Hi Please Help Me... PxController Problem...!!!
I’m sorry. I can not speak English well.
I am having problems now.
this is my code.
my Player Object is CapsuleController.
m_pScene = pPxScene;
PxCapsuleControllerDesc PxCapsuledesc;
PxCapsuledesc.position = PxExtendedVec3(0, 0, 0);
PxCapsuledesc.radius = 5.0f;
PxCapsuledesc.height = 10.0f;
PxCapsuledesc.stepOffset = 2.f;
PxCapsuledesc.volumeGrowth = 1.9f;
PxCapsuledesc.slopeLimit = cosf(XMConvertToRadians(15.f));
PxCapsuledesc.nonWalkableMode = PxControllerNonWalkableMode::eFORCE_SLIDING;
PxCapsuledesc.upDirection = PxVec3(0, 1, 0);
PxCapsuledesc.contactOffset = 0.0001f;
PxCapsuledesc.material = pPxMaterial;
m_pPxCharacterController = pPxControllerManager->createController(PxCapsuledesc);
My stage map used a triangle mesh.
PxTriangleMeshDesc meshDesc;
PxVec3* m_pVtxTex;
PxU32* m_pIndex;
_uint m_iCount;
m_iCount = CMeshMgr::GetInstance()->Get_MeshVtxCnt(m_uiObjNum);
m_pVtxTex = CMeshMgr::GetInstance()->Get_MeshPxVtx(m_uiObjNum);
m_pIndex = CMeshMgr::GetInstance()->Get_MeshPxIndex(m_uiObjNum);
meshDesc.points.count = m_iCount;
meshDesc.triangles.count = m_iCount/3;
meshDesc.points.stride = sizeof(PxVec3);
meshDesc.triangles.stride = sizeof(PxU32) * 3;
meshDesc.points.data = &(*m_pVtxTex);
meshDesc.triangles.data = &(*m_pIndex);
meshDesc.flags = PxMeshFlags(0);
PxDefaultMemoryOutputStream stream;
bool ok = pCooking->cookTriangleMesh(meshDesc, stream);
if (!ok)
return ;
PxDefaultMemoryInputData rb(stream.getData(), stream.getSize());
PxTriangleMesh* triangleMesh = pPxPhysics->createTriangleMesh(rb);
PxVec3 ScaleTemp = PxVec3(vScale.x, vScale.y, vScale.z);
//Scale
PxMeshScale PxScale;
PxScale.scale = ScaleTemp;
PxTriangleMeshGeometry meshGeom(triangleMesh, PxScale);
PxTransform _PxTransform(0, 0, 0);
m_pPxActor = PxCreateStatic(*pPxPhysics, _PxTransform, meshGeom, *pPxMaterial);
m_pPxActor->setName(name);
pPxScene->addActor(*m_pPxActor);
The problem I’m having here is that the controller is somewhat floating in the triangleMesh.
I don’t understand.
How do I get the controller to stick to the stage obects that surrounds the triangle mesh?
//example Pictures
lll   <-  capsule controller
l l
l l
l l
l l
l l
lll
      <------ this gap Why??????????
--------------------------- ← (triangle mesh) stage ground
I cannot see an actual picture with your post but I suspect the gap is just the “skin width” (a.k.a. contact offset) between the kinematic capsule embedded in a character controller, and the mesh.
How are you rendering the capsule? If you are just rendering the PxActor from the character controller, then this is not the volume used for collision detection and sweeps by the character controller module. You need to add the PxControllerDesc::contactOffset to the capsule’s radius.
You can try to set this parameter to 0.0 to see if it indeed makes the capsule touch the mesh (don’t do that permanently though, just to check whether this is indeed the problem).
  • Pierre
Thank you for your reply.
this is my Object code.
