Which Source list yaml are you talking about. If you are referring to source_list_dynamic.yaml and source_list_static.yaml that are in deepstream_test5.cpp directory then they are NOT changed at all. They are SAME as original.
Only YAML files changed were ds_config_nano.yaml file. downloaded version did NOT have “nvstreammux” section which was added and needed.
< - type: nvstreammux
< name: mux
< properties:
< batch-size: 4 # ← REQUIRED (matches your source/PGIE)
< width: 960 # keep consistent with your source infer size
< height: 544
< live-source: true
< batched-push-timeout: 30000
< # optional but sane:
< # buffer-pool-size: 4
< # sync-inputs: 0
There is a source yaml file in AI_NVR pn26/service-maker directory. This is not changed.
Content of ds-config_nano,yaml file are:
deepstream:
nodes:
SOURCE (REST add/remove)
type: nvmultiurisrcbin
properties:
ip-address: “localhost”
port: 9010
live-source: true
width: 960
height: 544
max-batch-size: 4
drop-pipeline-eos: true
file-loop: true
buffer-pool-size: 4
rtsp-reconnect-interval: 60
type: nvinfer
name of the primary inference must be ‘pgie’ for test app to route streams here
properties:
config-file-path: “/home/mobilestack/jps_2.0.1/ai_nvr/config/deepstream/pn26/config_infer_primary_RN34_PN26_960x544_orin_unprune_nano.txt”
model-engine-file: “/pn26-files/pn26_jp6_halfmem_bs4_gpu.engine”
# Put the TRT plan in a writable volume (mounted as /engines in compose)
model-engine-file: “/engines/pn26_jp6_halfmem_bs4_gpu.engine”
unique-id: 1
be sure to rename model-engine-file whenever batch-size is changed
batch-size: 4
type: nvtracker
properties:
ll-config-file: “/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml”
ll-lib-file: “/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so”
tracker-width: 960
tracker-height: 544
type: nvmsgconv
properties:
payload-type: 1
type: nvmsgbroker
properties:
config: “/home/mobilestack/jps_2.0.1/ai_nvr/config/deepstream/pn26/cfg_redis.txt”
proto-lib: “/opt/nvidia/deepstream/deepstream/lib/libnvds_redis_proto.so”
conn-str: “localhost;6379;test”
topic: “test”
sync: false
async: false
type: queue
type: nvmultistreamtiler
properties:
width: 1280
height: 720
rows: 2
columns: 2
type: nvdsosd
type: nvvideoconvert
type: tee
type: queue
type: queue
type: fakesink
properties:
async: false
sync: false
type: sample_video_probe.sample_video_probe
properties:
font-size: 15
type: queue
type: queue
type: queue
type: queue
type: queue
type: queue
edges:
pgie: [queue_tracker, osd_counter]
queue_tracker: tracker
tracker: queue_checkpoint
queue_checkpoint: checkpoint
checkpoint: queue_tiler
queue_tiler: tiler
tiler: queue_converter
queue_converter: converter
converter: queue_osd
queue_osd: osd
osd: queue_tee
queue_tee: tee
tee: [queue1, queue2]
queue1: sink
queue2: msgconv
msgconv: msgbroker
Running App-5 again. Here is the log below:
am_test5_app$ GST_DEBUG=4 /opt/nvidia/deepstream/deepstream-7.1/service-maker/sources/apps/cpp/deepstream_test5_app/build/deepstream-test5-app -s ~/jps_2.0.1/ai_nvr/config/deepstream/pn26/service-maker/source-list_nano.yaml -c ~/jps_2.0.1/ai_nvr/config/deepstream/pn26/service-maker/ds-config_nano.yaml -l ~/jps_2.0.1/ai_nvr/config/deepstream/pn26/labels.txt --perf-measurement-interval-sec 5
Initializing GStreamer Backend…!
0:00:00.001211544 3064254 0xaaaae048d800 INFO GST_INIT gst.c:592:init_pre: Initializing GStreamer Core Library version 1.20.3
0:00:00.001288636 3064254 0xaaaae048d800 INFO GST_INIT gst.c:593:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.001315517 3064254 0xaaaae048d800 INFO GST_INIT gst.c:611:init_pre: Linux ubuntu 5.15.148-tegra #1 SMP PREEMPT Mon Jun 16 08:24:48 PDT 2025 aarch64
0:00:00.002174213 3064254 0xaaaae048d800 INFO GST_INIT gstmessage.c:129:_priv_gst_message_initialize: init messages
0:00:00.003214933 3064254 0xaaaae048d800 INFO GST_INIT gstcontext.c:86:_priv_gst_context_initialize: init contexts
0:00:00.003433279 3064254 0xaaaae048d800 INFO GST_PLUGIN_LOADING gstplugin.c:324:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.003560805 3064254 0xaaaae048d800 INFO GST_PLUGIN_LOADING gstplugin.c:232:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.003581126 3064254 0xaaaae048d800 INFO GST_PLUGIN_LOADING gstplugin.c:234:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.003650633 3064254 0xaaaae048d800 INFO GST_REGISTRY gstregistry.c:1827:ensure_current_registry: reading registry cache: /home/mobilestack/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.023737548 3064254 0xaaaae048d800 INFO GST_REGISTRY gstregistrybinary.c:683:priv_gst_registry_binary_read_cache: loaded /home/mobilestack/.cache/gstreamer-1.0/registry.aarch64.bin in 0.020034 seconds
0:00:00.023974679 3064254 0xaaaae048d800 INFO GST_REGISTRY gstregistry.c:1693:scan_and_update_registry: Validating plugins from registry cache: /home/mobilestack/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.027029061 3064254 0xaaaae048d800 INFO GST_REGISTRY gstregistry.c:1785:scan_and_update_registry: Registry cache has not changed
0:00:00.027064455 3064254 0xaaaae048d800 INFO GST_REGISTRY gstregistry.c:1862:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.027082792 3064254 0xaaaae048d800 INFO GST_INIT gst.c:833:init_post: GLib runtime version: 2.72.4
0:00:00.027095944 3064254 0xaaaae048d800 INFO GST_INIT gst.c:835:init_post: GLib headers version: 2.72.4
0:00:00.027103688 3064254 0xaaaae048d800 INFO GST_INIT gst.c:837:init_post: initialized GStreamer successfully
0:00:00.027182284 3064254 0xaaaae048d800 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element “pipeline”
Node – deepstream :
Node – nodes :
Node – edges :
Element ---- nvmultiurisrcbin RefName multiurisrcbin
ip-address:localhost
port:9010
live-source:true
width:960
height:544
max-batch-size:4
batched-push-timeout:30000
drop-pipeline-eos:true
file-loop:true
buffer-pool-size:4
rtsp-reconnect-interval:60
Element ---- nvinfer RefName pgie
config-file-path:/home/mobilestack/jps_2.0.1/ai_nvr/config/deepstream/pn26/config_infer_primary_RN34_PN26_960x544_orin_unprune_nano.txt
model-engine-file:/engines/pn26_jp6_halfmem_bs4_gpu.engine
unique-id:1
batch-size:4
Element ---- nvtracker RefName tracker
ll-config-file:/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
ll-lib-file:/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
tracker-width:960
tracker-height:544
Element ---- nvmsgconv RefName msgconv
payload-type:1
Element ---- nvmsgbroker RefName msgbroker
config:/home/mobilestack/jps_2.0.1/ai_nvr/config/deepstream/pn26/cfg_redis.txt
proto-lib:/opt/nvidia/deepstream/deepstream/lib/libnvds_redis_proto.so
conn-str:localhost;6379;test
topic:test
sync:false
async:false
Element ---- queue RefName checkpoint
Element ---- nvmultistreamtiler RefName tiler
width:1280
height:720
rows:2
columns:2
Element ---- nvdsosd RefName osd
Element ---- nvvideoconvert RefName converter
Element ---- tee RefName tee
Element ---- queue RefName queue1
Element ---- queue RefName queue2
Element ---- fakesink RefName sink
async:false
sync:false
Element ---- sample_video_probe.sample_video_probe RefName osd_counter
font-size:15
Element ---- queue RefName queue_tracker
Element ---- queue RefName queue_checkpoint
Element ---- queue RefName queue_tiler
Element ---- queue RefName queue_converter
Element ---- queue RefName queue_osd
Element ---- queue RefName queue_tee
Element: nvmultiurisrcbin, Name: multiurisrcbin
0:00:00.039735506 3064254 0xaaaae048d800 INFO GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvmultiurisrcbin.so” loaded
0:00:00.040273163 3064254 0xaaaae048d800 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element “nvmultiurisrcbin”
