Hardware Platform (Jetson TX2 GPU)
• DeepStream Version:- 5.1
• JetPack Version:- 4.5.1
• TensorRT Version:- 7.1.3.0
**• How to reproduce the issue ? **
To reproduce go to deepstream-test4 and do make the file
Then give run the deepstream app as follows:
./deepstream-test4-app -i ../../../../samples/streams/test/coming\ to\ america\ \(all\ of\ the\ barbershop\ scenes\)\ 1080p\ hd.264 -p ../../../../../deepstream-5.1/lib/libnvds_kafka_proto.so --conn-str="localhost;9092;cropped_images" --no-display -s 0
the following is the error:
Using winsys: x11
Running...
ERROR from element nvmsg-broker: Could not configure supporting library.
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
unable to connect to broker library
Returned, stopping playback
Deleting pipeline
Kindly help me to solve this
bcao
June 29, 2021, 4:57am
#3
Sorry for the late, we will check internally
amycao
June 30, 2021, 5:30am
#5
Did you follow sources/libs/kafka_protocol_adaptor/README
to install kafka dependency and kafka broker?
@amycao Yes, I already installed kafka dependency and kafka broker by referring README document
amycao
July 1, 2021, 1:13am
#7
Please change the connection string accordingly
For Kafka - Connection string of format: host;port
additionally, you can enable logging for analysis. sources/tools/nvds_logger/setup_nvds_logger.sh
@amycao I will change the connection string as you mentioned and will check the result
@amycao I have tested as you said
./deepstream-test4-app -i ../../../../samples/streams/rajesh_face2.264 -p ../../../../../deepstream-5.1/lib/libnvds_kafka_proto.so --conn-str="iotk0.gluecktech.com;7200;cropped_images" --no-display -s 0
output:
Now playing: ../../../../samples/streams/rajesh_face2.264
Opening in BLOCKING MODE
%3|1625390749.492|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390749.492|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390749.492|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test4/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:02.835646134 13284 0x55b3f52950 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test4/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:02.835768119 13284 0x55b3f52950 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test4/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:02.835805719 13284 0x55b3f52950 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:29.365371854 13284 0x55b3f52950 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:29.471005278 13284 0x55b3f52950 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstest4_pgie_config.txt sucessfully
Running...
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Frame Number = 0 Vehicle Count = 0 Person Count = 0
Frame Number = 1 Vehicle Count = 0 Person Count = 0
Frame Number = 2 Vehicle Count = 0 Person Count = 0
Frame Number = 3 Vehicle Count = 0 Person Count = 0
Frame Number = 4 Vehicle Count = 0 Person Count = 0
Frame Number = 5 Vehicle Count = 0 Person Count = 0
Frame Number = 6 Vehicle Count = 0 Person Count = 1
Frame Number = 7 Vehicle Count = 0 Person Count = 0
Frame Number = 8 Vehicle Count = 0 Person Count = 0
Frame Number = 9 Vehicle Count = 0 Person Count = 1
Frame Number = 10 Vehicle Count = 0 Person Count = 1
Frame Number = 11 Vehicle Count = 0 Person Count = 1
Frame Number = 12 Vehicle Count = 0 Person Count = 0
Frame Number = 13 Vehicle Count = 0 Person Count = 0
Frame Number = 14 Vehicle Count = 0 Person Count = 0
Frame Number = 15 Vehicle Count = 0 Person Count = 1
Frame Number = 16 Vehicle Count = 0 Person Count = 1
Frame Number = 17 Vehicle Count = 0 Person Count = 0
Frame Number = 18 Vehicle Count = 0 Person Count = 1
Frame Number = 19 Vehicle Count = 0 Person Count = 1
Frame Number = 20 Vehicle Count = 0 Person Count = 1
Frame Number = 21 Vehicle Count = 0 Person Count = 0
Frame Number = 22 Vehicle Count = 0 Person Count = 0
Frame Number = 23 Vehicle Count = 0 Person Count = 1
%3|1625390778.427|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390778.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390778.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 24 Vehicle Count = 0 Person Count = 1
Frame Number = 25 Vehicle Count = 0 Person Count = 1
Frame Number = 26 Vehicle Count = 0 Person Count = 1
Frame Number = 27 Vehicle Count = 0 Person Count = 0
%3|1625390778.561|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390778.561|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390778.561|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 28 Vehicle Count = 0 Person Count = 0
Frame Number = 29 Vehicle Count = 0 Person Count = 0
Frame Number = 30 Vehicle Count = 0 Person Count = 0
Frame Number = 31 Vehicle Count = 0 Person Count = 0
Frame Number = 32 Vehicle Count = 0 Person Count = 0
Frame Number = 33 Vehicle Count = 0 Person Count = 0
Frame Number = 34 Vehicle Count = 0 Person Count = 0
Frame Number = 35 Vehicle Count = 0 Person Count = 0
Frame Number = 36 Vehicle Count = 0 Person Count = 0
Frame Number = 37 Vehicle Count = 0 Person Count = 0
Frame Number = 38 Vehicle Count = 0 Person Count = 0
Frame Number = 39 Vehicle Count = 0 Person Count = 0
Frame Number = 40 Vehicle Count = 0 Person Count = 0
Frame Number = 41 Vehicle Count = 0 Person Count = 0
Frame Number = 42 Vehicle Count = 0 Person Count = 0
Frame Number = 43 Vehicle Count = 0 Person Count = 0
Frame Number = 44 Vehicle Count = 0 Person Count = 0
Frame Number = 45 Vehicle Count = 0 Person Count = 0
Frame Number = 46 Vehicle Count = 0 Person Count = 0
Frame Number = 47 Vehicle Count = 0 Person Count = 0
Frame Number = 48 Vehicle Count = 0 Person Count = 0
Frame Number = 49 Vehicle Count = 0 Person Count = 0
Frame Number = 50 Vehicle Count = 0 Person Count = 0
Frame Number = 51 Vehicle Count = 0 Person Count = 0
Frame Number = 52 Vehicle Count = 0 Person Count = 1
Frame Number = 53 Vehicle Count = 0 Person Count = 1
