I have no idea what you are measuring, and I have had zero exposure to OpenCL. Under CUDA, the minimal observed kernel launch time is 5 microseconds for null kernels, meaning that there can be at most 200,000 kernel invocations per second. That minimal launch overhead has basically not changed much in about a decade, and the limiter appears to be the basic latency of the PCIe link. It is generally a good idea to design for minimal kernel execution time > 1 millisecond.
PCIe version and width impact primarily PCIe throughput, with little impact on PCIe latency. For minimum software overhead in the host-side driver stack, a CPU with high single-thread performance is recommended. At this time I would recommend a CPU with > 3.5 GHz base frequency as optimal.
