I am trying to put together a pipeline in which a source gets encoded as h264 and immediately gets decoded. However, I cannot get nvv4l2h264enc and nvv4l2decoder to work together like nvv4l2h264enc ! h264parse ! nvv4l2decoder in a single pipeline.
The following works for generating a test pattern:
gst-launch-1.0 videotestsrc pattern=ball num-buffers=200 ! 'video/x-raw,format=UYVY,width=1280,height=720' ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720,framerate=10/1,format=UYVY' ! nvvidconv ! nvv4l2h264enc ! h264parse ! video/x-h264,stream-format=byte-stream ! filesink location=ball.h264
I can decode the file with a command like:
gst-launch-1.0 filesrc location=ball.h264 ! h264parse ! nvv4l2decoder ! nvvidconv ! xvimagesink
However, when I chain the two pipelines together like so, nothing happens:
gst-launch-1.0 videotestsrc pattern=ball num-buffers=200 ! 'video/x-raw,format=UYVY,width=1280,height=720' ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720,framerate=10/1,format=UYVY' ! nvvidconv ! nvv4l2h264enc ! h264parse ! nvv4l2decoder ! nvvidconv ! xvimagesink
I would have expected to see a similar output to what gets displayed with:
gst-launch-1.0 videotestsrc pattern=ball num-buffers=200 ! 'video/x-raw,format=UYVY,width=1280,height=720' ! nvvidconv ! xvimagesink
However, nothing happens.
gst-launch-1.0 --version reports gst-launch-1.0 version 1.16.3, GStreamer 1.16.3.
I’d appreciate any suggestions on how to address this issue.