%3|1625390779.425|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390779.425|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390779.425|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 54 Vehicle Count = 0 Person Count = 1
Frame Number = 55 Vehicle Count = 0 Person Count = 0
Frame Number = 56 Vehicle Count = 0 Person Count = 0
Frame Number = 57 Vehicle Count = 0 Person Count = 0
Frame Number = 58 Vehicle Count = 0 Person Count = 0
Frame Number = 59 Vehicle Count = 0 Person Count = 0
Frame Number = 60 Vehicle Count = 0 Person Count = 0
Frame Number = 61 Vehicle Count = 0 Person Count = 0
Frame Number = 62 Vehicle Count = 0 Person Count = 0
Frame Number = 63 Vehicle Count = 0 Person Count = 0
Frame Number = 64 Vehicle Count = 0 Person Count = 0
Frame Number = 65 Vehicle Count = 0 Person Count = 0
Frame Number = 66 Vehicle Count = 0 Person Count = 1
Frame Number = 67 Vehicle Count = 0 Person Count = 0
Frame Number = 68 Vehicle Count = 0 Person Count = 0
Frame Number = 69 Vehicle Count = 0 Person Count = 0
Frame Number = 70 Vehicle Count = 0 Person Count = 0
Frame Number = 71 Vehicle Count = 0 Person Count = 0
Frame Number = 72 Vehicle Count = 0 Person Count = 0
Frame Number = 73 Vehicle Count = 0 Person Count = 1
Frame Number = 74 Vehicle Count = 0 Person Count = 0
Frame Number = 75 Vehicle Count = 0 Person Count = 0
Frame Number = 76 Vehicle Count = 0 Person Count = 0
Frame Number = 77 Vehicle Count = 0 Person Count = 0
Frame Number = 78 Vehicle Count = 0 Person Count = 0
Frame Number = 79 Vehicle Count = 0 Person Count = 0
Frame Number = 80 Vehicle Count = 0 Person Count = 0
Frame Number = 81 Vehicle Count = 0 Person Count = 0
Frame Number = 82 Vehicle Count = 0 Person Count = 0
Frame Number = 83 Vehicle Count = 0 Person Count = 0
%3|1625390780.426|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390780.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390780.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 84 Vehicle Count = 0 Person Count = 0
Frame Number = 85 Vehicle Count = 0 Person Count = 0
Frame Number = 86 Vehicle Count = 0 Person Count = 0
Frame Number = 87 Vehicle Count = 0 Person Count = 0
Frame Number = 88 Vehicle Count = 0 Person Count = 0
Frame Number = 89 Vehicle Count = 0 Person Count = 0
Frame Number = 90 Vehicle Count = 0 Person Count = 0
Frame Number = 91 Vehicle Count = 0 Person Count = 0
Frame Number = 92 Vehicle Count = 0 Person Count = 0
Frame Number = 93 Vehicle Count = 0 Person Count = 0
Frame Number = 94 Vehicle Count = 0 Person Count = 0
Frame Number = 95 Vehicle Count = 0 Person Count = 0
Frame Number = 96 Vehicle Count = 0 Person Count = 0
Frame Number = 97 Vehicle Count = 0 Person Count = 0
Frame Number = 98 Vehicle Count = 0 Person Count = 0
Frame Number = 99 Vehicle Count = 0 Person Count = 0
Frame Number = 100 Vehicle Count = 0 Person Count = 0
Frame Number = 101 Vehicle Count = 0 Person Count = 0
Frame Number = 102 Vehicle Count = 0 Person Count = 0
Frame Number = 103 Vehicle Count = 0 Person Count = 0
Frame Number = 104 Vehicle Count = 0 Person Count = 0
Frame Number = 105 Vehicle Count = 0 Person Count = 0
Frame Number = 106 Vehicle Count = 0 Person Count = 0
Frame Number = 107 Vehicle Count = 0 Person Count = 0
Frame Number = 108 Vehicle Count = 0 Person Count = 0
Frame Number = 109 Vehicle Count = 0 Person Count = 0
Frame Number = 110 Vehicle Count = 0 Person Count = 0
Frame Number = 111 Vehicle Count = 0 Person Count = 0
Frame Number = 112 Vehicle Count = 0 Person Count = 0
Frame Number = 113 Vehicle Count = 0 Person Count = 0
%3|1625390781.424|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390781.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390781.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 114 Vehicle Count = 0 Person Count = 0
Frame Number = 115 Vehicle Count = 0 Person Count = 0
Frame Number = 116 Vehicle Count = 0 Person Count = 0
Frame Number = 117 Vehicle Count = 0 Person Count = 0
Frame Number = 118 Vehicle Count = 0 Person Count = 0
Frame Number = 119 Vehicle Count = 0 Person Count = 0
Frame Number = 120 Vehicle Count = 0 Person Count = 1
Frame Number = 121 Vehicle Count = 0 Person Count = 0
Frame Number = 122 Vehicle Count = 0 Person Count = 0
Frame Number = 123 Vehicle Count = 0 Person Count = 1
Frame Number = 124 Vehicle Count = 0 Person Count = 1
Frame Number = 125 Vehicle Count = 0 Person Count = 1
Frame Number = 126 Vehicle Count = 0 Person Count = 1
Frame Number = 127 Vehicle Count = 0 Person Count = 1
Frame Number = 128 Vehicle Count = 0 Person Count = 0
Frame Number = 129 Vehicle Count = 0 Person Count = 0
Frame Number = 130 Vehicle Count = 0 Person Count = 1
Frame Number = 131 Vehicle Count = 0 Person Count = 0
Frame Number = 132 Vehicle Count = 0 Person Count = 0
Frame Number = 133 Vehicle Count = 0 Person Count = 1
Frame Number = 134 Vehicle Count = 0 Person Count = 1
Frame Number = 135 Vehicle Count = 0 Person Count = 1
Frame Number = 136 Vehicle Count = 0 Person Count = 0
Frame Number = 137 Vehicle Count = 0 Person Count = 1
Frame Number = 138 Vehicle Count = 0 Person Count = 1
Frame Number = 139 Vehicle Count = 0 Person Count = 1
Frame Number = 140 Vehicle Count = 0 Person Count = 0
Frame Number = 141 Vehicle Count = 0 Person Count = 0
Frame Number = 142 Vehicle Count = 0 Person Count = 1
Frame Number = 143 Vehicle Count = 0 Person Count = 1
%3|1625390782.429|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390782.429|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390782.429|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 144 Vehicle Count = 0 Person Count = 1
Frame Number = 145 Vehicle Count = 0 Person Count = 0
Frame Number = 146 Vehicle Count = 0 Person Count = 1
Frame Number = 147 Vehicle Count = 0 Person Count = 0
Frame Number = 148 Vehicle Count = 0 Person Count = 0
Frame Number = 149 Vehicle Count = 0 Person Count = 1
Frame Number = 150 Vehicle Count = 0 Person Count = 1
Frame Number = 151 Vehicle Count = 0 Person Count = 0
Frame Number = 152 Vehicle Count = 0 Person Count = 0
