Hi All,
I am trying to use inline assembly to generate different flavor of loads and store. I cannot get the syntax right. Can someone help me please?
Here is the cuda code I try to generate in inline asm.
__global__ void exampleCuda(float * array, float * arrayout) {
int tid = blockDim.x * blockIdx.x + threadIdx.x;
array[tid] = (1+ arrayout[tid]);
This is what I wrote, but it is not correct. Where I am doing wrong?
__global__ void ptxCode(float * array, float * arrayout) {
float* ptr = &array[tid];
float *outPtr = &arrayout[tid];
float data;
asm volatile("ld.global.f32 %0, [%1];" : "=f"(data) : "l"(ptr));
data++;
asm volatile("st.global.f32 [%0], %1;" : "=l"(outPtr) : "f"(data));
Godbot link
Thanks in advance
