I am using the classification_tf2 tao_voc with this config:
results_dir: '/workspace/tao-experiments/classification_tf2/output'
dataset:
train_dataset_path: "/workspace/tao-experiments/data/train"
val_dataset_path: "/workspace/tao-experiments/data/val"
preprocess_mode: 'torch'
num_classes: 2
augmentation:
enable_color_augmentation: True
enable_center_crop: True
train:
#class_weights: [1.0, 2.0] # Moderate bias toward class_2
qat: False
checkpoint: ''
batch_size_per_gpu: 32
num_epochs: 100
optim_config:
optimizer: 'sgd'
lr_config:
scheduler: 'cosine'
learning_rate: 0.05
soft_start: 0.05
reg_config:
type: 'L2'
scope: ['conv2d', 'dense']
weight_decay: 0.00005
model:
backbone: 'efficientnet-b0'
input_width: 256
input_height: 256
input_channels: 3
input_image_depth: 8
evaluate:
dataset_path: "/workspace/tao-experiments/data/test"
checkpoint: "/workspace/tao-experiments/classification_tf2/output/train/efficientnet-b0_100.tlt"
top_k: 3
batch_size: 256
n_workers: 8
prune:
checkpoint: '/workspace/tao-experiments/classification_tf2/output/train/efficientnet-b0_100.tlt'
threshold: 0.68
byom_model_path: ''
How do I add weight_bias here?
why am I getting this error.
To enable the following instructions: SSE3 SSE4.1 SSE4.2 AVX, in other operations, rebuild TensorFlow with the appropriate compiler flags.
Train results will be saved at: /workspace/tao-experiments/classification_tf2/output/train
wandb: WARNING Path /opt/nvidia/wandb/ wasn't writable, using system temp directory.
wandb: Currently logged in as: kazishehjad17 (kazishehjad17-sigmind-ai). Use `wandb login --relogin` to force relogin
wandb: Appending key for api.wandb.ai to your netrc file: /.netrc
wandb: ERROR Unable to read /.netrc
Initializing wandb.
wandb: Currently logged in as: kazishehjad17. Use `wandb login --relogin` to force relogin
File "/usr/local/lib/python3.10/dist-packages/wandb/sdk/wandb_init.py", line 1176, in init
run = wi.init()
File "/usr/local/lib/python3.10/dist-packages/wandb/sdk/wandb_init.py", line 633, in init
run = Run(
File "/usr/local/lib/python3.10/dist-packages/wandb/sdk/wandb_run.py", line 566, in __init__
self._init(
File "/usr/local/lib/python3.10/dist-packages/wandb/sdk/wandb_run.py", line 676, in _init
self._config._update(config, ignore_locked=True)
File "/usr/local/lib/python3.10/dist-packages/wandb/sdk/wandb_config.py", line 177, in _update
sanitized = self._sanitize_dict(
File "/usr/local/lib/python3.10/dist-packages/wandb/sdk/wandb_config.py", line 264, in _sanitize_dict
k, v = self._sanitize(k, v, allow_val_change)
File "/usr/local/lib/python3.10/dist-packages/wandb/sdk/wandb_config.py", line 282, in _sanitize
val = json_friendly_val(val)
File "/usr/local/lib/python3.10/dist-packages/wandb/util.py", line 671, in json_friendly_val
converted = asdict(val)
File "/usr/lib/python3.10/dataclasses.py", line 1238, in asdict
return _asdict_inner(obj, dict_factory)
File "/usr/lib/python3.10/dataclasses.py", line 1245, in _asdict_inner
value = _asdict_inner(getattr(obj, f.name), dict_factory)
File "/usr/lib/python3.10/dataclasses.py", line 1275, in _asdict_inner
return type(obj)((_asdict_inner(k, dict_factory),
TypeError: first argument must be callable or None
Problem at: <frozen common.mlops.wandb> 119 initialize_wandb
Wandb logging failed with error An unexpected error occurred
As mentioned in shared topic, please use 5.0 docker to try again.