#include "stdafx.h"
#include "Include.h"
#include "Player.h"
#include "AnimationInfo.h"
#include "Transform.h"
#include "MeshMgr.h"
#include "Gun.h"
#include "Management.h"
#include "Input.h"
#include "StateMachine.h"
#include "SoldierDefine.h"
#include "CameraMgr.h"
#include "Layer.h"
#include "DefaultObject.h"
#include "Scene.h"
#include "SphereMesh.h"
XMFLOAT3		g_vPlayerPos;
CPlayer::CPlayer(ID3D11DeviceContext* pContext)
: CDynamicObject(pContext)
, m_dwState(SOLDIER_IDLE)
, m_dwAniIdx(PLAYER_idle)
, m_pComStateMachine(NULL)
, m_eMoveDir(DIR_END)
, m_vMoveDir(0.f, 0.f, 0.f)
, m_bIsSoldier(true)
, m_fTimeDelta(0.f)
, m_iEquipBone(0)
, m_fRollSpeed(0.f)
, m_fRateOfFire(0.f)
, m_bFire(false)
, m_bAbleReload(false)
, m_pPxActor(NULL)
, m_pPxCharacterController(NULL)
, m_fFallAcceleration(9.8f)
, m_fFallvelocity(0.f)
, m_iHP(5)
	m_pInput = CInput::GetInstance();
	m_vLook = XMFLOAT3(0.f, 1.f, 0.f);
	XMStoreFloat4x4(&m_matEquipBone[0], XMMatrixIdentity());
	XMStoreFloat4x4(&m_matEquipBone[1], XMMatrixIdentity());
	ZeroMemory(m_pEquipment, sizeof(CEquipment*) * 2);
	ZeroMemory(&m_bKey, sizeof(bool) * KEY_END);
	m_pServer_PlayerData = new Ser_PLAYER_DATA;
	m_fSpeed = 40.f;
	XMStoreFloat4x4(&m_matBone, XMMatrixIdentity());
	m_iBoneNum = 0;
	pSphereMesh = CSphereMesh::Create(m_pContext, 1.f);
CPlayer::~CPlayer(void)
CPlayer* CPlayer::Create(ID3D11Device* pGraphicDev, ID3D11DeviceContext* pContext)
	CPlayer* pObject = new CPlayer(pContext);
	if (FAILED(pObject->Initialize(pGraphicDev)))
		Safe_Release(pObject);
	return pObject;
CPlayer* CPlayer::Create(ID3D11Device* pGraphicDev, ID3D11DeviceContext* pContext, XMFLOAT3 vPos)
	pObject->m_pTransform->m_vPos = vPos;
	return pObject;
HRESULT CPlayer::Initialize(ID3D11Device* pGraphicDev)
	m_uiObjNum		= MESHNUM_PLAYER;
	m_uiObjNum_Iron = MESHNUM_PLAYER2;
	if (FAILED(Ready_Component(pGraphicDev)))
		return E_FAIL;
	FAILED_CHECK(Prepare_StateMachine());
	m_pTransform->m_vScale = XMFLOAT3(1.f, 1.f, 1.f);
	m_pTransform->m_vAngle.x = 90.f;
	//m_pTransform->m_vPos = g_vPos;
	m_pTransform->m_vPos = XMFLOAT3(g_vPos);
	m_pTransform->m_vDir = XMFLOAT3(0.f, 0.f, -1.f);
	m_pAnimInfo->Set_Key((_ushort)m_dwAniIdx);
	m_pComStateMachine->Enter_State(SOLDIER_IDLE);
	// Equipment
	m_pEquipment[0] = CGun::Create(pGraphicDev, m_pContext);
	if(g_myid % 2 == 0)
		m_iTextureNumber = 0;
	else
		m_iTextureNumber = 1;
	return S_OK;
INT CPlayer::Update(const FLOAT& fTimeDelta)
	m_fTimeDelta = fTimeDelta;
	CDynamicObject::Update(fTimeDelta);
	//PhysX 함수
	PhysXUpdate(fTimeDelta);
	//Dynamic카메라 체크 함수(Dynamic 카메라일시 Update 안돌린다.
