Trying this using the NGC docker container or via direct download. The P-100 machine is in the cloud and i am connecting via vnc . I validate that the VNC is working.
appreciate any help.
deepstream-app -c configs/deepstream-app/source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt --gst-debug=3
0:00:00.178985661 27383 0x27af930 ERROR egladaption ext/eglgles/gstegladaptation_egl.c:144:gst_egl_adaptation_init_display:<sink_sub_bin_sink1> Could not get EGL display connection
0:00:00.179032829 27383 0x27af930 ERROR egladaption ext/eglgles/gstegladaptation_egl.c:185:gst_egl_adaptation_init_display:<sink_sub_bin_sink1> Couldn’t setup window/surface from handle
0:00:00.179039575 27383 0x27af930 ERROR nveglglessink ext/eglgles/gsteglglessink.c:532:egl_init:<sink_sub_bin_sink1> Couldn’t init EGL display
0:00:00.179044943 27383 0x27af930 ERROR nveglglessink ext/eglgles/gsteglglessink.c:558:egl_init:<sink_sub_bin_sink1> Failed to perform EGL init
** ERROR: main:564: Failed to set pipeline to PAUSED
Quitting
App run failed
deepstream-app -c configs/deepstream-app/source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt --gst-debug=4
0:00:00.000314923 27577 0x169a120 INFO GST_INIT gstmessage.c:119:_priv_gst_message_initialize: init messages
0:00:00.000699030 27577 0x169a120 INFO GST_INIT gstcontext.c:83:_priv_gst_context_initialize: init contexts
0:00:00.000846369 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:316:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000927255 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:224:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.000943088 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.000961418 27577 0x169a120 INFO GST_REGISTRY gstregistry.c:1723:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.011582093 27577 0x169a120 INFO GST_REGISTRY gstregistrybinary.c:619:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.x86_64.bin in 0.010600 seconds
0:00:00.011635577 27577 0x169a120 INFO GST_REGISTRY gstregistry.c:1579:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.012515322 27577 0x169a120 INFO GST_REGISTRY gstregistry.c:1681:scan_and_update_registry: Registry cache has not changed
0:00:00.012533375 27577 0x169a120 INFO GST_REGISTRY gstregistry.c:1758:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.012539753 27577 0x169a120 INFO GST_INIT gst.c:724:init_post: GLib runtime version: 2.48.2
0:00:00.012554133 27577 0x169a120 INFO GST_INIT gst.c:726:init_post: GLib headers version: 2.48.1
0:00:00.012565276 27577 0x169a120 INFO GST_INIT gst.c:727:init_post: initialized GStreamer successfully
0:00:00.012960802 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “pipeline” named “pipeline”
0:00:00.013052158 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “multi_src_bin”
0:00:00.015517377 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libnvdsgst_multistream.so” loaded
0:00:00.015545737 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “nvstreammux” named “src_bin_muxer”
0:00:00.015660966 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstNvStreamMux@0x18e6000 adding pad ‘src’
0:00:00.015700728 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “src_sub_bin0”
0:00:00.016821165 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstplayback.so” loaded
0:00:00.016844750 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.017323748 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.017347140 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “queue”
0:00:00.017429531 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6030 adding pad ‘sink’
0:00:00.017454784 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6030 adding pad ‘src’
0:00:00.017480915 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad queue:src
0:00:00.017534793 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link queue:src and src:proxypad0
0:00:00.017552203 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked queue:src and src:proxypad0, successful
0:00:00.017559470 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.017566105 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:queue:src Received event on flushing pad. Discarding
0:00:00.017584114 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<src_sub_bin0> adding pad ‘src’
0:00:00.017598832 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.017693720 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseSink@0x18fea30 adding pad ‘sink’
0:00:00.017716298 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.017731463 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6320 adding pad ‘sink’
0:00:00.017751050 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6320 adding pad ‘src’
0:00:00.017777474 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element “tee”
0:00:00.017823229 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstTee@0x1903000 adding pad ‘sink’
0:00:00.017854453 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.017870914 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.017893227 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.017914400 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.017930729 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.017946263 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.017953876 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.017967647 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.017973563 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.018002982 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad: adding pad ‘src_0’
0:00:00.018012790 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad queue:sink
0:00:00.018020866 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tee0:src_0 and queue:sink
0:00:00.018037925 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.018055092 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<src_sub_bin0:src> pad has no peer
0:00:00.018069797 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tee0:src_0 and queue:sink, successful
0:00:00.018082432 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.018088207 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:tee0:src_0 Received event on flushing pad. Discarding
0:00:00.018107787 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad: adding pad ‘src_1’
0:00:00.018121350 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.018128752 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tee0:src_1 and fakequeue:sink
0:00:00.018143348 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.018160345 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tee0:src_1 and fakequeue:sink, successful
0:00:00.018174225 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.018181298 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:tee0:src_1 Received event on flushing pad. Discarding
