I did Tensorflow Machine Learning (RNN) with the GTX1650, but it’s not as fast as I thought.
Before installing the GTX1650, it took about 75 seconds for 1 epoch when using only the CPU, but it was reduced to about 45 seconds when using the GTX1650 GPU.
It was only reduced from 75 seconds to only 30 seconds.
I thought it would be much shorter.
Is this normal?
Graphics card is GTX1650 with 4G GDDR6
CPU AMD Ryzen 3 3200 with VEGA
Tensorflow 2.3.1
CUDA 10.1.243_426.00
CuDNN 7.6.5.32
OS is Win10 and
I ran it in jupyter.
There were no errors in the execution of the GPU computation.
The GPU was recognized as 0, and the GPU share increased to around 25%.
Although it is certain that the GPU is used, the computation speed is not as expected.
