How to adjust DMIC gain (or audio volume) ?
(2) I think that there is a bug in the driver because ‘25600’ is too big and I seeing the following error in dmesg when this is set …
[ 314.961362] tegra210-dmic tegra210-dmic.2: Boost Gain overflow
The max value should be ‘25599’. This is not your problem, but FYI, this value is too big. We need to fix the driver so that it shows the correct limits and not …
Simple mixer control 'DMIC3 Boost Gain',0
  Capabilities: volume volume-joined
  Playback channels: Mono
  Capture channels: Mono
  Limits: 0 - 25600
  Mono: 0 [0%]
So I tried testing this and setting the gain to ‘400’ and I was able to verify that this worked and both channels were amplified. Setting the gain to 25599 also worked, but it was inaudible, basically noise, but again I did not have any issues with recording stereo. So at the moment, I am unable to reproduce this problem on my side. Can you try lower gain settings and see if you have the same problems?
(3) Your MVC settings look good to me and work for me. So per my other response check the Mux settings to make sure DMIC is not being routed to more than one device.
Regards,
Jon