Frame Number = 153 Vehicle Count = 0 Person Count = 0
Frame Number = 154 Vehicle Count = 0 Person Count = 0
Frame Number = 155 Vehicle Count = 0 Person Count = 0
Frame Number = 156 Vehicle Count = 0 Person Count = 0
Frame Number = 157 Vehicle Count = 0 Person Count = 0
Frame Number = 158 Vehicle Count = 0 Person Count = 0
Frame Number = 159 Vehicle Count = 0 Person Count = 0
Frame Number = 160 Vehicle Count = 0 Person Count = 0
Frame Number = 161 Vehicle Count = 0 Person Count = 0
Frame Number = 162 Vehicle Count = 0 Person Count = 0
Frame Number = 163 Vehicle Count = 0 Person Count = 1
Frame Number = 164 Vehicle Count = 0 Person Count = 1
Frame Number = 165 Vehicle Count = 0 Person Count = 1
Frame Number = 166 Vehicle Count = 0 Person Count = 1
Frame Number = 167 Vehicle Count = 0 Person Count = 1
Frame Number = 168 Vehicle Count = 0 Person Count = 0
Frame Number = 169 Vehicle Count = 0 Person Count = 0
Frame Number = 170 Vehicle Count = 0 Person Count = 0
Frame Number = 171 Vehicle Count = 0 Person Count = 0
Frame Number = 172 Vehicle Count = 0 Person Count = 0
Frame Number = 173 Vehicle Count = 0 Person Count = 0
%3|1625390783.427|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390783.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390783.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 174 Vehicle Count = 0 Person Count = 0
Frame Number = 175 Vehicle Count = 0 Person Count = 0
Frame Number = 176 Vehicle Count = 0 Person Count = 0
Frame Number = 177 Vehicle Count = 0 Person Count = 0
Frame Number = 178 Vehicle Count = 0 Person Count = 0
Frame Number = 179 Vehicle Count = 0 Person Count = 0
Frame Number = 180 Vehicle Count = 0 Person Count = 0
Frame Number = 181 Vehicle Count = 0 Person Count = 0
Frame Number = 182 Vehicle Count = 0 Person Count = 0
Frame Number = 183 Vehicle Count = 0 Person Count = 0
Frame Number = 184 Vehicle Count = 0 Person Count = 0
Frame Number = 185 Vehicle Count = 0 Person Count = 0
Frame Number = 186 Vehicle Count = 0 Person Count = 0
Frame Number = 187 Vehicle Count = 0 Person Count = 0
Frame Number = 188 Vehicle Count = 0 Person Count = 0
Frame Number = 189 Vehicle Count = 0 Person Count = 0
Frame Number = 190 Vehicle Count = 0 Person Count = 1
Frame Number = 191 Vehicle Count = 0 Person Count = 1
Frame Number = 192 Vehicle Count = 0 Person Count = 1
Frame Number = 193 Vehicle Count = 0 Person Count = 1
Frame Number = 194 Vehicle Count = 0 Person Count = 1
Frame Number = 195 Vehicle Count = 0 Person Count = 1
Frame Number = 196 Vehicle Count = 0 Person Count = 1
Frame Number = 197 Vehicle Count = 0 Person Count = 1
Frame Number = 198 Vehicle Count = 0 Person Count = 0
Frame Number = 199 Vehicle Count = 0 Person Count = 0
Frame Number = 200 Vehicle Count = 0 Person Count = 0
Frame Number = 201 Vehicle Count = 0 Person Count = 0
Frame Number = 202 Vehicle Count = 0 Person Count = 0
Frame Number = 203 Vehicle Count = 0 Person Count = 0
%3|1625390784.424|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390784.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390784.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 204 Vehicle Count = 0 Person Count = 0
Frame Number = 205 Vehicle Count = 0 Person Count = 0
Frame Number = 206 Vehicle Count = 0 Person Count = 0
Frame Number = 207 Vehicle Count = 0 Person Count = 0
Frame Number = 208 Vehicle Count = 0 Person Count = 0
Frame Number = 209 Vehicle Count = 0 Person Count = 0
Frame Number = 210 Vehicle Count = 0 Person Count = 0
Frame Number = 211 Vehicle Count = 0 Person Count = 0
Frame Number = 212 Vehicle Count = 0 Person Count = 0
Frame Number = 213 Vehicle Count = 0 Person Count = 0
Frame Number = 214 Vehicle Count = 0 Person Count = 0
Frame Number = 215 Vehicle Count = 0 Person Count = 0
Frame Number = 216 Vehicle Count = 0 Person Count = 0
Frame Number = 217 Vehicle Count = 0 Person Count = 0
Frame Number = 218 Vehicle Count = 0 Person Count = 0
Frame Number = 219 Vehicle Count = 0 Person Count = 0
Frame Number = 220 Vehicle Count = 0 Person Count = 0
Frame Number = 221 Vehicle Count = 0 Person Count = 1
Frame Number = 222 Vehicle Count = 0 Person Count = 0
Frame Number = 223 Vehicle Count = 0 Person Count = 0
Frame Number = 224 Vehicle Count = 0 Person Count = 1
Frame Number = 225 Vehicle Count = 0 Person Count = 1
Frame Number = 226 Vehicle Count = 0 Person Count = 1
Frame Number = 227 Vehicle Count = 0 Person Count = 0
Frame Number = 228 Vehicle Count = 0 Person Count = 0
Frame Number = 229 Vehicle Count = 0 Person Count = 0
Frame Number = 230 Vehicle Count = 0 Person Count = 0
Frame Number = 231 Vehicle Count = 0 Person Count = 1
Frame Number = 232 Vehicle Count = 0 Person Count = 0
Frame Number = 233 Vehicle Count = 0 Person Count = 0
%3|1625390785.427|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390785.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390785.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 234 Vehicle Count = 0 Person Count = 0
Frame Number = 235 Vehicle Count = 0 Person Count = 0
Frame Number = 236 Vehicle Count = 0 Person Count = 0
Frame Number = 237 Vehicle Count = 0 Person Count = 0
Frame Number = 238 Vehicle Count = 0 Person Count = 0
Frame Number = 239 Vehicle Count = 0 Person Count = 0
Frame Number = 240 Vehicle Count = 0 Person Count = 0
Frame Number = 241 Vehicle Count = 0 Person Count = 0
Frame Number = 242 Vehicle Count = 0 Person Count = 0
Frame Number = 243 Vehicle Count = 0 Person Count = 0
Frame Number = 244 Vehicle Count = 0 Person Count = 0
Frame Number = 245 Vehicle Count = 0 Person Count = 0
Frame Number = 246 Vehicle Count = 0 Person Count = 0
Frame Number = 247 Vehicle Count = 0 Person Count = 0
Frame Number = 248 Vehicle Count = 0 Person Count = 0
Frame Number = 249 Vehicle Count = 0 Person Count = 0
Frame Number = 250 Vehicle Count = 0 Person Count = 0
Frame Number = 251 Vehicle Count = 0 Person Count = 0
Frame Number = 252 Vehicle Count = 0 Person Count = 0
