I am using the NVIDIA Dali pipeline to get an output as a TensorGPU object,
I like to share those TensorGPU objects (nvidia.dali.backend_impl.TensorGPU) among the other processes,
I following the steps like
- Create a pointer for the TensorGPU object.
- Sharing those the pointer with handle in IPC.
- And use those pointers to retrieve the actual TensorGPU object in other processes.
Please refer to the following code for reference:
from nvidia.dali.pipeline import Pipeline
import nvidia.dali.fn as fn
import pycuda.driver as drv
pipe = Pipeline(batch_size=batch_size, num_threads=1, device_id=0)
with pipe:
for i in eii_list:
images = fn.external_source(source=i, num_outputs=1,device="gpu",batch=False)
enhance = fn.brightness_contrast(images, contrast=1)
pipe.set_outputs(enhance)
pipe.build()
data=batch_gpu.at(0)
#this data is of type <class 'nvidia.dali.backend_impl.TensorGPU'>
h = drv.mem_get_ipc_handle(data.data_ptr()) #data_ptr is the pointer to the TensorGPU object
but while creating a handle for data_ptr it gives the error: cuIpcGetMemHandle failed: invalid argument
I would like to ask for help on two points:
- How can I create a handle for the TensorGPU object with IPC so I can share that pointer handle to other processes and,
- How I can get the value again from that GPU pointer?