0:00:00.040424370 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:GstDsNvMultiUriBin@0xaaaae073e3f0 adding pad ‘src’
set ip-address: localhost
set port: 9010
set live-source: true
set width: 960
set height: 544
set max-batch-size: 4
set batched-push-timeout: 30000
set drop-pipeline-eos: true
set file-loop: true
set buffer-pool-size: 4
set rtsp-reconnect-interval: 60
Add Element … multiurisrcbin\
<snip - due to message size limit>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
gstevent.c:1660:gst_event_new_reconfigure: creating reconfigure event
0:00:00.547645735 3064254 0xaaaae048d800 INFO GST_EVENT gstpad.c:5946:gst_pad_send_event_unchecked:multiurisrcbin:src Received event on flushing pad. Discarding
0:00:00.547826799 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:1016:gst_element_get_static_pad: found pad tiler:sink
0:00:00.548320230 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.548393577 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.548414634 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.548476269 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘sink’ changed state to 2(READY) successfully
0:00:00.548755866 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.555932679 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.555983977 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556026027 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘msgbroker’ changed state to 2(READY) successfully
0:00:00.556060525 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.556077197 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.556087502 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556101839 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue1’ changed state to 2(READY) successfully
0:00:00.556118031 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.556128496 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.556137584 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556149201 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘msgconv’ changed state to 2(READY) successfully
0:00:00.556160977 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.556170642 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.556178386 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556189331 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue2’ changed state to 2(READY) successfully
0:00:00.556200851 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.556210900 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.556218804 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556229172 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tee’ changed state to 2(READY) successfully
0:00:00.556241173 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tee> current NULL pending VOID_PENDING, desired next READY
0:00:00.556249717 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tee> completed state change to READY
0:00:00.556257686 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tee> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556267702 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tee’ changed state to 2(READY) successfully
0:00:00.556280247 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.556288855 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.556297144 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556308088 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘osd’ changed state to 2(READY) successfully
0:00:00.556320601 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_osd> current NULL pending VOID_PENDING, desired next READY
0:00:00.556329113 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_osd> completed state change to READY
0:00:00.556337498 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_osd> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556347866 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_osd’ changed state to 2(READY) successfully
0:00:00.556362491 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.556375931 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.556384732 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556397468 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘converter’ changed state to 2(READY) successfully
0:00:00.556410365 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_converter> current NULL pending VOID_PENDING, desired next READY
0:00:00.556419869 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_converter> completed state change to READY
0:00:00.556428702 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_converter> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556439870 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_converter’ changed state to 2(READY) successfully
0:00:00.556453311 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.556463167 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.556471936 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556483104 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tiler’ changed state to 2(READY) successfully
0:00:00.556495681 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tiler> current NULL pending VOID_PENDING, desired next READY
0:00:00.556505633 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tiler> completed state change to READY
0:00:00.556517826 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tiler> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556535363 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tiler’ changed state to 2(READY) successfully
0:00:00.556549283 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.556558852 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.556567364 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556579045 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘checkpoint’ changed state to 2(READY) successfully
0:00:00.556593061 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_checkpoint> current NULL pending VOID_PENDING, desired next READY
0:00:00.556604070 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_checkpoint> completed state change to READY
0:00:00.556612742 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_checkpoint> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.556661641 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_checkpoint’ changed state to 2(READY) successfully
0:00:00.556681321 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.558733993 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.558865871 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.559004917 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tracker’ changed state to 2(READY) successfully
0:00:00.559030518 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tracker> current NULL pending VOID_PENDING, desired next READY
0:00:00.559042487 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tracker> completed state change to READY
0:00:00.559051991 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tracker> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.559067800 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tracker’ changed state to 2(READY) successfully
0:00:00.559083897 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.559095417 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.559128635 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.559143260 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘pgie’ changed state to 2(READY) successfully