	if (!DynamicCameraCheck())
		Operate_StateMAchine(fTimeDelta);
		KeyState(fTimeDelta);
		SendPacketAlways();
	// 본행렬 찾기 위한 디버그
	if (GetAsyncKeyState('G') & 1)
		m_iBoneNum += 1;
		cout << "BoneNum" << m_iBoneNum << endl;
	if (GetAsyncKeyState('H') & 1)
		m_iBoneNum -= 1;
	// Update
	CManagement::GetInstance()->Add_RenderGroup(CRenderer::RENDER_ZSORT, this);
	UpdateDir();
	Update_Equipment(fTimeDelta);
	pSphereMesh->Update(fTimeDelta);
	return 0;
void CPlayer::Release(void)
	CDynamicObject::Release();
	Safe_Release(m_pEquipment[0]);
HRESULT CPlayer::Ready_Component(ID3D11Device* pGraphicDev)
	if (FAILED(CDynamicObject::Ready_Component()))
		return E_FAIL;
	CComponent* pComponent = NULL;
	m_pAnimInfo_Normal = m_pAnimInfo;
	m_pMatBoneNode_Normal = m_pMatBoneNode;
	m_uiObjNum_Normal = m_uiObjNum;
	// AnimationInfo	Iron
	pComponent = CAnimationInfo::Create(MESHNUM(m_uiObjNum_Iron));
	m_pAnimInfo_Iron = dynamic_cast<CAnimationInfo*>(pComponent);
	if (pComponent == NULL) return E_FAIL;
	m_mapComponent.insert(MAPCOMPONENT::value_type(L"Com_AnimInfo_Iron", pComponent));
	// Matrix Bone		Iron
	m_pMatBoneNode_Iron = new MATNODE;
	CMeshMgr::GetInstance()->CreateBoneNode(m_uiObjNum_Iron, m_pMatBoneNode_Iron);
	//StateMachine
	pComponent = m_pComStateMachine = CStateMachine::Create(SOLDIER_END);
	NULL_CHECK_RETURN(pComponent, E_FAIL);
	m_mapComponent.insert(map<const TCHAR*, CComponent*>::value_type(L"StateMachine", pComponent));
	return S_OK;
void CPlayer::Update_Equipment(const FLOAT& fTimeDelta)
	m_matEquipBone[0] = CMeshMgr::GetInstance()->Get_TransMeshBone(m_uiObjNum, 0, m_iEquipBone, m_pMatBoneNode);
	if (XMMatrixIsIdentity(XMLoadFloat4x4(&m_matEquipBone[0])))
		return;
	m_matBone = CMeshMgr::GetInstance()->Get_TransMeshBone(m_uiObjNum, 0, m_iBoneNum, m_pMatBoneNode);
	XMMATRIX matWorld = XMLoadFloat4x4(&m_pTransform->m_matWorld);
	XMStoreFloat4x4(&m_matEquipBone[0], XMLoadFloat4x4(&m_matEquipBone[0]) * matWorld);
	XMStoreFloat4x4(&m_matBone, XMLoadFloat4x4(&m_matBone) * matWorld);
	((CSphereMesh*)pSphereMesh)->SetmatWorld(&m_matBone);
	m_pEquipment[0]->SetParent(m_matEquipBone[0]);
	m_pEquipment[0]->Update(fTimeDelta);
HRESULT CPlayer::Prepare_StateMachine(void)
	NULL_CHECK_RETURN(m_pComStateMachine, E_FAIL);
	CState*	pState = NULL;
	pState = CSoldierIdle::Create(this);
	FAILED_CHECK(m_pComStateMachine->Add_State(pState));
	pState = CSoldierMove::Create(this);
	pState = CSoldierLying::Create(this);
	pState = CSoldierRoll::Create(this);
	pState = CSoldierJump::Create(this);
	return S_OK;
void CPlayer::Operate_StateMAchine(const FLOAT& fTimeDelta)
	if (m_iHP < 0)
		if (m_dwState != SOLDIER_DEAD)
			m_dwState = SOLDIER_DEAD;
			if (m_bIsSoldier)
				PlayAnimation(PLAYER_Death2);
			else
				PlayAnimation(PLAYER_Iron_Death2);
		else
			if (Check_AnimationFrame())
				m_iHP = 5;
				m_dwState = SOLDIER_IDLE;
				if (m_bIsSoldier)
					PlayAnimation(PLAYER_idle);
				else
					PlayAnimation(PLAYER_Iron_Idle);
	else
		KeyCheck();
		DWORD dwState = m_pComStateMachine->Get_State();
		switch (dwState)
		case SOLDIER_IDLE:
			if (m_dwState == SOLDIER_MOVE)
				m_pComStateMachine->Enter_State(SOLDIER_MOVE);
			if (m_dwState == SOLDIER_LYING)
				m_pComStateMachine->Enter_State(SOLDIER_LYING);
			if (m_dwState == SOLDIER_JUMP)
				m_pComStateMachine->Enter_State(SOLDIER_JUMP);
				m_fFallvelocity = 120.f;
			break;
		case SOLDIER_MOVE:
			if (m_dwState == SOLDIER_IDLE)
			if (m_dwState == SOLDIER_ROLL)
				m_pComStateMachine->Enter_State(SOLDIER_ROLL);
				m_fFallvelocity = 60.f;
				m_fRollSpeed = m_fSpeed * 1.7f;
				m_fRollDir = m_vMoveDir;
			break;
		case SOLDIER_LYING:
			break;
		case SOLDIER_ROLL:
			break;
		case SOLDIER_JUMP:
			break;
		default:
			break;
		m_pComStateMachine->Update_State(dwState);
void CPlayer::PlayAnimation(DWORD dwAniIdx, bool bImmediate)
	if (bImmediate)
		m_pAnimInfo->Set_KeyImm((_ushort)dwAniIdx);
	m_pAnimInfo->Set_Key((_ushort)dwAniIdx);
	m_dwAniIdx = dwAniIdx;
	Ser_ANIMATION_DATA m_AnimationData;
	m_AnimationData.size = sizeof(Ser_ANIMATION_DATA);
	m_AnimationData.type = CLIENT_ANIMATION;
	m_AnimationData.ID = g_myid;
	m_AnimationData.bImmediate = bImmediate;
	m_AnimationData.dwAniIdx = dwAniIdx;
	m_AnimationData.bIsSoldier = m_bIsSoldier;
	g_Client->sendPacket(sizeof(Ser_ANIMATION_DATA), CLIENT_ANIMATION, reinterpret_cast<BYTE*>(&m_AnimationData));
bool CPlayer::Check_AnimationFrame(void)
	if (m_pAnimInfo->Get_CurFrame() >= m_pAnimInfo->Get_LastFrame())
		return true;
	return false;
bool CPlayer::IsOnGround(void)
	PxControllerState   m_pPxState;
	//피직스 객체의 상태값을 m_pPxState에 넣어준다.
