HELP NEEDED! cudamemcpy
I am having trouble with cudamemcpy. I have an array that I am sending in to the cuda kernel and it is suppose to return a modified copy, same length and type. However, when I try to copy my data from the device to the host, I am not getting the correct numbers! I am getting a bit frustrated, if anyone has an insight, please let me know.
Thanks, much appreciated!
unsigned int * cpu_in_image = (unsigned int *) malloc(mem_size);
unsigned int * cpu_out_image = (unsigned int *) malloc(mem_size);
unsigned int* gpu_in_image;
	CUDA_SAFE_CALL(cudaMalloc((void**)&gpu_in_image, mem_size));
	//copy CPU memory to GPU memory
	CUDA_SAFE_CALL(cudaMemcpy(gpu_in_image, cpu_in_image, mem_size, cudaMemcpyHostToDevice));
	//allocate GPU memory for results
	unsigned int *gpu_out_image;
	CUDA_SAFE_CALL(cudaMalloc((void**)&gpu_out_image, mem_size));
	//setup execution parameters
	dim3 grid(1, 1, 1);
	dim3 threads(num_threads, 1, 1); //Cannot have more than 2^16 Threads. That is, 256*256
	//execute kernel
	negativeKernel<<<grid, threads, 0>>>(gpu_in_image, gpu_out_image);
	CUT_CHECK_ERROR("Kernel execution failed");
	//Copy GPU Results Memory to CPU Results Memory
	CUDA_SAFE_CALL(cudaMemcpy(cpu_out_image, gpu_out_image, mem_size, cudaMemcpyDeviceToHost)); //GPU OUT IMAGE IS MESSED UP
I then use a for loop to display my contents before and after. They are not the correct results.
The kernel is as followed:
__global__ void
negativeKernel( unsigned int* gpu_in_image, unsigned int* gpu_out_image)
	__syncthreads();
	int tid = blockIdx.x * blockDim.x+threadIdx.x;
  	gpu_out_image[tid] =  gpu_in_image[tid];
	__syncthreads();
I don’t know what to do with this anymore!
what is num_threads? Because you cannot have more than 512 threads per block, not 2^16. So that is looking like your problem, your kernel never executed because num_threads is too big, so you are reading uninitialized values from GPU into out_image
CUT_CHECK_ERROR(“Kernel execution failed”); should catch this, but is only active in debug mode, so my guess is you are compiling in release mode.
Also as a side note, you don’t need the __synthreads() calls in your kernel. They are only needed when threads in a block cooperate with shared memory.
Thanks guys, that makes sense. My threads might be too big. There are definitely more than 512 threads per block. I am using release mode, following some of the examples that came with the software.
num_threads is my thread count, but at this point, it was 128*128, so I need to cut that down.
Much appreciated.