0:00:00.018204252 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad: no such pad ‘sink_0’ in element “src_bin_muxer”
0:00:00.018232439 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_0’
0:00:00.018241450 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad src_sub_bin0:src
0:00:00.018250627 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link src_sub_bin0:src and src_bin_muxer:sink_0
0:00:00.018260700 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.018305226 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.018337918 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked src_sub_bin0:src and src_bin_muxer:sink_0, successful
0:00:00.018352440 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.018357906 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<src_sub_bin0:src> Received event on flushing pad. Discarding
0:00:00.018373124 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “src_sub_bin1”
0:00:00.018393525 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.018425144 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “queue”
0:00:00.018444052 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6610 adding pad ‘sink’
0:00:00.018464406 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6610 adding pad ‘src’
0:00:00.018491174 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad queue:src
0:00:00.018510265 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link queue:src and src:proxypad1
0:00:00.018525540 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked queue:src and src:proxypad1, successful
0:00:00.018537862 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.018543288 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:queue:src Received event on flushing pad. Discarding
0:00:00.018557469 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<src_sub_bin1> adding pad ‘src’
0:00:00.018572175 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.018591186 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseSink@0x1908860 adding pad ‘sink’
0:00:00.018605764 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.018626527 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6900 adding pad ‘sink’
0:00:00.018655369 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6900 adding pad ‘src’
0:00:00.018667068 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element “tee”
0:00:00.018688588 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstTee@0x1903150 adding pad ‘sink’
0:00:00.018709536 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.018725415 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.018739750 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.018749813 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.018763608 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.018778568 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.018790845 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.018799291 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.018804991 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.018824013 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad: adding pad ‘src_0’
0:00:00.018838021 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad queue:sink
0:00:00.018850638 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tee1:src_0 and queue:sink
0:00:00.018860278 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee1:sink pad has no peer
0:00:00.018873959 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<src_sub_bin1:src> pad has no peer
0:00:00.018887979 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tee1:src_0 and queue:sink, successful
0:00:00.018899698 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.018906332 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:tee1:src_0 Received event on flushing pad. Discarding
0:00:00.018918109 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad: adding pad ‘src_1’
0:00:00.018925697 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.018932485 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tee1:src_1 and fakequeue:sink
0:00:00.018947290 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee1:sink pad has no peer
0:00:00.018957523 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tee1:src_1 and fakequeue:sink, successful
0:00:00.018969939 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.018976950 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:tee1:src_1 Received event on flushing pad. Discarding
0:00:00.018993179 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad: no such pad ‘sink_1’ in element “src_bin_muxer”
0:00:00.019013511 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_1’
0:00:00.019026380 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad src_sub_bin1:src
0:00:00.019039466 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link src_sub_bin1:src and src_bin_muxer:sink_1
0:00:00.019056429 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee1:sink pad has no peer
0:00:00.019070914 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.019087253 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked src_sub_bin1:src and src_bin_muxer:sink_1, successful
0:00:00.019101682 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.019106608 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<src_sub_bin1:src> Received event on flushing pad. Discarding
0:00:00.019114697 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “src_sub_bin2”
0:00:00.019128297 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.019149704 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “queue”
0:00:00.019171866 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6bf0 adding pad ‘sink’
0:00:00.019190703 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6bf0 adding pad ‘src’
0:00:00.019214438 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad queue:src
0:00:00.019231562 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link queue:src and src:proxypad2
0:00:00.019244668 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked queue:src and src:proxypad2, successful
0:00:00.019258122 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.019268102 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:queue:src Received event on flushing pad. Discarding
0:00:00.019275437 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<src_sub_bin2> adding pad ‘src’
0:00:00.019283001 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.019300281 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseSink@0x1910330 adding pad ‘sink’
0:00:00.019315364 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.019334333 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6ee0 adding pad ‘sink’
