help me to implement kernel function(element-wise product), size 1024*1024
Hi!!
I am not good to construct kernel function…
Now, Im trying to build a kernel function for element-wise product x vector and y vector.
However, the problem is that x’s type is cufftComplex, so x has real and imaginary value
and y is only integer.
For example, x → (3+2i),(2+4i), (10+7i)
y → 2, 5, 3
     result: 6+4i,  10+20i, 30+21i
I know that it is really simple but I confuse every time how thread index will be…
Also, it is pretty big size.
the number of x and y are 1024*1024 in respectively.
(Additionally, I think my program dies
on checkCudaErrors(cudaMemcpy(x_w, x_t, _size, cudaMemcpyHostToDevice));
checkCudaErrors(cudaMemcpy(h_w, h_t, _size, cudaMemcpyHostToDevice));
I assume that the size is too big…? is that right??? Is 1024*1024 too big?)
I attach the part of my code below (It doesn’t work well…)
and I’ve checked 3 main problems.
if anyone want to know full code, please tell me!
//////////////this part is the problem 1//////////////
global void point_wise_product(cufftComplex *a, int b){
int tid = threadIdx.x;
if(tid<SIGNAL_SIZE
SIGNAL_SIZE)
a[tid].x = a[tid].x * b[tid];
a[tid].y = a[tid].y * b[tid];
#define SIGNAL_SIZE 1024*1024
int main()
//skip for creation of h_t values
cufftComplex *x_t;
//Allocate host memory for the x(t)
x_t = (cufftComplex *)malloc(sizeof(cufftComplex) * SIGNAL_SIZE);
//Allocate host memory for the result(t)
cufftComplex *result = (cufftComplex *)malloc(_size);
cufftComplex *final_result = (cufftComplex *)malloc(_size);
//Initialize the memory for the signal
for(unsigned int i = 0; i < SIGNAL_SIZE; i++)
	x_t[i].x = rand()/(float)RAND_MAX * 100;
	x_t[i].y = 0;
	//printf("host signal: %f\n", x_t[i].x);
//Allocate device memory for signal
cufftComplex *x_w;
checkCudaErrors(cudaMalloc((void **)&x_w, _size));
//Allocate device memory for h
int *h_w;
checkCudaErrors(cudaMalloc((void **)&h_w, _size));
    //////////////**this part is the problem 2**//////////////////////////////
//Copy host memory to device
      .....fft.....
    //////////////**this part is the problem 3**//////////////////////////////
    dim3 dimGrids(SIGNAL_SIZE/TILE_WIDTH, SIGNAL_SIZE/TILE_WIDTH);
dim3 dimBlocks(TILE_WIDTH, TILE_WIDTH);
//Multiply the coefficients tohether and normalize the result
printf("Launching ComplexPointwiseAndScale<<< >>>\n");
point_wise_product<<<dimGrids, dimBlocks>>>(x_w, h_w);
Yes, provide full code.
No, 1024*1024 is not too big.
When you place code in this forum, it’s helpful if you:
  1. indent properly for easier reading
  2. use the code marker in the toolbar - it is the </> symbol. That is highlight the code you have just pasted into this forum, and then click the </> symbol above, before sending your reply.
I’m really sorry about late reply.
below is the full code.
