I managed to implement a basic pipeline that decodes a h264 stream from RTSP, encode it back again and store it to disk in chunks of a specified size.
I have two questions:
how can I change the encoding element and replace x264enc with nvv4l2h264enc so that the encoding also run in GPU? I tried to simply replace one for the other but I runs into linking issues
is it possible to bypass the decoding/encoding part and directly store on disk the stream as an mp4 containing h264?
I include a simple example of my implementation below.
I use DeepStream 4.0
many thanks in advance,
f
#include <gst/gst.h>
#include <unistd.h>
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
* pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning (msg, &error, &debug);
g_printerr ("WARNING from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
g_free (debug);
g_printerr ("Warning: %s\n", error->message);
g_error_free (error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
break;
default:
break;
return TRUE;
static void
cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, GstElement * next_element)
g_print ("In cb_newpad\n");
GstPad *sink_pad = NULL;
sink_pad = gst_element_get_static_pad (next_element, "sink");
GstCaps *sink_caps = gst_pad_get_current_caps (sink_pad);
g_print("***** %d\n", gst_caps_get_size (sink_caps));
const GstStructure *sink_str = gst_caps_get_structure (sink_caps, 0);
const gchar *sink_pad_type = gst_structure_get_name (sink_str);
GstCaps *src_caps = gst_pad_get_current_caps (decoder_src_pad);
const GstStructure *src_str = gst_caps_get_structure (src_caps, 0);
const gchar *new_pad_type = gst_structure_get_name (src_str);
GstCapsFeatures *features = gst_caps_get_features (src_caps, 0);
/* Need to check if the pad created by the decodebin is for video and not audio. */
if (g_str_has_prefix (new_pad_type, "video/x-raw")) {
/* Link the decodebin pad only if decodebin has picked nvidia
* decoder plugin nvdec_*. We do this by checking if the pad caps contain
* NVMM memory features. */
if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
/* Attempt the link */
GstPadLinkReturn ret = gst_pad_link (decoder_src_pad, sink_pad);
if (GST_PAD_LINK_FAILED (ret))
g_print ("Type is '%s' but link failed.\n", new_pad_type);
else
g_print ("Link succeeded (source is '%s' and sink is '%s').\n", new_pad_type, sink_pad_type);
/* Unreference the new pad's caps, if we got them */
if (src_caps != NULL)
gst_caps_unref (src_caps);
if (sink_caps != NULL)
gst_caps_unref (sink_caps);
/* Unreference the sink pad */
gst_object_unref (sink_pad);
int main(int argc, char *argv[]) {
GstElement *pipeline = NULL, *source = NULL, *convert = NULL, *queue = NULL, *encoder = NULL, *muxer = NULL, *sink = NULL;
GMainLoop *loop = NULL;
GstBus *bus;
GstStateChangeReturn ret;
/* Initialize GStreamer */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create the elements */
source = gst_element_factory_make ("uridecodebin", "uridecodebin");
convert = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
queue = gst_element_factory_make ("queue", NULL);
encoder = gst_element_factory_make("x264enc", NULL);
/* encoder = gst_element_factory_make("nvv4l2h264enc", NULL);*/
sink = gst_element_factory_make("splitmuxsink", NULL);
/* Create the empty pipeline */
pipeline = gst_pipeline_new ("test-pipeline");
/* check whether all elements are created*/
if (!pipeline || !source || !convert || !sink) {
g_printerr ("Not all elements could be created.\n");
return -1;
/* Build the pipeline without linking source with the rest of the elements */
gst_bin_add_many (GST_BIN (pipeline), source, convert, queue, encoder, sink, NULL);
if (!gst_element_link_many (convert, queue, encoder, sink, NULL)) {
g_printerr ("Elements could not be linked.\n");
gst_object_unref (pipeline);
return -1;
/* Set properties */
g_object_set (source, "uri", "rtsp://input_uri", NULL);
g_object_set (sink, "location", "/out_dir/file%02d.mp4", NULL);
g_object_set (sink, "max-size-bytes", 5 * 1024 * 1024, NULL);
/* g_object_set (sink, "max-size-time", 10 * 1000 * 1000, NULL);*/
/* Connect to the pad-added signal */
g_signal_connect (G_OBJECT (source), "pad-added", G_CALLBACK (cb_newpad), convert);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
guint bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
// Output a dot file of the pipeline
// Be sure to $ export GST_DEBUG_DUMP_DOT_DIR=/tmp
// and run with the --gst-enable-gst-debug command line switch
/* GST_DEBUG_BIN_TO_DOT_FILE(GST_BIN(pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "pipeline_graph");*/
/* Start playing */
ret = gst_element_set_state (pipeline, GST_STATE_PLAYING);
if (ret == GST_STATE_CHANGE_FAILURE) {
g_printerr ("Unable to set the pipeline to the playing state.\n");
return -1;
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Free resources */
gst_object_unref (bus);
gst_element_set_state (pipeline, GST_STATE_NULL);
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
