I have a c++ program which receives a video stream and I was wondering if it is at all possible to encode that in real-time (in h264 using CUDA) ?
So far, I’ve written a “pass-through” thingy, which copies the stream on my GPU than back without doing anything to it but I needed to test CUDA on my hardware and it works just fine.
//// STREAM COPY
__global__ void streamCopy(unsigned char *a, unsigned char *b, int vSize) {
/// How do I do h264 encoding ?
int i = blockIdx.x;
if (i < vSize) {
b[i] = a[i];
extern "C" void encodeX264(unsigned char *streamIn, unsigned char *streamOut, int vectorSize) {
unsigned char *d_streamIn, *d_streamOut;
gpuErrchk(cudaMalloc((void **)&d_streamIn, vectorSize));
gpuErrchk(cudaMalloc((void **)&d_streamOut, vectorSize));
// Copy input data to array on GPU.
gpuErrchk(cudaMemcpy(d_streamIn, streamIn, vectorSize, cudaMemcpyHostToDevice));
streamCopy<<<1, 1>>>(d_streamIn, d_streamOut, vectorSize);
// Copy output array from GPU back to CPU.
gpuErrchk(cudaMemcpy(streamOut, d_streamOut, vectorSize, cudaMemcpyDeviceToHost));
// Free up the arrays on the GPU.
gpuErrchk(cudaFree(d_streamIn));
gpuErrchk(cudaFree(d_streamOut));
gpuErrchk(cudaProfilerStop());
I just don’t know how to turn my incoming stream into a h264 stream.
Is there any resources that would help ?
I am not looking for a ready made solution, I’m just new to this world of stream encoding and don’t really know where to start.