Frame Number = 253 Vehicle Count = 0 Person Count = 0
Frame Number = 254 Vehicle Count = 0 Person Count = 0
Frame Number = 255 Vehicle Count = 0 Person Count = 0
Frame Number = 256 Vehicle Count = 0 Person Count = 0
Frame Number = 257 Vehicle Count = 0 Person Count = 0
Frame Number = 258 Vehicle Count = 0 Person Count = 0
Frame Number = 259 Vehicle Count = 0 Person Count = 0
Frame Number = 260 Vehicle Count = 0 Person Count = 0
Frame Number = 261 Vehicle Count = 0 Person Count = 0
Frame Number = 262 Vehicle Count = 0 Person Count = 0
%3|1625390786.417|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390786.417|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390786.417|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 263 Vehicle Count = 0 Person Count = 0
Frame Number = 264 Vehicle Count = 0 Person Count = 0
Frame Number = 265 Vehicle Count = 0 Person Count = 0
Frame Number = 266 Vehicle Count = 0 Person Count = 0
Frame Number = 267 Vehicle Count = 0 Person Count = 0
Frame Number = 268 Vehicle Count = 0 Person Count = 0
Frame Number = 269 Vehicle Count = 0 Person Count = 0
Frame Number = 270 Vehicle Count = 0 Person Count = 0
Frame Number = 271 Vehicle Count = 0 Person Count = 0
Frame Number = 272 Vehicle Count = 0 Person Count = 0
Frame Number = 273 Vehicle Count = 0 Person Count = 0
Frame Number = 274 Vehicle Count = 0 Person Count = 0
Frame Number = 275 Vehicle Count = 0 Person Count = 0
Frame Number = 276 Vehicle Count = 0 Person Count = 1
Frame Number = 277 Vehicle Count = 0 Person Count = 1
Frame Number = 278 Vehicle Count = 0 Person Count = 0
Frame Number = 279 Vehicle Count = 0 Person Count = 1
Frame Number = 280 Vehicle Count = 0 Person Count = 1
Frame Number = 281 Vehicle Count = 0 Person Count = 1
Frame Number = 282 Vehicle Count = 0 Person Count = 1
Frame Number = 283 Vehicle Count = 0 Person Count = 0
Frame Number = 284 Vehicle Count = 0 Person Count = 0
Frame Number = 285 Vehicle Count = 0 Person Count = 0
Frame Number = 286 Vehicle Count = 0 Person Count = 0
Frame Number = 287 Vehicle Count = 0 Person Count = 0
Frame Number = 288 Vehicle Count = 0 Person Count = 0
Frame Number = 289 Vehicle Count = 0 Person Count = 0
Frame Number = 290 Vehicle Count = 0 Person Count = 0
Frame Number = 291 Vehicle Count = 0 Person Count = 0
Frame Number = 292 Vehicle Count = 0 Person Count = 0
Frame Number = 293 Vehicle Count = 0 Person Count = 0
%3|1625390787.423|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390787.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390787.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 294 Vehicle Count = 0 Person Count = 0
Frame Number = 295 Vehicle Count = 0 Person Count = 0
Frame Number = 296 Vehicle Count = 0 Person Count = 0
Frame Number = 297 Vehicle Count = 0 Person Count = 0
Frame Number = 298 Vehicle Count = 0 Person Count = 0
Frame Number = 299 Vehicle Count = 0 Person Count = 0
Frame Number = 300 Vehicle Count = 0 Person Count = 0
Frame Number = 301 Vehicle Count = 0 Person Count = 0
Frame Number = 302 Vehicle Count = 0 Person Count = 0
Frame Number = 303 Vehicle Count = 0 Person Count = 0
Frame Number = 304 Vehicle Count = 0 Person Count = 0
Frame Number = 305 Vehicle Count = 0 Person Count = 1
Frame Number = 306 Vehicle Count = 0 Person Count = 1
Frame Number = 307 Vehicle Count = 0 Person Count = 1
Frame Number = 308 Vehicle Count = 0 Person Count = 1
Frame Number = 309 Vehicle Count = 0 Person Count = 1
Frame Number = 310 Vehicle Count = 0 Person Count = 1
Frame Number = 311 Vehicle Count = 0 Person Count = 1
Frame Number = 312 Vehicle Count = 0 Person Count = 1
Frame Number = 313 Vehicle Count = 0 Person Count = 0
Frame Number = 314 Vehicle Count = 0 Person Count = 0
Frame Number = 315 Vehicle Count = 0 Person Count = 0
Frame Number = 316 Vehicle Count = 0 Person Count = 0
Frame Number = 317 Vehicle Count = 0 Person Count = 0
Frame Number = 318 Vehicle Count = 0 Person Count = 0
Frame Number = 319 Vehicle Count = 0 Person Count = 0
Frame Number = 320 Vehicle Count = 0 Person Count = 0
Frame Number = 321 Vehicle Count = 0 Person Count = 0
Frame Number = 322 Vehicle Count = 0 Person Count = 0
Frame Number = 323 Vehicle Count = 0 Person Count = 0
%3|1625390788.428|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390788.429|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390788.430|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 324 Vehicle Count = 0 Person Count = 0
Frame Number = 325 Vehicle Count = 0 Person Count = 1
Frame Number = 326 Vehicle Count = 0 Person Count = 1
Frame Number = 327 Vehicle Count = 0 Person Count = 1
Frame Number = 328 Vehicle Count = 0 Person Count = 0
Frame Number = 329 Vehicle Count = 0 Person Count = 1
Frame Number = 330 Vehicle Count = 0 Person Count = 0
Frame Number = 331 Vehicle Count = 0 Person Count = 0
Frame Number = 332 Vehicle Count = 0 Person Count = 0
Frame Number = 333 Vehicle Count = 0 Person Count = 0
Frame Number = 334 Vehicle Count = 0 Person Count = 0
Frame Number = 335 Vehicle Count = 0 Person Count = 0
Frame Number = 336 Vehicle Count = 0 Person Count = 0
Frame Number = 337 Vehicle Count = 0 Person Count = 0
Frame Number = 338 Vehicle Count = 0 Person Count = 0
Frame Number = 339 Vehicle Count = 0 Person Count = 0
Frame Number = 340 Vehicle Count = 0 Person Count = 1
Frame Number = 341 Vehicle Count = 0 Person Count = 0
Frame Number = 342 Vehicle Count = 0 Person Count = 1
Frame Number = 343 Vehicle Count = 0 Person Count = 0
Frame Number = 344 Vehicle Count = 0 Person Count = 0
Frame Number = 345 Vehicle Count = 0 Person Count = 0
Frame Number = 346 Vehicle Count = 0 Person Count = 1
Frame Number = 347 Vehicle Count = 0 Person Count = 1
Frame Number = 348 Vehicle Count = 0 Person Count = 1
Frame Number = 349 Vehicle Count = 0 Person Count = 1
Frame Number = 350 Vehicle Count = 0 Person Count = 1
Frame Number = 351 Vehicle Count = 0 Person Count = 1
Frame Number = 352 Vehicle Count = 0 Person Count = 1