	m_pPxCharacterController->getState(m_pPxState);
	/*return m_pComGravity->Get_OnGround();*/
	if (m_pPxState.collisionFlags == PxControllerCollisionFlag::eCOLLISION_DOWN)
		return true;
	return false;
MOVE_DIR* CPlayer::GetMoveDir(void)
	return &m_eMoveDir;
void CPlayer::SoldierChange(void)
	if (m_bIsSoldier)
		m_bIsSoldier = false;
		m_uiObjNum = m_uiObjNum_Iron;
		m_pAnimInfo = m_pAnimInfo_Iron;
		m_pMatBoneNode = m_pMatBoneNode_Iron;
		PlayAnimation((_ushort)PLAYER_Iron_Idle);
		((CGun*)m_pEquipment[0])->ChangeWeapon(MESHNUM_SPECIALGUN);
		m_iEquipBone = 2;
	else
		m_bIsSoldier = true;
		m_uiObjNum = m_uiObjNum_Normal;
		m_pAnimInfo = m_pAnimInfo_Normal;
		m_pMatBoneNode = m_pMatBoneNode_Normal;
		PlayAnimation((_ushort)PLAYER_idle);
		((CGun*)m_pEquipment[0])->ChangeWeapon(MESHNUM_GUN);
		m_iEquipBone = 0;
	m_pAnimInfo->Update(1.f);
void CPlayer::KeyCheck(void)
	m_eMoveDir = DIR_END;
	m_vMoveDir = XMFLOAT3(0.f, 0.f, 0.f);
	if (m_pInput->Get_DIKeyState(DIK_W))
		m_bKey[KEY_UP] = true;
	if (m_pInput->Get_DIKeyState(DIK_S))
		m_bKey[KEY_DOWN] = true;
	if (m_pInput->Get_DIKeyState(DIK_A))
		m_bKey[KEY_LEFT] = true;
	if (m_pInput->Get_DIKeyState(DIK_D))
		m_bKey[KEY_RIGHT] = true;
	if (m_bKey[KEY_UP] == true && m_bKey[KEY_DOWN] == true)
		m_bKey[KEY_UP] = false;
		m_bKey[KEY_DOWN] = false;
	if (m_bKey[KEY_LEFT] == true && m_bKey[KEY_RIGHT] == true)
		m_bKey[KEY_LEFT] = false;
		m_bKey[KEY_RIGHT] = false;
	if (!m_bKey[KEY_UP] && !m_bKey[KEY_DOWN] && !m_bKey[KEY_LEFT] && !m_bKey[KEY_RIGHT])
		return;
	XMVECTOR vDir = XMVectorSet(m_pTransform->m_vDir.x, 0.f, m_pTransform->m_vDir.z, 0.0f);
	XMVECTOR vUp = XMVectorSet(0.0f, 1.0f, 0.0f, 0.0f);
	XMVECTOR vRight = XMVector3Cross(vUp, vDir);
	XMVECTOR vMoveDir = XMVectorSet(0.0f, 0.0f, 0.0f, 0.0f);
	vDir = XMVector3Normalize(vDir);
	vRight = XMVector3Normalize(vRight);
	if (m_bKey[KEY_UP])
		vMoveDir += vDir;
		if (m_bKey[KEY_LEFT])
			vMoveDir -= vRight;
			m_eMoveDir = DIR_UL;
		else if (m_bKey[KEY_RIGHT])
			vMoveDir += vRight;
			m_eMoveDir = DIR_UR;
		else
			m_eMoveDir = DIR_U;
	else if (m_bKey[KEY_DOWN])
		vMoveDir -= vDir;
			vMoveDir -= vRight;
			m_eMoveDir = DIR_DL;
			vMoveDir += vRight;
			m_eMoveDir = DIR_DR;
		else
			m_eMoveDir = DIR_D;
	else if (m_bKey[KEY_LEFT])
		vMoveDir -= vRight;
		m_eMoveDir = DIR_L;
		vMoveDir += vRight;
		m_eMoveDir = DIR_R;
	vMoveDir = XMVector3Normalize(vMoveDir);
	XMStoreFloat3(&m_vMoveDir, vMoveDir);
void CPlayer::KeyState(const FLOAT& fTimeDelta)
	_long lMouseMove = 0;
	if (lMouseMove = m_pInput->Get_DIMouseMove(CInput::DIMS_X))
		if (m_pTransform->m_vAngle.y >= 360.f)