0:00:00.019353810 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f6ee0 adding pad ‘src’
0:00:00.019377872 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element “tee”
0:00:00.019392880 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstTee@0x19032a0 adding pad ‘sink’
0:00:00.019415549 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.019424986 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.019433327 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.019440610 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.019450059 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.019458879 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.019465687 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.019473116 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.019478339 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.019490779 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad: adding pad ‘src_0’
0:00:00.019498604 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad queue:sink
0:00:00.019504985 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tee2:src_0 and queue:sink
0:00:00.019514376 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee2:sink pad has no peer
0:00:00.019522357 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<src_sub_bin2:src> pad has no peer
0:00:00.019530701 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tee2:src_0 and queue:sink, successful
0:00:00.019538270 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.019550278 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:tee2:src_0 Received event on flushing pad. Discarding
0:00:00.019563140 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad: adding pad ‘src_1’
0:00:00.019571857 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.019578155 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tee2:src_1 and fakequeue:sink
0:00:00.019585447 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee2:sink pad has no peer
0:00:00.019594628 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tee2:src_1 and fakequeue:sink, successful
0:00:00.019602368 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.019607151 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:tee2:src_1 Received event on flushing pad. Discarding
0:00:00.019622445 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad: no such pad ‘sink_2’ in element “src_bin_muxer”
0:00:00.019643011 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_2’
0:00:00.019655959 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad src_sub_bin2:src
0:00:00.019671587 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link src_sub_bin2:src and src_bin_muxer:sink_2
0:00:00.019686329 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee2:sink pad has no peer
0:00:00.019700424 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.019721639 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked src_sub_bin2:src and src_bin_muxer:sink_2, successful
0:00:00.019729471 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.019734233 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<src_sub_bin2:src> Received event on flushing pad. Discarding
0:00:00.019741950 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “src_sub_bin3”
0:00:00.019759759 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.019786072 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “queue”
0:00:00.019805526 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f71d0 adding pad ‘sink’
0:00:00.019823996 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f71d0 adding pad ‘src’
0:00:00.019844377 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad queue:src
0:00:00.019865712 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link queue:src and src:proxypad3
0:00:00.019873362 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked queue:src and src:proxypad3, successful
0:00:00.019884590 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.019889749 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:queue:src Received event on flushing pad. Discarding
0:00:00.019901520 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<src_sub_bin3> adding pad ‘src’
0:00:00.019912606 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.019929330 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseSink@0x1916af0 adding pad ‘sink’
0:00:00.019945131 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.019963765 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f74c0 adding pad ‘sink’
0:00:00.019980336 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f74c0 adding pad ‘src’
0:00:00.020000619 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element “tee”
0:00:00.020015652 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstTee@0x19033f0 adding pad ‘sink’
0:00:00.020030196 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.020038437 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.020046523 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.020060707 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.020073721 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.020086605 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.020098694 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.020110302 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.020115551 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.020133236 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad: adding pad ‘src_0’
0:00:00.020144732 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad queue:sink
0:00:00.020157329 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tee3:src_0 and queue:sink
0:00:00.020170178 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee3:sink pad has no peer
0:00:00.020183662 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<src_sub_bin3:src> pad has no peer
0:00:00.020195304 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tee3:src_0 and queue:sink, successful
0:00:00.020206593 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.020216785 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:tee3:src_0 Received event on flushing pad. Discarding
0:00:00.020234174 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad: adding pad ‘src_1’
0:00:00.020245786 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.020258000 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tee3:src_1 and fakequeue:sink
0:00:00.020270852 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee3:sink pad has no peer
0:00:00.020284297 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tee3:src_1 and fakequeue:sink, successful
0:00:00.020295755 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.020300864 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:tee3:src_1 Received event on flushing pad. Discarding
