Thank you so much for the quick reply!
From the links you send, I tried using this pipeline
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=3280, height=1848, framerate=28/1, format=NV12' ! nvvidconv left=200 right=3080 top=600 bottom=1200 ! 'video/x-raw,width=2880, height=600, framerate=28/1, format=NV12, pixel-aspect-ratio=1/1' ! nvvidconv ! nvv4l2h264enc ! h264parse ! flvmux ! rtmpsink location='rtmp://x.x.x.x:1935/live/test '
Should I change the location to rtmp://localhost:1935/live/test?
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21,000000 fps Duration = 47619048 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28,000001 fps Duration = 35714284 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3264 H = 2464
seconds to Run = 0
Frame Rate = 21,000000
GST_ARGUS: PowerService: requested_clock_Hz=37126320
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
H264: Profile = 66, Level = 0
ERROR: from element /GstPipeline:pipeline0/GstRTMPSink:rtmpsink0: Could not open resource for writing.
Additional debug info:
gstrtmpsink.c(245): gst_rtmp_sink_render (): /GstPipeline:pipeline0/GstRTMPSink:rtmpsink0:
Could not connect to RTMP stream "rtmp://localhost:1935/live/test " for writing
Execution ended after 0:00:01.062956562
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
GST_ARGUS:
PowerServiceHwVic::cleanupResources
This is the code I get when I try to execute this pipe.
Once again, thank you for your help!