			m_pTransform->m_vAngle.y = 0.f;
		if (m_pTransform->m_vAngle.y < 0.f)
			m_pTransform->m_vAngle.y = 360.f;
		m_pTransform->m_vAngle.y += lMouseMove * fTimeDelta * 5.f;
	if(m_bIsSoldier)
		Soldier_Move(fTimeDelta);
	else
		Soldier_Iron_Move(fTimeDelta);
	Soldier_Fire(fTimeDelta);
void CPlayer::Soldier_Move(const FLOAT& fTimeDelta)
	//XMVECTOR vDir;// = XMLoadFloat3(&m_vMoveDir);
	//XMVECTOR vPos = XMLoadFloat3(&m_pTransform->m_vPos);
	switch (m_dwState)
	case SOLDIER_MOVE:
		//vDir = XMLoadFloat3(&m_vMoveDir);
		if (m_dwAniIdx == PLAYER_sprint)
		m_pPxCharacterController->move(PxVec3(m_vMoveDir.x, m_vMoveDir.y, m_vMoveDir.z) * m_fSpeed * fTimeDelta * 1.4f, 0, fTimeDelta, PxControllerFilters());
		else
			if(m_eMoveDir == DIR_D || m_eMoveDir == DIR_DL || m_eMoveDir == DIR_DR)
				m_pPxCharacterController->move(PxVec3(m_vMoveDir.x, m_vMoveDir.y, m_vMoveDir.z) * m_fSpeed * fTimeDelta * 0.7f, 0, fTimeDelta, PxControllerFilters());
			else
				m_pPxCharacterController->move(PxVec3(m_vMoveDir.x, m_vMoveDir.y, m_vMoveDir.z) * m_fSpeed * fTimeDelta, 0, fTimeDelta, PxControllerFilters());
		break;
	case SOLDIER_LYING:
		if (m_dwAniIdx != PLAYER_Lying && m_dwAniIdx != PLAYER_LyingShoot)
			m_pPxCharacterController->move(PxVec3(m_vMoveDir.x, m_vMoveDir.y, m_vMoveDir.z) * m_fSpeed * fTimeDelta * 0.25f, 0, fTimeDelta, PxControllerFilters());
		break;
	case SOLDIER_JUMP:
		break;
	case SOLDIER_ROLL:
		//vDir = XMLoadFloat3(&m_fRollDir);
		m_pPxCharacterController->move(PxVec3(m_fRollDir.x, m_fRollDir.y, m_fRollDir.z) * m_fRollSpeed * fTimeDelta, 0, fTimeDelta, PxControllerFilters());
		m_fRollSpeed -= 20.f * fTimeDelta;
		break;
void CPlayer::Soldier_Iron_Move(const FLOAT& fTimeDelta)
	switch (m_dwState)
	case SOLDIER_MOVE:
		if (m_dwAniIdx == PLAYER_Iron_Sprint)
		else
		break;
	case SOLDIER_LYING:
		if (m_dwAniIdx != PLAYER_Iron_Lying && m_dwAniIdx != PLAYER_Iron_LyingShoot)
		break;
	case SOLDIER_JUMP:
		break;
	case SOLDIER_ROLL:
		break;
void CPlayer::Soldier_Fire(const FLOAT& fTimeDelta)
	if (!m_bFire)
		m_fRateOfFire = 0.f;
		return;
	m_fRateOfFire += fTimeDelta;
	if (m_fRateOfFire >= 0.2f)
		m_fRateOfFire = 0.1f;
		if (((CGun*)m_pEquipment[0])->Fire())
			XMFLOAT3 m_vCameraEye = CCameraMgr::GetInstance()->Get_CurCameraEye();
			XMFLOAT3 m_vCameraLookAt = CCameraMgr::GetInstance()->Get_CurCameraLookAt();
			PxVec3 OriginPos = PxVec3(m_vCameraEye.x, m_vCameraEye.y, m_vCameraEye.z);
			PxVec3 Dir = PxVec3(m_vCameraLookAt.x, m_vCameraLookAt.y, m_vCameraLookAt.z);
			PxReal maxDistance = 1000.f;
			PxRaycastBuffer Onehit;