0:00:00.020321538 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad: no such pad ‘sink_3’ in element “src_bin_muxer”
0:00:00.020343646 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_3’
0:00:00.020359250 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad src_sub_bin3:src
0:00:00.020367507 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link src_sub_bin3:src and src_bin_muxer:sink_3
0:00:00.020382362 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:tee3:sink pad has no peer
0:00:00.020396923 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.020421592 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked src_sub_bin3:src and src_bin_muxer:sink_3, successful
0:00:00.020430109 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.020435204 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<src_sub_bin3:src> Received event on flushing pad. Discarding
0:00:00.020442795 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad src_bin_muxer:src
0:00:00.020477840 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link src_bin_muxer:src and src:proxypad4
0:00:00.020491929 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked src_bin_muxer:src and src:proxypad4, successful
0:00:00.020498155 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.020502881 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<src_bin_muxer:src> Received event on flushing pad. Discarding
0:00:00.020521562 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<multi_src_bin> adding pad ‘src’
0:00:00.020562193 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “processing_bin_0”
0:00:00.020582165 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “sink_bin”
0:00:00.020592275 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “sink_bin_queue”
0:00:00.020619137 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f77b0 adding pad ‘sink’
0:00:00.020632645 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f77b0 adding pad ‘src’
0:00:00.020646938 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad sink_bin_queue:sink
0:00:00.020660421 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink:proxypad5 and sink_bin_queue:sink
0:00:00.020675063 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink:proxypad5 and sink_bin_queue:sink, successful
0:00:00.020686707 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.020696375 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<sink_bin> adding pad ‘sink’
0:00:00.020707667 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “tee” named “sink_bin_tee”
0:00:00.020727962 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstTee@0x1903540 adding pad ‘sink’
0:00:00.020745620 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element sink_bin_queue:(any) to element sink_bin_tee:(any)
0:00:00.020758406 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link sink_bin_queue:src and sink_bin_tee:sink
0:00:00.020772992 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:00.020787253 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: sink_bin_queue and sink_bin_tee in same bin, no need for ghost pads
0:00:00.020800539 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink_bin_queue:src and sink_bin_tee:sink
0:00:00.020813599 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:00.020826363 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink_bin_queue:src and sink_bin_tee:sink, successful
0:00:00.020837791 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.020847379 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<sink_bin_queue:src> Received event on flushing pad. Discarding
0:00:00.020860540 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “sink_sub_bin1”
0:00:00.020881857 27577 0x169a120 INFO NVDS_APP deepstream_sink_bin.c:50:create_render_bin: NVvideo renderer
0:00:00.061659347 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libnvdsgst_eglglessink.so” loaded
0:00:00.061697454 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “nveglglessink” named “sink_sub_bin_sink1”
0:00:00.061834894 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseSink@0x192b440 adding pad ‘sink’
0:00:00.061900170 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “capsfilter” named “sink_sub_bin_cap_filter1”
0:00:00.061973359 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x1930150 adding pad ‘sink’
0:00:00.061995120 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x1930150 adding pad ‘src’
0:00:00.062514478 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libnvdsgst_vidconv.so” loaded
0:00:00.062533978 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “nvvidconv” named “sink_sub_bin_transform1”
0:00:00.062608365 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x19330d0 adding pad ‘sink’
0:00:00.062629897 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x19330d0 adding pad ‘src’
0:00:00.062657470 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.062680967 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “render_queue1”
0:00:00.062705606 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f7aa0 adding pad ‘sink’
0:00:00.062719377 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x18f7aa0 adding pad ‘src’
0:00:00.062735774 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element sink_sub_bin_cap_filter1:(any) to element sink_sub_bin_sink1:(any)
0:00:00.062751565 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink
0:00:00.062767314 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<sink_sub_bin_cap_filter1:sink> pad has no peer
0:00:00.062811957 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: sink_sub_bin_cap_filter1 and sink_sub_bin_sink1 in same bin, no need for ghost pads
0:00:00.062831322 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink
0:00:00.062840059 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<sink_sub_bin_cap_filter1:sink> pad has no peer
0:00:00.062867729 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink, successful
0:00:00.062880895 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.062886619 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<sink_sub_bin_cap_filter1:src> Received event on flushing pad. Discarding
0:00:00.062895262 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element sink_sub_bin_transform1:(any) to element sink_sub_bin_cap_filter1:(any)
0:00:00.062908312 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link sink_sub_bin_transform1:src and sink_sub_bin_cap_filter1:sink
0:00:00.062921173 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<sink_sub_bin_transform1:sink> pad has no peer
0:00:00.063001740 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: sink_sub_bin_transform1 and sink_sub_bin_cap_filter1 in same bin, no need for ghost pads
