GStreamer "CameraCapture-Encode-Decode-Display" Single Pipeline Warning - A lot of buffers are being dropped
Hi All,
I want to “capture camera using nvarguscamerasrc, encode it with nvv4l2h264enc, decode it with nvv4l2decoder and display it on HDMI monitor using Single GStreamer Pilepline. I am facing " A lot of buffers are being dropped.” warning with below pipeline. Can you please provide working pipeline OR help to resolve the issue.
Note : The same pipeline works fine if i use videotestsrc instead of nvarguscamerasrc OR if i save the h264 stream and then do video playback as mentioned in Clarification about h264 parsing with nvv4l2h264enc / nvv4l2decoder
GStreamer pipeline
gst-launch-1.0 -v nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=640, height=480, framerate=30/1, format=NV12' ! nvv4l2h264enc ! nvv4l2decoder ! nvoverlaysink
GStreamer pipeline output with warnings
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, level=(string)NULL, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601, chroma-site=(string)jpeg
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, level=(string)NULL, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601, chroma-site=(string)jpeg
Redistribute latency…
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
/GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
H264: Profile = 66, Level = 0
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)640, height=(int)480, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)640, height=(int)480, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)30/1
WARNING: from element /GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0: A lot of buffers are being dropped.
> Additional debug info:
> gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0:
There may be a timestamping problem, or this computer is too slow.
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:05.071223021
Setting pipeline to READY …
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL …
(gst-launch-1.0:15198): GStreamer-CRITICAL **: 20:22:10.321: gst_mini_object_unref: assertion ‘GST_MINI_OBJECT_REFCOUNT_VALUE (mini_object) > 0’ failed
I cannot test now, but you may try specifying byte-stream fromat such as:
gst-launch-1.0 -v nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=640, height=480, framerate=30/1, format=NV12' ! nvv4l2h264enc !  video/x-h264, stream-format=byte-stream ! nvv4l2decoder ! nvoverlaysink
or add nvvidconv:
gst-launch-1.0 -v nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=640, height=480, framerate=30/1, format=NV12' ! nvv4l2h264enc ! video/x-h264, stream-format=byte-stream ! nvv4l2decoder ! nvvidconv ! nvoverlaysink
Hi, Thanks for your reply.
I tried the pipelines you suggested. Still the warning(A lot of buffers are being dropped) exists. Let me know if you want me to try any other pipeline.
I was able to run below pipeline for H.265, but it stalls when i run the ame pipeline for H.264. Are you aware why it stalls for H.264 ?
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1, format=NV12’ ! nvv4l2h265enc ! h265parse ! video/x-h265,stream-format=byte-stream ! nvv4l2decoder ! nvoverlaysink
FYI… Stalled H.64 pipeline
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1, format=NV12’ ! nvv4l2h264enc ! h264parse ! video/x-h264,stream-format=byte-stream ! nvv4l2decoder ! nvoverlaysink
Output of stalled H.264 pipeline. I had to press CTRL+C to come out of the pipeline.
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29.999999
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)constrained-baseline, level=(string)4, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)constrained-baseline, level=(string)4, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
(gst-launch-1.0:19183): GStreamer-CRITICAL **: 17:34:59.272: gst_mini_object_unref: assertion 'mini_object != NULL' failed
Interrupt: Stopping pipeline ...
Execution ended after 0:00:06.885789668
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
^C
For some reason, with h264 stream in byte-stream format, nvv4l2decoder fails.
The workaround is just to remove h264parse.