			PxQueryFilterData Onefd;
			Onefd.flags |= PxQueryFlag::ePOSTFILTER;
			bool m_bOneCheck = false;
			m_bOneCheck = m_pScene->raycast(OriginPos, Dir, maxDistance, Onehit, PxHitFlags(PxHitFlag::eDEFAULT), Onefd);
			//최종 검사
			if (m_bOneCheck == true)
				XMFLOAT3 m_vGoalPos = XMFLOAT3(Onehit.block.position.x, Onehit.block.position.y, Onehit.block.position.z);
				//Player의 월드 총구 포지션 설정
				XMFLOAT4X4 vmatWorld = ((CTransform*)m_pEquipment[0]->Get_Component(L"Com_Transform"))->m_matWorld;
				XMFLOAT3 m_vWorldGunPos;
				if (m_bIsSoldier)
					//x 가 z축의 역할을하네   z+가 x-
					m_vWorldGunPos = XMFLOAT3(50.f, -27.f, 40.f);
				else
					//x+가 z+축 z축 -x
					m_vWorldGunPos = XMFLOAT3(45.f, 5.f, 0.f);
				XMStoreFloat3(&m_vWorldGunPos, XMVector3TransformCoord(XMLoadFloat3(&m_vWorldGunPos), XMLoadFloat4x4(&vmatWorld)));
				//Bullet의 방향벡터
				XMFLOAT3 m_vBulletDir;
				XMStoreFloat3(&m_vBulletDir, XMVector3Normalize(XMLoadFloat3(&m_vGoalPos)- XMLoadFloat3(&m_vWorldGunPos)));
				PxReal maxGunDistance = 1000.f;
				PxRaycastBuffer Gunhit;
				PxQueryFilterData Gunfd;
				Gunfd.flags |= PxQueryFlag::ePOSTFILTER;
				bool m_bTwoCheck = false;
				PxVec3 StartPos = PxVec3(m_vWorldGunPos.x, m_vWorldGunPos.y, m_vWorldGunPos.z);
				PxVec3 BulletDir = PxVec3(m_vBulletDir.x, m_vBulletDir.y, m_vBulletDir.z);
				m_bTwoCheck = m_pScene->raycast(StartPos, BulletDir, maxGunDistance, Gunhit, PxHitFlags(PxHitFlag::eDEFAULT), Gunfd);
				if (m_bTwoCheck == true)
					CLayer* pLayer = CManagement::GetInstance()->GetScene()->FindLayer(L"Layer_GameLogic");
					list<CGameObject*>* m_pObject = pLayer->Find_ObjectList(L"TestPos");
					m_vtestpos = XMFLOAT3(Gunhit.block.position.x, Gunhit.block.position.y, Gunhit.block.position.z);
					//m_vtestpos = XMFLOAT3(vLocalPos.x, vLocalPos.y, vLocalPos.z);
					const char* pName = Gunhit.block.actor->getName();
					string strFullName = pName;
					int iStartIdx = strFullName.find("OtherPlayer_");
					if (iStartIdx != -1)
						string strID = strFullName.substr(12, strFullName.length() - 11);
						int intValue = atoi(strID.c_str());
						Ser_COLLLAY_DATA strColData;
						strColData.size = sizeof(Ser_COLLLAY_DATA);
						strColData.type = COLLISION_LAY;
						strColData.ID = intValue;
						g_Client->sendPacket(sizeof(Ser_COLLLAY_DATA), COLLISION_LAY, reinterpret_cast<BYTE*>(&strColData));
					if (m_pObject == NULL)
						CGameObject* pGameObject = CSphereMesh::Create(m_pContext, 2.5f, &m_vtestpos);
						pLayer->Ready_Object(L"TestPos", pGameObject);
					else
						list<CGameObject*>::iterator iter = m_pObject->begin();
