GTX 1650 No CUDA Support
An error occurred yesterday, (everything worked good until that moment, after which I could no longer use the GTX 1650 as a Cycles Engine Device. I reinstalled everything, all drivers (for GPU and CUDA), but after I started checking which versions of Blender have the same error, I found that it is in each. Therefore, I realized that the problem is in the GPU itself. Also GTX 1650 is not in the lists of CUDA GPUs and in Geeks3D “No CUDA support”. How can I fix that problem, help please.
