I’m doing some Eperiments with CUDA and OpenCL.
My last is, to program a Neuronal Network with both.
For this I must enter the same kernels a view times, to calculate the values.
On Cuda I can du something like this.
copy Initiating data to device
while(network is untrained)
run kernel
copy just “check conditions” out of device memory
check if network is trained
if not run next
else
exit while
Here I must copy the Data one time to device.
If I’ve manipulated it in the kernel function, on the next call, I can use the manipulated data, without any copy.
On OpenCL, this doesn’t run.
Every time, I call the kernel, there’s the same Data, as in the last “copy” call.
So I must copy the result out, of the device and after that, copy it in for the next call.
copy initiating data to kernel
run kernel
copy “all” data out
if not
copy all data to device
run next
else
exit while
This makes many traffic!
Is there any way, to do it like with CUDA?
