I have an h5 weights file, and I wanted to create a real-time image classifier(not object-detector) on Jetson. I referenced this GitHub page: GitHub - NVIDIA-AI-IOT/tf_to_trt_image_classification: Image classification with NVIDIA TensorRT from TensorFlow models.. However, I was confused as to 1) if it applied to my situation and 2) how it actually worked. I would sincerely appreciate any help!
It’s recommended to use TensorRT for real-time inference on Nano.
1. First, please convert your model into ONNX format.
You can achieves this by using below keras2onnx directly:
2. Then you can deploy the ONNX model with TensorRT directly.
/usr/src/tensorrt/bin/trtexec --onnx=[your/model]
Thanks,
When I try to convert, I get the follow error. AttributeError: 'KerasTensor' object has no attribute 'graph'
Many other people are also encountering this issue, so I was wondering if you had any other alternatives?
For anyone who faces this issue, I referenced this link:python - Why keras2onnx.convert_keras() function keeps getting me error "'KerasTensor' object has no attribute 'graph'" - Stack Overflow.
Also use model.save not model.save_weights. I also used TF 2.3.
Hello @AastaLLL , now when I try to run my onnx model using the command you gave I get the following error.
[04/23/2021-22:51:46] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32. [04/23/2021-22:51:48] [E] [TRT] Network has dynamic or shape inputs, but no optimization profile has been defined. [04/23/2021-22:51:48] [E] [TRT] Network validation failed. [04/23/2021-22:51:49] [E] Engine creation failed [04/23/2021-22:51:49] [E] Engine set up failed &&&& FAILED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=save.onnx
Many people point this issue to TensorRT, and not the ONNX model. Do you have any advice for me?
Could you try the command mentioned in the below comment:
What do I put in the --optShapes=[name].
Hi
The size of your input data.
