Python 2.7 and Python 3.8 are fixed versions on AGX Xavier. Trying to casually change them causes issues with the display manager, which is problematic.
I need to specify the Python path(Python3.9) to install OpenCV, but the path doesn’t change with update-alternatives
script: install_opencv.sh
cmake -D WITH_CUDA=ON
-D WITH_CUDNN=ON
-D CUDA_ARCH_BIN=“7.2”
-D CUDA_ARCH_PTX=“”
-D OPENCV_GENERATE_PKGCONFIG=ON
-D OPENCV_EXTRA_MODULES_PATH=…/…/opencv_contrib-${version}/modules
-D WITH_GSTREAMER=ON
-D WITH_LIBV4L=ON
-D BUILD_opencv_python3=ON
-D BUILD_TESTS=OFF
-D BUILD_PERF_TESTS=OFF
-D BUILD_EXAMPLES=OFF
-D CMAKE_BUILD_TYPE=RELEASE
-D CMAKE_INSTALL_PREFIX=/usr/local …
-D PYTHON_DEFAULT_EXECUTABLE=$(which python)
make -j$(nproc)
result :
– Python 2:
– Interpreter: /usr/bin/python2.7 (ver 2.7.18)
– Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.18)
– numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.16.5)
– install path: lib/python2.7/dist-packages/cv2/python-2.7
– Python 3:
– Interpreter: /usr/bin/python3 (ver 3.8.10)
– Libraries: /usr/lib/aarch64-linux-gnu/libpython3.8.so (ver 3.8.10)
– numpy: /usr/lib/python3/dist-packages/numpy/core/include (ver 1.17.4)
– install path: lib/python3.8/dist-packages/cv2/python-3.8
How can I safely change the Python path? Is there an inernal command to do this?
Please find below’s topic for the info:
You can modify the CMake command to build the OpenCV library for python 3.7.
For example, below are steps for building OpenCV with python 3.9.
** Install NumPy for python 3.9
$ sudo -H python3.9 -m pip install numpy --upgrade numpy
** Update CMake command for python 3.9
https://github.com/AastaNV/JEP/blob/master/script/install_opencv4.6.0_Jetson.sh#L62
$ cmake \
-D PYTHON_LIBRARIES=/usr/lib/python3.9/config-3.9-aarch64-linux-gnu/libpython3.9.so \
-D PYTHON3_EXECUTABLE=/usr/bin/python3…
Thank you for your response!
Despite running the install OpenCV shell script. the path is not being set.
Did somthing go wrong in the Python 3.9 installation process?
– python install
$ sudo apt install software-properties-common # add-apt-repository
$ sudo add-apt-repository ppa:deadsnakes/ppa
$ sudo apt update # update package
$ sudo apt install python3.9-dev
$ sudo apt install python3.9-dbg
$ sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.9 1
$ sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.8 2
$ sudo update-alternatives --config python # python3.9 selection
—cmake with opencv
echo “------------------------------------”
echo “** Download opencv “${version}” (2/4)”
mkdir $folder
cd ${folder}
curl -L https://github.com/opencv/opencv/archive/${version}.zip -o opencv-${version}.zip
curl -L https://github.com/opencv/opencv_contrib/archive/${version}.zip -o opencv_contrib-${version}.zip
unzip opencv-${version}.zip
unzip opencv_contrib-${version}.zip
rm opencv-${version}.zip opencv_contrib-${version}.zip
cd opencv-${version}/
echo “** Build opencv “${version}” (3/4)”
mkdir release
cd release/
-D WITH_CUDNN=ON
-D CUDA_ARCH_PTX=“”
-D WITH_LIBV4L=ON
-D BUILD_TESTS=OFF
-D PYTHON3_EXECUTABLE=/usr/bin/python3.9
make -j$(nproc)
echo “** Install opencv “${version}” (4/4)”
sudo make install
echo ‘export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH’ >> ~/.bashrc
echo ‘export PYTHONPATH=/usr/local/lib/python3.9/site-packages/:$PYTHONPATH’ >> ~/.bashrc
source ~/.bashrc
echo “** Install opencv “${version}” successfully”
echo “** Bye :)”
—result
– Python 2:
– Python 3:
– Interpreter: /usr/bin/python3.9 (ver 3.8.10)
– Python (for build): /usr/bin/python
I was able to switch to Python3.9 using a virtual environment!
Thank you for your help.
system
Closed
November 20, 2023, 6:31am
8
