Hi All,
I’m trying to figure out what might be wrong with a chunk of code. I have a subroutine which is part of a module which is in turn a part of a large simulation code. When compiled with no optimization or -O1 it works correctly - when compiled with -O it does not. When compiled with -O the code gives the right value on the first execution of the subroutine and an incorrect NaN value on subsequent execution for vr and vz in the code snippet below.
When I add write statements for current_angle, current_velocity, launch_velocity and vr,vz - before and after the assignment to vr,vz - they all contain appropriate values even vr,vz before the assignment. However, the values for vr,vz themselves change to NaN’s after the assignment while the other variables do not change (as expected). The write statement includes explicit calculations of the values assigned to vr,vz and these give the correct values as well.
This is compiler version 7.2.3 - RHEL5 - 32bit - core2
Are there any specific coding issues that could cause this sort of problem? I’ve run into these sorts of things occasionally and can never find a problem with the code itself. Are there any compiler options that could help me figure out what the compiler is doing and why it the optimized code doesn’t work?
Thanks,
David
P.S. Adding a SAVE to the declaration of vr,vz does not change the result
subroutine assign_velocity(item_velocity ,… launch_velocity,current_angle,current_velocity …)
type(velocity_type) :: item_velocity
real,intent(in) :: launch_velocity,current_angle
real,intent(out) :: current_velocity
! locals
real :: vr,vz
write(0,‘(a,10(1x,g12.5))’) ‘ASSIGN1:’,current_velocity,current_angle,vr,vz,neutral_time_step,&
¤t_velocity_in_r,current_velocity_in_z,COS (Current_Angle),sin(current_angle),&
& Current_Velocity * COS (Current_Angle), Current_Velocity * SIN (Current_Angle)
Current_Velocity = Launch_Velocity
vr = Current_Velocity * COS (Current_Angle)
vz = Current_Velocity * SIN (Current_Angle)
write(0,‘(a,10(1x,g12.5))’) ‘ASSIGN2:’,current_velocity,current_angle,vr,vz,neutral_time_step,&
item_velocity%v(1) = vr
item_velocity%v(2) = vz
end subroutine …
Output:
ASSIGN1: 1238.7 0.0000 975.81 0.0000 0.10000E-07 -0.85850E-05 -0.11991E-04 1.0000 0.0000 1238.7 0.0000
ASSIGN2: 975.81 0.0000 NaN NaN 0.10000E-07 NaN NaN 1.0000 0.0000 975.81 0.0000
