nvidia-driver:
deepstream-version: 6.4
The error is as follows:
Creating Pipeline
Creating streammux
Creating uridecodebin for [rtmp://127.0.0.1:10935/test/3]
source-bin-00
Creating Pgie
Creating H264 Encoder
Creating H264 rtppay
Linking elements in the Pipeline
0:00:00.112937172 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.112954868 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.112960005 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.112963669 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.112971627 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.112975346 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe minimum capture size for pixelformat Y444
0:00:00.112978397 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.112981989 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe maximum capture size for pixelformat Y444
0:00:00.112989492 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.112993275 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe minimum capture size for pixelformat P410
0:00:00.112996440 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.112999954 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe maximum capture size for pixelformat P410
0:00:00.113009287 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.113012527 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe minimum capture size for pixelformat PM10
0:00:00.113015576 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.113019587 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe maximum capture size for pixelformat PM10
0:00:00.113043737 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.113049683 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.113053303 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:sink> Unable to try format: Unknown error -1
0:00:00.113057457 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<encoder:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.113097228 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:src> Unable to try format: Unknown error -1
0:00:00.113103375 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<encoder:src> Could not probe minimum capture size for pixelformat H264
0:00:00.113109008 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<encoder:src> Unable to try format: Unknown error -1
0:00:00.113117385 51867 0x55c0053ffc00 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<encoder:src> Could not probe maximum capture size for pixelformat H264
0:00:06.270525896 51867 0x55c0053ffc00 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.4/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b30_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:06.359784146 51867 0x55c0053ffc00 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b30_gpu0_int8.engine
0:00:06.366809230 51867 0x55c0053ffc00 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out/dstest1_pgie_config.txt sucessfully
Decodebin child added: source
Decodebin child added: typefindelement0
Decodebin child added: decodebin0
Starting pipeline
Set_state PLAYING
Decodebin child added: queue2-0
Decodebin child added: flvdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
0:00:06.393327707 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393362541 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:06.393378987 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393393188 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:06.393429202 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393442811 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat AV10
0:00:06.393477859 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393518588 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat AV10
0:00:06.393556141 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393589134 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX5
0:00:06.393603163 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393617106 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX5
0:00:06.393639795 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393654306 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX4
0:00:06.393666927 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393680299 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX4
0:00:06.393704270 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393719443 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:06.393730676 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393749084 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:06.393773219 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393787299 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:06.393799686 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393812604 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:06.393838617 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393853698 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:00:06.393868880 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393882853 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:00:06.393905699 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393919482 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP90
0:00:06.393931855 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393949130 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP90
0:00:06.393970549 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.393984462 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP80
0:00:06.393996933 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.394010647 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP80
0:00:06.394036134 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.394049496 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:00:06.394063092 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:06.394075639 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:00:06.394155402 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:06.394170428 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat Y444
0:00:06.394183329 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:06.394197838 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat Y444
0:00:06.394229166 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:06.394285322 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat P410
0:00:06.394300726 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:06.394314771 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat P410
0:00:06.394343221 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:06.394357379 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat PM10
0:00:06.394370000 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:06.394383952 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat PM10
0:00:06.394410127 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:06.394423924 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2985:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:00:06.394436554 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:3100:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:06.394450183 51867 0x7f1cf0016b60 WARN v4l2 gstv4l2object.c:2991:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
In cb_newpad
gstname= video/x-raw
sink_0
Decodebin linked to pipeline
0:00:06.531737716 51867 0x7f1cf0016b60 WARN v4l2bufferpool gstv4l2bufferpool.c:1114:gst_v4l2_buffer_pool_start:<encoder:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:06.532194671 51867 0x7f1cf0016b60 WARN v4l2videodec gstv4l2videodec.c:2258:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:06.532215381 51867 0x7f1cf0016b60 WARN v4l2bufferpool gstv4l2bufferpool.c:1114:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:06.533602774 51867 0x7f1ccc049060 WARN v4l2bufferpool gstv4l2bufferpool.c:1565:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
time --:2025-01-02 21:39:12.402626
time --:2025-01-02 21:39:12.403074
time --:2025-01-02 21:39:12.403373
time --:2025-01-02 21:39:12.403660
(python3:51867): GStreamer-WARNING **: 21:39:12.454: (../gst/gstinfo.c:556):gst_debug_log_valist: runtime check failed: (object == NULL || G_IS_OBJECT (object))
(python3:51867): GStreamer-WARNING **: 21:39:12.454: (../gst/gstinfo.c:1340):gst_debug_log_default: runtime check failed: (object == NULL || G_IS_OBJECT (object))
0:00:07.351692951 51867 0x55c005249300 ERROR v4l2bufferpool gstv4l2bufferpool.c:320:gst_v4l2_buffer_pool_copy_buffer:buffer: 0x7f1cec054b40, pts 0:00:00.000000000, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0 ERROR in BufSurfacecopy
0:00:07.351719531 51867 0x55c005249300 ERROR v4l2bufferpool gstv4l2bufferpool.c:2420:gst_v4l2_buffer_pool_process:<encoder:pool:sink> failed to prepare data
0:00:07.351799644 51867 0x55c005249300 WARN v4l2videoenc gstv4l2videoenc.c:1756:gst_v4l2_video_enc_handle_frame:<encoder> error: Failed to process frame.
