How to allocate global dynamic memory on device from host
is it possible to allocate global dynamic Memory on the device from the host ??
I must calculate a amount of Memory on the Host. Then after a init process this amount is fixed.
So i want to allocate some Memory on the Device within the pointer p_GLOBAL_HOLDER_Picture.
The Function call cudaMemcpyToSymbol(…) does not allocate any Memory, but executes without any error…
The Example is the same as in the CUDA-Programmers Guide.
__device__ unsigned char * p_GLOBAL_HOLDER_Picture;
unsigned char * ptr;
cudaMalloc((void **)&ptr, SIZE);
 cudaMemcpyToSymbol(p_GLOBAL_HOLDER_Picture, &ptr, sizeof(ptr));
__global__ void CKNL_GrayTransform()
    if (NULL == p_GLOBAL_HOLDER_Picture)
        // Is True for ever
Regards TinTin
It’s possible. Not very sensible, but possible.
you do it exactly the way you have indicated
Hi Robert, thanks for the answer. Can you briefly give me a working example? Because it does not work for me … The memory is not placed under my global pointer. The pointer remains NULL
Its not much more than what you have shown already.
$ cat t402.cu
#include <stdio.h>
        printf("omg bob does not know what he is talking about\n");
    else
      printf("the data is: %u\n", p_GLOBAL_HOLDER_Picture[0]);
int main(){
  const int SIZE = 1;
  cudaMemset(ptr, 43, SIZE);
  CKNL_GrayTransform<<<1,1>>>();
  cudaDeviceSynchronize();
$ nvcc -o t402 t402.cu
$ cuda-memcheck ./t402
========= CUDA-MEMCHECK
the data is: 43
========= ERROR SUMMARY: 0 errors
Hi Robert,
okay you are right. I reduced everything in my program to the minimal example and then it works.
So it has to be something else. There are still some things different which I will then check piece by piece.
Many thanks for the support.
Hi Robert, as soon as I apply the global memory externally, my project no longer works.
File1.cu
File2.cu
extern __device__ unsigned char * p_GLOBAL_HOLDER_Picture;
        // Is True for ever
Okay, for separate compilation you have to explicitly tell the CUDA compiler to use relocatable object files.
https://docs.nvidia.com/cuda/cuda-compiler-driver-nvcc/index.html#code-changes-for-separate-compilation
Visual-Studio: Configuration Properties → CUDA C/C++ → Common : Generate Relocatable Device Code := Yes (-rcd=true)
Now it works,
Thx for help