0:00:00.559155452 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.566061436 3064254 0xaaaae0d05b30 INFO GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so” loaded
0:00:00.566722331 3064254 0xaaaae0d05b30 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element “nvstreammux”
0:00:00.566865537 3064254 0xaaaae0d05b30 INFO GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:GstNvStreamMux@0xffff60014060 adding pad ‘src’
0:00:00.566938533 3064254 0xaaaae0d05b30 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element “bin”
0:00:00.567029897 3064254 0xaaaae0d05b30 INFO GST_ELEMENT_PADS gstelement.c:1016:gst_element_get_static_pad: found pad src_bin_muxer:src
0:00:00.567162703 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:2382:gst_pad_link_prepare: trying to link src_bin_muxer:src and src:proxypad2
0:00:00.567186864 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:2590:gst_pad_link_full: linked src_bin_muxer:src and src:proxypad2, successful
0:00:00.567198289 3064254 0xaaaae0d05b30 INFO GST_EVENT gstevent.c:1660:gst_event_new_reconfigure: creating reconfigure event
0:00:00.567212306 3064254 0xaaaae0d05b30 INFO GST_EVENT gstpad.c:5946:gst_pad_send_event_unchecked:<src_bin_muxer:src> Received event on flushing pad. Discarding
0:00:00.567258388 3064254 0xaaaae0d05b30 INFO GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<multiurisrcbin_creator> adding pad ‘src’
0:00:00.567274196 3064254 0xaaaae0d05b30 INFO GST_ELEMENT_PADS gstelement.c:1016:gst_element_get_static_pad: found pad src_bin_muxer:src
0:00:00.568399273 3064254 0xaaaae0d05b30 INFO GST_ELEMENT_PADS gstelement.c:1016:gst_element_get_static_pad: found pad multiurisrcbin_creator:src
0:00:00.568463180 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:2382:gst_pad_link_prepare: trying to link multiurisrcbin_creator:src and src:proxypad0
0:00:00.568482380 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:2590:gst_pad_link_full: linked multiurisrcbin_creator:src and src:proxypad0, successful
0:00:00.568543599 3064254 0xaaaae0d05b30 INFO GST_EVENT gstevent.c:1660:gst_event_new_reconfigure: creating reconfigure event
0:00:00.568559440 3064254 0xaaaae0d05b30 INFO GST_EVENT gstpad.c:5946:gst_pad_send_event_unchecked:<multiurisrcbin_creator:src> Received event on flushing pad. Discarding
cannot bind to 9010: 98 (Address already in use)
Failed to setup server ports
CivetException caught: null context when constructing CivetServer. Possible problem binding to port. Error: Failed to setup server ports
REST Server start failed, Users may still have all sources mentioned with uri-list in the pipeline
0:00:00.740614356 3064254 0xffff60005060 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<src_bin_muxer> completed state change to NULL
0:00:00.740746874 3064254 0xffff600050c0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<src_bin_muxer> current NULL pending VOID_PENDING, desired next READY
0:00:00.741445018 3064254 0xffff600050c0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<src_bin_muxer> completed state change to READY
0:00:00.741476027 3064254 0xffff600050c0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<src_bin_muxer> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.741534334 3064254 0xffff600050c0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<multiurisrcbin_creator> child ‘src_bin_muxer’ changed state to 2(READY) successfully
0:00:00.741553247 3064254 0xffff600050c0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<multiurisrcbin_creator> completed state change to READY
0:00:00.741564736 3064254 0xffff600050c0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<multiurisrcbin_creator> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.741631811 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<multiurisrcbin_creator> current READY pending VOID_PENDING, desired next READY
0:00:00.741642339 3064254 0xffff600050c0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<src_bin_muxer> completed state change to READY
0:00:00.741713382 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<src_bin_muxer> current READY pending VOID_PENDING, desired next READY
0:00:00.741731175 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2597:gst_bin_element_set_state:<src_bin_muxer> skipping transition from READY to READY
0:00:00.741742824 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<multiurisrcbin_creator> child ‘src_bin_muxer’ changed state to 2(READY) successfully
0:00:00.741756872 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<multiurisrcbin_creator> completed state change to READY
0:00:00.741771465 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘multiurisrcbin_creator’ changed state to 2(READY) successfully
0:00:00.741782378 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:00.741789322 3064254 0xffff600050c0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<src_bin_muxer> current READY pending VOID_PENDING, desired next READY
0:00:00.741810091 3064254 0xffff600050c0 INFO GST_STATES gstbin.c:2597:gst_bin_element_set_state:<src_bin_muxer> skipping transition from READY to READY
0:00:00.741844428 3064254 0xffff600050c0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<multiurisrcbin_creator> child ‘src_bin_muxer’ changed state to 2(READY) successfully
0:00:00.741792586 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.741860269 3064254 0xffff600050c0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<multiurisrcbin_creator> completed state change to READY
0:00:00.741895279 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘multiurisrcbin’ changed state to 2(READY) successfully
0:00:00.741922320 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2778:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.741925872 3064254 0xffff600050c0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<src_bin_muxer> completed state change to READY
0:00:00.741958066 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.741975347 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2786:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:00:00.742043446 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.742094360 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.742106809 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.742120793 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘sink’ changed state to 3(PAUSED) successfully
0:00:00.742133530 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.742151707 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.742161403 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.742173404 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘msgbroker’ changed state to 3(PAUSED) successfully
0:00:00.742185436 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.742246335 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0c34b50 on task 0xffff6001d050
0:00:00.742263840 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:queue1:src created task 0xffff6001d050
0:00:00.742501515 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.742520076 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.742536109 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue1’ changed state to 3(PAUSED) successfully
0:00:00.742550445 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.742582927 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.742593455 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.742605744 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘msgconv’ changed state to 3(PAUSED) successfully