0:00:07.351806244 51867 0x55c005249300 WARN v4l2videoenc gstv4l2videoenc.c:1756:gst_v4l2_video_enc_handle_frame:<encoder> error: Maybe be due to not enough memory or failing driver
0:00:07.351916611 51867 0x55c005249300 WARN nvinfer gstnvinfer.cpp:2406:gst_nvinfer_output_loop:<primary-inference> error: Internal data stream error.
0:00:07.351940718 51867 0x55c005249300 WARN nvinfer gstnvinfer.cpp:2406:gst_nvinfer_output_loop:<primary-inference> error: streaming stopped, reason error (-5)
Error: gst-resource-error-quark: Failed to process frame. (1): gstv4l2videoenc.c(1756): gst_v4l2_video_enc_handle_frame (): /GstPipeline:pipeline0/nvv4l2h264enc:encoder:
err result= []
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(2406): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
err result= []
time --:2025-01-02 21:39:12.483294
time --:2025-01-02 21:39:12.483631
time --:2025-01-02 21:39:12.483911
time --:2025-01-02 21:39:12.484218
(python3:51867): GStreamer-WARNING **: 21:39:12.487: (../gst/gstinfo.c:556):gst_debug_log_valist: runtime check failed: (object == NULL || G_IS_OBJECT (object))
(python3:51867): GStreamer-WARNING **: 21:39:12.487: (../gst/gstinfo.c:1340):gst_debug_log_default: runtime check failed: (object == NULL || G_IS_OBJECT (object))
0:00:07.384683471 51867 0x55c005249300 ERROR v4l2bufferpool gstv4l2bufferpool.c:320:gst_v4l2_buffer_pool_copy_buffer:buffer: 0x7f1cec054c60, pts 0:00:00.040000000, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0 ERROR in BufSurfacecopy
0:00:07.384698444 51867 0x55c005249300 ERROR v4l2bufferpool gstv4l2bufferpool.c:2420:gst_v4l2_buffer_pool_process:<encoder:pool:sink> failed to prepare data
0:00:07.384708085 51867 0x55c005249300 WARN v4l2videoenc gstv4l2videoenc.c:1756:gst_v4l2_video_enc_handle_frame:<encoder> error: Failed to process frame.
0:00:07.384714162 51867 0x55c005249300 WARN v4l2videoenc gstv4l2videoenc.c:1756:gst_v4l2_video_enc_handle_frame:<encoder> error: Maybe be due to not enough memory or failing driver
err result= []
time --:2025-01-02 21:39:12.514621
0:00:07.417395620 51867 0x55c0240236a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1565:gst_v4l2_buffer_pool_dqbuf:<encoder:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:07.447890373 51867 0x55c0052491e0 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop:<source> error: Internal data stream error.
0:00:07.447924138 51867 0x55c0052491e0 WARN basesrc gstbasesrc.c:3127:gst_base_src_loop:<source> error: streaming stopped, reason error (-5)
Error: gst-stream-error-quark: Internal data stream error. (1): ../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-00/GstRtmp2Src:source:
err result= ['source-bin-00']
The video stream is normal:rtmp://127.0.0.1:10935/test/3
I am running the example normally:
python3 deepstream_test1_rtsp_in_rtsp_out.py -i rtmp://127.0.0.1:10935/test/3
I wrote a demo based on this example, but it encountered the error mentioned above
#coding=utf-8
# The MIT License
# Copyright (c) 2019-2023, Prominence AI, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
#!/usr/bin/env python
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib, GstRtspServer
from gi.repository import GLib
import pyds
import sys, datetime, re
#sys.path.insert(0, "../../")
import os
os.environ['CUDA_VISIBLE_DEVICES'] = '0'
os.environ["GST_DEBUG_DUMP_DOT_DIR"] = "/tmp"
os.putenv('GST_DEBUG_DUMP_DIR_DIR', '/tmp')
class DSLPipline():
def __init__(self, gpu_id,
drop_frame_interval, frame_skip, video_url,
inferConfigFile
self.gpu_id = gpu_id
self.drop_frame_interval = drop_frame_interval
self.frame_skip = frame_skip
self.video_url = video_url
self.inferConfigFile = inferConfigFile
self.pipeline = None
self.streammux = None
def _tiler_sink_pad_buffer_probe(self, pad, info, u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
source_id = frame_meta.source_id
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta = pyds.glist_get_nvds_object_meta(l_obj.data)
break
try:
l_obj = l_obj.next
break
display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
py_nvosd_text_params.display_text = "time --:{}".format(datetime.datetime.now())
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def _bus_call(self, bus, message, loop):
t = message.type
if t == Gst.MessageType.EOS:
sys.stdout.write("End-of-stream\n")
#loop.quit()
elif t == Gst.MessageType.WARNING:
err, debug = message.parse_warning()
sys.stderr.write("Warning: %s: %s\n" % (err, debug))
warning = "Warning: %s: %s\n" % (err, debug)
result = re.findall(r"source-bin-\d+", warning)
print("warning result=", result)
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
sys.stderr.write("Error: %s: %s\n" % (err, debug))
err_str = "Error: %s: %s\n" % (err, debug)
result = re.findall(r"source-bin-\d+", err_str)
print("err result=", result)
elif t == Gst.MessageType.ELEMENT:
struct = message.get_structure()
# Check for stream-eos message
if struct is not None and struct.has_name("stream-eos"):
parsed, stream_id = struct.get_uint("stream-id")
if parsed:
# Set eos status of stream to True, to be deleted in delete-sources
print("Got EOS from stream %d" % stream_id)
return True
def _create_uridecode_bin(self, source_id, url):
def decodebin_child_added(child_proxy, Object, name, user_data):
print("Decodebin child added:", name, "\n")
if (name.find("decodebin") != -1):
Object.connect("child-added", decodebin_child_added, user_data)
if (name.find("nvv4l2decoder") != -1):
Object.set_property("gpu_id", 0)
Object.set_property("drop-frame-interval", self.drop_frame_interval)
def cb_newpad(decodebin, pad, data):
print("In cb_newpad\n")
caps = pad.get_current_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=", gstname)
if (gstname.find("video") != -1):
source_id = data
pad_name = "sink_%u" % source_id
print(pad_name)
# Get a sink pad from the streammux, link to decodebin
sinkpad = self.streammux.request_pad_simple(pad_name)
if not sinkpad:
print("Unable to create sink pad bin \n")
if pad.link(sinkpad) == Gst.PadLinkReturn.OK:
print("Decodebin linked to pipeline")
else:
print("Failed to link decodebin to pipeline\n")
print("Creating uridecodebin for [%s]" % url)
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name = "source-bin-%02d" % source_id
print(bin_name)
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
bin = Gst.ElementFactory.make("uridecodebin", bin_name)
if not bin:
print(" Unable to create uri decode bin \n")
# We set the input uri to the source element
bin.set_property("uri", url)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has been created by the decodebin
bin.connect("pad-added", cb_newpad, source_id)
bin.connect("child-added", decodebin_child_added, source_id)
return bin
def run(self):
# Standard GStreamer initialization
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
self.pipeline = Gst.Pipeline()
is_live = False
if not self.pipeline:
print(" Unable to create Pipeline \n")
return
print("Creating streammux \n ")
