Jetson Xavier error decoding H264 stream with nvv4l2decoder: NvMediaParserParse Unsupported Codec
Hello
I’m working with a Jetson Xavier NX, Jetpack 35.2.1.
I’m trying to receive a video stream, compressed with H264, and show it in the screen. If I produce the video with the Nvidia H264 encoder:
gst-launch-1.0 videotestsrc ! nvvidconv ! 'video/x-raw(memory:NVMM), format=NV12, width=1920, height=1080' ! nvv4l2h264enc insert-sps-pps=true ! h264parse ! rtph264pay pt=96 ! udpsink host=192.168.1.53 port=1234 sync=false
I can correctly open and show it:
gst-launch-1.0 udpsrc port=1234 caps='application/x-rtp, encoding-name=(string)H264, payload=(int)96' ! rtph264depay ! queue ! nvv4l2decoder ! nvvidconv ! videoconvert ! autovideosink
However, if I compress the video using, for instance, the software encoder x264enc:
gst-launch-1.0 videotestsrc ! videoconvert ! x264enc ! h264parse ! rtph264pay pt=96 ! udpsink host=192.168.1.53 port=1234 sync=fals
I get the following error:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
NVMEDIA: NvMMLiteNVMEDIAProcessVES: 1824: NvMediaParserParse Unsupported Codec
Stream format not found, dropping the frame
NVMEDIA: NvMMLiteNVMEDIADecDoWork: 2228: NVMEDIA Video Dec Unsupported Stream
ERROR: from element /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0: Failed to process frame.
Additional debug info:
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0:
Maybe be due to not enough memory or failing driver
Execution ended after 0:00:03.604760601
Setting pipeline to NULL ...
Freeing pipeline ...
What am I doing wrong? Is there something missing?
Thanks in advance
Please add h264parse and see if it works:
... ! rtph264depay ! h264parse ! nvv4l2decoder ! ...
Hello DaneLLL,
adding h264parse does not solve it, but forcing I420 format before the encoder does.
