I have a MIPI CSI-2 camera which output UYVY format @1080p 60fps.
h.264 encoder can not achieve 60fps
I use this gstreamer cmd and only got 30-32fps.
gst-launch-1.0 v4l2src num-buffers=300 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)60/1" ! videoconvert ! omxh264enc ! matroskamux ! filesink location=videoname.mkv
Also tried nvv4l2h264enc encoder which got same result.
I post gstreamer debug info, hope will help:
export GST_DEBUG="*:3"
0:00:00.084741262 9786 0x55a7757870 WARN omx gstomx.c:2826:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/xumm/.config:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
0:00:00.120136552 9786 0x55a77c3800 FIXME videoencoder gstvideoencoder.c:661:gst_video_encoder_setcaps:<omxh264enc-omxh264enc0> GstVideoEncoder::reset() is deprecated
Framerate set to : 60 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
0:00:00.123010972 9786 0x55a77c3800 WARN omxvideoenc gstomxvideoenc.c:1860:gst_omx_video_enc_set_format:<omxh264enc-omxh264enc0> Error setting temporal_tradeoff 0 : Vendor specific error (0x00000001)
H264: Profile = 66, Level = 40
0:00:00.401167094 9786 0x55a77c3800 WARN v4l2src gstv4l2src.c:911:gst_v4l2src_create:<v4l2src0> Timestamp does not correlate with any clock, ignoring driver timestamps
NVMEDIA_ENC: bBlitMode is set to TRUE
0:00:00.458222133 9786 0x7f700044f0 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event:<filesink0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
Got EOS from element "pipeline0".
Execution ended after 0:00:08.853691203
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
difference between nvvidconv and videoconvert
nvvidconv output 28fps
gst-launch-1.0 v4l2src ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)60/1" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420,framerate=(fraction)60/1" ! fpsdisplaysink video-sink=fakesink -v
videoconvert output 60fps
gst-launch-1.0 v4l2src ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)60/1" ! videoconvert ! fpsdisplaysink video-sink=fakesink -v
I can be sure that the output frame rate of this camera is fine.
Grateful for any help, thanks!
