I can’t find enough information about constant memory cache. What is the nature of constant cache. I’ve read somewhere that each SP (Streaming multiprocessor) has 8Kb of cache. Is it a separate on-chip memory or is it registers that store these constants? How fast is cache, is it slower than shared memory or registers? I’m using around 300 - 500 bytes of constant memory. As far as I understand it should fit inside those 8 kilobytes that each SP has. What I would like is a procedure that caches all my constants in the beginning.
Here is “Kernel.h”
[codebox]
#include <stdio.h>
#include <cutil.h>
#include <cuda_runtime.h>
#include <cutil_inline.h>
#include “DeviceTypes.h”
constant Single* inputs;
constant UInt32* genotypes;
constant Single* phenotypes;
constant GaConsts gaConfig;
constant MmConsts mmConfig;
constant NnConsts nnConfig;
constant NnXLayer nnLayers[Layers];
#define MatrixARows(layer) nnLayers[layer].OutputRows
#define MatrixACols(layer) nnLayers[layer].InputRows
#define MatrixBRows(layer) nnLayers[layer].InputCols
#define MatrixBCols(layer) nnLayers[layer].OutputCols
#define MatrixSRows(layer) nnLayers[layer].OutputRows
#define MatrixSCols(layer) nnLayers[layer].OutputCols
global void Kernel()
#ifdef DEVICE_EMULATION
if ((blockIdx.y * gridDim.x + blockIdx.x) * blockDim.x * blockDim.y + threadIdx.y * blockDim.x + threadIdx.x == 0)
printf("Genetic algorithm configuration:\r\n");
printf("Steps.......................... %u\r\n", gaConfig.Steps);
printf("PopulationSize................. %u\r\n", gaConfig.PopulationSize);
printf("CrossoverProbability........... %u\r\n", gaConfig.CrossoverProbability);
printf("MutationProbability............ %u\r\n", gaConfig.MutationProbability);
printf("InversionProbability........... %u\r\n", gaConfig.InversionProbability);
printf("RangeA......................... %f\r\n", gaConfig.RangeA);
printf("RangeDelta..................... %f\r\n", gaConfig.RangeDelta);
printf("Matrix multiplication configuration:\r\n");
printf("WindowSize..................... %f\r\n", mmConfig.WindowSize);
printf("WindowCapacity................. %f\r\n", mmConfig.WindowCapacity);
printf("--------------\r\n");
#endif
UInt32 index = (blockIdx.y * gridDim.x + blockIdx.x) * blockDim.x * blockDim.y + threadIdx.y * blockDim.x + threadIdx.x;
UInt32 spicieIndex = index / mmConfig.WindowCapacity;
UInt32 windowIndex = index - spicieIndex * mmConfig.WindowCapacity;
UInt32 windowRow = windowIndex / mmConfig.WindowSize;
UInt32 windowCol = windowIndex - windowRow * mmConfig.WindowSize;
for (UInt32 layer = 0; layer < nnConfig.Layers; layer++)
// Here I evaluate neural network
template T* Allocate(UInt32 size)
Byte* ptr;
CUDA_SAFE_CALL(cudaMalloc((void**)&ptr, size));
return ptr;
template void Free(T* ptr)
CUDA_SAFE_CALL(cudaFree(ptr));
extern “C” void LaunchKernel
Byte* gaConfig,
Byte* mmConfig,
Byte* nnConfig,
Byte* layerConsts,
UInt32 layerConstsSize,
Byte* inputGlobals,
UInt32 inputGlobalsSize,
Byte* genotypeGlobals,
UInt32 genotypeGlobalsSize,
Byte* phenotypeGlobals,
UInt32 phenotypeGlobalsSize
#ifndef DEVICE_EMULATION
cudaSetDevice(cutGetMaxGflopsDeviceId());
#endif
unsigned int timer = 0;
Byte* inputGlobalsDevice = Allocate<Byte>(inputGlobalsSize);
Byte* genotypeGlobalsDevice = Allocate<Byte>(genotypeGlobalsSize);
Byte* phenotypeGlobalsDevice = Allocate<Byte>(phenotypeGlobalsSize);
