This is not solution, when I switched to Nvidia Performance mode it caused to generate more power and heat so it triggered fan to rump up very loud. I looked into temps monitor nvidia-smi the Nvidia used about 30watt power constantly even I just move around cursor this was caused more heat and fan ramping up so out loud,
I will not install any Linux on Hybrid laptop so I will stick on Windows due to Driver software problems on Linux, I’ve been waiting for this about 1 year nothing seemed to fix I just gave up not to try another solution I will get rid Linux on my entire drive.
Another month gone by, and still no response from nVidia AT ALL. This serious issue has been around for 1.5 YEARS. Laptop can only function using the built-in display, what a farce.
Another two weeks, another ignored major issue.
I have the same problem. I have Pop OS 22.04 with Nvidia Graphics.
That’s a shame that Nvidia doesn’t fix this issue !
Hi All,
I have tested few systems like Alienware m17; Acer Nitro AN517-41 and Dell Alienware with Ubuntu and Fedora releases recently with latest released driver but could not duplicate issue locally.
I will try to find similar systems reported in this thread and share test results with pop OS.
Apologies for the delayed response but will make sure to prioritize it.
Found this thread trying to figure out whats going on here. The profile is currently in “NVIDIA On-Demand” mode.
External Samsung 34" 3440x1440@100hz connected over usb-c and providing power to the laptop. Laptop screen is also in use at 2560x1600 resolution
System and driver information as well as top snapshot:
I am on Omen 15 2020 which has Ryzen 7 4800H RTX 2060 after updated to the latest stable kernel and Nvidia drivers the problem is still there, Currently using PopOS, but I had tested a bunch of ditros with the same exact issues.
As far as I can tell, this depends on the specific hardware video output path (configuration) of the device.
Case in point for my Dell Inspiron 16 plus (7610), a Tiger Lake 11800H + Nvidia 3060 RTX device which has one HDMI output and one USB-C port (which serves graphics data via Thunderbolt Alternate Mode or DisplayPort Alternate Mode).
The HDMI port is exclusively served by the Intel GPU, and the Intel GPU itself is unable to send data via USB-C
The Nvidia GPU is the only GPU that is able to generate any output through the USB-C port (and, IIRC, the Nvidia GPU is unable to output to the built-in screen of the notebook).
(I believe I am describing a MUX design here, which is the “cheap” version of doing hardware)
In that constellation, with the exact same external 4K screen attached to the device on
- HDMI == only Intel GPU works; all good
- USB-C (using an Alternate Mode) == Intel GPU serves built-in display; Nvidia GPU serves external screen
In the latter configuration, you will see all this massive CPU load on the Xorg process; and all this load is coming from the in-process Nvidia driver, with a massive number of calls to the LInux VDSO to get the current time.
This posting of mine shows more technical detail: Nvidia X11 driver busy-polls kernel on clock_gettime in a tight loop - this also has an nvidia-smicall to expose the problem much better: It gets a whole lot worse, i.e. much worse than the badness in the “normal” case, if you downclock the Nvidia GPU.
I believe one use case may be handled rather badly by the existing Nvidia driver: If the Nvidia GPU is connected to the output (“connector”) but does not do the rendering itself.
On a hybrid notebook that is not really abnormal - personally, I want to use the Nvidia cores not for graphics, but for compute; i’s just a (unfortunate) fact of life that the notebook vendor decided to wire up the Nvidia GPU to be the one and only device producing output on USB-C.
Is this a case of poorly configured /unconfigured systems encountering a systemd /dbus bug continually knocking services out including GDM. ? Causing it to continually restart.
In my case, with the Dell Inspiron 7610, this is not the case - I am linking to a Linux kernel perf trace (rendered through, effectively, a Chrome flamegraph) which demonstrates very clearly that
- there are not errors
- the nvidia driver keeps spamming the VDSO for getting time - apparently in an attempt to sync up something (it’s hard to see the details with a totally stripped Nvidia X driver)
For me, your info just confirms that this a SystemD issue.
