#define CUERR do{ cudaError_t err; \
cudaThreadSynchronize(); \
if ((err = cudaGetLastError()) != cudaSuccess) { \
printf("ERROR: CUDA error: %s, line %d\n", cudaGetErrorString(err), __LINE__); \
exit(1);}}while(0)
#include <iostream>
#include <ctime>
using namespace std;
* Number of threads per block
const int blocksize = 8;
time_t seconds;
__global__ void scan(float *g_odata, float *g_idata, int n)
extern __shared__ float temp[]; // allocated on invocation
int thid = threadIdx.x;
int pout = 0, pin = 1;
// load input into shared memory.
// This is exclusive scan, so shift right by one and set first elt to 0
temp[pout*n + thid] = (thid > 0) ? g_idata[thid-1] : 0;
__syncthreads();
for ( int offset = 1; offset < n; offset *= 2 )
pout = 1 - pout; // swap double buffer indices
pin = 1 - pout;
if ( thid >= offset )
temp[pout*n+thid] += temp[pin*n+thid - offset];
else
temp[pout*n+thid] = temp[pin*n+thid];
__syncthreads();
g_odata[thid] = temp[pout*n+thid]; // write output
// g_odata[thid] = 3.0;
// printf("g_odata = %f\n", g_odata[thid]);
__global__ void prescan(float *g_odata, float *g_idata, int n)
extern __shared__ float temp[];// allocated on invocation
int offset = 1;
temp[2*thid] = g_idata[2*thid]; // load input into shared memory
temp[2*thid+1] = g_idata[2*thid+1];
for ( int d = n>>1; d > 0; d >>= 1 ) // build sum in place up the tree
__syncthreads();
if ( thid < d )
int ai = offset*(2*thid+1)-1;
int bi = offset*(2*thid+2)-1;
temp[bi] += temp[ai];
offset *= 2;
if ( thid == 0 )
temp[n - 1] = 0;
} // clear the last element
for ( int d = 1; d < n; d *= 2 ) // traverse down tree & build scan
offset >>= 1;
__syncthreads();
if ( thid < d )
float t = temp[ai];
temp[ai] = temp[bi];
temp[bi] += t;
__syncthreads();
g_odata[2*thid] = temp[2*thid]; // write results to device memory
g_odata[2*thid+1] = temp[2*thid+1];
int main ( int argc, char *argv[] )
* Command line arguments must be 1 which is the number of rows
* and columns for a matrix and the size of the vector.
// if ( argc != 2 )
// cout<<"usage: "<< argv[0] <<" <size n>\n";
// return EXIT_FAILURE;
int N = 1024;
float *a = new float[N];
float *b = new float[N];
// float *c = new float[N];
seconds = time (NULL);
srand(seconds);
for ( int i = 0; i < N; ++i )
a[i] = (float) i*2.0;
//cout << "a[" << i << "]: " << a[i] << endl;
// calculate a random number between 0 and 1000
b[i] = (float) 10;
float *ad, *bd;
const int sizeVec = N*sizeof(float);
cudaMalloc( (void**)&ad, sizeVec );
cudaMalloc( (void**)&bd, sizeVec );
cudaMemcpy( ad, a, sizeVec, cudaMemcpyHostToDevice );
CUERR;
dim3 dimBlock(blocksize);
dim3 dimGrid(ceil(N/(float)blocksize));
cout << endl;
prescan<<<dimGrid, dimBlock>>>( bd, ad, N );
CUERR;
cudaMemcpy( b, bd, sizeVec, cudaMemcpyDeviceToHost );
CUERR;
* GPU Output.
/*for ( int i = 0; i < N; ++i )
cout << "b[" << i << "]: " << b[i] << endl;
cudaFree( ad );
cudaFree( bd );
delete[] a;
delete[] b;
return 0;
exit(1);}}while(0)
#include <iostream>
#include <ctime>
time_t seconds;
__syncthreads();
pin = 1 - pout;
else
__syncthreads();
int offset = 1;
__syncthreads();
if ( thid < d )
offset *= 2;
if ( thid == 0 )
temp[n - 1] = 0;
offset >>= 1;
__syncthreads();
if ( thid < d )
float t = temp[ai];
temp[bi] += t;
__syncthreads();
// if ( argc != 2 )
int N = 1024;
srand(seconds);
b[i] = (float) 10;
float *ad, *bd;
CUERR;
cout << endl;
CUERR;
CUERR;
* GPU Output.
cudaFree( ad );
cudaFree( bd );
delete[] a;
delete[] b;
return 0;
exit(1);}}while(0)
#include <iostream>
#include <ctime>
time_t seconds;
__syncthreads();
pin = 1 - pout;
else
__syncthreads();
int offset = 1;
__syncthreads();
if ( thid < d )
offset *= 2;
if ( thid == 0 )
temp[n - 1] = 0;
offset >>= 1;
__syncthreads();
if ( thid < d )
float t = temp[ai];
temp[bi] += t;
__syncthreads();
// if ( argc != 2 )
int N = 1024;
srand(seconds);
b[i] = (float) 10;
float *ad, *bd;
CUERR;
cout << endl;
CUERR;
CUERR;
* GPU Output.
cudaFree( ad );
cudaFree( bd );
delete[] a;
delete[] b;
return 0;
