The use case is to support time synchronization between the Jetson and another chip.
We would trigger a gpio toggle from the Jetson, and timestamp it with the GTE. It would give us the timestamp of the toggle in Jetson time.
The same signal is sampled by another chip, which also stamps it in HW, and then transfers this foreign timestamp together with other data to the Jetson via a serial communication.
We can then align the data to jetson time thanks to this.
Ignoring the second GTE event could be considered, but I would need to check if it puts a limit on the achievable frequency at which we can use the GTE without ambiguity.
In general understanding what is going on, and avoiding workarounds would be preferred, since careful evaluation of the side effects would need to be done. Also this functionality requires a high level of reliability.
I hope you can help us to understand the machinery behind this.
Sorry for the late response.
