Hi everyone
I am creating a c ++ project managed by cmake, but it works fine in cuda8.0, but not in cuda9.0. I do not know why. Please advise。
cmakefile
cmake_minimum_required(VERSION 2.8)
project(RobconCV)
set(CMAKE_CXX_COMPILER "g++")
set(CMAKE_CXX_FLAGS "-std=c++11 -O3 -ffast-math")
set(EXECUTABLE_OUTPUT_PATH ${PROJECT_SOURCE_DIR}/bin)
set(LIBRARY_OUTPUT_PATH ${PROJECT_SOURCE_DIR}/lib)
find_package(OpenCV REQUIRED)
include_directories(${OpenCV_INCLUDE_DIRS})
find_package(CUDA REQUIRED)
include_directories(${CUDA_INCLUDE_DIRS})
LIST(APPEND CUDA_NVCC_FLAGS --complier-options -fno-strict-aliasting -lineinfo -use_fast_math -Xptxas -dlcm=cg)
find_library(/usr/lib/libueye_api64.so.4.90 ueye_api)
set(THIRD_PARTY_LIBS
${OpenCV_LIBS}
${CUDA_LIBRARIES}
ueye_api
include_directories(${PROJECT_SOURCE_DIR}/include)
add_subdirectory(src)
add_subdirectory(test)
cmakefile in test folder
add_executable(CvuEye_Test CvuEye_Test.cpp)
target_link_libraries(CvuEye_Test CvuEye)
add_executable(GpuuEye_Test GpuuEye_Test.cpp)
target_link_libraries(GpuuEye_Test CvuEye)
add_executable(GpuMatNpp_Test GpuMatNpp_Test.cpp)
target_link_libraries(GpuMatNpp_Test CvuEye)
code where has problem
> File Name: GpuMatNpp_Test.cpp
> Author:
> Mail:
> Created Time: 2017年12月15日 星期五 10时44分15秒
#include "cuda_runtime.h"
#include <iostream>
#include "opencv2/gpu/gpu.hpp"
#include "opencv2/opencv.hpp"
#include <nppi.h>
using namespace std;
using namespace cv;
int main()
Mat hSrc = imread("../zero.jpg",1);
imshow("Input",hSrc);
gpu::GpuMat dSrc;
dSrc.upload(hSrc);
cout<<"Image on host memory, step = "<<hSrc.step<<" isContinuous? "<<hSrc.isContinuous()<<endl;
cout<<"Image on device memory, step = "<<dSrc.step<<" isContinuous? "<<dSrc.isContinuous()<<endl;
NppiSize oMaskSize = {5, 5};
NppiSize oSizeROI = {hSrc.cols - oMaskSize.width + 1, hSrc.rows - oMaskSize.height + 1};
NppiPoint oAnchor = {0, 0};
Size oSize(oSizeROI.width,oSizeROI.height);
Mat hDst = Mat(oSize,hSrc.type());
gpu::GpuMat dDst(oSize,hSrc.type());
nppiFilterBox_8u_C3R(dSrc.data, dSrc.step, dDst.data, dDst.step, oSizeROI, oMaskSize, oAnchor);
dDst.download(hDst);
imshow("Output",hDst);
cvWaitKey();
return 0;