Frame Number = 353 Vehicle Count = 0 Person Count = 0
%3|1625390789.427|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390789.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390789.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 354 Vehicle Count = 0 Person Count = 1
Frame Number = 355 Vehicle Count = 0 Person Count = 0
Frame Number = 356 Vehicle Count = 0 Person Count = 0
Frame Number = 357 Vehicle Count = 0 Person Count = 0
Frame Number = 358 Vehicle Count = 0 Person Count = 0
Frame Number = 359 Vehicle Count = 0 Person Count = 0
Frame Number = 360 Vehicle Count = 0 Person Count = 0
Frame Number = 361 Vehicle Count = 0 Person Count = 1
Frame Number = 362 Vehicle Count = 0 Person Count = 0
Frame Number = 363 Vehicle Count = 0 Person Count = 0
Frame Number = 364 Vehicle Count = 0 Person Count = 0
Frame Number = 365 Vehicle Count = 0 Person Count = 1
Frame Number = 366 Vehicle Count = 0 Person Count = 0
Frame Number = 367 Vehicle Count = 0 Person Count = 1
Frame Number = 368 Vehicle Count = 0 Person Count = 0
Frame Number = 369 Vehicle Count = 0 Person Count = 0
Frame Number = 370 Vehicle Count = 0 Person Count = 0
Frame Number = 371 Vehicle Count = 0 Person Count = 1
Frame Number = 372 Vehicle Count = 0 Person Count = 1
Frame Number = 373 Vehicle Count = 0 Person Count = 1
Frame Number = 374 Vehicle Count = 0 Person Count = 1
Frame Number = 375 Vehicle Count = 0 Person Count = 1
Frame Number = 376 Vehicle Count = 0 Person Count = 1
Frame Number = 377 Vehicle Count = 0 Person Count = 1
Frame Number = 378 Vehicle Count = 0 Person Count = 0
Frame Number = 379 Vehicle Count = 0 Person Count = 1
Frame Number = 380 Vehicle Count = 0 Person Count = 0
Frame Number = 381 Vehicle Count = 0 Person Count = 1
Frame Number = 382 Vehicle Count = 0 Person Count = 1
Frame Number = 383 Vehicle Count = 0 Person Count = 0
%3|1625390790.424|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390790.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390790.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 384 Vehicle Count = 0 Person Count = 0
Frame Number = 385 Vehicle Count = 0 Person Count = 0
Frame Number = 386 Vehicle Count = 0 Person Count = 0
Frame Number = 387 Vehicle Count = 0 Person Count = 0
Frame Number = 388 Vehicle Count = 0 Person Count = 0
Frame Number = 389 Vehicle Count = 0 Person Count = 1
Frame Number = 390 Vehicle Count = 0 Person Count = 1
Frame Number = 391 Vehicle Count = 0 Person Count = 1
Frame Number = 392 Vehicle Count = 0 Person Count = 1
Frame Number = 393 Vehicle Count = 0 Person Count = 0
Frame Number = 394 Vehicle Count = 0 Person Count = 1
Frame Number = 395 Vehicle Count = 0 Person Count = 0
Frame Number = 396 Vehicle Count = 0 Person Count = 0
Frame Number = 397 Vehicle Count = 0 Person Count = 0
Frame Number = 398 Vehicle Count = 0 Person Count = 0
Frame Number = 399 Vehicle Count = 0 Person Count = 0
Frame Number = 400 Vehicle Count = 0 Person Count = 0
Frame Number = 401 Vehicle Count = 0 Person Count = 1
Frame Number = 402 Vehicle Count = 0 Person Count = 0
Frame Number = 403 Vehicle Count = 0 Person Count = 0
Frame Number = 404 Vehicle Count = 0 Person Count = 0
Frame Number = 405 Vehicle Count = 0 Person Count = 0
Frame Number = 406 Vehicle Count = 0 Person Count = 0
Frame Number = 407 Vehicle Count = 0 Person Count = 0
Frame Number = 408 Vehicle Count = 0 Person Count = 0
Frame Number = 409 Vehicle Count = 0 Person Count = 0
Frame Number = 410 Vehicle Count = 0 Person Count = 1
Frame Number = 411 Vehicle Count = 0 Person Count = 0
Frame Number = 412 Vehicle Count = 0 Person Count = 0
Frame Number = 413 Vehicle Count = 0 Person Count = 0
%3|1625390791.426|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390791.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390791.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 414 Vehicle Count = 0 Person Count = 0
Frame Number = 415 Vehicle Count = 0 Person Count = 0
Frame Number = 416 Vehicle Count = 0 Person Count = 0
Frame Number = 417 Vehicle Count = 0 Person Count = 0
Frame Number = 418 Vehicle Count = 0 Person Count = 0
Frame Number = 419 Vehicle Count = 0 Person Count = 0
Frame Number = 420 Vehicle Count = 0 Person Count = 0
Frame Number = 421 Vehicle Count = 0 Person Count = 0
Frame Number = 422 Vehicle Count = 0 Person Count = 0
Frame Number = 423 Vehicle Count = 0 Person Count = 0
Frame Number = 424 Vehicle Count = 0 Person Count = 0
Frame Number = 425 Vehicle Count = 0 Person Count = 0
Frame Number = 426 Vehicle Count = 0 Person Count = 0
Frame Number = 427 Vehicle Count = 0 Person Count = 0
Frame Number = 428 Vehicle Count = 0 Person Count = 0
Frame Number = 429 Vehicle Count = 0 Person Count = 0
Frame Number = 430 Vehicle Count = 0 Person Count = 0
Frame Number = 431 Vehicle Count = 0 Person Count = 0
Frame Number = 432 Vehicle Count = 0 Person Count = 0
Frame Number = 433 Vehicle Count = 0 Person Count = 0
Frame Number = 434 Vehicle Count = 0 Person Count = 0
Frame Number = 435 Vehicle Count = 0 Person Count = 0
Frame Number = 436 Vehicle Count = 0 Person Count = 0
Frame Number = 437 Vehicle Count = 0 Person Count = 0
Frame Number = 438 Vehicle Count = 0 Person Count = 0
Frame Number = 439 Vehicle Count = 0 Person Count = 0
Frame Number = 440 Vehicle Count = 0 Person Count = 0
Frame Number = 441 Vehicle Count = 0 Person Count = 0
Frame Number = 442 Vehicle Count = 0 Person Count = 0
Frame Number = 443 Vehicle Count = 0 Person Count = 0
%3|1625390792.428|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390792.428|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390792.428|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 444 Vehicle Count = 0 Person Count = 0
Frame Number = 445 Vehicle Count = 0 Person Count = 0
Frame Number = 446 Vehicle Count = 0 Person Count = 0
Frame Number = 447 Vehicle Count = 0 Person Count = 0
Frame Number = 448 Vehicle Count = 0 Person Count = 0
