currently i’m using texture memory and i found my reads from texture is very large, since i read same data again n again … so i thought i should cache texture data to shared memory and operate on it… but i can’t find a way to load data…
currently my kernel is as follows
__device__ inline Byte
ComputeSpatial (const float InTemp[3][3])
float temp_val = 0 ;
unsigned int temp;
temp_val = ( InTemp[0][0] + ( InTemp[0][1]*2.0f ) + InTemp[0][2] + ( InTemp[1][0]*2.0f ) + (InTemp[1][1]*4.0f) +
( InTemp[1][2]*2.0f) + InTemp[2][0] + ( InTemp[2][1]*2.0f ) + InTemp[2][2] );
//convert it into unsigned char
temp = static_cast <unsigned int>(rint(temp_val*255.0f));
temp = ( temp + 8 ) >> 4 ;
return ( static_cast <Byte> ( temp ) );
FetchPixelsSpatial (const unsigned int g_Row_Index , const unsigned int g_Col_Index, float InTemp[3][3] )
InTemp[0][0] = tex2D( In_texImage, g_Col_Index-1, g_Row_Index-1 );
InTemp[0][1] = tex2D( In_texImage, g_Col_Index, g_Row_Index-1 );
InTemp[0][2] = tex2D( In_texImage, g_Col_Index+1, g_Row_Index-1 );
InTemp[1][0] = tex2D( In_texImage, g_Col_Index-1, g_Row_Index );
InTemp[1][1] = tex2D( In_texImage, g_Col_Index, g_Row_Index );
InTemp[1][2] = tex2D( In_texImage, g_Col_Index+1, g_Row_Index );
InTemp[2][0] = tex2D( In_texImage, g_Col_Index-1, g_Row_Index+1 );
InTemp[2][1] = tex2D( In_texImage, g_Col_Index, g_Row_Index+1 );
InTemp[2][2] = tex2D( In_texImage, g_Col_Index+1, g_Row_Index+1 );
return ( ComputeSpatial (InTemp) );
//Spatial filter kernel
__global__ void
Spatial_Filter ( unsigned int *Spatial_Filtered, const int Width, const int Height)
//calculate global memory location index
const unsigned int g_Col_Index = __umul24 (blockIdx.x , blockDim.x ) + threadIdx.x ;
const unsigned int g_Row_Index = __umul24 (blockIdx.y , blockDim.y ) + threadIdx.y ;
//for intermediate calculation
float InTemp[3][3] ;
//Boundary Conditions
if (g_Col_Index >= Width || g_Row_Index >= Height )
return ;
//image boundary condtion
if ( ( g_Row_Index != 0 ) && ( g_Col_Index != 0 ) && (g_Row_Index != Height - 1 ) && ( g_Col_Index != Width - 1 ) )
Spatial_Filtered [ __umul24( g_Row_Index , Width ) + g_Col_Index ] = FetchPixelsSpatial(g_Row_Index , g_Col_Index, InTemp);
return ;
Please some one can help me to cache data from texture memory to shared memory for fast processing
