• Hardware Platform (Jetson / GPU) GPU V100/A100
• DeepStream Version 6.4 (also 7.0)
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 535.161.08
• Issue Type( questions, new requirements, bugs) question/bug
I’ve got an deepstream based application that need to run both on V100 and A100 platforms, I’ve noticed that there is no hardware video encoder in A100 (nvv4l2h264enc doesn’t work). I tried to replace nvv4l2h264enc with x264enc, I’m using the encoder to create a periodic output video using splitmuxsink every 10 seconds, I’ve used deepstream_test_2 code to demonstrate the problem, please take a look at the code below (simply put in deepstream_test_2 folder and run), you can control the selection of encoder using the flag “nvidia_encoder”, when it set to False I’m getting the following error:
0:00:21.473494937 1598 0x558320503b60 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine
0:00:21.478006193 1598 0x558320503b60 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 1]: Load new model:dstest2_pgie_config.txt sucessfully
Frame Number=0 Number of Objects=0 Vehicle_count=0 Person_count=0
streamId= 0
surfaceStreamID= 0
0:00:22.779871988 1598 0x55831a6afb40 WARN nvinfer gstnvinfer.cpp:2237:gst_nvinfer_submit_input_buffer: error: Internal data stream error.
0:00:22.780531350 1598 0x55831a6afb40 WARN nvinfer gstnvinfer.cpp:2237:gst_nvinfer_submit_input_buffer: error: streaming stopped, reason not-linked (-1)
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(2237): gst_nvinfer_submit_input_buffer (): /GstPipeline:pipeline0/GstNvInfer:secondary2-nvinference-engine:
0:00:22.795421123 1598 0x55831a6afb40 WARN nvinfer gstnvinfer.cpp:2237:gst_nvinfer_submit_input_buffer: error: Internal data stream error.
0:00:22.795432384 1598 0x55831a6afb40 WARN nvinfer gstnvinfer.cpp:2237:gst_nvinfer_submit_input_buffer: error: streaming stopped, reason not-linked (-1)
[NvMultiObjectTracker] De-initialized
The code of deepstream_test_2.py:
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2019-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import sys
sys.path.append('../')
import platform
import configparser
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
#from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
import pyds
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_BATCH_TIMEOUT_USEC = 33000
def osd_sink_pad_buffer_probe(pad,info,u_data):
frame_number=0
#Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_VEHICLE:0,
PGIE_CLASS_ID_PERSON:0,
PGIE_CLASS_ID_BICYCLE:0,
PGIE_CLASS_ID_ROADSIGN:0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number=frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
obj_counter[obj_meta.class_id] += 1
try:
l_obj=l_obj.next
break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_VEHICLE], obj_counter[PGIE_CLASS_ID_PERSON])
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame=l_frame.next
break
#past tracking meta data
l_user=batch_meta.batch_user_meta_list
while l_user is not None:
try:
# Note that l_user.data needs a cast to pyds.NvDsUserMeta
# The casting is done by pyds.NvDsUserMeta.cast()
# it alone
user_meta=pyds.NvDsUserMeta.cast(l_user.data)
break
if(user_meta and user_meta.base_meta.meta_type==pyds.NvDsMetaType.NVDS_TRACKER_PAST_FRAME_META):
try:
# Note that user_meta.user_meta_data needs a cast to pyds.NvDsTargetMiscDataBatch
# The casting is done by pyds.NvDsTargetMiscDataBatch.cast()
# it alone
pPastDataBatch = pyds.NvDsTargetMiscDataBatch.cast(user_meta.user_meta_data)
break
for miscDataStream in pyds.NvDsTargetMiscDataBatch.list(pPastDataBatch):
print("streamId=",miscDataStream.streamID)
print("surfaceStreamID=",miscDataStream.surfaceStreamID)
for miscDataObj in pyds.NvDsTargetMiscDataStream.list(miscDataStream):
print("numobj=",miscDataObj.numObj)
print("uniqueId=",miscDataObj.uniqueId)
print("classId=",miscDataObj.classId)
print("objLabel=",miscDataObj.objLabel)
for miscDataFrame in pyds.NvDsTargetMiscDataObject.list(miscDataObj):
print('frameNum:', miscDataFrame.frameNum)
print('tBbox.left:', miscDataFrame.tBbox.left)
print('tBbox.width:', miscDataFrame.tBbox.width)
print('tBbox.top:', miscDataFrame.tBbox.top)
print('tBbox.right:', miscDataFrame.tBbox.height)
print('confidence:', miscDataFrame.confidence)
print('age:', miscDataFrame.age)
try:
l_user=l_user.next
break
return Gst.PadProbeReturn.OK
def main(args):
# Check input arguments
if(len(args)<2):
sys.stderr.write("usage: %s <h264_elementary_stream>\n" % args[0])
sys.exit(1)
# Standard GStreamer initialization
Gst.init(None)
# Create gstreamer elements
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
# Source element for reading from the file
print("Creating Source \n ")
source = Gst.ElementFactory.make("filesrc", "file-source")
if not source:
sys.stderr.write(" Unable to create Source \n")
# Since the data format in the input file is elementary h264 stream,
# we need a h264parser
print("Creating H264Parser \n")
h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
