Ih’ave the same problem and I don’t know how i can find the number of device supposed to be audio nvidia (1:00:10 ?)
I’m on linux mint mate 18.3 Sylvia 64bits
$ inxi -SMCGx
System: Host: andromeda Kernel: 4.13.0-37-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: MATE 1.18.0 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.3 Sylvia
Machine: Mobo: ASUSTeK model: FX503VM v: 1.0 Bios: American Megatrends v: FX503VM.305 date: 12/25/2017
CPU: Quad core Intel Core i7-7700HQ (-HT-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 22464
clock speeds: max: 3800 MHz 1: 2800 MHz 2: 2800 MHz 3: 2800 MHz 4: 2800 MHz 5: 2800 MHz 6: 2800 MHz
7: 2800 MHz 8: 2800 MHz
Graphics: Card: NVIDIA Device 1c20 bus-ID: 01:00.0
Display Server: X.Org 1.18.4 driver: nvidia Resolution: 1920x1080@60.01hz
GLX Renderer: GeForce GTX 1060/PCIe/SSE2 GLX Version: 4.6.0 NVIDIA 390.42 Direct Rendering: Yes
pegasus@andromeda /var/log $ inxi -Fxz
Audio: Card Intel Device a171 driver: snd_hda_intel bus-ID: 00:1f.3 Sound: ALSA v: k4.13.0-37-generic
Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Card-2: Intel Device 24fd driver: iwlwifi bus-ID: 04:00.0
IF: wlp4s0 state: up speed: N/A duplex: N/A mac: <filter>
Drives: HDD Total Size: 126.0GB (91.5% used) ID-1: /dev/sda model: SanDisk_SDSSDP12 size: 126.0GB temp: 33C
Partition: ID-1: / size: 107G used: 100G (99%) fs: ext4 dev: /dev/dm-1
ID-2: /boot size: 473M used: 196M (44%) fs: ext2 dev: /dev/sda2
ID-3: swap-1 size: 8.54GB used: 0.00GB (0%) fs: swap dev: /dev/dm-3
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 57.0C mobo: N/A gpu: 0.0:51C
Fan Speeds (in rpm): cpu: 0
Info: Processes: 275 Uptime: 4:40 Memory: 3051.2/7929.0MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
Client: Shell (bash 4.3.481) inxi: 2.2.35
$ lspci -vv
00:00.0 Host bridge: Intel Corporation Device 5910 (rev 05)
Subsystem: ASUSTeK Computer Inc. Device 1b90
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation Sky Lake PCIe Controller (x16) (rev 05) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 16
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: de000000-df0fffff
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
Kernel modules: shpchp
00:08.0 System peripheral: Intel Corporation Sky Lake Gaussian Mixture Model
Subsystem: ASUSTeK Computer Inc. Skylake Gaussian Mixture Model
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 11
Region 0: Memory at df430000 (64-bit, non-prefetchable) [disabled]
00:14.0 USB controller: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller (rev 31) (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H USB 3.0 xHCI Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 124
Region 0: Memory at df410000 (64-bit, non-prefetchable)
Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-H Thermal subsystem (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H Thermal subsystem
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin C routed to IRQ 18
Region 0: Memory at df42f000 (64-bit, non-prefetchable)
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-H LPSS I2C Controller #0 (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H Serial IO I2C Controller
Region 0: Memory at df42e000 (64-bit, non-prefetchable)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:16.0 Communication controller: Intel Corporation Sunrise Point-H CSME HECI #1 (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H CSME HECI
Latency: 0
Interrupt: pin A routed to IRQ 320
Region 0: Memory at df42d000 (64-bit, non-prefetchable)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 31)
Subsystem: ASUSTeK Computer Inc. 82801 Mobile SATA Controller [RAID mode]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 318
Region 0: Memory at df428000 (32-bit, non-prefetchable)
Region 1: Memory at df42c000 (32-bit, non-prefetchable)
Region 2: I/O ports at f050
Region 3: I/O ports at f040
Region 4: I/O ports at f020
Region 5: Memory at df42b000 (32-bit, non-prefetchable)
Kernel driver in use: ahci
Kernel modules: ahci
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #5 (rev f1) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 121
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: df300000-df3fffff
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #6 (rev f1) (prog-if 00 [Normal decode])
Interrupt: pin B routed to IRQ 122
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: df200000-df2fffff
00:1c.6 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #7 (rev f1) (prog-if 00 [Normal decode])
Interrupt: pin C routed to IRQ 123
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: df100000-df1fffff
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-H LPC Controller (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H LPC Controller
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
00:1f.2 Memory controller: Intel Corporation Sunrise Point-H PMC (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H PMC
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: Memory at df424000 (32-bit, non-prefetchable) [disabled]
00:1f.3 Audio device: Intel Corporation Device a171 (rev 31)
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 321
Region 0: Memory at df420000 (64-bit, non-prefetchable)
Region 4: Memory at df400000 (64-bit, non-prefetchable)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1f.4 SMBus: Intel Corporation Sunrise Point-H SMBus (rev 31)
Subsystem: ASUSTeK Computer Inc. Sunrise Point-H SMBus
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: Memory at df42a000 (64-bit, non-prefetchable)
Region 4: I/O ports at f000
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1c20 (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device 154e
Latency: 0
Interrupt: pin A routed to IRQ 323
Region 0: Memory at de000000 (32-bit, non-prefetchable)
Region 1: Memory at c0000000 (64-bit, prefetchable)
Region 3: Memory at d0000000 (64-bit, prefetchable)
Region 5: I/O ports at e000
[virtual] Expansion ROM at 000c0000 [disabled]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: ASUSTeK Computer Inc. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Interrupt: pin A routed to IRQ 319
Region 0: I/O ports at d000
Region 2: Memory at df304000 (64-bit, non-prefetchable)
Region 4: Memory at df300000 (64-bit, non-prefetchable)
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
Subsystem: ASUSTeK Computer Inc. RTS5229 PCI Express Card Reader
Interrupt: pin A routed to IRQ 317
Region 0: Memory at df200000 (32-bit, non-prefetchable)
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
04:00.0 Network controller: Intel Corporation Device 24fd (rev 78)
Subsystem: Intel Corporation Device 0010
Interrupt: pin A routed to IRQ 322
Region 0: Memory at df100000 (64-bit, non-prefetchable)
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