0:00:00.742618992 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.742645298 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0c34ff0 on task 0xffff6001d170
0:00:00.742657554 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:queue2:src created task 0xffff6001d170
0:00:00.742800857 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.742818842 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.742833594 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue2’ changed state to 3(PAUSED) successfully
0:00:00.742846299 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.742864636 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.742872732 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.742883485 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tee’ changed state to 3(PAUSED) successfully
0:00:00.742893789 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tee> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.742912478 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0d06ea0 on task 0xffff6001d290
0:00:00.742923614 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:<queue_tee:src> created task 0xffff6001d290
0:00:00.743029379 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tee> completed state change to PAUSED
0:00:00.743048740 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tee> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.743063941 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tee’ changed state to 3(PAUSED) successfully
0:00:00.743077222 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.745968683 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.746002093 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.746036079 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘osd’ changed state to 3(PAUSED) successfully
0:00:00.746059536 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_osd> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.746101298 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0d06a00 on task 0xffff6001d3b0
0:00:00.746114770 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:<queue_osd:src> created task 0xffff6001d3b0
0:00:00.746251673 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_osd> completed state change to PAUSED
0:00:00.746268537 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_osd> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.746285274 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_osd’ changed state to 3(PAUSED) successfully
0:00:00.746301147 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.746326524 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.746336669 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.746367838 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘converter’ changed state to 3(PAUSED) successfully
0:00:00.746385087 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_converter> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.746407136 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0d06560 on task 0xffff6001d4d0
0:00:00.746418528 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:<queue_converter:src> created task 0xffff6001d4d0
0:00:00.746541958 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_converter> completed state change to PAUSED
0:00:00.746557927 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_converter> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.746576552 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_converter’ changed state to 3(PAUSED) successfully
0:00:00.746593480 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.748512801 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.748707146 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.748816207 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tiler’ changed state to 3(PAUSED) successfully
0:00:00.748931317 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tiler> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.749064347 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0d060c0 on task 0xffff6001d5f0
0:00:00.749092124 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:<queue_tiler:src> created task 0xffff6001d5f0
0:00:00.749436332 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tiler> completed state change to PAUSED
0:00:00.749555026 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tiler> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.749750907 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tiler’ changed state to 3(PAUSED) successfully
0:00:00.749888993 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.750010535 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0bbf4d0 on task 0xffff6001d710
0:00:00.750034440 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:checkpoint:src created task 0xffff6001d710
0:00:00.750177166 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:00.750195791 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.750211056 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘checkpoint’ changed state to 3(PAUSED) successfully
0:00:00.750226097 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_checkpoint> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.750244914 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0c35b80 on task 0xffff6001d830
0:00:00.750253266 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:<queue_checkpoint:src> created task 0xffff6001d830
0:00:00.750342806 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_checkpoint> completed state change to PAUSED
0:00:00.750361271 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_checkpoint> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.750405465 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_checkpoint’ changed state to 3(PAUSED) successfully
0:00:00.750425434 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:01.383152467 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to PAUSED
0:00:01.383219862 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.383292409 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tracker’ changed state to 3(PAUSED) successfully
0:00:01.383330875 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tracker> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.383396478 3064254 0xaaaae0d05b30 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0xaaaae0c356e0 on task 0xffff6001d950
0:00:01.383413439 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:6291:gst_pad_start_task:<queue_tracker:src> created task 0xffff6001d950
0:00:01.383526468 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tracker> completed state change to PAUSED
0:00:01.383542405 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tracker> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.383579110 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tracker’ changed state to 3(PAUSED) successfully
0:00:01.383600647 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
WARNING: Deserialize engine failed because file path: /engines/pn26_jp6_halfmem_bs4_gpu.engine open error
0:00:01.390845943 3064254 0xaaaae0d05b30 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 1]: deserialize engine from file :/engines/pn26_jp6_halfmem_bs4_gpu.engine failed
0:00:01.390891001 3064254 0xaaaae0d05b30 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 1]: deserialize backend context from engine from file :/engines/pn26_jp6_halfmem_bs4_gpu.engine failed, try rebuild
0:00:01.390906458 3064254 0xaaaae0d05b30 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
ERROR: Cannot access ONNX file ‘/pn26-files’
ERROR: failed to build network since parsing model errors.