0:00:00.063018206 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink_sub_bin_transform1:src and sink_sub_bin_cap_filter1:sink
0:00:00.063025958 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<sink_sub_bin_transform1:sink> pad has no peer
0:00:00.063095656 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink_sub_bin_transform1:src and sink_sub_bin_cap_filter1:sink, successful
0:00:00.063111043 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.063116257 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<sink_sub_bin_transform1:src> Received event on flushing pad. Discarding
0:00:00.063130258 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element render_queue1:(any) to element sink_sub_bin_transform1:(any)
0:00:00.063144891 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link render_queue1:src and sink_sub_bin_transform1:sink
0:00:00.063159893 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<render_queue1:sink> pad has no peer
0:00:00.063233123 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: render_queue1 and sink_sub_bin_transform1 in same bin, no need for ghost pads
0:00:00.063248861 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link render_queue1:src and sink_sub_bin_transform1:sink
0:00:00.063257204 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<render_queue1:sink> pad has no peer
0:00:00.063329426 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked render_queue1:src and sink_sub_bin_transform1:sink, successful
0:00:00.063343900 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.063348988 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<render_queue1:src> Received event on flushing pad. Discarding
0:00:00.063358201 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad render_queue1:sink
0:00:00.063384045 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink:proxypad6 and render_queue1:sink
0:00:00.063398063 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink:proxypad6 and render_queue1:sink, successful
0:00:00.063404196 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.063413558 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<sink_sub_bin1> adding pad ‘sink’
0:00:00.063444012 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<sink_bin_tee> adding pad ‘src_0’
0:00:00.063458635 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad sink_sub_bin1:sink
0:00:00.063466416 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink_bin_tee:src_0 and sink_sub_bin1:sink
0:00:00.063481097 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:00.063562284 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink_bin_tee:src_0 and sink_sub_bin1:sink, successful
0:00:00.063577262 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.063582422 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<sink_bin_tee:src_0> Received event on flushing pad. Discarding
0:00:00.063599720 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “osd_bin”
0:00:00.063629751 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “nvvidconv” named “osd_conv”
0:00:00.063651244 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x1937790 adding pad ‘sink’
0:00:00.063679002 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x1937790 adding pad ‘src’
0:00:00.063694097 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “osd_queue”
0:00:00.063715634 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x19201f0 adding pad ‘sink’
0:00:00.063728863 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x19201f0 adding pad ‘src’
0:00:00.067335279 27577 0x169a120 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libnvdsgst_osd.so” loaded
0:00:00.067357228 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “nvosd” named “nvosd0”
0:00:00.067421475 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x1947980 adding pad ‘sink’
0:00:00.067446185 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x1947980 adding pad ‘src’
0:00:00.067490685 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element osd_queue:(any) to element osd_conv:(any)
0:00:00.067507066 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link osd_queue:src and osd_conv:sink
0:00:00.067523797 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.067538921 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<osd_conv:src> pad has no peer
0:00:00.067608028 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: osd_queue and osd_conv in same bin, no need for ghost pads
0:00:00.067626413 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link osd_queue:src and osd_conv:sink
0:00:00.067642072 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.067655278 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<osd_conv:src> pad has no peer
0:00:00.067704387 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked osd_queue:src and osd_conv:sink, successful
0:00:00.067719050 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.067726534 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<osd_queue:src> Received event on flushing pad. Discarding
0:00:00.067740646 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element osd_conv:(any) to element nvosd0:(any)
0:00:00.067754497 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link osd_conv:src and nvosd0:sink
0:00:00.067770465 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.067821476 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:nvosd0:src pad has no peer
0:00:00.067843765 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: osd_conv and nvosd0 in same bin, no need for ghost pads
0:00:00.067858377 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link osd_conv:src and nvosd0:sink
0:00:00.067874557 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.067925387 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:nvosd0:src pad has no peer
0:00:00.067944489 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked osd_conv:src and nvosd0:sink, successful
0:00:00.067957073 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.067962208 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<osd_conv:src> Received event on flushing pad. Discarding
0:00:00.067975753 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad osd_queue:sink
0:00:00.068000009 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink:proxypad7 and osd_queue:sink
0:00:00.068013285 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink:proxypad7 and osd_queue:sink, successful
0:00:00.068026406 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.068039330 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<osd_bin> adding pad ‘sink’
0:00:00.068051450 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad nvosd0:src
0:00:00.068071258 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link nvosd0:src and src:proxypad8