CUDA_SAFE_CALL(cudaMemcpy(inputGlobalsDevice, inputGlobals, inputGlobalsSize, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpy(genotypeGlobalsDevice, genotypeGlobals, genotypeGlobalsSize, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpy(phenotypeGlobalsDevice, phenotypeGlobals, phenotypeGlobalsSize, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpyToSymbol(inputs, (void*)&inputGlobalsDevice, sizeof(Single*), 0, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpyToSymbol(genotypes, (void*)&genotypeGlobalsDevice, sizeof(UInt32*), 0, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpyToSymbol(phenotypes, (void*)&phenotypeGlobalsDevice, sizeof(Single*), 0, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpyToSymbol(::gaConfig, (void*)gaConfig, sizeof(GaConsts), 0, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpyToSymbol(::mmConfig, (void*)mmConfig, sizeof(MmConsts), 0, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpyToSymbol(::nnConfig, (void*)nnConfig, sizeof(NnConsts), 0, cudaMemcpyHostToDevice));
CUDA_SAFE_CALL(cudaMemcpyToSymbol(::nnLayers, (void*)layerConsts, layerConstsSize, 0, cudaMemcpyHostToDevice));
cutilCheckError(cutCreateTimer(&timer));
cutilCheckError(cutStartTimer(timer));
Kernel<<<1, 128>>>();
cudaThreadSynchronize();
cutilCheckError(cutStopTimer(timer));
Single timerValue = cutGetTimerValue(timer);
cutilCheckError(cutDeleteTimer(timer));
printf("Processing time: %f (ms)\n", timerValue);
Free(inputGlobalsDevice);
Free(genotypeGlobalsDevice);
Free(phenotypeGlobalsDevice);
[/codebox]
Here is “Program.cpp”
[codebox]
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include “Common.h”
#include “HostTypes.h”
Byte* gaConsts,
Byte* mmConsts,
Byte* nnConsts,
Byte* layerConsts,
Byte* inputGlobals,
int main(int argc, char** argv)
srand(Date);
RandomSingleMatrix input = RandomSingleMatrix(InputRows, InputCols, GrayRangeA, GrayRangeB);
ZeroSingleExLayer phenotypeLayer = ZeroSingleExLayer(InputRows, InputCols, OutputRows, OutputCols);
RandomUInt32ExLayer genotypeLayer = RandomUInt32ExLayer(InputRows, InputCols, OutputRows, OutputCols, None);
Object** genotypeNetwork = new Object*[Layers];
Object** phenotypeNetwork = new Object*[Layers];
for (UInt32 i = 0; i < Layers; i++)
genotypeNetwork[i] = &genotypeLayer;
phenotypeNetwork[i] = &phenotypeLayer;
GeneralCollection genotype = GeneralCollection(Layers, genotypeNetwork, None);
GeneralCollection phenotype = GeneralCollection(Layers, phenotypeNetwork, None);
GeneralVector inputs = GeneralVector(PopulationSize, &input, None);
GeneralVector genotypes = GeneralVector(PopulationSize, &genotype, None);
GeneralVector phenotypes = GeneralVector(PopulationSize, &phenotype, None);
GeneticAlgorithmConfiguration gac = GeneticAlgorithmConfiguration
Steps,
PopulationSize,
CrossoverProbabililty,
MutationProbabililty,
InversionProbabililty,
GrayRangeA,
GrayRangeB
NeuralNetworkConfiguration nnc = NeuralNetworkConfiguration
Layers,
genotype.GetGlobalsSize(),
phenotype.GetGlobalsSize(),
genotypeLayer.GetGlobalsSize(),
phenotypeLayer.GetGlobalsSize()
MatrixMultiplicationConfiguration mmc = MatrixMultiplicationConfiguration(WindowSize);
ConstantsBuffer *gacConstants = gac.GetConstants();
ConstantsBuffer *mmcConstants = mmc.GetConstants();
ConstantsBuffer *nncConstants = nnc.GetConstants();
GlobalsBuffer *inputsGlobals = inputs.GetGlobals();
GlobalsBuffer *genotypesGlobals = genotypes.GetGlobals();
GlobalsBuffer *phenotypesGlobals = phenotypes.GetGlobals();
ConstantsBuffer *layerConstants = genotypes.GetConstants();
LaunchKernel
gacConstants->Ptr,
mmcConstants->Ptr,
nncConstants->Ptr,
layerConstants->Ptr,
layerConstants->Size,
inputsGlobals->Ptr,
inputsGlobals->Size,
genotypesGlobals->Ptr,
genotypesGlobals->Size,
phenotypesGlobals->Ptr,
phenotypesGlobals->Size
delete gacConstants;
delete mmcConstants;
delete nncConstants;
delete inputsGlobals;
delete genotypesGlobals;
delete phenotypesGlobals;
delete layerConstants;
[/codebox]
Here is “Common.h”
[codebox]
#ifndef COMMON
#define COMMON
// Types
typedef int Int32;
typedef short Int16;
typedef float Single;
typedef double Double;
typedef signed char SByte;
typedef unsigned char Byte;
typedef unsigned int UInt32;
typedef unsigned short UInt16;
// Constants
static const UInt32 Date = 20090409;
static const Single GrayRangeA = -1;
static const Single GrayRangeB = 1;
static const UInt32 WindowSize = 2;
static const UInt32 Steps = 4;
static const UInt32 PopulationSize = 1024;
static const UInt32 Layers = 8;
static const UInt32 InputRows = 8;
static const UInt32 InputCols = 8;
static const UInt32 OutputRows = 8;
static const UInt32 OutputCols = 8;
static const UInt32 CrossoverProbabililty = (UInt32)(0.95 * UINT_MAX);
static const UInt32 MutationProbabililty = (UInt32)(0.03 * UINT_MAX);
static const UInt32 InversionProbabililty = (UInt32)(0.02 * UINT_MAX);
#endif
[/codebox]
Here are “HostTypes.h”
[codebox]
// TODO : Replace ‘new’ with ‘cudaMallocHost’
// TODO : Make objects singleton or mutable
#ifndef HOSTTYPES
#define HOSTTYPES
#include “Common.h”
enum Space
None = 0,
Globals = 1,
Constants = 2,
Mixed = 3
class Buffer
private:
static Byte* Allocate(UInt32 size)
Byte* result;
CUDA_SAFE_CALL(cudaMallocHost((void**)&result, size));
return result;
protected:
Buffer() : Size(0), Ptr(NULL)
Offset = 0;
Buffer(UInt32 size) : Size(size), Ptr(new Byte)
Offset = 0;
public:
UInt32 Offset;
Byte *Ptr;
UInt32 Size;
bool IsEmpty()
return Size == 0 || Ptr == NULL;
template <typename T> void Add(T value)
// When buffer not specified, we only count elements
if (Ptr != NULL)
// Before writing we should check for buffer overflow
// TODO: add #ifndef NO_BUFFER_OVERFLOW_CHECK
if (Offset + sizeof(T) <= Size)
*((T*)(Ptr + Offset)) = value;
else
throw "Buffer overflow in Buffer::Add(T value)";
Offset += sizeof(T);
template <typename T> T* Allocate(UInt32 count)
T* result = (T*)(Ptr + Offset);
Offset += count * sizeof(T);
if (Offset > Size)
Offset -= count * sizeof(T);
throw "Buffer overflow in T* Buffer::Allocate<T>(UInt32 count)";
return result;
template <typename T> void Account(UInt32 count)
void AccountOffset(UInt32 offset)
Offset += offset;
virtual ~Buffer()
if (Ptr != NULL) CUDA_SAFE_CALL(cudaFreeHost(Ptr));
class GlobalsBuffer : public Buffer
public:
GlobalsBuffer() : Buffer()
GlobalsBuffer(UInt32 size) : Buffer(size)
class ConstantsBuffer : public Buffer
public:
ConstantsBuffer() : Buffer()
ConstantsBuffer(UInt32 size) : Buffer(size)
class Object
public:
virtual UInt32 GetGlobalsSize() const
GlobalsBuffer buffer = GlobalsBuffer();
RenderGlobals(&buffer);
return buffer.Offset;
virtual UInt32 GetConstantsSize() const
ConstantsBuffer buffer = ConstantsBuffer();
RenderConstants(&buffer);
virtual void RenderGlobals(GlobalsBuffer *buffer) const = 0;
virtual void RenderConstants(ConstantsBuffer *buffer) const = 0;
virtual ConstantsBuffer* GetConstants() const
return GetConstants(GetConstantsSize());
virtual ConstantsBuffer* GetConstants(UInt32 size) const
ConstantsBuffer *result = new ConstantsBuffer(size);
RenderConstants(result);
return result;
virtual ConstantsBuffer* GetConstants(ConstantsBuffer *buffer) const
RenderConstants(buffer);
return buffer;
virtual GlobalsBuffer* GetGlobals() const
return GetGlobals(GetGlobalsSize());
virtual GlobalsBuffer* GetGlobals(UInt32 size) const
GlobalsBuffer *result = new GlobalsBuffer(size);
RenderGlobals(result);
return result;
virtual GlobalsBuffer* GetGlobals(GlobalsBuffer *buffer)
RenderGlobals(buffer);
return buffer;
// MixedObject objects can affect both constant and global memory spaces depending on the value of field ‘ObjectSpace’.
class MixedObject : public Object
protected:
virtual void RenderObjectGlobals(GlobalsBuffer *buffer) const = 0;
virtual void RenderObjectConstants(ConstantsBuffer *buffer) const = 0;
public:
Space ObjectSpace;
MixedObject(Space objectSpace = Mixed) : ObjectSpace(objectSpace)
virtual void RenderGlobals(GlobalsBuffer *buffer) const override
if (ObjectSpace & Globals) RenderObjectGlobals(buffer);
virtual void RenderConstants(ConstantsBuffer *buffer) const override
if (ObjectSpace & Constants) RenderObjectConstants(buffer);
// GlobalObject lies in global memory space and therefore not affects constant memory space
class GlobalObject : public Object
private:
// This is empty method, no changes are made to the buffer
virtual UInt32 GetConstantsSize() const override
return 0;
// ConstantObject lies in constant memory space and therefore not affects global memory space
class ConstantObject : public Object
private:
virtual UInt32 GetGlobalsSize() const override
return 0;
class UInt32Object : public GlobalObject
public:
return sizeof(UInt32);
class SingleObject : public GlobalObject
public:
return sizeof(Single);
class ZeroUInt32 : public UInt32Object
public:
buffer->Add<UInt32>(0);
class ZeroSingle : public SingleObject
public:
buffer->Add<Single>(0);
class RandomUInt32 : public UInt32Object
public:
buffer->Add(rand() + (rand() << 16));
class RandomSingle : public SingleObject
public:
Single GrayRangeA;
Single RangeDeltaNormalized;
RandomSingle() : GrayRangeA(0), RangeDeltaNormalized(1.0F / UINT_MAX)
RandomSingle
Single rangeA,
Single rangeDelta
) : GrayRangeA(rangeA),
RangeDeltaNormalized(rangeDelta / UINT_MAX)
buffer->Add(GrayRangeA + (rand() + (rand() << 16)) * RangeDeltaNormalized);
class Container : public MixedObject
private:
virtual void RenderObjectGlobals(GlobalsBuffer *buffer) const override
// Containers can't have any globals, only their children can.
protected:
virtual void RenderObjectConstants(ConstantsBuffer *buffer) const override
buffer->Add(Length);
buffer->Add(GetGlobalsSize());
public:
UInt32 Length;
Space ChildSpace;
Container(UInt32 length, Space objectSpace = Constants, Space childSpace = Mixed) : Length(length), ChildSpace(childSpace), MixedObject(objectSpace)
// MixedObjectContainer is the object that contains mixed child elements.
class MixedObjectContainer : public Container
protected:
virtual void RenderChildGlobals(GlobalsBuffer *buffer) const = 0;
virtual void RenderChildConstants(ConstantsBuffer *buffer) const = 0;
public:
MixedObjectContainer(UInt32 length, Space objectSpace = Constants, Space childSpace = Mixed) : Container(length, objectSpace, childSpace)
if (ChildSpace & Globals) RenderChildGlobals(buffer);
Container::RenderConstants(buffer);
if (ChildSpace & Constants) RenderChildConstants(buffer);
class GlobalObjectContainer : public Container
protected:
public:
GlobalObjectContainer(UInt32 length, Space objectSpace = Constants, Space childSpace = Globals) : Container(length, objectSpace, childSpace)
class ConstantObjectContainer : public Container
protected:
public:
ConstantObjectContainer(UInt32 length, Space objectSpace = Constants, Space childSpace = Constants) : Container(length, objectSpace, childSpace)
// No globals
class UInt32Vector : public GlobalObjectContainer
protected:
GlobalObjectContainer::RenderObjectConstants(buffer);
buffer->Add(Length * sizeof(UInt32));
public:
UInt32Vector(UInt32 length, Space objectSpace = Constants, Space childSpace = Globals) : GlobalObjectContainer(length, objectSpace, childSpace)
return Length * sizeof(UInt32);
class SingleVector : public GlobalObjectContainer
protected:
buffer->Add(Length * sizeof(Single));
public:
SingleVector(UInt32 length, Space objectSpace = Constants, Space childSpace = Globals) : GlobalObjectContainer(length, objectSpace, childSpace)
return Length * sizeof(Single);
class ZeroUInt32Vector : public UInt32Vector
protected:
virtual void RenderChildGlobals(GlobalsBuffer *buffer) const override
if (buffer->IsEmpty())
buffer->Account<UInt32>(Length);
else
UInt32 length = Length;
UInt32 *pointer = buffer->Allocate<UInt32>(length);
for (UInt32 i = 0; i < length; i++) pointer[i] = 0;
public:
ZeroUInt32Vector(UInt32 length, Space objectSpace = Constants, Space childSpace = Globals) : UInt32Vector(length, objectSpace, childSpace)
class ZeroSingleVector : public SingleVector
protected:
buffer->Account<Single>(Length);
else
Single *pointer = buffer->Allocate<Single>(length);
for (UInt32 i = 0; i < length; i++) pointer[i] = 0.0F;
public:
ZeroSingleVector(UInt32 length, Space objectSpace = Constants, Space childSpace = Globals) : SingleVector(length, objectSpace, childSpace)
class RandomUInt32Vector : public UInt32Vector
protected:
else
for (UInt32 i = 0; i < length; i++) pointer[i] = rand() + (rand() << 16);
public:
RandomUInt32Vector(UInt32 length, Space objectSpace = Constants, Space childSpace = Globals) : UInt32Vector(length, objectSpace, childSpace)
class RandomSingleVector : public SingleVector
protected:
else
Single rangeA = GrayRangeA;
Single rangeDelta = RangeDeltaNormalized;
for (UInt32 i = 0; i < length; i++) pointer[i] = rangeA + (rand() + (rand() << 16)) * rangeDelta;
public:
Single GrayRangeA;
RandomSingleVector(UInt32 length, Single rangeA, Single rangeDelta, Space objectSpace = Constants, Space childSpace = Globals) : GrayRangeA(rangeA), RangeDeltaNormalized(rangeDelta / UINT_MAX), SingleVector(length, objectSpace, childSpace)
class ZeroUInt32Matrix : public ZeroUInt32Vector
protected:
ZeroUInt32Vector::RenderObjectConstants(buffer);
buffer->Add(Rows);
buffer->Add(Cols);
public:
UInt32 Rows;
UInt32 Cols;
ZeroUInt32Matrix(UInt32 rows, UInt32 cols, Space objectSpace = Constants, Space childSpace = Globals) : Rows(rows), Cols(cols), ZeroUInt32Vector(rows * cols, objectSpace, childSpace)
class ZeroSingleMatrix : public ZeroSingleVector
protected:
ZeroSingleVector::RenderObjectConstants(buffer);
buffer->Add(Rows);
buffer->Add(Cols);
public:
UInt32 Rows;
UInt32 Cols;
ZeroSingleMatrix(UInt32 rows, UInt32 cols, Space objectSpace = Constants, Space childSpace = Globals) : Rows(rows), Cols(cols), ZeroSingleVector(rows * cols, objectSpace, childSpace)
class RandomUInt32Matrix : public RandomUInt32Vector
protected:
buffer->Add(Rows);
buffer->Add(Cols);
public:
UInt32 Rows;
UInt32 Cols;
RandomUInt32Matrix(UInt32 rows, UInt32 cols, Space objectSpace = Constants, Space childSpace = Globals) : Rows(rows), Cols(cols), RandomUInt32Vector(rows * cols, objectSpace, childSpace)
class RandomSingleMatrix : public RandomSingleVector
protected:
RandomSingleVector::RenderObjectConstants(buffer);
buffer->Add(Rows);
buffer->Add(Cols);
public:
UInt32 Rows;
UInt32 Cols;
RandomSingleMatrix(UInt32 rows, UInt32 cols, Single rangeA, Single rangeDelta, Space objectSpace = Constants, Space childSpace = Globals) : Rows(rows), Cols(cols), RandomSingleVector(rows * cols, rangeA, rangeDelta, objectSpace, childSpace)
class GeneralCollection : public MixedObjectContainer
protected:
buffer->AccountOffset(GetGlobalsSize());
else
for (UInt32 i = 0; i < Length; i++) Elements[i]->RenderGlobals(buffer);
virtual void RenderChildConstants(ConstantsBuffer *buffer) const override
buffer->AccountOffset(GetConstantsSize());
else
for (UInt32 i = 0; i < length; i++) Elements[i]->RenderConstants(buffer);
public:
Object **Elements;
GeneralCollection(UInt32 length, Object **elements, Space objectSpace = Constants, Space childSpace = Mixed) : Elements(elements), MixedObjectContainer(length, objectSpace, childSpace)
UInt32 size = 0;
for (UInt32 i = 0; i < length; i++) size += Elements[i]->GetGlobalsSize();
return size;
UInt32 size = 0;
for (UInt32 i = 0; i < length; i++) size += Elements[i]->GetConstantsSize();
return size;
class GeneralVector : public MixedObjectContainer
protected:
buffer->AccountOffset(Length * Element->GetGlobalsSize());
else
for (UInt32 i = 0; i < Length; i++) Element->RenderGlobals(buffer);
Element->RenderConstants(buffer);
public:
Object *Element;
GeneralVector(UInt32 length, Object *element, Space objectSpace = Constants, Space childSpace = Mixed) : Element(element), MixedObjectContainer(length, objectSpace, childSpace)
return Length * Element->GetGlobalsSize();
class GeneralMatrix : public GeneralVector
protected:
GeneralVector::RenderObjectConstants(buffer);
buffer->Add(Rows);
buffer->Add(Cols);
public:
UInt32 Rows;
UInt32 Cols;
GeneralMatrix(UInt32 rows, UInt32 cols, Object *element, Space objectSpace = Constants, Space childSpace = Mixed) : Rows(rows), Cols(cols), GeneralVector(rows * cols, element, objectSpace, childSpace)
// Standard neural network layer consists of a vector “Connections” that represents connections
// and a vector “Biases” that represents biases. Having some input vector “Input” to calculate
// current layer pass we need to do the following:
// “Connections” * “Input” + “Biases” (corresponding vector dimensions must agree)
// Though not in every case it is easy to work with vectors, you need non mathematical procedures
// to create a 2-dimensional matrix out of a vector, and in my opinion it is not good.
// In this case I’m using 2 matrices “Left” and “Right” as the connections and matrix “Biases”
// as the biases. To complete current layer pass I will have to do the following:
// “Left” * “Input” * “Right” + “Biases”
// By having the input matrix dimensions equal to “InputRows x InputCols” and by willing to receive
// “OutputRows x OutputCols” matrix from current layer pass the above operation should look like:
// “OutputRows x InputRows” * “InputRows x InputCols” * “InputCols x OutputCols” + “OutputRows x OutputCols”
class ExLayer : public MixedObject
private:
// No globals
protected:
UInt32 offset = 0;
buffer->Add(InputRows);
buffer->Add(InputCols);
buffer->Add(OutputRows);
buffer->Add(OutputCols);
buffer->Add(offset += Left->GetGlobalsSize());
buffer->Add(offset += Right->GetGlobalsSize());
buffer->Add(offset += Biases->GetGlobalsSize());
buffer->Add(offset += LeftOutput->GetGlobalsSize());
buffer->Add(offset += RightOutput->GetGlobalsSize());
ExLayer
UInt32 inputRows,
UInt32 inputCols,
UInt32 outputRows,
UInt32 outputCols,
Object *left,
Object *leftOutput,
Object *right,
Object *rightOutput,
Object *biases,
Space outSpace = Globals,
Space lrbSpace = Globals,
) : Left(left),
Right(right),
Biases(biases),
LeftOutput(leftOutput),
RightOutput(rightOutput),
InputRows(inputRows),
InputCols(inputCols),
OutputRows(outputRows),
OutputCols(outputCols),
LrbSpace(lrbSpace),
OutSpace(outSpace),
public:
Space OutSpace;
Space LrbSpace;
Object *Left;
Object *Right;
Object *Biases;
Object *LeftOutput;
Object *RightOutput;
UInt32 InputRows;
UInt32 InputCols;
UInt32 OutputRows;
UInt32 OutputCols;
if (LrbSpace & Globals)
Left->RenderGlobals(buffer);
Right->RenderGlobals(buffer);
Biases->RenderGlobals(buffer);
if (OutSpace & Globals)
LeftOutput->RenderGlobals(buffer);
RightOutput->RenderGlobals(buffer);
MixedObject::RenderConstants(buffer);
if (LrbSpace & Constants)
Left->RenderConstants(buffer);
Right->RenderConstants(buffer);
Biases->RenderConstants(buffer);
if (OutSpace & Constants)
LeftOutput->RenderConstants(buffer);
RightOutput->RenderConstants(buffer);
~ExLayer()
delete Left;
delete Right;
delete Biases;
delete LeftOutput;
delete RightOutput;
class ZeroUInt32ExLayer : public ExLayer
public:
ZeroUInt32ExLayer(UInt32 inputRows, UInt32 inputCols, UInt32 outputRows, UInt32 outputCols, Space outSpace = Globals, Space lrbSpace = Globals, Space objectSpace = Constants) : ExLayer
inputRows,
inputCols,
outputRows,
outputCols,
new ZeroUInt32Matrix(outputRows, inputRows, Constants, Mixed),
new ZeroUInt32Matrix(inputCols, outputCols, Constants, Mixed),
new ZeroUInt32Matrix(outputRows, outputCols, Constants, Mixed),
new ZeroUInt32Matrix(outputRows, inputCols, Constants, Mixed),
outSpace, lrbSpace, objectSpace
class RandomUInt32ExLayer : public ExLayer
public:
RandomUInt32ExLayer(UInt32 inputRows, UInt32 inputCols, UInt32 outputRows, UInt32 outputCols, Space outSpace = Globals, Space lrbSpace = Globals, Space objectSpace = Constants) : ExLayer
inputRows,
inputCols,
outputRows,
outputCols,
new RandomUInt32Matrix(outputRows, inputRows, Constants, Mixed),
new RandomUInt32Matrix(inputCols, outputCols, Constants, Mixed),
new RandomUInt32Matrix(outputRows, outputCols, Constants, Mixed),
new RandomUInt32Matrix(outputRows, inputCols, Constants, Mixed),
class ZeroSingleExLayer : public ExLayer
public:
ZeroSingleExLayer
UInt32 inputRows,
UInt32 inputCols,
UInt32 outputRows,
UInt32 outputCols,
) : ExLayer
inputRows,
inputCols,
outputRows,
outputCols,
new ZeroSingleMatrix(outputRows, inputRows, Constants, Globals),
new ZeroSingleMatrix(inputCols, outputCols, Constants, Globals),
new ZeroSingleMatrix(outputRows, outputCols, Constants, Globals),
new ZeroSingleMatrix(outputRows, inputCols, Constants, Globals),
class RandomSingleExLayer : public ExLayer
public:
RandomSingleExLayer(UInt32 inputRows, UInt32 inputCols, UInt32 outputRows, UInt32 outputCols, Single rangeA, Single rangeDelta, Space outSpace = Globals, Space lrbSpace = Globals, Space objectSpace = Constants) : ExLayer
inputRows,
inputCols,
outputRows,
outputCols,
new RandomSingleMatrix(outputRows, inputRows, rangeA, rangeDelta, Constants, Globals),
new RandomSingleMatrix(inputCols, outputCols, rangeA, rangeDelta, Constants, Globals),
new RandomSingleMatrix(outputRows, outputCols, rangeA, rangeDelta, Constants, Globals),
new RandomSingleMatrix(outputRows, inputCols, rangeA, rangeDelta, Constants, Globals),
class GeneralExLayer : public ExLayer
public:
GeneralExLayer(UInt32 inputRows, UInt32 inputCols, UInt32 outputRows, UInt32 outputCols, Object *element, Space outSpace = Globals, Space lrbSpace = Globals, Space objectSpace = Constants) :
ExLayer
inputRows,
inputCols,
outputRows,
outputCols,
new GeneralMatrix(outputRows, inputRows, element, Constants, Mixed),
new GeneralMatrix(inputCols, outputCols, element, Constants, Mixed),
new GeneralMatrix(outputRows, outputCols, element, Constants, Mixed),
new GeneralMatrix(outputRows, InputCols, element, Constants, Mixed),
class GeneticAlgorithmConfiguration : public ConstantObject
public:
UInt32 Steps;
UInt32 PopulationSize;
UInt32 CrossoverProbability;
UInt32 MutationProbability;
UInt32 InversionProbability;
Single GrayRangeA;
Single GrayRangeB;
UInt32 steps,
UInt32 populationSize,
UInt32 crossoverProbability,
UInt32 mutationProbability,
UInt32 inversionProbability,
Single grayRangeA,
Single grayRangeB
Steps(steps),
PopulationSize(populationSize),
CrossoverProbability(crossoverProbability),
MutationProbability(mutationProbability),
InversionProbability(inversionProbability),
GrayRangeA(grayRangeA),
GrayRangeB(grayRangeB)
buffer->Add(Steps);
buffer->Add(PopulationSize);
buffer->Add(CrossoverProbability);
buffer->Add(MutationProbability);
buffer->Add(InversionProbability);
buffer->Add(GrayRangeA);
buffer->Add((GrayRangeB - GrayRangeA) / UINT_MAX);
class MatrixMultiplicationConfiguration : public ConstantObject
public:
UInt32 WindowSize;
UInt32 WindowCapacity;
MatrixMultiplicationConfiguration(UInt32 windowSize) : WindowSize(windowSize), WindowCapacity(windowSize * windowSize)
buffer->Add(WindowSize);
buffer->Add(WindowCapacity);
class NeuralNetworkConfiguration : public ConstantObject
public:
UInt32 Layers;
UInt32 GenotypeSize;
UInt32 PhenotypeSize;
UInt32 GenotypeLayerSize;
UInt32 PhenotypeLayerSize;
UInt32 layers,
UInt32 genotypeSize,
UInt32 phenotypeSize,
UInt32 genotypeLayerSize,
UInt32 phenotypeLayerSize
) : Layers(layers),
GenotypeSize(genotypeSize),
PhenotypeSize(phenotypeSize),
GenotypeLayerSize(genotypeLayerSize),
PhenotypeLayerSize(phenotypeLayerSize)
buffer->Add(Layers);
buffer->Add(GenotypeSize);
buffer->Add(PhenotypeSize);
buffer->Add(GenotypeLayerSize);
buffer->Add(PhenotypeLayerSize);
#endif
[/codebox]
Here are “DeviceTypes.h”
[codebox]
#ifndef DEVICETYPES
#define DEVICETYPES
#include “Common.h”
typedef struct align(8)
UInt32 Length;
UInt32 Size;
} Array;
UInt32 Length;
UInt32 Size;
} Collection;
typedef struct align(16)
UInt32 Length;
UInt32 Size;
UInt32 Rows;
UInt32 Cols;
} Matrix;
UInt32 InputRows;
UInt32 InputCols;
UInt32 OutputRows;
UInt32 OutputCols;
UInt32 LeftOffset;
UInt32 RightOffset;
UInt32 BiasesOffset;
UInt32 LeftOutputOffset;
UInt32 RightOutputOffset;
} NnXLayer;
typedef struct align(4)
UInt32 Layers;
} NnConsts;
UInt32 Steps;
Single RangeA;
Single RangeDelta;
} GaConsts;
UInt32 WindowSize;
} MmConsts;
#endif
[/codebox]