Frame Number = 449 Vehicle Count = 0 Person Count = 0
Frame Number = 450 Vehicle Count = 0 Person Count = 0
Frame Number = 451 Vehicle Count = 0 Person Count = 0
Frame Number = 452 Vehicle Count = 0 Person Count = 0
Frame Number = 453 Vehicle Count = 0 Person Count = 0
Frame Number = 454 Vehicle Count = 0 Person Count = 0
Frame Number = 455 Vehicle Count = 0 Person Count = 0
Frame Number = 456 Vehicle Count = 0 Person Count = 1
Frame Number = 457 Vehicle Count = 0 Person Count = 1
Frame Number = 458 Vehicle Count = 0 Person Count = 1
Frame Number = 459 Vehicle Count = 0 Person Count = 0
Frame Number = 460 Vehicle Count = 0 Person Count = 0
Frame Number = 461 Vehicle Count = 0 Person Count = 0
Frame Number = 462 Vehicle Count = 0 Person Count = 0
Frame Number = 463 Vehicle Count = 0 Person Count = 0
Frame Number = 464 Vehicle Count = 0 Person Count = 0
Frame Number = 465 Vehicle Count = 0 Person Count = 0
Frame Number = 466 Vehicle Count = 0 Person Count = 0
Frame Number = 467 Vehicle Count = 0 Person Count = 0
Frame Number = 468 Vehicle Count = 0 Person Count = 0
Frame Number = 469 Vehicle Count = 0 Person Count = 0
Frame Number = 470 Vehicle Count = 0 Person Count = 0
Frame Number = 471 Vehicle Count = 0 Person Count = 0
Frame Number = 472 Vehicle Count = 0 Person Count = 0
Frame Number = 473 Vehicle Count = 0 Person Count = 0
%3|1625390793.432|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390793.432|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390793.432|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 474 Vehicle Count = 0 Person Count = 0
Frame Number = 475 Vehicle Count = 0 Person Count = 0
Frame Number = 476 Vehicle Count = 0 Person Count = 0
Frame Number = 477 Vehicle Count = 0 Person Count = 0
Frame Number = 478 Vehicle Count = 0 Person Count = 0
Frame Number = 479 Vehicle Count = 0 Person Count = 0
Frame Number = 480 Vehicle Count = 0 Person Count = 0
Frame Number = 481 Vehicle Count = 0 Person Count = 0
Frame Number = 482 Vehicle Count = 0 Person Count = 0
Frame Number = 483 Vehicle Count = 0 Person Count = 0
Frame Number = 484 Vehicle Count = 0 Person Count = 0
Frame Number = 485 Vehicle Count = 0 Person Count = 0
Frame Number = 486 Vehicle Count = 0 Person Count = 0
Frame Number = 487 Vehicle Count = 0 Person Count = 1
Frame Number = 488 Vehicle Count = 0 Person Count = 1
Frame Number = 489 Vehicle Count = 0 Person Count = 1
Frame Number = 490 Vehicle Count = 0 Person Count = 0
Frame Number = 491 Vehicle Count = 0 Person Count = 0
Frame Number = 492 Vehicle Count = 0 Person Count = 1
Frame Number = 493 Vehicle Count = 0 Person Count = 1
Frame Number = 494 Vehicle Count = 0 Person Count = 1
Frame Number = 495 Vehicle Count = 0 Person Count = 1
Frame Number = 496 Vehicle Count = 0 Person Count = 1
Frame Number = 497 Vehicle Count = 0 Person Count = 1
Frame Number = 498 Vehicle Count = 0 Person Count = 1
Frame Number = 499 Vehicle Count = 0 Person Count = 1
Frame Number = 500 Vehicle Count = 0 Person Count = 1
Frame Number = 501 Vehicle Count = 0 Person Count = 1
Frame Number = 502 Vehicle Count = 0 Person Count = 0
Frame Number = 503 Vehicle Count = 0 Person Count = 0
%3|1625390794.429|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390794.429|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390794.429|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 504 Vehicle Count = 0 Person Count = 0
Frame Number = 505 Vehicle Count = 0 Person Count = 0
Frame Number = 506 Vehicle Count = 0 Person Count = 0
Frame Number = 507 Vehicle Count = 0 Person Count = 0
Frame Number = 508 Vehicle Count = 0 Person Count = 1
Frame Number = 509 Vehicle Count = 0 Person Count = 1
Frame Number = 510 Vehicle Count = 0 Person Count = 0
Frame Number = 511 Vehicle Count = 0 Person Count = 0
Frame Number = 512 Vehicle Count = 0 Person Count = 1
Frame Number = 513 Vehicle Count = 0 Person Count = 1
Frame Number = 514 Vehicle Count = 0 Person Count = 1
Frame Number = 515 Vehicle Count = 0 Person Count = 0
Frame Number = 516 Vehicle Count = 0 Person Count = 1
Frame Number = 517 Vehicle Count = 0 Person Count = 1
Frame Number = 518 Vehicle Count = 0 Person Count = 1
Frame Number = 519 Vehicle Count = 0 Person Count = 1
Frame Number = 520 Vehicle Count = 0 Person Count = 1
Frame Number = 521 Vehicle Count = 0 Person Count = 1
Frame Number = 522 Vehicle Count = 0 Person Count = 0
Frame Number = 523 Vehicle Count = 0 Person Count = 0
Frame Number = 524 Vehicle Count = 0 Person Count = 0
Frame Number = 525 Vehicle Count = 0 Person Count = 0
Frame Number = 526 Vehicle Count = 0 Person Count = 0
Frame Number = 527 Vehicle Count = 0 Person Count = 0
Frame Number = 528 Vehicle Count = 0 Person Count = 0
Frame Number = 529 Vehicle Count = 0 Person Count = 0
Frame Number = 530 Vehicle Count = 0 Person Count = 0
Frame Number = 531 Vehicle Count = 0 Person Count = 0
Frame Number = 532 Vehicle Count = 0 Person Count = 0
Frame Number = 533 Vehicle Count = 0 Person Count = 0
%3|1625390795.429|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390795.429|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390795.429|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 534 Vehicle Count = 0 Person Count = 0
Frame Number = 535 Vehicle Count = 0 Person Count = 0
Frame Number = 536 Vehicle Count = 0 Person Count = 0
Frame Number = 537 Vehicle Count = 0 Person Count = 0
Frame Number = 538 Vehicle Count = 0 Person Count = 0
Frame Number = 539 Vehicle Count = 0 Person Count = 0
Frame Number = 540 Vehicle Count = 0 Person Count = 0
Frame Number = 541 Vehicle Count = 0 Person Count = 0
Frame Number = 542 Vehicle Count = 0 Person Count = 0
Frame Number = 543 Vehicle Count = 0 Person Count = 1
Frame Number = 544 Vehicle Count = 0 Person Count = 0
Frame Number = 545 Vehicle Count = 0 Person Count = 0
Frame Number = 546 Vehicle Count = 0 Person Count = 0
Frame Number = 547 Vehicle Count = 0 Person Count = 0
Frame Number = 548 Vehicle Count = 0 Person Count = 0
