[Help] Fine-tuned Qwen3-8B for tool-calling — single-turn is ~95%, but multi-turn BFCL is stuck at ~10–22%. Out of ideas
#TL;DR:
I’ve been fine-tuning Qwen3-8B for function calling. Single-turn BFCL is genuinely strong (92–97% AST). But multi-turn has not moved across five experiments — it’s stuck at ~10–22% per category no matter what data I throw at it. I’ve tried dataset blending, a third “agentic” dataset, and 72B-teacher synthetic data targeting my top-3 failure buckets. Nothing helps multi-turn. Looking for advice on what to try next.
Setup -
Base model: Qwen3-8B - Method: LoRA (r=16, α=32, dropout=0.05), BF16 and later NF4 QLoRA - Benchmark: BFCL v4. Output format is the XLAM Python-AST style — [func(arg=val)] — scored with the non-FC Qwen3-8B handler (this matters; it’s why single-turn parses cleanly). - Multi-turn categories: multi_turn_base, multi_turn_miss_func, multi_turn_miss_param, multi_turn_long_context. BFCL multi-turn is all-or-nothing per trajectory — one bad step fails the whole sample.
The journey (real numbers from my eval artifacts)
Baseline —
Qwen3-8B, no fine-tuning - Multi-turn: base 34%, miss_func 38%, miss_param 24%, long_context 25% (avg ~32%) - So the pretrained model actually has some multi-turn ability.
Exp 1 —
xLAM-60k only (single-turn control) - Data: Salesforce/xlam-function-calling-60k, 100% (57k train). All single-turn. - Config: BF16 LoRA, 800 steps, eff. batch 16, lr 2e-4 cosine, max_seq 4096. eval_loss 0.022. - Result: single-turn 86% avg (simple_python 93.75%, multiple 91%, parallel 85%). - But multi-turn collapsed to 0.25% avg (base 0.5 / miss_func 0.0 / miss_param 0.0 / long_ctx 0.5). - Lesson: pure single-turn SFT erases the pretrained multi-turn ability. Catastrophic forgetting — xLAM has zero “tool result → continuation” examples.
Exp 2 — 60% xLAM + 40% ToolACE blend (continuity supervision)
  • Hypothesis: ToolACE has multi-turn trajectories (tool-result → continuation), so blending should restore multi-turn without killing single-turn.
  • Data: xLAM 60% + ToolACE 40% (~38k examples), max_seq 2048, schema dropout 15%, schema jitter 50%.
  • Config: BF16 LoRA, 1 epoch, eval_loss 0.054, token acc 98.5%.
  • Trained fine; this line of work continued into Exp 3.
Exp 3 — add ToolMind (“agentic” multi-turn data), ~50k blend
  • Data: xLAM + ToolACE + ToolMind multi-turn data, filtered → train_with_toolmind_10k...jsonl (~50k rows). Warm-started from the Exp 2 merged model. max_seq 8192, lr 5e-5.
  • Result (the gut-punch):
    • Single-turn: simple_python 96.8%, multiple 95%, parallel 94%, parallel_multiple 92%, irrelevance 87.9% — basically solved.
    • Multi-turn: base 28% / miss_func 10.5% / miss_param 14.5% / long_context 13.5% (overall avg 62.9% only because single-turn carries it).
  • Adding a whole agentic dataset barely moved multi-turn off baseline.
Exp 5 — synthetic data targeting my failure analysis (NF4 QLoRA, ~50k blend)
This is where I tried to be surgical. I ran a failure analysis on the multi-turn eval outputs and bucketed every failing trajectory. Top categories:
Failure category Share
Invalid / wrong parameter 39.5%
Infinite or redundant loop (re-emits the same calls) 32.5%
Premature termination (gives up too early) 13.2%
Policy/constraint, missing tool call, wrong tool rest
So I built 72B-teacher synthetic data (Qwen2.5-72B-AWQ) targeting the top three, in three generation modes:
  1. Clarify — when params are missing/wrong, briefly clarify then act (targets the 39% invalid-param bucket).
  2. Stop-loop — recognize repeated failures and stop instead of looping (targets the 32% loop bucket).
  3. Abstain — when no tool applies, answer in plain text / don’t over-trigger (targets spurious calls + premature behavior).
All generated from real tool schemas already in the training pool (no hardcoded/out-of-domain tools), validated for format, blended at a small % into the ~50k base.
  • Result: single-turn stayed strong (92–97% AST, irrelevance 84.6%, live 78–81%).
  • Multi-turn: base 22% / miss_func 12% / miss_param 10.5% / long_context 15%.
  • Essentially identical to Exp 3. The targeted synthetic data did not move multi-turn at all.
Where I’m stuck
Experiment Single-turn (avg) MT base MT miss_func MT miss_param MT long_ctx
Baseline (no FT) ~88 34% 38% 24% 25%
Exp1 xLAM-only 86% 0.5% 0% 0% 0.5%
Exp3 +ToolMind ~93% 28% 10.5% 14.5% 13.5%
Exp5 +synthetic ~93% 22% 12% 10.5% 15%
Things I’ve already ruled out as the cause (with hard numbers):
  • Format / wrong BFCL handler — single-turn parses at 92–97% with the same handler, so the format is correct.
  • <think> / thinking-mode leak — 0 out of ~8000 multi-turn steps contain it.
  • max_tokens truncation — <0.5% of steps near the cap.
  • Masking / response-only loss — verified; eval_loss is healthy.
  • Undertraining — a fully-trained run scores the same multi-turn band as a shorter one.
For reference, Qwen3-8B-FC (the official FC variant) only reaches ~30% multi-turn, so I think ~30% is a realistic ceiling — but I can’t even get close to it, despite matching/beating it on single-turn.
What I’m asking
  1. Is the all-or-nothing-per-trajectory scoring just punishing me for any single-step error, and if so what’s the highest-leverage way to reduce per-step error rate in multi-turn?
  2. Is SFT on multi-turn trajectories fundamentally the wrong tool here? Should I be looking at RL / preference methods instead?
  3. Has anyone successfully lifted an open 8B model’s BFCL multi-turn meaningfully above the pretrained baseline with SFT alone? What did the data actually look like?
  4. Is there something about how I’m constructing multi-turn training trajectories (tool results, state, error feedback) that’s the real bottleneck rather than the quantity/mix of data?
Happy to share configs / eval breakdowns. Any pointers appreciated — single-turn was easy, multi-turn is eating me alive.