if not h264parser:
sys.stderr.write(" Unable to create h264 parser \n")
# Use nvdec_h264 for hardware accelerated decode on GPU
print("Creating Decoder \n")
decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
if not decoder:
sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
# Use nvinfer to run inferencing on decoder's output,
# behaviour of inferencing is set through config file
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
if not tracker:
sys.stderr.write(" Unable to create tracker \n")
sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
if not sgie1:
sys.stderr.write(" Unable to make sgie1 \n")
sgie2 = Gst.ElementFactory.make("nvinfer", "secondary2-nvinference-engine")
if not sgie2:
sys.stderr.write(" Unable to make sgie2 \n")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
# Create OSD to draw on the converted RGBA buffer
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
print("Creating Encoder \n")
nvidia_encoder=False
if nvidia_encoder:
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
encoder.set_property("bitrate", 2000000)
encoder.set_property("idrinterval", 30)
else:
encoder = Gst.ElementFactory.make("x264enc", "encoder")
encoder.set_property("aud", "false")
encoder.set_property("key-int-max", 10)
encoder.set_property("tune", "zerolatency")
if not encoder:
sys.stderr.write(" Unable to create encoder \n")
print("Creating h264 Parser \n")
h264parser2 = Gst.ElementFactory.make("h264parse", "h264-parser2")
if not h264parser2:
sys.stderr.write(" Unable to create h264parse parser \n")
print("Creating file Sink \n")
sink = Gst.ElementFactory.make("splitmuxsink", "splitmuxsink")
if not sink:
sys.stderr.write(" Unable to create file sink \n")
sink.set_property("location", "/tmp/video%02d.mp4")
sink.set_property("max-size-time", 10000000000)
# sink.set_property("max-size-bytes", 0)
sink.set_property("async-finalize", "true")
# sink.set_property("max-files", 10)
sink.set_property("muxer-factory", "mp4mux")
# # Finally render the osd output
# if is_aarch64():
# print("Creating nv3dsink \n")
# sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
# if not sink:
# sys.stderr.write(" Unable to create nv3dsink \n")
# else:
# print("Creating EGLSink \n")
# sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
# if not sink:
# sys.stderr.write(" Unable to create egl sink \n")
print("Playing file %s " %args[1])
source.set_property('location', args[1])
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batch-size', 1)
streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
#Set properties of pgie and sgie
pgie.set_property('config-file-path', "dstest2_pgie_config.txt")
sgie1.set_property('config-file-path', "dstest2_sgie1_config.txt")
sgie2.set_property('config-file-path', "dstest2_sgie2_config.txt")
#Set properties of tracker
config = configparser.ConfigParser()
config.read('dstest2_tracker_config.txt')
config.sections()
for key in config['tracker']:
if key == 'tracker-width' :
tracker_width = config.getint('tracker', key)
tracker.set_property('tracker-width', tracker_width)
if key == 'tracker-height' :
tracker_height = config.getint('tracker', key)
tracker.set_property('tracker-height', tracker_height)
if key == 'gpu-id' :
tracker_gpu_id = config.getint('tracker', key)
tracker.set_property('gpu_id', tracker_gpu_id)
if key == 'll-lib-file' :
tracker_ll_lib_file = config.get('tracker', key)
tracker.set_property('ll-lib-file', tracker_ll_lib_file)
if key == 'll-config-file' :
tracker_ll_config_file = config.get('tracker', key)
tracker.set_property('ll-config-file', tracker_ll_config_file)
print("Adding elements to Pipeline \n")
pipeline.add(source)
pipeline.add(h264parser)
pipeline.add(decoder)
pipeline.add(streammux)
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(sgie1)
pipeline.add(sgie2)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(encoder)
pipeline.add(h264parser2)
pipeline.add(sink)
# we link the elements together
# file-source -> h264-parser -> nvh264-decoder ->
# nvinfer -> nvvidconv -> nvosd -> video-renderer
print("Linking elements in the Pipeline \n")
source.link(h264parser)
h264parser.link(decoder)
sinkpad = streammux.get_request_pad("sink_0")
if not sinkpad:
sys.stderr.write(" Unable to get the sink pad of streammux \n")
srcpad = decoder.get_static_pad("src")
if not srcpad:
sys.stderr.write(" Unable to get source pad of decoder \n")
srcpad.link(sinkpad)
streammux.link(pgie)
pgie.link(tracker)
tracker.link(sgie1)
sgie1.link(sgie2)
sgie2.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(encoder)
encoder.link(h264parser2)
h264parser2.link(sink)
# create and event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
# Lets add probe to get informed of the meta data generated, we add probe to
# the sink pad of the osd element, since by that time, the buffer would have
# had got all the metadata.
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
print("Starting pipeline \n")
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
sys.exit(main(sys.argv))