ERROR: failed to build network.
0:00:21.875693001 3064254 0xaaaae0d05b30 ERROR nvinfer gstnvinfer.cpp:678:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2126> [UID = 1]: build engine file failed
0:00:22.481328540 3064254 0xaaaae0d05b30 ERROR nvinfer gstnvinfer.cpp:678:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2213> [UID = 1]: build backend context failed
0:00:22.482046653 3064254 0xaaaae0d05b30 ERROR nvinfer gstnvinfer.cpp:678:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1351> [UID = 1]: generate backend failed, check config file settings
0:00:22.490345784 3064254 0xaaaae0d05b30 WARN nvinfer gstnvinfer.cpp:914:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:22.517747226 3064254 0xaaaae0d05b30 WARN nvinfer gstnvinfer.cpp:914:gst_nvinfer_start: error: Config file path: /home/mobilestack/jps_2.0.1/ai_nvr/config/deepstream/pn26/config_infer_primary_RN34_PN26_960x544_orin_unprune_nano.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
0:00:22.521501125 3064254 0xaaaae0d05b30 INFO GST_ERROR_SYSTEM gstelement.c:2271:gst_element_message_full_with_details: posting message: Failed to create NvDsInferContext instance
0:00:22.524794364 3064254 0xaaaae0d05b30 INFO GST_ERROR_SYSTEM gstelement.c:2298:gst_element_message_full_with_details: posted error message: Failed to create NvDsInferContext instance
0:00:22.526939742 3064254 0xaaaae0d05b30 INFO GST_PADS gstpad.c:1275:activate_mode_internal:pgie:sink failed to activate in push mode
0:00:22.526979775 3064254 0xaaaae0d05b30 WARN GST_PADS gstpad.c:1141:gst_pad_set_active:pgie:sink Failed to activate pad
0:00:22.527094725 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:3091:gst_element_change_state: have FAILURE change_state return
0:00:22.527112325 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2678:gst_element_abort_state: aborting state from READY to PAUSED
0:00:22.527156231 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2944:gst_bin_change_state_func: child ‘pgie’ failed to go to state 3(PAUSED)
0:00:22.531157790 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.531209728 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.531274083 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.531289316 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.532583711 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.532662691 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.535889334 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.536048701 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.536417390 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.536439759 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.536513778 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.536529715 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.537092909 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tee> completed state change to READY
0:00:22.537107086 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tee> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.542922327 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.542991706 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.543190691 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_osd> completed state change to READY
0:00:22.543210628 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_osd> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.543864098 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.543889187 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.544737066 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_converter> completed state change to READY
0:00:22.544863535 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_converter> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.545574480 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.545609329 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.545732503 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tiler> completed state change to READY
0:00:22.545751704 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tiler> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.545862557 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.545883806 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.545933952 3064254 0xffff60005180 INFO task gsttask.c:368:gst_task_func:<queue_checkpoint:src> Task going to paused
0:00:22.545988163 3064254 0xffff60005180 INFO task gsttask.c:370:gst_task_func:<queue_checkpoint:src> Task resume from paused
0:00:22.546043013 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_checkpoint> completed state change to READY
0:00:22.546057318 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_checkpoint> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.546546812 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.546571837 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.546665826 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tracker> completed state change to READY
0:00:22.546685955 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tracker> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:22.546710020 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.547201274 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<multiurisrcbin_creator> current READY pending VOID_PENDING, desired next READY
0:00:22.547231579 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<src_bin_muxer> current READY pending VOID_PENDING, desired next READY
0:00:22.547247068 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2597:gst_bin_element_set_state:<src_bin_muxer> skipping transition from READY to READY
0:00:22.547257757 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<multiurisrcbin_creator> child ‘src_bin_muxer’ changed state to 2(READY) successfully
0:00:22.547269629 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<multiurisrcbin_creator> completed state change to READY
0:00:22.547280862 3064254 0xaaaae0d05b30 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘multiurisrcbin_creator’ changed state to 2(READY) successfully
0:00:22.547289054 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to READY
0:00:22.547312159 3064254 0xaaaae0d05b30 INFO pipeline gstpipeline.c:533:gst_pipeline_change_state: pipeline is not live
0:00:22.547320416 3064254 0xaaaae0d05b30 INFO GST_STATES gstelement.c:3091:gst_element_change_state: have FAILURE change_state return
Unable to set the pipeline to the playing state.