0:00:00.068084432 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked nvosd0:src and src:proxypad8, successful
0:00:00.068090485 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.068100496 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:nvosd0:src Received event on flushing pad. Discarding
0:00:00.068107460 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<osd_bin> adding pad ‘src’
0:00:00.068125057 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element osd_bin:(any) to element sink_bin:(any)
0:00:00.068139534 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link osd_bin:src and sink_bin:sink
0:00:00.068150633 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<osd_bin:sink> pad has no peer
0:00:00.068291238 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: osd_bin and sink_bin in same bin, no need for ghost pads
0:00:00.068309762 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link osd_bin:src and sink_bin:sink
0:00:00.068326784 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<osd_bin:sink> pad has no peer
0:00:00.068455744 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked osd_bin:src and sink_bin:sink, successful
0:00:00.068470731 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.068476231 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<osd_bin:src> Received event on flushing pad. Discarding
0:00:00.068489477 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad osd_bin:sink
0:00:00.068510448 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink:proxypad9 and osd_bin:sink
0:00:00.068523670 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink:proxypad9 and osd_bin:sink, successful
0:00:00.068537369 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.068549718 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<processing_bin_0> adding pad ‘sink’
0:00:00.068561409 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad nvosd0:sink
0:00:00.068587457 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “tiled_display_bin”
0:00:00.068608420 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “queue” named “tiled_display_queue”
0:00:00.068631954 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x19204e0 adding pad ‘sink’
0:00:00.068651211 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstQueue@0x19204e0 adding pad ‘src’
0:00:00.068669461 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “nvmultistreamtiler” named “tiled_display_tiler”
0:00:00.068737514 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x198d8f0 adding pad ‘sink’
0:00:00.068756881 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:GstBaseTransform@0x198d8f0 adding pad ‘src’
0:00:00.068780923 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element tiled_display_queue:(any) to element tiled_display_tiler:(any)
0:00:00.068795349 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link tiled_display_queue:src and tiled_display_tiler:sink
0:00:00.068811676 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<tiled_display_queue:sink> pad has no peer
0:00:00.068828864 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<tiled_display_tiler:src> pad has no peer
0:00:00.068855366 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: tiled_display_queue and tiled_display_tiler in same bin, no need for ghost pads
0:00:00.068872017 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tiled_display_queue:src and tiled_display_tiler:sink
0:00:00.068880399 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<tiled_display_queue:sink> pad has no peer
0:00:00.068888983 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<tiled_display_tiler:src> pad has no peer
0:00:00.068905034 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tiled_display_queue:src and tiled_display_tiler:sink, successful
0:00:00.068918326 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.068923789 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<tiled_display_queue:src> Received event on flushing pad. Discarding
0:00:00.068937010 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad tiled_display_queue:sink
0:00:00.068959435 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link sink:proxypad10 and tiled_display_queue:sink
0:00:00.068972596 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked sink:proxypad10 and tiled_display_queue:sink, successful
0:00:00.068985845 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.068998328 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<tiled_display_bin> adding pad ‘sink’
0:00:00.069010027 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad tiled_display_tiler:src
0:00:00.069030201 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tiled_display_tiler:src and src:proxypad11
0:00:00.069046567 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tiled_display_tiler:src and src:proxypad11, successful
0:00:00.069052978 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.069063135 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<tiled_display_tiler:src> Received event on flushing pad. Discarding
0:00:00.069070218 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<tiled_display_bin> adding pad ‘src’
0:00:00.069086719 27577 0x169a120 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element tiled_display_bin:(any) to element processing_bin_0:(any)
0:00:00.069100237 27577 0x169a120 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link tiled_display_bin:src and processing_bin_0:sink
0:00:00.069116851 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<tiled_display_bin:sink> pad has no peer
0:00:00.069268807 27577 0x169a120 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: tiled_display_bin and processing_bin_0 in same bin, no need for ghost pads
0:00:00.069287404 27577 0x169a120 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link tiled_display_bin:src and processing_bin_0:sink
0:00:00.069304081 27577 0x169a120 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<tiled_display_bin:sink> pad has no peer
0:00:00.069450238 27577 0x169a120 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked tiled_display_bin:src and processing_bin_0:sink, successful
0:00:00.069466025 27577 0x169a120 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.069471488 27577 0x169a120 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<tiled_display_bin:src> Received event on flushing pad. Discarding
0:00:00.069484665 27577 0x169a120 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad tiled_display_bin:sink
0:00:00.069492906 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element “bin” named “secondary_gie_bin”
0:00:00.069518366 27577 0x169a120 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create:
