Jetson TX2 RTSP Streaming, FFmpeg or Gstreamer?
I am using the Jetson TX2 dev board to work on real-time video processing.
Thanks to many other topics, I wrote this code :
#include "iostream"
#include "string"
#include "opencv2/opencv.hpp"
#include "opencv2/core.hpp"
int main()
// VideoCapture Pipe
std::string Cap_pipeline("nvarguscamerasrc ! "
"video/x-raw(memory:NVMM), width=1920, height=1080,format=NV12, framerate=30/1 ! "
“nvvidconv ! video/x-raw,format=I420 ! appsink”);
// VideoWriter Pipe
std::string Stream_Pipeline("appsrc is-live=true ! autovideoconvert ! "
"omxh264enc control-rate=2 bitrate=10000000 ! video/x-h264, "
"stream-format=byte-stream ! rtph264pay mtu=1400 ! "
“udpsink host=192.168.1.102 port=5000 sync=false async=false”);
cv::VideoCapture Cap(Cap_pipeline,cv::CAP_GSTREAMER);
cv::VideoWriter Stream(Stream_Pipeline, cv::CAP_GSTREAMER,
30, cv::Size(1920, 1080), true);
// check for issues
if(!Cap.isOpened() || !Stream.isOpened()) {
std::cout << “I/O Pipeline issue” << std::endl;
while(true) {
cv::Mat frame;
Cap >> frame; //read last frame
if (frame.empty()) break;
  cv::Mat bgr;
  cv::cvtColor(frame, bgr, cv::COLOR_YUV2BGR_I420);
  //video processing
  Stream.write(bgr);// write the frame to the stream
  char c = (char)cv::waitKey(1);
  if( c == 27 ) break;
Cap.release();
Stream.release();
return 0;
With this code, I can recover, process and live-stream the video coming from the onboard CSI camera to a client PC.
To read the stream, I can use GStreamer with the following command :
gst-launch-1.0 udpsrc port=5000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! queue ! avdec_h264 ! autovideosink sync=false async=false -e
or FFmpeg or VLC using an SDP file.
However, I would like to use an RTSP stream, so that a do not have to use an SDP file, which would more easy for the future.
I have two questions :
  • Is there a way to use a code similar to ./test- launch from gst-rtsp-server to stream the cv::Mat processed with openCV in RTSP?
  • Which library has better performance between FFmpeg and GStreamer for h264/h265 RTSP video streaming?
OpenCV version: 4.3.0 (instaled with JEP script : https://github.com/AastaNV/JEP/tree/master/script)
Jetpack version: 4.4 DeepStream
hi,
The questions are more about OpenCV. Suggest go to OpenCV forum.
You may say you have a pipeline to run UDP streaming:
// VideoWriter Pipe
"x264enc ! video/x-h264, "
And ask for suggestion of changing it to RTSP streaming. Once you have a working pipeline, you may replace x264enc with hardware encoder nvv4l2h264enc.
We are deprecating omx plugins and please use v4l2 plugins for video encoding/decoding.
Hi @DaneLLL
Thank you for your help, I will ask this question on the OpenCV forum.
You may use the videowriter with a gstreamer pipeline producing the h264 stream and sending to shmsink, so that you can get it from shmsrc inside test-launch:
#include <iostream>
#include <opencv2/opencv.hpp>
#include <opencv2/videoio.hpp>
int main ()
  //setenv ("GST_DEBUG", "*:3", 0);
  /* Setup capture with gstreamer pipeline from onboard camera converting into BGR frames for app */
  const char *gst_cap =
    "nvarguscamerasrc  ! video/x-raw(memory:NVMM), format=(string)NV12, width=(int)640, height=(int)480, framerate=(fraction)30/1 ! "
    "nvvidconv    ! video/x-raw,              format=(string)BGRx ! "
    "videoconvert ! video/x-raw,              format=(string)BGR  ! "
    "appsink";
  cv::VideoCapture cap (gst_cap, cv::CAP_GSTREAMER);
  if (!cap.isOpened ()) {
    std::cout << "Failed to open camera." << std::endl;
    return (-1);
  unsigned int width = cap.get (cv::CAP_PROP_FRAME_WIDTH);
  unsigned int height = cap.get (cv::CAP_PROP_FRAME_HEIGHT);
  unsigned int fps = cap.get (cv::CAP_PROP_FPS);
  unsigned int pixels = width * height;
  std::cout << " Frame size : " << width << " x " << height << ", " << pixels <<
    " Pixels " << fps << " FPS" << std::endl;
  cv::VideoWriter h264_shmsink
     ("appsrc is-live=true ! queue ! videoconvert ! video/x-raw, format=RGBA ! nvvidconv ! "
      "omxh264enc insert-vui=true ! video/x-h264, stream-format=byte-stream ! h264parse ! shmsink socket-path=/tmp/my_h264_sock ",
     cv::CAP_GSTREAMER, 0, fps, cv::Size (width, height));
  if (!h264_shmsink.isOpened ()) {
    std::cout << "Failed to open h264_shmsink writer." << std::endl;
    return (-2);
  /* Loop for 3000 frames (100s at 30 fps) */
  cv::Mat frame_in;
  int frameCount = 0;
  while (frameCount++ < 3000) {
    if (!cap.read (frame_in)) {
      std::cout << "Capture read error" << std::endl;
      break;
    else {
      h264_shmsink.write (frame_in);
  h264_shmsink.release();
  cap.release ();
  return 0;
Build, then launch it. It would write into /tmp/my_h264_sock.
So now you would launch your RTSP server with:
./test-launch "shmsrc socket-path=/tmp/my_h264_sock ! video/x-h264, stream-format=byte-stream, width=640, height=480, framerate=30/1 ! h264parse ! video/x-h264, stream-format=byte-stream ! rtph264pay pt=96 name=pay0 "
Just checked from localhost with:
gst-launch-1.0 -ev rtspsrc location=rtsp://127.0.0.1:8554/test ! application/x-rtp, media=video, encoding-name=H264 ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! videoconvert ! xvimagesink
…seems to work fine so far, at least in this case.
Got surprizing results with nvv4l2 encoder/decoder, so I propose using OMX plugins for now with this case.
For using VLC on receiver side, some extra work may be required (EDIT: mainly need to use property do-timestamp=1 for shmrc in test-launch pipeline).
Note that sockets are created by shmsink, but won’t be deleted if a shmsrc is still connected.
So after each trial when your app and test-launch are closed, remove any remaining socket with:
rm /tmp/my_h264_sock*
before trying again.
Hy @Honey_Patouceul
Indeed, this solution could work. I think I will do this temporary, but I’ll try to merge openCV and test-launch.c later to obtain something more user-friendly.
Matteo Luci
If it can help anyone, I used the appsrc.c example of GstRtspServer to write this code :
#include "gstreamer-1.0/gst/gst.h"
#include "gstreamer-1.0/gst/gstmessage.h"
#include "gstreamer-1.0/gst/rtsp-server/rtsp-server.h"
#include "glib-2.0/glib.h"
#include <gstreamer-1.0/gst/app/app.h>
#include <iostream>
#include <string>
#define W 1920
#define H 1080
#define FPS 30
typedef struct
	cv::VideoCapture *cap;
	cv::Mat *lastFrame;
	int *numberFrames;
	GstClockTime timestamp;
} MyContext;
// should be private data of c++ class
int numberFrames = 0;
cv::Mat lastFrame;
std::string launchString = "nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)" +
		std::to_string(W) + ", height=(int)" +
    	std::to_string(H) + ", format=(string)NV12, framerate=(fraction)" +
    	std::to_string(FPS) + "/1 ! nvvidconv flip-method=" +
    	std::to_string(0) + " ! video/x-raw, width=(int)" +
    	std::to_string(H) + ", format=(string)BGRx"
    	" ! videoconvert ! video/x-raw, format=(string)BGR ! appsink sync=false";
cv::VideoCapture cap = cv::VideoCapture(launchString, cv::CAP_GSTREAMER);
/* called when we need to give data to appsrc */
static void
need_data (GstElement * appsrc, guint unused, MyContext * ctx)
	if (ctx->cap->isOpened()) {
		if (ctx->cap->read(*(ctx->lastFrame))) {
			GstBuffer *buffer;
			uint64_t size=W*H*4; // Image size * deth of BGRx;
			GstFlowReturn ret;
			buffer = gst_buffer_new_allocate (NULL, size, NULL);
			GstMapInfo map;
			gint8 *raw;
			gst_buffer_map (buffer, &map, GST_MAP_WRITE); // make buffer writable
			raw = (gint8 *)map.data;
			for (int i = 0; i<H; i++) {
				cv::Vec3b* ptr = ctx->lastFrame->ptr<cv::Vec3b>(i);
				for (int j = 0; j<W; j++) {
					uint64_t offset = ((i*W)+j)*4;
					raw[offset] = ptr[j][0];
					raw[offset+1] = ptr[j][1];
					raw[offset+2] = ptr[j][2];
					raw[offset+3] = 127;
			gst_buffer_unmap (buffer, &map);
			/* increment the timestamp every 1/FPS second */
			GST_BUFFER_PTS (buffer) = ctx->timestamp;
			GST_BUFFER_DURATION (buffer) = gst_util_uint64_scale_int (1, GST_SECOND, FPS);
			ctx->timestamp += GST_BUFFER_DURATION (buffer);
			g_signal_emit_by_name (appsrc, "push-buffer", buffer, &ret);
			gst_buffer_unref (buffer);
/* called when a new media pipeline is constructed. We can query the
 * pipeline and configure our appsrc */
static void
media_configure (GstRTSPMediaFactory * factory, GstRTSPMedia * media, gpointer user_data)
	// should be incremented once on each frame for timestamping
	GstElement *element, *appsrc;
	MyContext *ctx;
	/* get the element used for providing the streams of the media */
	element = gst_rtsp_media_get_element (media);
	/* get our appsrc, we named it 'mysrc' with the name property */
	appsrc = gst_bin_get_by_name_recurse_up (GST_BIN (element), "mysrc");
	/* this instructs appsrc that we will be dealing with timed buffer */
	gst_util_set_object_arg (G_OBJECT (appsrc), "format", "time");
	/* configure the caps of the video */
	g_object_set (G_OBJECT (appsrc), "caps",
	gst_caps_new_simple ("video/x-raw",
				"format", G_TYPE_STRING, "BGRx",
				"width", G_TYPE_INT, W,
				"height", G_TYPE_INT, H,
				"framerate", GST_TYPE_FRACTION, FPS, 1, NULL), NULL);
	ctx = g_new0 (MyContext, 1);
	ctx->timestamp = 0;
	ctx->cap = &cap;
	ctx->lastFrame = &lastFrame;
	ctx->numberFrames = &numberFrames;
	/* make sure ther datais freed when the media is gone */
	g_object_set_data_full (G_OBJECT (media), "my-extra-data", ctx, (GDestroyNotify) g_free);
	/* install the callback that will be called when a buffer is needed */
	g_signal_connect (appsrc, "need-data", (GCallback) need_data, ctx);
	gst_object_unref (appsrc);
	gst_object_unref (element);
int main (int argc, char *argv[])
	GMainLoop *loop;
	GstRTSPServer *server;
	GstRTSPMountPoints *mounts;
	GstRTSPMediaFactory *factory;
	gst_init (&argc, &argv);
	loop = g_main_loop_new (NULL, FALSE);
	/* create a server instance */
	server = gst_rtsp_server_new ();
	/* get the mount points for this server, every server has a default object
	* that be used to map uri mount points to media factories */
    mounts = gst_rtsp_server_get_mount_points (server);
	/* make a media factory for a test stream. The default media factory can use
	* gst-launch syntax to create pipelines.
	* any launch line works as long as it contains elements named pay%d. Each
	* element with pay%d names will be a stream */
	factory = gst_rtsp_media_factory_new ();
	gst_rtsp_media_factory_set_launch (factory,
			"( appsrc name=mysrc is-live=true ! videoconvert ! omxh265enc ! rtph265pay mtu=1400 name=pay0 pt=96 )");
	gst_rtsp_media_factory_set_shared (factory, TRUE);
	/* notify when our media is ready, This is called whenever someone asks for
	* the media and a new pipeline with our appsrc is created */
	g_signal_connect (factory, "media-configure", (GCallback) media_configure, NULL);
	/* attach the test factory to the /test url */
	gst_rtsp_mount_points_add_factory (mounts, "/test", factory);
	/* don't need the ref to the mounts anymore */
	g_object_unref (mounts);
	/* attach the server to the default maincontext */
	gst_rtsp_server_attach (server, NULL);
	/* start serving */
	g_print ("stream ready at rtsp://127.0.0.1:8554/test\n");
	g_main_loop_run (loop);
	return 0;
All this code can be put in a C++ class and the GMainloop can loop in a separate thread.
With this code, it is possible to send cv::mat data to an RTSP stream, and therefore, any processing can be done on those frames.
I think that there is a lot of improvement that must be done to optimize all this, but it is a working base.
Hello, how can I use v4l2 for video capturing with VideoCapture instead of gst?
I edited your code but got some problem(Im using vlc for receiveing video):
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
[ WARN:0] global /home/niyaz/opencv/modules/videoio/src/cap_v4l.cpp (1001) tryIoctl VIDEOIO(V4L2:/dev/video0): select() timeout.
This edited code:
// g++ opencv-gst-rtsp.cpp $(pkg-config --cflags --libs glib-2.0) $(pkg-config --cflags --libs gstreamer-1.0 gstreamer-rtsp-server-1.0) -o opencv_gst_rtsp $(pkg-config --cflags --libs opencv4)
include “gstreamer-1.0/gst/gst.h”
include “gstreamer-1.0/gst/gstmessage.h”
include “gstreamer-1.0/gst/rtsp-server/rtsp-server.h”
include “glib-2.0/glib.h”
include
include
define W 1920
define H 1080
define FPS 30
typedef struct
cv::Mat *lastFrame;
int *numberFrames;
} MyContext;
cv::Mat lastFrame;
// std::string launchString = “nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)” +
// std::to_string(W) + “, height=(int)” +
// std::to_string(H) + “, format=(string)NV12, framerate=(fraction)” +
// std::to_string(FPS) + “/1 ! nvvidconv flip-method=” +
// std::to_string(0) + " ! video/x-raw, width=(int)" +
// std::to_string(H) + “, format=(string)BGRx”
// " ! videoconvert ! video/x-raw, format=(string)BGR ! appsink sync=false";
// cv::VideoCapture cap = cv::VideoCapture(launchString, cv::CAP_GSTREAMER);
cv::VideoCapture cap = cv::VideoCapture(0 + 200);
/* called when we need to give data to appsrc /
static void
ctx->cap->set(3,1920);
ctx->cap->set(4,1080);
if (ctx->cap->read(
        GstBuffer *buffer;
        GstFlowReturn ret;
        GstMapInfo map;
        gint8 *raw;
  • pipeline and configure our appsrc */
    static void
    MyContext *ctx;
    /* get our appsrc, we named it ‘mysrc’ with the name property */
    appsrc = gst_bin_get_by_name_recurse_up (GST_BIN (element), “mysrc”);
    /* this instructs appsrc that we will be dealing with timed buffer /
    gst_util_set_object_arg (G_OBJECT (appsrc), “format”, “time”);
    g_object_set (G_OBJECT (appsrc), “caps”,
    gst_caps_new_simple (“video/x-raw”,
    “format”, G_TYPE_STRING, “BGRx”,
    “width”, G_TYPE_INT, W,
    “height”, G_TYPE_INT, H,
    “framerate”, GST_TYPE_FRACTION, FPS, 1, NULL), NULL);
    ctx->timestamp = 0;
    ctx->cap = ∩
    g_object_set_data_full (G_OBJECT (media), “my-extra-data”, ctx, (GDestroyNotify) g_free);
    g_signal_connect (appsrc, “need-data”, (GCallback) need_data, ctx);
int main (int argc, char *argv)
GMainLoop *loop;
        "( appsrc name=mysrc is-live=true ! videoconvert ! omxh264enc ! rtph264pay mtu=1400 name=pay0 pt=96 )");
/* start serving */
return 0;
Hello xenonscrinium,
If you would like to read /dev/video0 using v4l2 with VideoCapture, you can do this :
cv::VideoCapture(0, cv::CAP_V4L2);
I also had issues reading the RTSP stream using VLC. However, it was working with Gstreamer or FFmpeg but it strangely work later with VLC also, maybe an update on their side.
If you are not able to read the video using Gstreamer of FFmpeg on the client-side, first try to display the video directly on the jetson to be sure the video is correctly detected.
You may also have to check to pixel format in your CV::mat.
Mattéo
