Help installing PyTorch on Jetson Orin Nano
I’m very frustrated ‘cause after updating Jetson Orin Nano on latest Jetpack can’t instal proper working versin of PyTorch. I even think that PyTorch is instaled but Pyton cant use (find) it.
In directory usr/local/cuda-12.6/targets/aarch64-linux/lib I have libcusparseLt.so.12 and and symbolic links
libcusparse.so.12 (libc6,AArch64) => /usr/local/cuda/targets/aarch64-linux/lib/libcusparse.so.12
libcusparse.so (libc6,AArch64) => /usr/local/cuda/targets/aarch64-linux/lib/libcusparse.so
But simple code:
python3 -c “import torch; print(‘Torch:’, torch.version); print(‘CUDA available:’, torch.cuda.is_available()); print(‘GPU:’, torch.cuda.get_device_name(0) if torch.cuda.is_available() else ‘None’); print(‘cuDNN:’, torch.backends.cudnn.version())”
says: GPU: None
Where to find and how to install proper version of PyTorch.
Simon
@simon.pogorelcnik download a wheel from jp6/cu129 index . There are two versions availablecp310 and cp312
This is what I’m using:
Torch: 2.8.0
CUDA available: True
GPU: Orin
cuDNN: 90300
Don’t install torch from a Ubuntu repo.
Thank you very much. I will try this week.
One more question: Is it better to install also proper version of torchvision & torchaudio.
I would like to start playing with simple project with YOLO8 models and object recognition and classification.
Do I need any more compatible tools to use this kind of model?
Thank you for your kind answer.
Regards.
Please refer to the following download center for torchvision and torchaudio packages:
Thank you.
I’m tottaly stuck… I did:
  1. Remove OLD CPU version:
sudo pip uninstall torch torchvision torchaudio -y
sudo rm -rf /usr/local/lib/python3.10/dist-packages/torch*
sudo rm -rf ~/.local/lib/python3.10/site-packages/torch*
sudo rm -rf ~/.cache/torch
  1. Check: python3 -m pip show torch
    Torch not found
  2. Clean Install from:
    pip install torch torchvision torchaudio --extra-index-url jp6/cu126 index
  3. Check with:
Result:
Torch: 2.9.0+cpu
Path: /usr/local/lib/python3.10/dist-packages/torch/init.py
CUDA available: False
GPU: None
cuDNN: None
Please help. Tnx
It is recommended to perform a full flash and install the jp6/cu126 index package.
Yes. I did.. and it’s running. Thank you.
