• Hardware Platform: RTX-3060
• DeepStream Version: 6.3
• TensorRT Version: 8.5.3
• NVIDIA GPU Driver Version (valid for GPU only): 535.183.66
• Issue Type: question
I have a modified deepstream-test2 sgie for performing OCR (using nvdsvideotemplate instead on nvinfer). I am using nvOCDR and followed
deepstream-nvocdr-app
and
nvocdr_ds
I am unable to get any OCR output on OSD. How to access the metadata (OCR output) from nvocdr/nvdsvideotemplate in OSD probe?
What params of OCDR should i use so that it works onlly on pgie detector output?
I am still not able to get OCR data
obj_meta.obj_label returns class label of my PGIE detector
I modified deepstream-test2 sample app, instead of nvinfer I used nvvideotemplate element for sgie2 as mentioned in deepstream-tao-apps
sgie1 = Gst.ElementFactory.make("nvdsvideotemplate", "OCDR")
if not sgie1:
sys.stderr.write(" Unable to make sgie1 \n")
sgie1.set_property('customlib-name', "NVIDIA-Optical-Character-Detection-and-Recognition-Solution/deepstream/libnvocdr_impl.so")
sgie1.set_property("customlib-props", "ocdnet-engine-path:ocdnet.fp16.engine")
sgie1.set_property("customlib-props", "ocdnet-input-shape:3,736,1280")
sgie1.set_property("customlib-props", "ocdnet-binarize-threshold:0.1")
sgie1.set_property("customlib-props", "ocdnet-polygon-threshold:0.3")
sgie1.set_property("customlib-props", "ocdnet-max-candidate:200")
sgie1.set_property("customlib-props", "ocrnet-engine-path:ocrnet.fp16.engine")
sgie1.set_property("customlib-props", "ocrnet-dict-path:/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-npr/character_list.txt")
sgie1.set_property("customlib-props", "ocrnet-input-shape:1,32,200")
sgie1.set_property("customlib-props", "ocrnet-decode:Attention")
My pipeline is as follows steammux->pgie>tracker->sgie1->nvvidconv->nvosd>->sink
where sgie1==nvocdr
and probe added to osd sink pad