I think that my kernel function’s tid is too bad…
#define TILE_WIDTH 16
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <iomanip>
// includes, project
#include <cuda_runtime.h>
#include <cufft.h>
#include <helper_functions.h>
#include <helper_cuda.h>
#include <windows.h>
#include "device_launch_parameters.h"
#include <iostream>
#include <fstream>
__global__ void point_wise_product(cufftComplex *a, int *b){
	if(tid<SIGNAL_SIZE*SIGNAL_SIZE)
int main(int argc, char **argv)
	cudaError_t err;
	//return device ID
	//findCudaDevice(argc, (const char **)argv);
	int _size = sizeof(cufftComplex) * SIGNAL_SIZE;
	LARGE_INTEGER liCounter1, liCounter2, liFrequency;
	QueryPerformanceFrequency(&liFrequency);
	//h_t values
	int *h_t;
	h_t = (int *)malloc(sizeof(int) * SIGNAL_SIZE);
	h_t[0] = 1;
	h_t[SIGNAL_SIZE/2] = 1;
	for(unsigned int i = 0; i < SIGNAL_SIZE/2 - 1; i++)
		h_t[i+1] = 2;
		h_t[SIGNAL_SIZE/2 + 1 + i] = 0;
	//cufftReal *x_t;
	cufftComplex *x_t;
		x_t[i].y = 0;
	cufftComplex *x_w;
	int *h_w;
	err = cudaMalloc((void **)&h_w, _size);
	printf("%d , %d  ..malloc ", cudaSuccess, err);
	err = cudaMemcpy(x_w, x_t, _size, cudaMemcpyHostToDevice);
	printf("%d , %d  .. ", cudaSuccess, err);
	Sleep(3);
	err = cudaMemcpy(h_w, h_t, _size, cudaMemcpyHostToDevice);
	printf("%d , %d", cudaSuccess, err);
	//cufft plan
	cufftHandle plan;
	checkCudaErrors(cufftPlan1d(&plan, SIGNAL_SIZE, CUFFT_C2C, 1));
	QueryPerformanceCounter(&liCounter1);
	//transform signal
	printf("Transforming signal cufftexecR2C\n");
	checkCudaErrors(cufftExecC2C(plan, x_w, x_w, CUFFT_FORWARD));
	//Copy device memory to host
	checkCudaErrors(cudaMemcpy(result, x_w, _size, cudaMemcpyDeviceToHost));
	//transform signal
	printf("Transforming signal cufftexecC2C\n");
	cufftHandle plan2;
	checkCudaErrors(cufftPlan1d(&plan2, SIGNAL_SIZE, CUFFT_C2C, 1));
	checkCudaErrors(cufftExecC2C(plan2, (cufftComplex *)x_w, (cufftComplex *)x_w, 1));
	QueryPerformanceCounter(&liCounter2);
	printf("Copy device memory to host\n");
	checkCudaErrors(cudaMemcpy(final_result, x_w, _size, cudaMemcpyDeviceToHost));
	cufftDestroy(plan);
	cufftDestroy(plan2);
	free(x_t);
	cudaFree(x_w);
	cudaFree(h_w);
	free(result);
	free(final_result);
int tid = (blockDim.x * blockIdx.x) + threadIdx.x;
if(tid<SIGNAL_SIZE)
dim3 dimGrids((SIGNAL_SIZE / 128), 1, 1);
dim3 dimBlocks(128, 1, 1);
little_jimmy
thanks for you reply!
I changed my code and attached it below.
it’s okay when signal_size is 128128
however, if signal_size modifies to 1024
1024, it didn’t work.
also, program dead point in my code is attached below too.
#define SIGNAL_SIZE 128*128
#define TILE_WIDTH 128
	const int Row = blockIdx.y*TILE_WIDTH + threadIdx.y;
	const int Col = blockIdx.x*TILE_WIDTH + threadIdx.x;
	const int numThreads = SIGNAL_SIZE*SIGNAL_SIZE;
	if(Row < SIGNAL_SIZE && Col < SIGNAL_SIZE){
		a[Row*TILE_WIDTH + Col].x = a[Row*TILE_WIDTH + Col].x * b[Row*TILE_WIDTH + Col];
		a[Row*TILE_WIDTH + Col].y = a[Row*TILE_WIDTH + Col].y * b[Row*TILE_WIDTH + Col];
dead point:
        //here is the dead point. It never returns any err msg.
does anyone know why this program died?
i fail to comprehend why you need to use tiles, given that you seem to be using ‘flat’ arrays, in a ‘flat’ manner
the additional dimensions of the tile add no value, and rather seems to be a point of confusion
and i fail to comprehend why you need more threads than array elements
and
you did not show the block/ grid dimension allocation of the above kernel
in essence, what are dimGrids and dimBlocks assigned to for the above kernel
how you assign the block/ grid dimensions and how you use threads of the block would determine whether the code would work or not
Oh, I found the problem… I had a mistake for h_w size.
when I allocate device memory for h_w, the size was int _size = sizeof(cufftComplex) * SIGNAL_SIZE
However, h_w size should be int _size = sizeof(int) * SIGNAL_SIZE, and this problem was solved!
Thanks guys!
