ashwin
February 25, 2011, 7:09am
1
What is the equivalent technique of an assertion in CUDA kernel code?
There does not seem to be an assert for CUDA kernel code. I want a way to catch programmer mistakes easily in kernel code. A mechanism where I can set conditions that need to be true and the kernel should bail out when the condition is false with an error message.
LSChien
February 25, 2011, 7:27am
2
You can do assert as usual, for example
#include <stdio.h>
#define assert( X ) if ( !(X) ) \
printf("tid %d: %s, %d\n", threadIdx.x, __FILE__, __LINE__);\
return ;
__global__ void foo(int *data )
int tid = threadIdx.x ;
assert ( tid >= 5 ) ;
int main(int argc, char *argv[])
foo<<<1,256 >>>(NULL);
cudaThreadExit();
result is
tid 0: main.cu, 12
tid 1: main.cu, 12
tid 2: main.cu, 12
tid 3: main.cu, 12
tid 4: main.cu, 12
However when assertion fails, not all threads terminate. If you have some synchronization issue,
then program may hang.
ashwin
March 2, 2011, 8:19am
3
#include <stdio.h>
return ;
Thanks so much, this is perfect! External Image
