timestamps RTP extension
vorbis: vorbistag: VorbisTag
vorbis: vorbisparse: VorbisParse
vorbis: vorbisdec: Vorbis audio decoder
vorbis: vorbisenc: Vorbis audio encoder
dvb: dvbbasebin: DVB bin
dvb: dvbsrc: DVB Source
icydemux: icydemux: ICY tag demuxer
autodetect: autoaudiosrc: Auto audio source
autodetect: autoaudiosink: Auto audio sink
autodetect: autovideosrc: Auto video source
autodetect: autovideosink: Auto video sink
nvivafilter: nvivafilter: NvIVAFilter Plugin
camerabin: camerabin: Camera Bin
camerabin: wrappercamerabinsrc: Wrapper camera src element for camerabin2
camerabin: viewfinderbin: Viewfinder Bin
uvch264: uvch264src: UVC H264 Source
uvch264: uvch264mjpgdemux: UVC H264 MJPG Demuxer
vmnc: vmncdec: VMnc video decoder
coreelements: streamiddemux: Streamid Demux
coreelements: valve: Valve element
coreelements: multiqueue: MultiQueue
coreelements: typefind: TypeFind
coreelements: tee: Tee pipe fitting
coreelements: filesink: File Sink
coreelements: queue2: Queue 2
coreelements: queue: Queue
coreelements: output-selector: Output selector
coreelements: input-selector: Input selector
coreelements: identity: Identity
coreelements: funnel: Funnel pipe fitting
coreelements: filesrc: File Source
coreelements: fdsink: Filedescriptor Sink
coreelements: fdsrc: Filedescriptor Source
coreelements: fakesink: Fake Sink
coreelements: fakesrc: Fake Source
coreelements: downloadbuffer: DownloadBuffer
coreelements: dataurisrc: data: URI source element
coreelements: concat: Concat
coreelements: capsfilter: CapsFilter
modplug: modplug: ModPlug
playback: parsebin: Parse Bin
playback: urisourcebin: URI reader
playback: uridecodebin3: URI Decoder
playback: uridecodebin: URI Decoder
playback: decodebin3: Decoder Bin 3
playback: decodebin: Decoder Bin
playback: streamsynchronizer: Stream Synchronizer
playback: subtitleoverlay: Subtitle Overlay
playback: playsink: Player Sink
playback: playbin3: Player Bin 3
playback: playbin: Player Bin 2
videofiltersbad: videodiff: Video Diff
videofiltersbad: zebrastripe: Zebra stripe overlay
videofiltersbad: scenechange: Scene change detector
coloreffects: chromahold: Chroma hold filter
coloreffects: coloreffects: Color Look-up Table filter
bayer: rgb2bayer: RGB to Bayer converter
bayer: bayer2rgb: Bayer to RGB decoder for cameras
oss4: oss4src: OSS v4 Audio Source
oss4: oss4sink: OSS v4 Audio Sink
flxdec: flxdec: FLX video decoder
autoconvert: autovideoconvert: Select color space convertor based on caps
autoconvert: autoconvert: Select convertor based on caps
opus: opusdec: Opus audio decoder
opus: opusenc: Opus audio encoder
ogg: oggaviparse: Ogg AVI parser
ogg: oggparse: Ogg parser
ogg: ogmtextparse: OGM text stream parser
ogg: ogmvideoparse: OGM video stream parser
ogg: ogmaudioparse: OGM audio stream parser
ogg: oggmux: Ogg muxer
ogg: oggdemux: Ogg demuxer
rsvg: rsvgdec: SVG image decoder
rsvg: rsvgoverlay: RSVG overlay
isomp4: qtmoovrecover: QT Moov Recover
isomp4: mj2mux: MJ2 Muxer
isomp4: 3gppmux: 3GPP Muxer
isomp4: ismlmux: ISML Muxer
isomp4: mp4mux: MP4 Muxer
isomp4: qtmux: QuickTime Muxer
isomp4: rtpxqtdepay: RTP packet depayloader
isomp4: qtdemux: QuickTime demuxer
nvvideosink: nvvideosink: nVidia Video Sink
ipcpipeline: ipcslavepipeline: Inter-process slave pipeline
ipcpipeline: ipcpipelinesink: Inter-process Pipeline Sink
ipcpipeline: ipcpipelinesrc: Inter-process Pipeline Source
debug: cpureport: CPU report
debug: testsink: Test plugin
debug: taginject: TagInject
debug: progressreport: Progress report
debug: pushfilesrc: Push File Source
debug: navseek: Seek based on left-right arrows
debug: rndbuffersize: Random buffer size
debug: capssetter: CapsSetter
debug: breakmydata: Break my data
audiomixer: audiointerleave: AudioInterleave
audiomixer: liveadder: AudioMixer
audiomixer: audiomixer: AudioMixer
aiff: aiffmux: AIFF audio muxer
aiff: aiffparse: AIFF audio demuxer
kate: katetag: Kate stream tagger
kate: kateparse: Kate stream parser
kate: kateenc: Kate stream encoder
kate: katedec: Kate stream text decoder
gme: gmedec: Gaming console music file decoder
fluidsynthmidi: fluiddec: Fluidsynth
sndfile: sfdec: Sndfile decoder
alaw: alawdec: A Law audio decoder
alaw: alawenc: A Law audio encoder
videoparsersbad: vc1parse: VC1 parser
videoparsersbad: h265parse: H.265 parser
videoparsersbad: jpeg2000parse: JPEG 2000 parser
videoparsersbad: pngparse: PNG parser
videoparsersbad: mpeg4videoparse: MPEG 4 video elementary stream parser
videoparsersbad: mpegvideoparse: MPEG video elementary stream parser
videoparsersbad: diracparse: Dirac parser
videoparsersbad: h264parse: H.264 parser
videoparsersbad: h263parse: H.263 parser
jpeg: jpegdec: JPEG image decoder
jpeg: jpegenc: JPEG image encoder
webrtc: webrtcbin: WebRTC Bin
musepack: musepackdec: Musepack decoder
cairo: cairooverlay: Cairo overlay
cutter: cutter: Audio cutter
stereo: stereo: Stereo effect
ossaudio: osssink: Audio Sink (OSS)
ossaudio: osssrc: Audio Source (OSS)
rfbsrc: rfbsrc: Rfb source
app: appsink: AppSink
app: appsrc: AppSrc
audiobuffersplit: audiobuffersplit: Audio Buffer Split
teletext: teletextdec: Teletext decoder
openjpeg: openjpegenc: OpenJPEG JPEG2000 encoder
openjpeg: openjpegdec: OpenJPEG JPEG2000 decoder
pcapparse: irtspparse: IRTSPParse
pcapparse: pcapparse: PCapParse
videobox: videobox: Video box filter
volume: volume: Volume
staticelements: bin: Generic bin
staticelements: pipeline: Pipeline object
Total count: 283 plugins (7 blacklist entries not shown), 859 features
For this warning, please refer to Frequently Asked Questions — DeepStream documentation
Seems you Kafka server is not configured correctly.
