hello
I run the code and put the output below.
Maybe I should explain what I am trying to do. I want to record video with my PI Camera. I also need the ability to stop recording and restart it. The Time delay between the restart end the point where a new frame is saved should be as short as possible. I also want to break the recorded video up in smaller files so it becomes easier to handle later. The problem wars never that I wasn’t able to record Video from my PI camera, the problem was that I did it wrong and it dropped 90% of all frames. I am sure that there is a easy solution out there from someone who knows more about this stuff then I do. I would be happy with something like:
open pipeline to camera with specified resolution and frame rate,
start recording to file X for 60 sec
check if still recording
yes: record again for 60 sec
no: wait for start signal
EDIT:
so I need the hardware support
0:00:00.000274635 5856 0x55ae4eb200 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.1
0:00:00.000399114 5856 0x55ae4eb200 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000457291 5856 0x55ae4eb200 INFO GST_INIT gst.c:607:init_pre: Linux jetson 4.9.140-tegra #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019 aarch64
0:00:00.001109425 5856 0x55ae4eb200 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.002560828 5856 0x55ae4eb200 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.003374368 5856 0x55ae4eb200 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.003671971 5856 0x55ae4eb200 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.003720409 5856 0x55ae4eb200 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.003787492 5856 0x55ae4eb200 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/jet/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.043473652 5856 0x55ae4eb200 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/jet/.cache/gstreamer-1.0/registry.aarch64.bin in 0,039590 seconds
0:00:00.043622350 5856 0x55ae4eb200 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/jet/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.049132650 5856 0x55ae4eb200 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.049172650 5856 0x55ae4eb200 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.049192442 5856 0x55ae4eb200 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.049210775 5856 0x55ae4eb200 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.2
0:00:00.049223900 5856 0x55ae4eb200 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.049303223 5856 0x55ae4eb200 INFO GST_PIPELINE gstparse.c:337:gst_parse_launch_full: parsing pipeline description 'nvarguscamerasrc ! video/x-raw(memory:NVMM),\ width=(int)1280,\ height=(int)720,\ format=(string)NV12,\ framerate=(fraction)60/1 ! nvvidconv flip-method=0 ! video/x-raw,\ width=(int)1280,\ height=(int)720,\ format=(string)BGRx ! fakesink silent=false '
0:00:00.098514778 5856 0x55ae4eb200 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so" loaded
0:00:00.098574986 5856 0x55ae4eb200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "nvarguscamerasrc"
0:00:00.099013788 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSrc@0x55ae77d4e0> adding pad 'src'
0:00:00.100092952 5856 0x55ae4eb200 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so" loaded
0:00:00.100132327 5856 0x55ae4eb200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "nvvidconv"
0:00:00.100437534 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55ae7860e0> adding pad 'sink'
0:00:00.100490243 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55ae7860e0> adding pad 'src'
0:00:00.101594250 5856 0x55ae4eb200 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.101634407 5856 0x55ae4eb200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "fakesink"
0:00:00.101849927 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSink@0x55ae78e9e0> adding pad 'sink'
0:00:00.101910969 5856 0x55ae4eb200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "pipeline"
0:00:00.102142791 5856 0x55ae4eb200 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstNvArgusCameraSrc named nvarguscamerasrc0 to some pad of Gstnvvconv named nvvconv0 (0/0) with caps "video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1"
0:00:00.102176489 5856 0x55ae4eb200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "capsfilter"
0:00:00.102326280 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55ae794130> adding pad 'sink'
0:00:00.102371020 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55ae794130> adding pad 'src'
0:00:00.102403311 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2087:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.102452634 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.102487530 5856 0x55ae4eb200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.102518832 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvarguscamerasrc0:(any) to element capsfilter0:sink
0:00:00.102550290 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.102575394 5856 0x55ae4eb200 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvarguscamerasrc0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.102607529 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvarguscamerasrc0:src and capsfilter0:sink
0:00:00.102645863 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<capsfilter0:src> pad has no peer
0:00:00.102689508 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvarguscamerasrc0:src and capsfilter0:sink, successful
0:00:00.102706592 5856 0x55ae4eb200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.102735550 5856 0x55ae4eb200 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<nvarguscamerasrc0:src> Received event on flushing pad. Discarding
0:00:00.102774612 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element capsfilter0:src to element nvvconv0:(any)
0:00:00.102794404 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.102818102 5856 0x55ae4eb200 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link capsfilter0:src and nvvconv0:sink
0:00:00.102866279 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<nvvconv0:src> pad has no peer
0:00:00.103030029 5856 0x55ae4eb200 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: capsfilter0 and nvvconv0 in same bin, no need for ghost pads
0:00:00.103066487 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link capsfilter0:src and nvvconv0:sink
0:00:00.103110757 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<nvvconv0:src> pad has no peer
0:00:00.103240549 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked capsfilter0:src and nvvconv0:sink, successful
0:00:00.103261330 5856 0x55ae4eb200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.103282424 5856 0x55ae4eb200 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<capsfilter0:src> Received event on flushing pad. Discarding
0:00:00.103333934 5856 0x55ae4eb200 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of Gstnvvconv named nvvconv0 to some pad of GstFakeSink named fakesink0 (0/0) with caps "video/x-raw, width=(int)1280, height=(int)720, format=(string)BGRx"
0:00:00.103360913 5856 0x55ae4eb200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "capsfilter"
0:00:00.103407684 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55ae794470> adding pad 'sink'
0:00:00.103447215 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55ae794470> adding pad 'src'
0:00:00.103480600 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2087:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.103524819 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to NULL
0:00:00.103552111 5856 0x55ae4eb200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.103583673 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvvconv0:(any) to element capsfilter1:sink
0:00:00.103607527 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter1:sink
0:00:00.103630496 5856 0x55ae4eb200 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvvconv0 and capsfilter1 in same bin, no need for ghost pads
0:00:00.103660183 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvvconv0:src and capsfilter1:sink
0:00:00.103767527 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<capsfilter1:src> pad has no peer
0:00:00.103810287 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvvconv0:src and capsfilter1:sink, successful
0:00:00.103830131 5856 0x55ae4eb200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.103850652 5856 0x55ae4eb200 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<nvvconv0:src> Received event on flushing pad. Discarding
0:00:00.103884037 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element capsfilter1:src to element fakesink0:(any)
0:00:00.103906954 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter1:src
0:00:00.103931954 5856 0x55ae4eb200 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link capsfilter1:src and fakesink0:sink
0:00:00.104050547 5856 0x55ae4eb200 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: capsfilter1 and fakesink0 in same bin, no need for ghost pads
0:00:00.104083412 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link capsfilter1:src and fakesink0:sink
0:00:00.104207422 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked capsfilter1:src and fakesink0:sink, successful
0:00:00.104228828 5856 0x55ae4eb200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.104250234 5856 0x55ae4eb200 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<capsfilter1:src> Received event on flushing pad. Discarding
Setting pipeline to PAUSED ...
0:00:00.104349765 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<fakesink0> current NULL pending VOID_PENDING, desired next READY
0:00:00.104379765 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<fakesink0> completed state change to READY
0:00:00.104405234 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<fakesink0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.104451379 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'fakesink0' changed state to 2(READY) successfully
0:00:00.104483411 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter1> current NULL pending VOID_PENDING, desired next READY
0:00:00.104508098 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to READY
0:00:00.104532213 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.104611015 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 2(READY) successfully
0:00:00.104653358 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvvconv0> current NULL pending VOID_PENDING, desired next READY
0:00:00.104682837 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to READY
0:00:00.104706639 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.104736639 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 2(READY) successfully
0:00:00.104764348 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter0> current NULL pending VOID_PENDING, desired next READY
0:00:00.104787316 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:00.104810962 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.104841483 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:00.104869243 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvarguscamerasrc0> current NULL pending VOID_PENDING, desired next READY
0:00:00.104893722 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to READY
0:00:00.104917628 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.104948930 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 2(READY) successfully
0:00:00.104982472 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2651:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.105006587 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.105057941 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2658:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:00.105100180 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<fakesink0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.105141690 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2958:gst_bin_change_state_func:<pipeline0> child 'fakesink0' is changing state asynchronously to PAUSED
0:00:00.105171899 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter1> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.105206430 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to PAUSED
0:00:00.105229607 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.105262211 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 3(PAUSED) successfully
0:00:00.105290388 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvvconv0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.105518825 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to PAUSED
0:00:00.105551012 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.105586741 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 3(PAUSED) successfully
0:00:00.105619502 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.105654293 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:00.105678356 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.105709293 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:00.105737991 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvarguscamerasrc0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.105786689 5856 0x55ae4eb200 INFO basesrc gstbasesrc.c:1358:gst_base_src_do_seek:<nvarguscamerasrc0> seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1,000000, applied_rate=1,000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.105843928 5856 0x55ae4eb200 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x55ae77e110 on task 0x55ae7a4050
0:00:00.105868616 5856 0x55ae4eb200 INFO GST_PADS gstpad.c:6131:gst_pad_start_task:<nvarguscamerasrc0:src> created task 0x55ae7a4050
0:00:00.105991741 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to PAUSED
0:00:00.106022938 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.106062522 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2995:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 3(PAUSED) successfully without preroll
0:00:00.106089292 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to PAUSED
0:00:00.106094188 5856 0x55ae788230 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad 'sink' in element "nvarguscamerasrc0"
0:00:00.106155751 5856 0x55ae788230 FIXME default gstutils.c:3963:gst_pad_create_stream_id_internal:<nvarguscamerasrc0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.106159240 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
Pipeline is live and does not need PREROLL ...
0:00:00.107163821 5856 0x55ae788230 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
0:00:00.107292467 5856 0x55ae788230 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps:<capsfilter0> reuse caps
0:00:00.107333040 5856 0x55ae788230 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: stream-start (10254), GstEventStreamStart, stream-id=(string)935d05503663308cd7511df756edaddb, flags=(GstStreamFlags)GST_STREAM_FLAG_NONE, group-id=(uint)1;) 0x55ae78d900
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
0:00:00.107562831 5856 0x55ae788230 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)BGRx
Setting pipeline to PLAYING ...
0:00:00.107770851 5856 0x55ae788230 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps:<capsfilter1> reuse caps
0:00:00.107799966 5856 0x55ae4eb200 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.107822257 5856 0x55ae788230 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)BGRx
0:00:00.107850174 5856 0x55ae4eb200 INFO bin gstbin.c:2781:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:00.107989705 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<fakesink0> current READY pending PAUSED, desired next PLAYING
0:00:00.108039392 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2958:gst_bin_change_state_func:<pipeline0> child 'fakesink0' is changing state asynchronously to PLAYING
0:00:00.108075590 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter1> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.108105642 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to PLAYING
0:00:00.108149861 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.108188506 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 4(PLAYING) successfully
0:00:00.108249965 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvvconv0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.108280069 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to PLAYING
0:00:00.108468506 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.108504079 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 4(PLAYING) successfully
0:00:00.108603349 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.108631891 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to PLAYING
0:00:00.108652724 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.108701422 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:00.108735484 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to PLAYING
0:00:00.108786161 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.108817359 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 4(PLAYING) successfully
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)BGRx
New clock: GstSystemClock
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)BGRx
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: caps (12814), GstEventCaps, caps=(GstCaps)"video/x-raw\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ framerate\=\(fraction\)60/1\,\ format\=\(string\)BGRx";) 0x55ae78dac0
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)BGRx
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)BGRx
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21,000000 fps Duration = 47619048 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28,000001 fps Duration = 35714284 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120,000005
GST_ARGUS: PowerService: requested_clock_Hz=12096000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
0:00:00.729162403 5856 0x55ae788230 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1,000000, applied_rate=1,000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.729386569 5856 0x55ae788230 INFO basesrc gstbasesrc.c:2945:gst_base_src_loop:<nvarguscamerasrc0> marking pending DISCONT
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: segment (17934), GstEventSegment, segment=(GstSegment)"GstSegment, flags=(GstSegmentFlags)GST_SEGMENT_FLAG_NONE, rate=(double)1, applied-rate=(double)1, format=(GstFormat)GST_FORMAT_TIME, base=(guint64)0, offset=(guint64)0, start=(guint64)0, stop=(guint64)18446744073709551615, time=(guint64)0, position=(guint64)0, duration=(guint64)18446744073709551615;";) 0x55ae78db30
0:00:00.738874672 5856 0x55ae788230 INFO GST_STATES gstbin.c:3431:bin_handle_async_done:<pipeline0> setting state from PAUSED to PAUSED, pending PLAYING
0:00:00.738918057 5856 0x55ae788230 INFO GST_STATES gstbin.c:3451:bin_handle_async_done:<pipeline0> continue state change, pending PLAYING
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = preroll *******
0:00:00.739247327 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:3248:gst_bin_continue_func:<pipeline0> continue state change PAUSED to PLAYING, final PLAYING
0:00:00.739432796 5856 0x55ae7885e0 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.739531650 5856 0x55ae7885e0 INFO bin gstbin.c:2781:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:00.739614931 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<fakesink0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.739664670 5856 0x55ae7885e0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<fakesink0> completed state change to PLAYING
0:00:00.739701337 5856 0x55ae7885e0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<fakesink0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.621405458, pts: 0:00:00.621405458, duration: none, offset: -1, offset_end: -1, flags: 00000040 discont , meta: none) 0x7f7400a6d0
0:00:00.739990972 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'fakesink0' changed state to 4(PLAYING) successfully
0:00:00.740033576 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter1> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.740062065 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2621:gst_bin_element_set_state:<capsfilter1> skipping transition from PLAYING to PLAYING
0:00:00.740088107 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 4(PLAYING) successfully
0:00:00.740121180 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvvconv0> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.740146388 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2621:gst_bin_element_set_state:<nvvconv0> skipping transition from PLAYING to PLAYING
0:00:00.740172794 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 4(PLAYING) successfully
0:00:00.740201648 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter0> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.740227221 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2621:gst_bin_element_set_state:<capsfilter0> skipping transition from PLAYING to PLAYING
0:00:00.740252117 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:00.740279721 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvarguscamerasrc0> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.740300294 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2621:gst_bin_element_set_state:<nvarguscamerasrc0> skipping transition from PLAYING to PLAYING
0:00:00.740325450 5856 0x55ae7885e0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 4(PLAYING) successfully
0:00:00.740354096 5856 0x55ae7885e0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to PLAYING
0:00:00.740379825 5856 0x55ae7885e0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.637405837, pts: 0:00:00.637405837, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.653833299, pts: 0:00:00.653833299, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.671114249, pts: 0:00:00.671114249, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.688318689, pts: 0:00:00.688318689, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.704888442, pts: 0:00:00.704888442, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ac20
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.721504081, pts: 0:00:00.721504081, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.738615760, pts: 0:00:00.738615760, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.755514054, pts: 0:00:00.755514054, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.772958077, pts: 0:00:00.772958077, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.790445276, pts: 0:00:00.790445276, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a6d0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.807552372, pts: 0:00:00.807552372, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.824243791, pts: 0:00:00.824243791, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.841247867, pts: 0:00:00.841247867, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.858619650, pts: 0:00:00.858619650, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.876058984, pts: 0:00:00.876058984, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ac20
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.893136966, pts: 0:00:00.893136966, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.910212395, pts: 0:00:00.910212395, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.927639230, pts: 0:00:00.927639230, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.944566430, pts: 0:00:00.944566430, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.961773630, pts: 0:00:00.961773630, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a6d0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.978804372, pts: 0:00:00.978804372, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:00.996031572, pts: 0:00:00.996031572, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.013547052, pts: 0:00:01.013547052, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.030888210, pts: 0:00:01.030888210, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.047719942, pts: 0:00:01.047719942, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ac20
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.065012923, pts: 0:00:01.065012923, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.082220800, pts: 0:00:01.082220800, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.099368677, pts: 0:00:01.099368677, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.116591346, pts: 0:00:01.116591346, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.133944066, pts: 0:00:01.133944066, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a6d0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.150974964, pts: 0:00:01.150974964, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.168084508, pts: 0:00:01.168084508, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.185349208, pts: 0:00:01.185349208, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.202452033, pts: 0:00:01.202452033, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.219749962, pts: 0:00:01.219749962, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ac20
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.236889610, pts: 0:00:01.236889610, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.254114257, pts: 0:00:01.254114257, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.271018125, pts: 0:00:01.271018125, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.288396887, pts: 0:00:01.288396887, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.305474608, pts: 0:00:01.305474608, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a6d0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.322679932, pts: 0:00:01.322679932, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.339962600, pts: 0:00:01.339962600, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.357318965, pts: 0:00:01.357318965, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.375165902, pts: 0:00:01.375165902, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.392619872, pts: 0:00:01.392619872, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ac20
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.409908477, pts: 0:00:01.409908477, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400ab10
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.426942916, pts: 0:00:01.426942916, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400aa00
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.444288187, pts: 0:00:01.444288187, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.461885541, pts: 0:00:01.461885541, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.478853887, pts: 0:00:01.478853887, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a6d0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.495591451, pts: 0:00:01.495591451, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a7e0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (3686400 bytes, dts: 0:00:01.513242555, pts: 0:00:01.513242555, duration: none, offset: -1, offset_end: -1, flags: 00000000 , meta: none) 0x7f7400a8f0
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:01.529916475
0:00:01.638865552 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<fakesink0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:01.638931073 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2958:gst_bin_change_state_func:<pipeline0> child 'fakesink0' is changing state asynchronously to PAUSED
0:00:01.638983677 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter1> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:01.639022218 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to PAUSED
0:00:01.639059562 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:01.639121385 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 3(PAUSED) successfully
0:00:01.639168937 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvvconv0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:01.639207739 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to PAUSED
0:00:01.639244093 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:01.639290187 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 3(PAUSED) successfully
0:00:01.639400186 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:01.639444561 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:01.639482634 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:01.639530603 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:01.639577217 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvarguscamerasrc0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:01.639617165 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to PAUSED
0:00:01.639654613 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:01.639703154 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2995:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 3(PAUSED) successfully without preroll
0:00:01.639747998 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to PAUSED
0:00:01.639790498 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
Setting pipeline to READY ...
0:00:01.639990602 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<fakesink0> current PLAYING pending PAUSED, desired next READY
0:00:01.640115549 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<fakesink0> completed state change to READY
0:00:01.640172841 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<fakesink0> notifying about state-changed PLAYING to READY (VOID_PENDING pending)
0:00:01.640242684 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'fakesink0' changed state to 2(READY) successfully
0:00:01.640305601 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter1> current PAUSED pending VOID_PENDING, desired next READY
0:00:01.640393778 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to READY
0:00:01.640450132 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:01.640514350 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 2(READY) successfully
0:00:01.640700287 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvvconv0> current PAUSED pending VOID_PENDING, desired next READY
0:00:01.641210755 5856 0x55ae788230 INFO basesrc gstbasesrc.c:2965:gst_base_src_loop:<nvarguscamerasrc0> pausing after gst_pad_push() = flushing
0:00:01.641287838 5856 0x55ae788230 INFO task gsttask.c:316:gst_task_func:<nvarguscamerasrc0:src> Task going to paused
0:00:01.642018201 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to READY
0:00:01.642286638 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:01.642366169 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 2(READY) successfully
0:00:01.642429190 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next READY
0:00:01.642520231 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:01.642561898 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:01.642612679 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:01.642708564 5856 0x55ae788230 INFO task gsttask.c:318:gst_task_func:<nvarguscamerasrc0:src> Task resume from paused
GST_ARGUS: Cleaning up
GST_ARGUS:
PowerServiceHwVic::cleanupResources
CONSUMER: Done Success
GST_ARGUS: Done Success
0:00:01.777587933 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to READY
0:00:01.777640381 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:01.777683141 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 2(READY) successfully
0:00:01.777723662 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to READY
0:00:01.777751214 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:01.777808557 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2087:gst_bin_get_state_func:<pipeline0> getting state
Setting pipeline to NULL ...
0:00:01.777889182 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<fakesink0> current READY pending VOID_PENDING, desired next NULL
0:00:01.777932463 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<fakesink0> completed state change to NULL
0:00:01.777962463 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<fakesink0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:01.777997359 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'fakesink0' changed state to 1(NULL) successfully
0:00:01.778028192 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter1> current READY pending VOID_PENDING, desired next NULL
0:00:01.778057567 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to NULL
0:00:01.778081942 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:01.778116734 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 1(NULL) successfully
0:00:01.778142307 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvvconv0> current READY pending VOID_PENDING, desired next NULL
0:00:01.778174077 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to NULL
0:00:01.778202098 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:01.778230483 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 1(NULL) successfully
0:00:01.778256213 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next NULL
0:00:01.778288296 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:01.778312515 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:01.778343869 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 1(NULL) successfully
0:00:01.778371264 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2504:gst_bin_element_set_state:<nvarguscamerasrc0> current READY pending VOID_PENDING, desired next NULL
0:00:01.778399910 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to NULL
0:00:01.778424233 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:01.778455066 5856 0x55ae4eb200 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 1(NULL) successfully
0:00:01.778545847 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to NULL
0:00:01.778572983 5856 0x55ae4eb200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to NULL (VOID_PENDING pending)
Freeing pipeline ...
0:00:01.778638035 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvvconv0:src(0x55ae77e540) and capsfilter1:sink(0x55ae77ee80)
0:00:01.778678972 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvvconv0:src and capsfilter1:sink
0:00:01.778715586 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking capsfilter1:src(0x55ae77f0d0) and fakesink0:sink(0x55ae77e790)
0:00:01.778746576 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked capsfilter1:src and fakesink0:sink
0:00:01.778775586 5856 0x55ae4eb200 INFO GST_PARENTAGE gstbin.c:1799:gst_bin_remove_func:<pipeline0> removed child "capsfilter1"
0:00:01.778821992 5856 0x55ae4eb200 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<capsfilter1> 0x55ae794470 dispose
0:00:01.778848919 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<capsfilter1> removing pad 'sink'
0:00:01.778881419 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<capsfilter1> removing pad 'src'
0:00:01.778911471 5856 0x55ae4eb200 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<capsfilter1> 0x55ae794470 parent class dispose
0:00:01.778934909 5856 0x55ae4eb200 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<capsfilter1> 0x55ae794470 finalize
0:00:01.778956367 5856 0x55ae4eb200 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<capsfilter1> 0x55ae794470 finalize parent
0:00:01.778990117 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvarguscamerasrc0:src(0x55ae77e0a0) and capsfilter0:sink(0x55ae77e9e0)
0:00:01.779022148 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvarguscamerasrc0:src and capsfilter0:sink
0:00:01.779057617 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking capsfilter0:src(0x55ae77ec30) and nvvconv0:sink(0x55ae77e2f0)
0:00:01.779087773 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked capsfilter0:src and nvvconv0:sink
0:00:01.779116002 5856 0x55ae4eb200 INFO GST_PARENTAGE gstbin.c:1799:gst_bin_remove_func:<pipeline0> removed child "capsfilter0"
0:00:01.779153815 5856 0x55ae4eb200 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<capsfilter0> 0x55ae794130 dispose
0:00:01.779176419 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<capsfilter0> removing pad 'sink'
0:00:01.779203658 5856 0x55ae4eb200 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<capsfilter0> removing pad 'src'
0:00:01.779231054 5856 0x55ae4eb200 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<capsfilter0> 0x55ae794130 parent class dispose
0:00:01.779252460 5856 0x55ae4eb200 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<capsfilter0> 0x55ae794130 finalize
0:00:01.779273554 5856 0x55ae4eb200 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<capsfilter0> 0x55ae794130 finalize parent
0:00:01.779300168 5856 0x55ae4eb200 INFO GST_PARENTAGE gstbin.c:1799:gst_bin_remove_func:<pipeline0> removed child "fakesink0"
0:00:01.779330689 5856 0x55ae4eb200 INFO