0:00:22.555204295 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.555290699 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.555307724 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.555366511 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘sink’ changed state to 1(NULL) successfully
0:00:22.555386704 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581016897 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581086020 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581141767 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘msgbroker’ changed state to 1(NULL) successfully
0:00:22.581184169 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581212010 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581225899 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581243179 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue1’ changed state to 1(NULL) successfully
0:00:22.581262540 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581278893 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581291470 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581307566 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘msgconv’ changed state to 1(NULL) successfully
0:00:22.581324655 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581339728 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581351344 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581367441 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue2’ changed state to 1(NULL) successfully
0:00:22.581383218 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581398131 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581409747 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581425748 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tee’ changed state to 1(NULL) successfully
0:00:22.581442229 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tee> current READY pending VOID_PENDING, desired next NULL
0:00:22.581455605 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tee> completed state change to NULL
0:00:22.581467382 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tee> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581481142 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tee’ changed state to 1(NULL) successfully
0:00:22.581496375 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581510936 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581521720 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581535481 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘osd’ changed state to 1(NULL) successfully
0:00:22.581550650 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_osd> current READY pending VOID_PENDING, desired next NULL
0:00:22.581563802 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_osd> completed state change to NULL
0:00:22.581574715 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_osd> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581590235 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_osd’ changed state to 1(NULL) successfully
0:00:22.581605180 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581624509 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581635677 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581649662 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘converter’ changed state to 1(NULL) successfully
0:00:22.581665119 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_converter> current READY pending VOID_PENDING, desired next NULL
0:00:22.581678879 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_converter> completed state change to NULL
0:00:22.581689824 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_converter> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581716833 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_converter’ changed state to 1(NULL) successfully
0:00:22.581732610 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581747554 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581759523 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581773828 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tiler’ changed state to 1(NULL) successfully
0:00:22.581788708 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tiler> current READY pending VOID_PENDING, desired next NULL
0:00:22.581802757 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tiler> completed state change to NULL
0:00:22.581814278 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tiler> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581856295 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tiler’ changed state to 1(NULL) successfully
0:00:22.581872104 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581887465 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.581898761 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581912362 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘checkpoint’ changed state to 1(NULL) successfully
0:00:22.581927723 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_checkpoint> current READY pending VOID_PENDING, desired next NULL
0:00:22.581941899 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_checkpoint> completed state change to NULL
0:00:22.581953004 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_checkpoint> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.581967181 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_checkpoint’ changed state to 1(NULL) successfully
0:00:22.581982541 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.581995854 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.582007022 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.582020335 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘tracker’ changed state to 1(NULL) successfully
0:00:22.582035632 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<queue_tracker> current READY pending VOID_PENDING, desired next NULL
0:00:22.582049456 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<queue_tracker> completed state change to NULL
0:00:22.582060337 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<queue_tracker> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.582074321 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘queue_tracker’ changed state to 1(NULL) successfully
0:00:22.582090546 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.582112339 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.582123092 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.582136340 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘pgie’ changed state to 1(NULL) successfully
0:00:22.582149845 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:22.582337373 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<multiurisrcbin_creator> current READY pending VOID_PENDING, desired next NULL
0:00:22.582365599 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<src_bin_muxer> current READY pending VOID_PENDING, desired next NULL
0:00:22.586319507 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<src_bin_muxer> completed state change to NULL
0:00:22.586350869 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<src_bin_muxer> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.586382518 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<multiurisrcbin_creator> child ‘src_bin_muxer’ changed state to 1(NULL) successfully
0:00:22.586404407 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<multiurisrcbin_creator> completed state change to NULL
0:00:22.586415063 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<multiurisrcbin_creator> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.586435128 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘multiurisrcbin_creator’ changed state to 1(NULL) successfully
0:00:22.586448313 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.586459642 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.586475738 3064254 0xaaaae048d800 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func: child ‘multiurisrcbin’ changed state to 1(NULL) successfully
0:00:22.586731622 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2806:gst_element_continue_state: completed state change to NULL
0:00:22.586752743 3064254 0xaaaae048d800 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:22.589211799 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking osd:src(0xaaaae0bbfda0) and queue_tee:sink(0xaaaae0d06be0)
0:00:22.589308476 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked osd:src and queue_tee:sink
0:00:22.589336605 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking queue_tee:src(0xaaaae0d06e30) and tee:sink(0xaaaae0c34640)
0:00:22.589352157 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked queue_tee:src and tee:sink
0:00:22.589366366 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “queue_tee”
0:00:22.589417440 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose:<queue_tee> 0xaaaae0c198a0 dispose
0:00:22.589432321 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_tee> removing pad ‘sink’
0:00:22.589458690 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_tee> removing pad ‘src’
