I am using ffserver with the following config to push video file into stream:
Port 8090
# bind to all IPs aliased or not
BindAddress 0.0.0.0
# max number of simultaneous clients
MaxClients 1000
# max bandwidth per-client (kb/s)
MaxBandwidth 10000
# Suppress that if you want to launch ffserver as a daemon.
NoDaemon
<Feed feed1.ffm>
File /tmp/feed1.ffm
FileMaxSize 5M
</Feed>
<Stream test.swf>
Feed feed1.ffm
Format swf
VideoCodec flv
VideoFrameRate 15
VideoBufferSize 80000
VideoBitRate 100
VideoQMin 1
VideoQMax 5
VideoSize 352x288
PreRoll 0
Noaudio
I can watch it with ffmpeg like this:
ffplay http://SERVERIP:8090/test.swf
If I replace uri in working deepstream config:
[source0]
uri=http://SERVERIP:8090/test.swf
then I get this error:
WARNING from src_elem: No decoder available for type 'application/x-shockwave-flash'.
Debug info: gsturidecodebin.c(921): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem
ERROR from src_elem: Your GStreamer installation is missing a plug-in.
Debug info: gsturidecodebin.c(988): no_more_pads_full (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem:
no suitable plugins found:
gstdecodebin2.c(4679): gst_decode_bin_expose (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0:
Missing decoder: application/x-shockwave-flash (application/x-shockwave-flash)
Quitting
ERROR from source: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstSoupHTTPSrc:source:
streaming stopped, reason not-linked (-1)
App run failed
how can I fix it?