Frame Number = 549 Vehicle Count = 0 Person Count = 0
Frame Number = 550 Vehicle Count = 0 Person Count = 0
Frame Number = 551 Vehicle Count = 0 Person Count = 0
Frame Number = 552 Vehicle Count = 0 Person Count = 0
Frame Number = 553 Vehicle Count = 0 Person Count = 0
Frame Number = 554 Vehicle Count = 0 Person Count = 0
Frame Number = 555 Vehicle Count = 0 Person Count = 0
Frame Number = 556 Vehicle Count = 0 Person Count = 0
Frame Number = 557 Vehicle Count = 0 Person Count = 0
Frame Number = 558 Vehicle Count = 0 Person Count = 0
Frame Number = 559 Vehicle Count = 0 Person Count = 0
Frame Number = 560 Vehicle Count = 0 Person Count = 0
Frame Number = 561 Vehicle Count = 0 Person Count = 0
Frame Number = 562 Vehicle Count = 0 Person Count = 0
Frame Number = 563 Vehicle Count = 0 Person Count = 0
%3|1625390796.427|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390796.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390796.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 564 Vehicle Count = 0 Person Count = 0
Frame Number = 565 Vehicle Count = 0 Person Count = 0
Frame Number = 566 Vehicle Count = 0 Person Count = 0
Frame Number = 567 Vehicle Count = 0 Person Count = 0
Frame Number = 568 Vehicle Count = 0 Person Count = 0
Frame Number = 569 Vehicle Count = 0 Person Count = 0
Frame Number = 570 Vehicle Count = 0 Person Count = 0
Frame Number = 571 Vehicle Count = 0 Person Count = 0
Frame Number = 572 Vehicle Count = 0 Person Count = 0
Frame Number = 573 Vehicle Count = 0 Person Count = 0
Frame Number = 574 Vehicle Count = 0 Person Count = 0
Frame Number = 575 Vehicle Count = 0 Person Count = 0
Frame Number = 576 Vehicle Count = 0 Person Count = 0
Frame Number = 577 Vehicle Count = 0 Person Count = 0
Frame Number = 578 Vehicle Count = 0 Person Count = 0
Frame Number = 579 Vehicle Count = 0 Person Count = 0
Frame Number = 580 Vehicle Count = 0 Person Count = 0
Frame Number = 581 Vehicle Count = 0 Person Count = 0
Frame Number = 582 Vehicle Count = 0 Person Count = 0
Frame Number = 583 Vehicle Count = 0 Person Count = 0
Frame Number = 584 Vehicle Count = 0 Person Count = 0
Frame Number = 585 Vehicle Count = 0 Person Count = 0
Frame Number = 586 Vehicle Count = 0 Person Count = 0
Frame Number = 587 Vehicle Count = 0 Person Count = 0
Frame Number = 588 Vehicle Count = 0 Person Count = 0
Frame Number = 589 Vehicle Count = 0 Person Count = 0
Frame Number = 590 Vehicle Count = 0 Person Count = 0
Frame Number = 591 Vehicle Count = 0 Person Count = 0
Frame Number = 592 Vehicle Count = 0 Person Count = 0
Frame Number = 593 Vehicle Count = 0 Person Count = 0
%3|1625390797.426|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390797.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390797.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 594 Vehicle Count = 0 Person Count = 0
Frame Number = 595 Vehicle Count = 0 Person Count = 0
Frame Number = 596 Vehicle Count = 0 Person Count = 0
Frame Number = 597 Vehicle Count = 0 Person Count = 0
Frame Number = 598 Vehicle Count = 0 Person Count = 0
Frame Number = 599 Vehicle Count = 0 Person Count = 0
Frame Number = 600 Vehicle Count = 0 Person Count = 0
Frame Number = 601 Vehicle Count = 0 Person Count = 0
Frame Number = 602 Vehicle Count = 0 Person Count = 0
Frame Number = 603 Vehicle Count = 0 Person Count = 0
Frame Number = 604 Vehicle Count = 0 Person Count = 0
Frame Number = 605 Vehicle Count = 0 Person Count = 0
Frame Number = 606 Vehicle Count = 0 Person Count = 0
Frame Number = 607 Vehicle Count = 0 Person Count = 0
Frame Number = 608 Vehicle Count = 0 Person Count = 0
Frame Number = 609 Vehicle Count = 0 Person Count = 0
Frame Number = 610 Vehicle Count = 0 Person Count = 0
Frame Number = 611 Vehicle Count = 0 Person Count = 0
Frame Number = 612 Vehicle Count = 0 Person Count = 0
Frame Number = 613 Vehicle Count = 0 Person Count = 0
Frame Number = 614 Vehicle Count = 0 Person Count = 0
Frame Number = 615 Vehicle Count = 0 Person Count = 0
Frame Number = 616 Vehicle Count = 0 Person Count = 0
Frame Number = 617 Vehicle Count = 0 Person Count = 0
Frame Number = 618 Vehicle Count = 0 Person Count = 0
Frame Number = 619 Vehicle Count = 0 Person Count = 1
Frame Number = 620 Vehicle Count = 0 Person Count = 1
Frame Number = 621 Vehicle Count = 0 Person Count = 1
Frame Number = 622 Vehicle Count = 0 Person Count = 0
Frame Number = 623 Vehicle Count = 0 Person Count = 0
%3|1625390798.425|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390798.425|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390798.425|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 624 Vehicle Count = 0 Person Count = 0
Frame Number = 625 Vehicle Count = 0 Person Count = 0
Frame Number = 626 Vehicle Count = 0 Person Count = 0
Frame Number = 627 Vehicle Count = 0 Person Count = 0
Frame Number = 628 Vehicle Count = 0 Person Count = 0
Frame Number = 629 Vehicle Count = 0 Person Count = 0
Frame Number = 630 Vehicle Count = 0 Person Count = 0
Frame Number = 631 Vehicle Count = 0 Person Count = 0
Frame Number = 632 Vehicle Count = 0 Person Count = 0
Frame Number = 633 Vehicle Count = 0 Person Count = 0
Frame Number = 634 Vehicle Count = 0 Person Count = 0
Frame Number = 635 Vehicle Count = 0 Person Count = 0
Frame Number = 636 Vehicle Count = 0 Person Count = 0
Frame Number = 637 Vehicle Count = 0 Person Count = 0
Frame Number = 638 Vehicle Count = 0 Person Count = 0
Frame Number = 639 Vehicle Count = 0 Person Count = 0
Frame Number = 640 Vehicle Count = 0 Person Count = 0
Frame Number = 641 Vehicle Count = 0 Person Count = 0
Frame Number = 642 Vehicle Count = 0 Person Count = 0
Frame Number = 643 Vehicle Count = 0 Person Count = 1
Frame Number = 644 Vehicle Count = 0 Person Count = 0
Frame Number = 645 Vehicle Count = 0 Person Count = 0
Frame Number = 646 Vehicle Count = 0 Person Count = 0
Frame Number = 647 Vehicle Count = 0 Person Count = 0
Frame Number = 648 Vehicle Count = 0 Person Count = 0
