All -
I am attempting to use the Face Detect/License Plate detect models (models/Secondary_FaceDetect/fd_lpd.caffemodel_b4_fp16.engine) as [secondary-gie2] but can not figure out how to get the bounding boxes for the face+LP to show up in the tiled output.
My primary config file is:
# Copyright (c) 2019 NVIDIA Corporation. All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=/home/james/Desktop/Kitti
[tiled-display]
enable=1
rows=2
columns=2
width=2560
height=1440
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://XXX@192.168.128.89:554/unicast/c1/s0/live
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=4
uri=rtsp://XXX@192.168.128.89:554/unicast/c2/s0/live
num-sources=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=4
uri=rtsp://XXX@192.168.128.89:554/unicast/c3/s0/live
num-sources=1
gpu-id=0
cudadec-memtype=0
[source3]
enable=1
type=4
uri=rtsp://XXX@192.168.128.89:554/unicast/c4/s0/live
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=8
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=80000
## Set muxer output width and height
width=2560
height=1440
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=/opt/nvidia/deepstream/deepstream-4.0/samples/models/Primary_Detector/resnet10.caffemodel_b4_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_primary_nano.txt
[secondary-gie0]
enable=1
model-engine-file=/opt/nvidia/deepstream/deepstream-4.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_int8.engine
gpu-id=0
batch-size=4
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=1
model-engine-file=/opt/nvidia/deepstream/deepstream-4.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_int8.engine
batch-size=4
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_secondary_carcolor.txt
[secondary-gie2]
enable=0
model-engine-file=/opt/nvidia/deepstream/deepstream-4.0/samples/models/Secondary_FaceDetect/fd_lpd.caffemodel_b4_fp16.engine
batch-size=4
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
interval=4
config-file=/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_secondary_licenseplate.txt
[tracker]
enable=1
tracker-width=480
tracker-height=272
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for IOU only
#ll-config-file=iou_config.txt
gpu-id=0
[tests]
file-loop=0
the config file for secondary-gie2 is:
# Copyright (c) 2018 NVIDIA Corporation. All rights reserved.
# Following properties are mandatory when engine files are not specified:
# int8-calib-file(Only in INT8)
# Caffemodel mandatory properties: model-file, proto-file, output-blob-names
# UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
# ONNX: onnx-file
# Mandatory properties for detectors:
# num-detected-classes
# Optional properties for detectors:
# enable-dbscan(Default=false), interval(Primary mode only, Default=0)
# custom-lib-path,
# parse-bbox-func-name
# Mandatory properties for classifiers:
# classifier-threshold, is-classifier
# Optional properties for classifiers:
# classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
# operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
# input-object-min-width, input-object-min-height, input-object-max-width,
# input-object-max-height
# Following properties are always recommended:
# batch-size(Default=1)
# Other optional properties:
# net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
# model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
# mean-file, gie-unique-id(Default=0), offsets, gie-mode (Default=1 i.e. primary),
# custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../models/Secondary_FaceDetect/fd_lpd.caffemodel
proto-file=../../models/Secondary_FaceDetect/fd_lpd.prototxt
model-engine-file=../../models/Secondary_FaceDetect/fd_lpd.caffemodel_b16_fp16.engine
#int8-calib-file=../../models/Secondary_FaceDetect/cal_trt.bin
#mean-file=../../models/Secondary_FaceDetect/mean.ppm
labelfile-path=../../models/Secondary_FaceDetect/labels.txt
batch-size=16
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=4
process-mode=1
#is-classifier=1
output-blob-names=output_cov/Sigmoid_branch_2
#classifier-async-mode=1
#classifier-threshold=0.51
input-object-min-width=64
input-object-min-height=64
operate-on-gie-id=1
[class-attrs-all]
threshold=0.2
group-threshold=1
## Set eps=0.7 and minBoxes for enable-dbscan=1
eps=0.2
#minBoxes=3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
I am pretty sure I’m missing something basic here but have tried a bunch of things without success.
Any help would be appreciated.