0:00:22.589473123 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose:<queue_tee> 0xaaaae0c198a0 parent class dispose
0:00:22.589502052 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize:<queue_tee> 0xaaaae0c198a0 finalize
0:00:22.589512805 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize:<queue_tee> 0xaaaae0c198a0 finalize parent
0:00:22.589530918 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking converter:src(0xaaaae0c343f0) and queue_osd:sink(0xaaaae0d06740)
0:00:22.589545990 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked converter:src and queue_osd:sink
0:00:22.589561319 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking queue_osd:src(0xaaaae0d06990) and osd:sink(0xaaaae0bbfb50)
0:00:22.589572936 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked queue_osd:src and osd:sink
0:00:22.589583496 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “queue_osd”
0:00:22.589599017 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose:<queue_osd> 0xaaaae0c195a0 dispose
0:00:22.589608777 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_osd> removing pad ‘sink’
0:00:22.589623338 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_osd> removing pad ‘src’
0:00:22.589637579 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose:<queue_osd> 0xaaaae0c195a0 parent class dispose
0:00:22.589648235 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize:<queue_osd> 0xaaaae0c195a0 finalize
0:00:22.589657867 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize:<queue_osd> 0xaaaae0c195a0 finalize parent
0:00:22.589673228 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking tiler:src(0xaaaae0bbf900) and queue_converter:sink(0xaaaae0d062a0)
0:00:22.589686317 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked tiler:src and queue_converter:sink
0:00:22.589700525 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking queue_converter:src(0xaaaae0d064f0) and converter:sink(0xaaaae0c341a0)
0:00:22.589712046 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked queue_converter:src and converter:sink
0:00:22.589722798 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “queue_converter”
0:00:22.589736399 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose:<queue_converter> 0xaaaae0c192a0 dispose
0:00:22.589745359 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_converter> removing pad ‘sink’
0:00:22.589758704 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_converter> removing pad ‘src’
0:00:22.589771889 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose:<queue_converter> 0xaaaae0c192a0 parent class dispose
0:00:22.589782289 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize:<queue_converter> 0xaaaae0c192a0 finalize
0:00:22.589791186 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize:<queue_converter> 0xaaaae0c192a0 finalize parent
0:00:22.589805010 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking checkpoint:src(0xaaaae0bbf460) and queue_tiler:sink(0xaaaae0c35d60)
0:00:22.589847860 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked checkpoint:src and queue_tiler:sink
0:00:22.589866005 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking queue_tiler:src(0xaaaae0d06050) and tiler:sink(0xaaaae0bbf6b0)
0:00:22.589878294 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked queue_tiler:src and tiler:sink
0:00:22.589889206 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “queue_tiler”
0:00:22.589902519 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose:<queue_tiler> 0xaaaae0c18fa0 dispose
0:00:22.589912951 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_tiler> removing pad ‘sink’
0:00:22.589928728 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_tiler> removing pad ‘src’
0:00:22.589941944 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose:<queue_tiler> 0xaaaae0c18fa0 parent class dispose
0:00:22.589952761 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize:<queue_tiler> 0xaaaae0c18fa0 finalize
0:00:22.589961945 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize:<queue_tiler> 0xaaaae0c18fa0 finalize parent
0:00:22.589976922 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking tracker:src(0xaaaae0bbe8d0) and queue_checkpoint:sink(0xaaaae0c358c0)
0:00:22.589989915 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked tracker:src and queue_checkpoint:sink
0:00:22.590004315 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking queue_checkpoint:src(0xaaaae0c35b10) and checkpoint:sink(0xaaaae0bbf210)
0:00:22.590015484 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked queue_checkpoint:src and checkpoint:sink
0:00:22.590025852 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “queue_checkpoint”
0:00:22.590038461 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose:<queue_checkpoint> 0xaaaae0c18ca0 dispose
0:00:22.590047293 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_checkpoint> removing pad ‘sink’
0:00:22.590060830 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_checkpoint> removing pad ‘src’
0:00:22.590074526 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose:<queue_checkpoint> 0xaaaae0c18ca0 parent class dispose
0:00:22.590084863 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize:<queue_checkpoint> 0xaaaae0c18ca0 finalize
0:00:22.590093919 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize:<queue_checkpoint> 0xaaaae0c18ca0 finalize parent
0:00:22.590107072 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking pgie:src(0xaaaae0bbe430) and queue_tracker:sink(0xaaaae0c35420)
0:00:22.590119296 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked pgie:src and queue_tracker:sink
0:00:22.590132577 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking queue_tracker:src(0xaaaae0c35670) and tracker:sink(0xaaaae0bbe680)
0:00:22.590144514 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked queue_tracker:src and tracker:sink
0:00:22.590154850 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “queue_tracker”
0:00:22.590166851 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose:<queue_tracker> 0xaaaae0c189a0 dispose
0:00:22.590176451 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_tracker> removing pad ‘sink’
0:00:22.590191684 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<queue_tracker> removing pad ‘src’
0:00:22.590204036 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose:<queue_tracker> 0xaaaae0c189a0 parent class dispose
0:00:22.590332202 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize:<queue_tracker> 0xaaaae0c189a0 finalize
0:00:22.590359083 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize:<queue_tracker> 0xaaaae0c189a0 finalize parent
0:00:22.590385453 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking queue1:src(0xaaaae0c34ae0) and sink:sink(0xaaaae0c351d0)
0:00:22.590405646 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked queue1:src and sink:sink
0:00:22.590419790 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “sink”
0:00:22.590460720 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0cffae0 dispose
0:00:22.590474545 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.590491601 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0cffae0 parent class dispose
0:00:22.590511058 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0cffae0 finalize
0:00:22.590521971 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0cffae0 finalize parent
0:00:22.590536756 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking tee:src_1(0xaaaae0754580) and queue2:sink(0xaaaae0c34d30)
0:00:22.590551316 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked tee:src_1 and queue2:sink
0:00:22.590567349 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking queue2:src(0xaaaae0c34f80) and msgconv:sink(0xaaaae0bbeb20)
0:00:22.590579061 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked queue2:src and msgconv:sink
0:00:22.590588950 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “queue2”
0:00:22.590603383 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0c186a0 dispose
0:00:22.590613143 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.590627096 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.590641112 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0c186a0 parent class dispose
0:00:22.590653177 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0c186a0 finalize
0:00:22.590662553 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0c186a0 finalize parent
0:00:22.590683514 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking tee:src_0(0xaaaae0754320) and queue1:sink(0xaaaae0c34890)
0:00:22.590697019 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked tee:src_0 and queue1:sink
0:00:22.590711836 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “queue1”
0:00:22.590724892 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0c183a0 dispose
0:00:22.590734109 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.590748541 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.590761374 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0c183a0 parent class dispose