						((CSphereMesh*)(*iter))->SetPosition(m_vtestpos);
		else
			m_bAbleReload = true;
void CPlayer::Soldier_Iron_AddVelocity(float fFallVel)
	m_fFallvelocity += 1000.f * m_fTimeDelta;
void CPlayer::Reload(void)
	((CGun*)m_pEquipment[0])->Reload();
	m_bAbleReload = false;
void CPlayer::UpdateDir(void)
	XMVECTOR vDir;
	vDir = XMLoadFloat3(&m_pTransform->m_vDir);
	vDir = XMVector3TransformNormal(XMLoadFloat3(&m_vLook), XMLoadFloat4x4(&m_pTransform->m_matWorld));
	XMStoreFloat3(&m_pTransform->m_vDir,vDir);
_bool CPlayer::DynamicCameraCheck(void)
	if (CCameraMgr::GetInstance()->Get_CurCamera() == CCameraMgr::CAMERA_DYNAMIC)
		return true;
	return false;
void CPlayer::Render(void)
	CDynamicObject::Render();
	pSphereMesh->Render();
void CPlayer::BuildObject(PxPhysics* pPxPhysics, PxScene* pPxScene, PxMaterial *pPxMaterial, PxControllerManager *pPxControllerManager)
	XMFLOAT3 vMin = *(CMeshMgr::GetInstance()->Get_MeshMin(m_uiObjNum));
	XMFLOAT3 vMax = *(CMeshMgr::GetInstance()->Get_MeshMax(m_uiObjNum));
	XMFLOAT3 _d3dxvExtents =
		XMFLOAT3((abs(vMin.x) + abs(vMax.x)) / 2, (abs(vMin.y) + abs(vMax.y)) / 2, (abs(vMin.z) + abs(vMax.z)) / 2);
	Player의 바운딩 박스 생성
	PxBoxControllerDesc PxBoxdesc;
	PxBoxdesc.position = PxExtendedVec3(0, 0, 0);
	PxBoxdesc.halfForwardExtent = _d3dxvExtents.y / 2;
	PxBoxdesc.halfSideExtent = _d3dxvExtents.z / 2;
	PxBoxdesc.halfHeight = _d3dxvExtents.x / 2;
	PxBoxdesc.slopeLimit = 10;
	PxBoxdesc.contactOffset = 0.00001;
	PxBoxdesc.upDirection = PxVec3(0, 1, 0);
	PxBoxdesc.material = pPxMaterial;
	//캐릭터가 올라갈 수있는 장애물의 최대 높이를 정의합니다.
	//캐시 된 볼륨 증가.
	//성능을 향상시키기 위해 캐싱하는 컨트롤러 주변의 공간입니다.  이것은 1.0f보다 커야하지만 너무 크지 않아야하며, 2.0f보다 낮아야합니다.
	//캐릭터가 걸어 갈 수있는 최대 경사.
	//PxCapsuledesc.nonWalkableMode = PxControllerNonWalkableMode::eFORCE_SLIDING;
	PxCapsuledesc.contactOffset = 0.0f; //접촉 오프셋
void CPlayer::SetPosition(XMFLOAT3 vPosition)
	m_pPxCharacterController->setFootPosition(PxExtendedVec3(vPosition.x, vPosition.y, vPosition.z));
void CPlayer::SetRotate(XMFLOAT3 vRot)
//PhysX 함수
void CPlayer::PhysXUpdate(const FLOAT& fTimeDelta)
	//PhysX에 값을 전달해준다. 중력
	m_fFallvelocity -= m_fFallAcceleration * fTimeDelta * 50.f;
	if (m_fFallvelocity < -1000.f)
		m_fFallvelocity = -1000.f;
	m_pPxCharacterController->move(PxVec3(0, 1.f, 0) * fTimeDelta * m_fFallvelocity, 0, fTimeDelta, PxControllerFilters());
	//윗쪽 충돌하거나 아랫쪽 충돌하면 m_fFallvelocity = 0.0f
	if (m_pPxState.collisionFlags == PxControllerCollisionFlag::eCOLLISION_DOWN ||
		m_pPxState.collisionFlags == PxControllerCollisionFlag::eCOLLISION_UP)
		m_fFallvelocity = 0.f;
	//현재 PhysX의 값으로 객체의 월드행렬을 만들어준다.
