How many can use Blocks to effcient parallel prog
Hello.
I searched Sums Function in forums.
Many Peopls said that See Reduction Example.
So, I’m seeing that.
But, In 4 pages of Reduction DOC.. I don’t understand …
IN 4 Pages
Problem : Global Synchronization
CUDA has no global synchronization. Why?
Expensive to build in hardware for GPUs with high processor count
Would force programmer to run fewer blocks (no more than # multiprocessors * # resident blocks / multiprocessor) to avoid deadlock, which may reduce overall efficiency
I don’t understand…
Needs Many Blocks for my program..
I have matched M -Number of Block and Up to 512 threads of a block
I knew that Using Maximum Blocks in One cycles is Most Efficency till yesterday!!
But,That is My miss. Above statement (Would force ~~~~)
Geforce 9800 GT;
14 MPs;
a BLOCK has up to 512threads
a Grid has up to 3-D : 512 * 512 * 64
I need 2-Demsion Grid. (512 * 512)
that has 512 * 512 Blocks.. equal 262144;
How many can use that one cycles..??
and How code that??
Seperate Auto?? or Manual?
Simple (My code);;
int idx = threadIdx.x;
int j = blockIdx.x + gridDim.x * blockIdx.y;
result[j + idx] = arr[j + idx] * ALPHA;
sums[j] += result[j + idx]
Help me..
Thanks.. Read This…
That is incorrect
A block can have up to 512 threads in a 3D arragement, with maximum dimensions in the x,y, and z directions of 512,512 and 64.
A grid can have up to 4294836225 blocks in a 2D arrangement, with maximum dimensions 65535x65535
I think That is incorrect…
I metioned data from deviceQuery;
When The size of A block is more than 500(600 in the Limit test), Test failed.
Output : Incorrect Value
Before that test, I have test 2-D block… because that test failed, I had above test.
I want to really know, Not Why test failed, How many can use Thread, Block, Grid… in 1 cycle.
From Test…
in Addition…
[b] Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1[/b]
second line…
I think (( )) first.
blockDim.x < 512, blockDim.y < 512, blockDim…z < 64
gridDim.x < 65535, gridDim.y < 65535
But I don’t think that NoW…
Now
blockIdx.x < 512, blockIdx.y < 512, blockIdx.z < 64
gridIdx.x < 65535, gridIdx.y < 65535
What is the case correct ???
What I wrote is 100% correct and exactly mirrored in the device query output you posted above. I don’t understand where you think the ambiguity is.
BlockDim and GridDim are the selected block and grid size. threadIdx and blockIdx are the indices of a given thread and block within the block/grid hierachy so that
threadIdx.{x,y,z} < blockDim.{x,y,z} < {512,512,64} and blockIdx.{x,y}<gridDim.{x,y} < {65535,65535}
just to make clear to anyone not familiar with the matter there are more conditions:
0 < blockDim.x * blockDim.y * blockDim.z <=512, with the 512 being a maimum that might need to be smaller depending on kernel register usage.
I had missed…
I said you that below articles. I have test already Modification blockDim… I’m failed… dim3 dblock(500,500,60) ;
Looking CUDA programming guide DOC, have coded.
Modificate dimx,dimy,dimz ; Conclusion is Total Number of threads of 3D - block equal to that of 1D-block;
I have told this…
of course, I’m not experts; As first articles. I’m beginner;
If you have example codes about {512,512,64}; I want that you send me e-mails ;
8-Days… This problem make me Crazy;
Thanks for comment;
Again, I think you are misunderstanding something. The maximum number of threads in a block is always 512. The maximum dimensions of a block in the x,y, and z directions is 512,512, and 64. There is a difference between those two statements. A block of (500,500,60) is illegal, it has more than 512 total threads, even though its individual x,y, and z dimensions are permitted.
mrkyunby: “Maximum number of threads per block: 512”
E.D. Riedijk: “0 < blockDim.x * blockDim.y * blockDim.z <=512”
mrhyunby: “Conclusion is Total Number of threads of 3D - block equal to that of 1D-block;”
avidday: “the maximum number of threads in a block is always 512”
I don’t understand… you keep saying the same thing over and over again and stating that the other side is wrong… :)
Um… I want to have confidence that Above texts…
Before Said… I’m beginner. so I have mistake that, at first…
I want to know subject this article.
I had mistaken… about Dimension of block;
So, I worry that didn’n know about HOW MANY can use ther MAXIMUM number of BLOCKS…
Addition. [b]For Efficient Parallel Prog.
the relation between THE NUMBER of MP , SP and Grid, BLock… [/b]
If) Blocks have Maximum number of threads = 512 threads.
Then) I Needs RESOURCES for Test
Maximum Number of threads of a block : 500
Maximum Number of blocks : 10,000
May be… Automatically Compiler divide Blocks to suitable or Efficient My environment…??
;; HA… Is that Impossible? ==;;
Thanks… and Sorry…
