. I am writing to seek assistance with an issue I encountered while using MATLAB 2019b and JetPack 4.6.1 with my Nvidia Jetson device. Upon running the code, I received the following error: “Warning: Unable to find ‘nvcc’ on the system path. Update the ‘.bashrc’ script on the target to set up the required environment variables.”
I have reviewed various resources, including forums and support pages, but have not been able to resolve this issue. I have ensured that the necessary environment variables are set, but the error persists.
I would greatly appreciate it if you could provide guidance or a solution to address this issue. Any assistance you can offer would be invaluable. i have now cuda 10.2 installed.
Usually nvcc is installed in "/usr/local/cuda<version>/bin/. There is a symbolic link from “cuda<verison>” to cuda which could be considered the “default” version (all of which of course assumes it was installed via JetPack which matches the L4T release…see “head -n 1 /etc/nv_tegra_release” for that). So basically you could add “/usr/local/cuda/bin” to your path.
The traditional way of doing that is to edit the ~/.bashrc, and assuming there is already a PATH setting in there somewhere, add something similar to this at or after the existing PATH:
export PATH=/usr/local/cuda/bin:$PATH
This is just a colon-delimited string. The $PATH is just your old path, so the above prepends your update to the original PATH.