0:00:22.590772030 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0c183a0 finalize
0:00:22.590781471 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0c183a0 finalize parent
0:00:22.590793855 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “tee”
0:00:22.590860738 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src_0’
0:00:22.590897764 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src_1’
0:00:22.590917765 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0cfa000 dispose
0:00:22.590929765 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.590945990 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0cfa000 parent class dispose
0:00:22.590957287 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0cfa000 finalize
0:00:22.590967271 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0cfa000 finalize parent
0:00:22.590982024 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “converter”
0:00:22.590995720 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0cf6280 dispose
0:00:22.591004937 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.591018506 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.591029674 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0cf6280 parent class dispose
0:00:22.591044843 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0cf6280 finalize
0:00:22.591053483 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0cf6280 finalize parent
0:00:22.591064716 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “osd”
0:00:22.591281206 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0c30c30 dispose
0:00:22.591302678 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.591324984 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.591342712 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0c30c30 parent class dispose
0:00:22.591383802 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0c30c30 finalize
0:00:22.591396283 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0c30c30 finalize parent
0:00:22.591413852 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “tiler”
0:00:22.591432412 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0c1be90 dispose
0:00:22.591445789 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.591459230 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.591475454 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0c1be90 parent class dispose
0:00:22.591487871 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0c1be90 finalize
0:00:22.591499423 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0c1be90 finalize parent
0:00:22.591514144 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “checkpoint”
0:00:22.591529345 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0c180a0 dispose
0:00:22.591540353 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.591555778 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.591570563 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0c180a0 parent class dispose
0:00:22.591582243 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0c180a0 finalize
0:00:22.591591812 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0c180a0 finalize parent
0:00:22.591612229 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking msgconv:src(0xaaaae0bbed70) and msgbroker:sink(0xaaaae0bbefc0)
0:00:22.591633990 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked msgconv:src and msgbroker:sink
0:00:22.591650310 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “msgbroker”
0:00:22.591666791 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0c13a90 dispose
0:00:22.591678312 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.591693960 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0c13a90 parent class dispose
0:00:22.591709289 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0c13a90 finalize
0:00:22.591720330 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0c13a90 finalize parent
0:00:22.591734826 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “msgconv”
0:00:22.591752363 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0c14250 dispose
0:00:22.591764108 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.591780108 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.591794925 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0c14250 parent class dispose
0:00:22.591807374 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0c14250 finalize
0:00:22.591817838 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0c14250 finalize parent
0:00:22.591832303 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “tracker”
0:00:22.591846767 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0c04c80 dispose
0:00:22.591857936 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.591872464 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.591886417 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0c04c80 parent class dispose
[NvMultiObjectTracker] De-initialized
0:00:22.791282935 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0c04c80 finalize
0:00:22.791352187 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0c04c80 finalize parent
0:00:22.795565563 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking multiurisrcbin:src(0xaaaae0752050) and pgie:sink(0xaaaae0bbe1e0)
0:00:22.796048337 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked multiurisrcbin:src and pgie:sink
0:00:22.796196183 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “pgie”
0:00:22.796398305 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae0bbcca0 dispose
0:00:22.796497573 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘sink’
0:00:22.796622571 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.797287209 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae0bbcca0 parent class dispose
0:00:22.797461553 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae0bbcca0 finalize
0:00:22.797488786 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae0bbcca0 finalize parent
0:00:22.798062189 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “multiurisrcbin”
0:00:22.798297879 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking multiurisrcbin_creator:src(0xaaaae0752a10) and src:proxypad0(0xaaaae07540d0)
0:00:22.798343993 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked multiurisrcbin_creator:src and src:proxypad0
0:00:22.798359386 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func: removed child “multiurisrcbin_creator”
0:00:22.798398812 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2137:gst_pad_unlink: unlinking src_bin_muxer:src(0xaaaae0d07770) and src:proxypad2(0xaaaae0754a50)
0:00:22.798413821 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstpad.c:2192:gst_pad_unlink: unlinked src_bin_muxer:src and src:proxypad2
0:00:22.798425565 3064254 0xaaaae048d800 INFO GST_PARENTAGE gstbin.c:1803:gst_bin_remove_func:<multiurisrcbin_creator> removed child “src_bin_muxer”
0:00:22.799277284 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose:<src_bin_muxer> 0xffff60014060 dispose
0:00:22.799426475 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<src_bin_muxer> removing pad ‘src’
0:00:22.799551664 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose:<src_bin_muxer> 0xffff60014060 parent class dispose
0:00:22.799581490 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize:<src_bin_muxer> 0xffff60014060 finalize
0:00:22.799737529 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize:<src_bin_muxer> 0xffff60014060 finalize parent
0:00:22.799835709 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose:<multiurisrcbin_creator> 0xffff60018030 dispose
0:00:22.799943682 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad:<multiurisrcbin_creator> removing pad ‘src’
0:00:22.800076936 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose:<multiurisrcbin_creator> 0xffff60018030 parent class dispose
0:00:22.800106954 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize:<multiurisrcbin_creator> 0xffff60018030 finalize
0:00:22.800119786 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize:<multiurisrcbin_creator> 0xffff60018030 finalize parent
0:00:22.800130347 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae073e3f0 dispose
0:00:22.800137835 3064254 0xaaaae048d800 INFO GST_ELEMENT_PADS gstelement.c:875:gst_element_remove_pad: removing pad ‘src’
0:00:22.800432089 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae073e3f0 parent class dispose
0:00:22.800467514 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae073e3f0 finalize
0:00:22.800556318 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae073e3f0 finalize parent
0:00:22.800588928 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3382:gst_element_dispose: 0xaaaae073e210 dispose
0:00:22.800747079 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3428:gst_element_dispose: 0xaaaae073e210 parent class dispose
0:00:22.800835243 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3460:gst_element_finalize: 0xaaaae073e210 finalize
0:00:22.800922383 3064254 0xaaaae048d800 INFO GST_REFCOUNTING gstelement.c:3465:gst_element_finalize: 0xaaaae073e210 finalize parent
Does this mean, SUCCESS?