Frame Number = 649 Vehicle Count = 0 Person Count = 0
Frame Number = 650 Vehicle Count = 0 Person Count = 0
Frame Number = 651 Vehicle Count = 0 Person Count = 1
Frame Number = 652 Vehicle Count = 0 Person Count = 1
Frame Number = 653 Vehicle Count = 0 Person Count = 1
%3|1625390799.425|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390799.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390799.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Frame Number = 654 Vehicle Count = 0 Person Count = 1
Frame Number = 655 Vehicle Count = 0 Person Count = 1
Frame Number = 656 Vehicle Count = 0 Person Count = 1
Frame Number = 657 Vehicle Count = 0 Person Count = 1
Frame Number = 658 Vehicle Count = 0 Person Count = 1
Frame Number = 659 Vehicle Count = 0 Person Count = 1
Frame Number = 660 Vehicle Count = 0 Person Count = 1
Frame Number = 661 Vehicle Count = 0 Person Count = 1
Frame Number = 662 Vehicle Count = 0 Person Count = 1
Frame Number = 663 Vehicle Count = 0 Person Count = 1
Frame Number = 664 Vehicle Count = 0 Person Count = 1
Frame Number = 665 Vehicle Count = 0 Person Count = 1
Frame Number = 666 Vehicle Count = 0 Person Count = 0
Frame Number = 667 Vehicle Count = 0 Person Count = 0
Frame Number = 668 Vehicle Count = 0 Person Count = 1
Frame Number = 669 Vehicle Count = 0 Person Count = 0
Frame Number = 670 Vehicle Count = 0 Person Count = 0
Frame Number = 671 Vehicle Count = 0 Person Count = 0
Frame Number = 672 Vehicle Count = 0 Person Count = 0
Frame Number = 673 Vehicle Count = 0 Person Count = 0
Frame Number = 674 Vehicle Count = 0 Person Count = 0
Frame Number = 675 Vehicle Count = 0 Person Count = 0
Frame Number = 676 Vehicle Count = 0 Person Count = 0
End of stream
%3|1625390800.426|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390800.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390800.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390801.420|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390801.420|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390801.420|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390802.433|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390802.433|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390802.433|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390803.426|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390803.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390803.426|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390804.427|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390804.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390804.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390805.436|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390805.436|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390805.436|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390806.449|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390806.449|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390806.449|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390807.427|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390807.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390807.427|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390808.430|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390808.430|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390808.430|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
%3|1625390809.424|FAIL|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390809.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: iotk0.gluecktech.com:7200/bootstrap: Receive failed: Disconnected
%3|1625390809.424|ERROR|rdkafka#producer-1| [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down
Deleting pipeline
I am getting [thrd:iotk0.gluecktech.com:7200/bootstrap]: 1/1 brokers are down error
amycao
July 5, 2021, 2:04am
#10
Please check your broker status, make sure it’s running successful.
@amycao Im checking on my broker part … will check and get back to you
@amycao Hi, I have tested my broker it is running without any issues
I have tested same configuration in Virtual machine but I received different error
sudo ./deepstream-test4-app -i ../../../../samples/streams/rajesh_face2.264 -p /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_kafka_proto.so --conn-str=iotk0.gluecktech.com:7200 --topic=cropped_images -s 1
libEGL warning: DRI2: failed to authenticate
Running...
Error details: gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
Deleting pipeline
I have tested using both local and public IP both are showing same error
amycao
July 9, 2021, 6:15am
#13
Sorry about this comment,
the message shows that TCP connection got disconnected after a period of inactivity. But it will get reestablished when there are messages to be sent.
amycao
July 9, 2021, 6:50am
#14
You are running sample succuesfully.
You will get “brokers are down” message when in one case broker handle session terminating.
amycao
July 9, 2021, 6:59am
#15
Please do as comment 6 to enable logging, get more logs for analysis.
@amycao I will check and get the log for reference
@amycao
This is the log file created while im testing my kafka broker
ds.log (105 Bytes)
amycao
July 13, 2021, 1:41am
#18
-echo “if ($msg contains ‘DSLOG’) and ($syslogseverity <= 6) then $nvdslogfilepath” >> 11-nvds.conf
+echo “if ($msg contains ‘DSLOG’) and ($syslogseverity <= 7) then $nvdslogfilepath” >> 11-nvds.conf
please change logging level to 7, clean the log, rerun again.
@amycao Herewith I have attached the log file for the kafka
ds.log (17.5 KB)
amycao
July 13, 2021, 7:48am
#20
Jul 12 17:53:27 glueck-desktop deepstream-test4-app: DSLOG:NVDS_KAFKA_PROTO: Kafka connection successful
Can you confirm you receive the log like above when you met error as in comment #12 ? it’s impossible when you met error as in #12 , you receive log “Kafka connection successful”.
Are you telling to check the TCP connection?