# Create nvstreammux instance to form batches from one or more sources.
self.streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
self.streammux.set_property("batched-push-timeout", 25000)
self.streammux.set_property("batch-size", 30)
self.streammux.set_property("gpu_id", 0)
self.streammux.set_property('width', 1280)
self.streammux.set_property('height', 720)
if not self.streammux:
print(" Unable to create NvStreamMux \n")
return
if self.video_url.find("rtsp://") == 0:
is_live = True
print("Atleast one of the sources is live")
self.streammux.set_property('live-source', 1)
# Create first source bin and add to pipeline
source_bin = self._create_uridecode_bin(0, self.video_url)
if not source_bin:
print("Failed to create source bin. Exiting. \n")
return
self.pipeline.add(source_bin)
print("Creating Pgie \n ")
# pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
print(" Unable to create pgie \n")
# Set pgie, sgie1, and sgie2 configuration file paths
pgie.set_property('config-file-path', self.inferConfigFile)
# Set necessary properties of the nvinfer element, the necessary ones are:
pgie.set_property("batch-size", 12)
# Set gpu IDs of the inference engines
pgie.set_property("gpu_id", 0)
codec = "H264"
enc_type = 0
bitrate = 4000000
# Use convertor to convert from NV12 to RGBA as required by nvosd
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
# Create OSD to draw on the converted RGBA buffer
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
# Create a caps filter
caps = Gst.ElementFactory.make("capsfilter", "filter")
if enc_type == 0:
caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
else:
caps.set_property("caps", Gst.Caps.from_string("video/x-raw, format=I420"))
# Make the encoder
if codec == "H264":
if enc_type == 0:
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
else:
encoder = Gst.ElementFactory.make("x264enc", "encoder")
print("Creating H264 Encoder")
elif codec == "H265":
if enc_type == 0:
encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
else:
encoder = Gst.ElementFactory.make("x265enc", "encoder")
print("Creating H265 Encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property('bitrate', bitrate)
# Make the payload-encode video into RTP packets
if codec == "H264":
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
print("Creating H264 rtppay")
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
print("Creating H265 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
# Make the UDP sink
updsink_port_num = 5400
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
sink.set_property('host', '224.224.255.255')
sink.set_property('port', updsink_port_num)
sink.set_property('async', False)
sink.set_property('sync', 1)
self.pipeline.add(self.streammux)
self.pipeline.add(pgie)
self.pipeline.add(nvvidconv)
self.pipeline.add(nvosd)
self.pipeline.add(nvvidconv_postosd)
self.pipeline.add(caps)
self.pipeline.add(encoder)
self.pipeline.add(rtppay)
self.pipeline.add(sink)
# We link elements in the following order:
# sourcebin -> streammux -> nvinfer -> nvtracker -> nvdsanalytics ->
# nvtiler -> nvvideoconvert -> nvdsosd -> sink
print("Linking elements in the Pipeline \n")
self.streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoder)
encoder.link(rtppay)
rtppay.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = self.pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", self._bus_call, loop)
self.pipeline.set_state(Gst.State.PAUSED)
# Start streaming
rtsp_port_num = 8554
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch(
"( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (
updsink_port_num, "H264"))
factory.set_shared(True)
server.get_mount_points().add_factory("/ds-test", factory)
# had got all the metadata.
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
#osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, self._save_frame, 0)
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, self._tiler_sink_pad_buffer_probe, 0)
Gst.debug_bin_to_dot_file(self.pipeline, Gst.DebugGraphDetails.ALL, "pipeline")
print("Starting pipeline \n")
# start play back and listed to events
self.pipeline.set_state(Gst.State.PLAYING)
print("Set_state PLAYING \n")
try:
loop.run()
except:
import traceback
print(traceback.format_exc())
# cleanup
print("Exiting app\n")
self.pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
p = DSLPipline(
gpu_id=0,
drop_frame_interval=4,
frame_skip=8,
video_url="rtmp://127.0.0.1:10935/test/3",
inferConfigFile='/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out/dstest1_pgie_config.txt',
p.run()
The flowchart of the example is as follows:
pipeline:
Can you give me some tips? Thank you very much