	m_pTransform->m_vPos = XMFLOAT3(m_pPxCharacterController->getFootPosition().x, m_pPxCharacterController->getFootPosition().y, m_pPxCharacterController->getFootPosition().z);
	_float m_fRevice = 0.5f; //Player의 Y보정값(발이 지면에 안박히게 보정)
	if (!m_bIsSoldier)
		m_fRevice = 0.0f;
	XMMATRIX matTrans = XMMatrixTranslation(m_pTransform->m_vPos.x, m_pTransform->m_vPos.y + m_fRevice, m_pTransform->m_vPos.z);
	XMMATRIX matScale = XMMatrixScaling(m_pTransform->m_vScale.x, m_pTransform->m_vScale.y, m_pTransform->m_vScale.z);
	XMMATRIX matRotX = XMMatrixRotationX((_float)D3DXToRadian(m_pTransform->m_vAngle.x));
	XMMATRIX matRotY = XMMatrixRotationY((_float)D3DXToRadian(m_pTransform->m_vAngle.y));
	XMMATRIX matRotZ = XMMatrixRotationZ((_float)D3DXToRadian(m_pTransform->m_vAngle.z));
	XMStoreFloat4x4(&m_pTransform->m_matWorld, matScale * matRotX * matRotY * matRotZ * matTrans);
void CPlayer::SendPacketAlways(void)
	Ser_PLAYER_DATA m_pPlayerData;
	m_pPlayerData.size = sizeof(Ser_PLAYER_DATA);
	m_pPlayerData.type = CLIENT_POSITION;
	m_pPlayerData.ID = g_myid;
	m_pPlayerData.vPos = m_pTransform->m_vPos;
	m_pPlayerData.vDir = m_pTransform->m_vAngle;
	g_Client->sendPacket(sizeof(Ser_PLAYER_DATA), CLIENT_POSITION, reinterpret_cast<BYTE*>(&m_pPlayerData));
PxCapsuledesc.contactOffset = 0.0f; //접촉 오프셋 <---- Modify
but The object is still floating.
Pictures can not be uploaded here.
And when Contact Offset = 0.0f, the program can not be executed at the moment.
Error
https://www.gamedev.net/topic/672848-physx-character-controller-s-shape-always-hover-from-the-ground/
This is the situation most similar to me.
How are you rendering your character’s capsule/box? Are you sure you use the “height” parameter correctly? Maybe you need to multiply it by two, as there’s often a confusion between what the “height” or “half height” means.
The capsule should touch the ground, as it does in our samples. You might try to check the samples and compare them to your app, to find where the difference comes from.
Otherwise, would you have a small repro that I could use? (maybe a small zip with a the minimum source code needed to reproduce the problem). The code above doesn’t show me enough to figure out where the problem comes from.
I received your reply.
I’m just using a character controller.
Player Object
variable
PxController* m_pPxCharacterController;
It is a character controller setting.
PxCapsuledesc.contactOffset = 0.1f;
Character Controller Gravity Setting
The character controller spontaneously falls from top to bottom.
Object UPDATE Part
Object that creates the map (-> ground Object)
variable
PxRigidStatic *m_pPxActor;
Using TriAngle Mesh;
It is a Static setting.
PxVec3*			m_pVtxTex;
PxU32*			m_pIndex;
_uint			m_iCount;
//Mesh vertex Count
if (!ok)
return ;
//Scale
That’s all !!
However, when the character controller falls under gravity and is closed to the ground, it does not stop but stops above a certain distance.
I really can not understand.!!!
Have you tried visualizing in PVD(PhysX Visual Debugger)? This would let you see exactly what PhysX is simulating. You may find that what is rendered in PVD looks like it’s touching the ground. If that is the case, then the issue may be the following:
(1) The halfHeight value is the height of a line segment that is the basis vector for the capsule. The full height of the capsule is halfHeight + 2*radius. If the thing you are rendering is not as big as the thing PhysX is simulating, your render will look like it’s floating.
(2) The location of the capsule is defined at center of the capsule. Please ensure that the model you’re rendering is also centered around the same space. If it isn’t (say if the geometry is centered around the base of the capsule/box), you would need to compensate for this somehow when assigning the PhysX transform to your render object.
If you take a look in PVD, you will probably see that the capsule/box is touching the ground. Alternatively, you could also confirm this by placing a very small dynamic object on the ground near your character and have it walk towards it. If the character can push the object even through the shape you’re rendering seems like it is floating above the object, that’s a good indicator that the problem is that what you’re rendering doesn’t match what PhysX is simulating.
Hope this helps.
Thank you for the reply.
(1)
I was already using PVD(PhysX Visual Debugger). Already in PVD, the Character Controller was slightly floating from the ground.
The Character Controller is affected by gravity and falls down, and the Character Controller stops at a certain height before it closes to the ground.
However, when using an object using the Dynamic Actor, the object is gravitationally affected and falls down to the ground.
Dynamic Actor is very close to the ground.
If so, is there a problem with the Character Controller?
I can not understand.
