My algorithm needs TensorRT6, so I want to install TensorRT6 in a virtual environment, How do I install TensorRT6 for Jetson NX?
Sorry that there is no available TensorRT6 for XavierNX.
We do have an image for JetPack4.3 but it mounts libraries from the host that make host need to be JetPack4.3 also.
Would you mind to tell us why do you need TensorRT6?
Do you meet any error when upgrading your algorithm into TensoRT7?
Hello, I met ths same problem. please help.
We need to transfer our old project which works on TrT6 to xavier nx. But we met many problems on Trt7. To debug this issue is very time-consuming, and our technical level is also quite limited.
Is there any way to install Trt76 on xavier nx, e.g. docker images for jetpack 4.3?
Please help to open a new topic for your issue. Thanks