I believe they call this behaviour progress not a bug.
Multiple patches that down stream Distro’s havent handled well.
It’s a mess. The impression I get is SystemD /Kernel Dev’s are playing Simon Says and everyone is scrambling to catch up.
I believe this also presents on some systems with:
“[drm:nv_drm_master_set [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership”
“mtd device must be supplied (device name is empty)”
In GDM causing high cpu usage (GDM continually being kicked off dbus), in kDE causing network dropouts and freezing and preventing some systems not to boot.
I could be completely wrong.
This thread conflates a number of issues:
- The starting post had very obvious problems visible in the X log (see their Nvidia bug report attachment).
- Then people jumped in and said “my CPU is high”; I suspect that for many of these people the root cause is not found in the X log, but elsewhere.
I did notice this thread before posting my Nvidia X11 driver busy-polls kernel on clock_gettime in a tight loop question - just to start with a cleaner plate.
Alas, my posting never received any attention from Nvidia, although I suspect this to be a rather structural and generic challenge in the Nvidia driver on X, when it comes to coordinating “something” across two GPUs (Intel and Nvidia, in my case).
Lenovo T15 Gen 1, problem is highly visible and it hurts a lot. Arch Linux, no Gnome and other garbage, just XOrg and i3wm. I believe that the laptop’s monitor is connected to the internal eDP-1 output while all other outputs are connected to nVidia GPU. The problem is equally reproducible with the HDMI port or HDMI cable plugged into a USB-C hub (appears as DP port in this case).
The configuration of XOrg is done in such a way that no app uses GPU directly without invoking it specifically with prime-run. E.g. nvtop shows no apps using the GPU except XOrg itself.
Once I activate the second monitor with XRandr, the CPU usage by XOrg process spikes to 100% and the rendering of even primitive things becomes noticeably slower. Disabling the 2nd monitor gets things back to normal. Enabling maximum GPU performance with nVidia settings app does relieve the pressure a bit - XOrg process CPU usage goes down to ~25% and things become more live. But at the cost of power consumption, the fans start to work.
And I did try to strace XOrg process in the past and noticed the unusually high number of calls to gettime (or something similar) syscall, many hundreds per second. Yet, nothing gets written to XOrg log file or any other logs indicating a frequent action or a process starting and dying instantly.
FWIW, strace will only show the problem, IIRC, if the VDSO for the clock_gettime is not used.
If you see this via strace, your CPU load will be even higher compared to systems where the VDSO is used.
Wonder if this issue has anything to do with it:
No, checked with dbus-monitor, no traffic. dbus daemon is also sitting nearly idle.
No the systemd service and the X11 driver are two totally distinct things.
I would like to share my “workaround”
lets go:
my bios is mshybrid (nvidia optimus)
prime-select on-demand
I inserted into 70-uaccess.rules (udev), affet this line # DRI video devices
- SUBSYSTEM==“drm”, KERNEL==“fb0”, TAG+=“uaccess” ← avoid built-in monitor glitches when nvidia is set primary_gpu
10-nvidia.conf
- Option ""PrimaryGPU “Yes”
It is not final solution but i believe it can contribute some with this issue …
Thank you
Luiz
Without primary gpu yes (option), (xvidtune -show) [this command show up wrong info]
steam game champions_of_regnum suffers from use right resolution (ignore external display default resolution), even the game launched with env primeoffload or vgaswitcherooctl (vgaswitcherooctl launch %command%) :(
My build is Ubuntu 22.04.1 LTS, nvidia driver 515.65.01
Other info, when i ran, lshw -businfo -class display, i got this:
Informações do barramento Dispositivo Classe Descrição
pci@0000:01:00.0 /dev/fb0 display GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
pci@0000:00:02.0 /dev/fb0 display TigerLake-H GT1 [UHD Graphics]
Both using same fb0 dev
and, after running, hwinfo --gfxcard, i got this:
Primary display adapter: #15 (nvidia)
Even if bios and prime-select are set mshybrid&on-demand
